K230D 0.8V current requirement - less than 2A total?
Viewed 127
The Hardware design guidelines for the K230 https://www.kendryte.com/k230/en/dev/00_hardware/K230_Hardware_Design_Guide.html lists for the core module power supply:
VDD0P8_CORE: 2250mA, recommended at least 3A DC/DC
VDD0P8_CPU: 1000mA, recommended at least 2A DC/DC
VDD0P8_KPU: 3000mA, recommended at least 4A DC/DC
However, the schematics of the k230 Zero board https://drive.google.com/file/d/1OL0th-8sUaoSTe_JDoHtI3H66p_a0VLr/view (or alternative baidu clowd link: https://pan.baidu.com/s/1jkMmp628suSp_lUphqsuJg?pwd=8888 (PIN code: 8888))shows that for VDD0P8_CORE + VDD0P8_CPU + VDD0P8_KPU only a single TLV62569 is used, which has a maximum output current of 2A https://www.ti.com/lit/ds/symlink/tlv62569.pdf?ts=1776565078299
Are the current requirements in the hardware design guidelines not applicable for the k230D - or how does the k230 Zero manage to supply all three 0.8V cores with a single 2A DC/DC buck converter?
K230 Zero
K230 Zero
This set of data represents an extreme case. In real applications on the K230D, such as face detection and gesture detection, the current consumption is not that high. The VDD0V8(VDD0P8_CORE + VDD0P8_CPU + VDD0P8_KPU) current can be estimated at about 1.2A. Therefore, the current capability of the TLV62569 is sufficient.
