wifi初始化失败
Viewed 184
串口输出:
OpenSBI v1.1-3-gfc14caa
heap: [0x004fb940 - 0x024fb940], size 32768 KB
page: [0x024fb948 - 0x0fffec00], size 224268 KB
find touch ft5x06 on i2c3
[I/SDIO] emmc card capacity 15267840 KB, card sec count:30535680.
found part[0], begin: 115343360, size: 10.0MB
found part[1], begin: 125829120, size: 500.0MB
[E/[RW007]] The wifi Stage 1 status ffffffff ffffffff f 1
[E/[RW007]] rw007 transfer failed
[I/WLAN.dev] wlan init failed
To initialize device:sta failed. The error code is -2
[E/WLAN.dev] L:75 wlan init failed
[E/WLAN.mgnt] F:rt_wlan_set_mode L:894 F:rt_wlan_set_mode L:894 wlan init failed
[I/WLAN.dev] wlan init success
[E/[RW007]] The wifi Stage 1 status ffffffff ffffffff f 2
[E/WLAN.dev] L:81 wlan config mode failed
[E/[RW007]] The wifi Stage 1 status ffffffff ffffffff f 3
rw007 sn: [ᆳ▒]
1.按照https://www.kendryte.com/k230_canmv/zh/main/zh/userguide/how_to_build.html自定义固件教程从Gitee下载代码,更改配置为k230_canmv_rtt_evb_defconfig,编译,烧录/home/ubuntu/rt-smart+canmv/output/k230_canmv_rtt_evb_defconfig目录下的img镜像文件到sd卡,插入开发板,选择sd卡启动
2.未识别到CanMV设备,串口显示wifi初始化失败
RT-Smart ai开发套件
CanMV-K230_RTT_EVB_BOARD_micropython_local_nncase_v2.9.0
尝试重新插拔wifi模块,无效果
你好,这个是硬件问题,应该是交换一下spi的d0和d1,具体的请咨询RTT的客户。
