K230micropython下能实现同时用USB摄像头和板载摄像头YOLO识别并显示在IDE上吗?以及如何提高USB进行YOLO识别的帧数?
Viewed 343
from libs.AI2D import Ai2d
import os,sys,ujson,gc,math, urandom
from media.uvc import *
import aidemo
from nonai2d import CSC
# Custom YOLOv8 object detection class
    def __init__(self, kmodel_path, labels, model_input_size, max_boxes_num, confidence_threshold=0.5, nms_threshold=0.2, rgb888p_size=[224,224], display_size=[1920,1080], debug_mode=0):
        Initialize object detection system.
        Parameters:
        - kmodel_path: Path to YOLOv8 KModel.
        - labels: List of class labels.
        - model_input_size: Model input size.
        - max_boxes_num: Max detection results to keep.
        - confidence_threshold: Detection score threshold.
        - nms_threshold: Non-max suppression threshold.
        - rgb888p_size: Camera input size (aligned to 16-width).
        - display_size: Output display size.
        - debug_mode: Enable debug timing logs.
        self.labels = labels
        self.confidence_threshold = confidence_threshold
        self.nms_threshold = nms_threshold
        self.max_boxes_num = max_boxes_num
        # Align width to multiple of 16 for hardware compatibility
        self.debug_mode = debug_mode
        # Predefined colors for each class
        self.color_four = get_colors(len(self.labels))
        # Input scaling factors
        self.x_factor = float(self.rgb888p_size[0]) / self.model_input_size[0]
        self.y_factor = float(self.rgb888p_size[1]) / self.model_input_size[1]
        # Ai2d instance for preprocessing
        self.ai2d = Ai2d(debug_mode)
        Configure pre-processing: padding and resizing using Ai2d.
            top, bottom, left, right, self.scale = letterbox_pad_param(self.rgb888p_size, self.model_input_size)
            self.ai2d.build(
                [1, 3, ai2d_input_size[1], ai2d_input_size[0]],
                [1, 3, self.model_input_size[1], self.model_input_size[0]]
        Apply YOLOv8 post-processing including NMS and thresholding.
            new_result = results[0][0].transpose()
            det_res = aidemo.yolov8_det_postprocess(
                new_result.copy(),
                [self.rgb888p_size[1], self.rgb888p_size[0]],
                [self.model_input_size[1], self.model_input_size[0]],
                [self.display_size[1], self.display_size[0]],
                len(self.labels),
                self.confidence_threshold,
                self.nms_threshold,
                self.max_boxes_num
            return det_res
        Draw detection results and send label info via UART.
            if dets:
                for i in range(len(dets[0])):
                    x, y, w, h = map(lambda x: int(round(x, 0)), dets[0][i])
                    img.draw_rectangle(x,y, w, h, color=self.color_four[dets[1][i]],thickness=4)
                    img.draw_string_advanced( x , y-50,32," " + self.labels[dets[1][i]] + " " + str(round(dets[2][i],2)) , color=self.color_four[dets[1][i]])
    # Align display width to 16 bytes for hardware requirement
    # Create CSC instance for pixel format conversion (e.g., to RGB888)
    csc = CSC(0, CSC.PIXEL_FORMAT_RGB_888)
    # Initialize LCD display (ST7701) and enable IDE display
    # Initialize media manager to manage frame buffers and UVC stream
    # Wait for USB camera to be detected
        plugin, dev = UVC.probe()
        if plugin:
            print(f"detect USB Camera {dev}")
    # Select and configure UVC video mode: 640x480 @ 30 FPS, MJPEG format
    mode = UVC.video_mode(640, 480, UVC.FORMAT_MJPEG, 30)
    succ, mode = UVC.select_video_mode(mode)
    print(f"select mode success: {succ}, mode: {mode}")
    rgb888p_size = [640, 480]
    # Path to the YOLOv8n kmodel
    kmodel_path = "/sdcard/examples/kmodel/yolov8n_224.kmodel"
    # COCO class labels used for detection
    labels = ["person", "bicycle", "car", "motorcycle", "airplane", "bus", "train", "truck", "boat",
              "traffic light", "fire hydrant", "stop sign", "parking meter", "bench", "bird", "cat",
              "dog", "horse", "sheep", "cow", "elephant", "bear", "zebra", "giraffe", "backpack",
              "umbrella", "handbag", "tie", "suitcase", "frisbee", "skis", "snowboard", "sports ball",
              "kite", "baseball bat", "baseball glove", "skateboard", "surfboard", "tennis racket",
              "bottle", "wine glass", "cup", "fork", "knife", "spoon", "bowl", "banana", "apple",
              "sandwich", "orange", "broccoli", "carrot", "hot dog", "pizza", "donut", "cake", "chair",
              "couch", "potted plant", "bed", "dining table", "toilet", "tv", "laptop", "mouse", "remote",
              "keyboard", "cell phone", "microwave", "oven", "toaster", "sink", "refrigerator", "book",
              "clock", "vase", "scissors", "teddy bear", "hair drier", "toothbrush"]
    # Detection parameters
    confidence_threshold = 0.3  # Minimum confidence to accept a detection
    nms_threshold = 0.4         # Non-Maximum Suppression threshold
    max_boxes_num = 30          # Max boxes per frame after filtering
    # Initialize object detection application with YOLOv8 model
    ob_det = ObjectDetectionApp(
        kmodel_path,
        labels=labels,
        model_input_size=[224, 224],
        max_boxes_num=max_boxes_num,
        confidence_threshold=confidence_threshold,
        nms_threshold=nms_threshold,
        rgb888p_size=rgb888p_size,
        display_size=rgb888p_size,
        debug_mode=0
    # Configure Ai2d preprocessing (resize + letterbox pad)
    ob_det.config_preprocess()
    # Start UVC video stream with pixel format conversion enabled
    UVC.start(cvt=True)
    # Main loop: acquire frame, run inference, draw and display
        img = UVC.snapshot()
        if img is not None:
            # Convert format (e.g., to RGB888)
            img = csc.convert(img)
            # Convert to Ulab.Numpy.ndarray
            img_np_hwc = img.to_numpy_ref()
            # HWC->CHW
            img_np_chw = hwc2chw(img_np_hwc)
            # Run YOLOv8 inference on the current frame
            res = ob_det.run(img_np_chw)
            # Draw detection results on the frame
            ob_det.draw_result(img, res)
            # Show result on display
            # Explicitly release image buffer
            img.__del__()
        # Print current frame rate
        print(f"fps: {clock.fps()}")
    # Clean up: stop display and media system
    ob_det.deinit()
    csc.destroy()
    UVC.stop()
您好,我想问下您用的是哪个版本的固件,我一直没找到有uvc库的固件
uvc的帧率现在只能达到这个帧率了,再加上AI处理也就这样了
