你好,k230拍照保存成图片需要先将图片格式转换为rgb565,然后可以保存成jpeg bmp或者png
可是例程里面只有RGB888的格式,我不知道怎么转换格式
compressed可以把RGB888格式转成jpeg格式
    #将RGB88的照片压缩为JPEG
    imga = img.compressed(quality=70)
import time, os, sys
# save image raw data, use 7yuv to preview
    print("camera_test")
    sensor = Sensor()
    # sensor reset
    # set chn0 output size, 1920x1080
    # set chn0 output format
    # bind sensor chn0 to display layer video 1
    # set chn1 output format
    sensor.set_framesize(width = 640, height = 480, chn = CAM_CHN_ID_1)
    sensor.set_pixformat(Sensor.RGB565, chn = CAM_CHN_ID_1)
    # use hdmi as display output
    # init media manager
    # sensor start run
    # drop 100 frames
    for i in range(100):
        sensor.snapshot()
    img = sensor.snapshot(chn = CAM_CHN_ID_1)
    img.save("/sdcard/test.jpg")
    print(f"user stop")
    print(f"Exception '{e}'")
    # sensor stop run
    # deinit display
    # release media buffer
试一下这个,RGB565的应该是可以保存的,烧录1.1的固件。
frame = sensor.snapshot(chn=CAM_CHN_ID_0)
save_image = frame.compress(100)
save_image.save("/data/image/test001.jpg")
注意自己新建一个image文件夹
记得图像格式设置成这个,其他没有试过不确定行不行
sensor.set_pixformat(Sensor.RGB888, chn=CAM_CHN_ID_0)
