有关kmodel转换验证文件test_yolo26\classify\test_cls_kmodel运行出现 sim.load_model(kmodel) RuntimeError: The specified module could not be found.
Viewed 66
具体表现为:
File "e:\ultralytics\test_yolo26\classify\test_cls_kmodel.py", line 99, in
main()
File "e:\ultralytics\test_yolo26\classify\test_cls_kmodel.py", line 72, in main
nncase 2.11.0
nncase-kpu 2.11.0
解决了,变量的路径设置到E:\miniconda3\envs....\Lib\site-packages就好了,不要到....\site-packages\nncase
使用dotnet7。set NNCASE_PLUGIN_PATH=E:\miniconda3\envs\yolo_test_p311_new\Lib\site-packages\nncase
set PATH=%PATH%;E:\miniconda3\envs\yolo_test_p311_new\Lib\site-packages\nncase
添加环境变量后,依然The specified module could not be found.
赞,环境变量配置到nncase包的路径,不要配到里面
