k230Dyolov5s官方模型纯测试推理帧率33.9,加上摄像头采集就降到了16.1,这个是正常的吗
Viewed 186
import os, time, gc
kmodel_path = "/sdcard/examples/kmodel/yolov5s.kmodel"
input_w = 320
input_h = 320
rgb888p_size = [640, 360]
sensor = Sensor(fps=30)
sensor.set_framesize(w=rgb888p_size[0], h=rgb888p_size[1], chn=CAM_CHN_ID_2)
sensor.set_pixformat(Sensor.RGBP888, chn=CAM_CHN_ID_2)
kpu = nn.kpu()
kpu.load_kmodel(kmodel_path)
input_data = np.ones((1, 3, input_h, input_w), dtype=np.uint8)
kpu_input_tensor = nn.from_numpy(input_data)
kpu.set_input_tensor(0, kpu_input_tensor)
ai2d = nn.ai2d()
ai2d.set_resize_param(True, nn.interp_method.tf_bilinear, nn.interp_mode.half_pixel)
ai2d_builder = ai2d.build([1, 3, rgb888p_size[1], rgb888p_size[0]], [1, 3, input_h, input_w])
fps = time.clock()
        fps.tick()
        img = sensor.snapshot(chn=CAM_CHN_ID_2)
        img_np = img.to_numpy_ref()
        shape = img_np.shape
        img_chw = img_np.reshape((shape[0]*shape[1], shape[2])).transpose().copy().reshape((shape[2], shape[0], shape[1]))
        ai2d_input = nn.from_numpy(img_chw)
        ai2d_builder.run(ai2d_input, kpu_input_tensor)
        kpu.run()
        print(fps.fps())
except KeyboardInterrupt:
    pass
    print("exit:", e)
CanMV_K230D_MINI_micropython_local_nncase_v2.11.0
帧率和模型大小有关,包括模型的型号比如n/s/m/l,也和模型的输入分辨率有关,你这个是什么分辨率的模型?
分辨率是320x320的,使用的型号是官方的yolov5s,转换的
