ST7703 display with Canmv-K230-v1.1
Viewed 345
I'm currently using an Canmv-K230-v1.1 that has built-in support (driver) for the ST7701 display, and it's working perfectly.
Now, I want to switch to a ST7703 display. However, board doesn't directly support ST7703. I couldn't find a built-in driver or config for it.
Can you please help me on steps to run Dispaly wth board.
I am using https://developer.canaan-creative.com/k230/en/dev/01_software/board/mpp/K230_LCD_Adaptation_Guide.html but not getting exact steps to run display as i do not have driver file.
You can refer to this documentation to add a new panel for the ST7703. Unfortunately, this guide is currently only available in Chinese.
I have updated the display_debugger_config.txt file to match the specifications of the connected display, including modifications to the height and width parameters. Additionally, I modified the display_lcd.py example by setting:
Display.init(Display.DEBUGGER, to_ide=True)
However, upon execution, I encountered the following error:
File "", line 55, in
File "", line 17, in display_test
File "media/display.py", line 329, in init
RuntimeError: Get display device info failed.
Could you please help on how to resolve it?
it seems not enable the DEBUGGER device driver
I have enabled display configuration in mpp and .img file is also updated, still facing same issue
