深度学习使用中无法使用sensor等函数
Viewed 108
运行代码一直显示sensor没有定义,run等函数不存在等问题,是不是深度学习之后无法使用OpenCV库里面的内容
import os, gc, time
from time import ticks_ms
from machine import FPIOA
from machine import Pin
from machine import PWM
from machine import Timer
sensor = None
save_folder = "/data/data/images/"
# Set display mode: options are 'hdmi', 'lcd', 'lt9611', 'st7701', 'hx8399'
# 'hdmi' defaults to 'lt9611' (1920x1080); 'lcd' defaults to 'st7701' (800x480)
display_mode = "lt9611"
# Define the input size for the RGB888P video frames
rgb888p_size = [1280, 720]
# Set root directory path for model and config
# Load deployment configuration
kmodel_path = root_path + deploy_conf["kmodel_path"]              # KModel path
labels = deploy_conf["categories"]                                # Label list
confidence_threshold = deploy_conf["confidence_threshold"]        # Confidence threshold
nms_threshold = deploy_conf["nms_threshold"]                      # NMS threshold
model_input_size = deploy_conf["img_size"]                        # Model input size
nms_option = deploy_conf["nms_option"]                            # NMS strategy
model_type = deploy_conf["model_type"]                            # Detection model type
anchors = []
# Inference configuration
inference_mode = "video"                                          # Inference mode: 'video'
debug_mode = 0                                                    # Debug mode flag
# Create and initialize the video/display pipeline
# Initialize object detection application
det_app = DetectionApp(inference_mode,kmodel_path,labels,model_input_size,anchors,model_type,confidence_threshold,nms_threshold,rgb888p_size,display_size,debug_mode=debug_mode)
# Configure preprocessing for the model
det_app.config_preprocess()
# Main loop: capture, run inference, display results
        img = pl.get_frame()                          # Capture current frame
        res = det_app.run(img)                        # Run inference
        det_app.draw_result(pl.osd_img, res)          # Draw detection results
        if res['scores'] == []:
            a = 0
            print(a)
            if res["scores"][0] > 0.8:
                if res["idx"][0] == 0:
                    os.mkdir(save_folder+"1")
                    print("will collect {} class in {} s".format(class_lst[class_id], 3-i))
                    time.sleep_ms(1000)
        pl.show_image()                               # Show result on display
        gc.collect()                                  # Run garbage collection
# Cleanup: These lines will only run if the loop is interrupted (e.g., by an IDE break or external interruption)
det_app.deinit()                                      # De-initialize detection app
pl.destroy()                                          # Destroy pipeline instance
CanMV_K230_LCKFB_micropython_v1.3-0-g8dd764f_nncase_v2.9.0.img
micropython没有opencv的python版本,如果需要使用要从cpp层封装。你把报错内容贴上来
