Audio Module API Manual#
This manual aims to provide a detailed introduction to the CanMV audio module, guiding developers on how to achieve audio capture and playback functions by calling the Python API interface.
API Introduction#
wave#
The wave module provides a convenient way to read and process WAV files.
  • The wave.open function can open a WAV file and return the corresponding class object.
  • The wave.Wave_read class provides methods for obtaining metadata from a WAV file (such as sample rate, sample points, number of channels, and sampling precision) and reading WAV audio data from the file.
  • The wave.Wave_write class provides methods for setting metadata for a WAV file (such as sample rate, sample points, number of channels, and sampling precision) and saving PCM audio data to a WAV file.
This module, when used in conjunction with the pyaudio module, can easily achieve the playback and capture of WAV file audio and save WAV audio files.
open#
Open a WAVE file to read or write audio data.
Syntax
open(f, mode=None)
Parameter Name
Input/Output
f
File name
Input
Open mode (‘r’, ‘rb’, ‘w’, ‘wb’)
Input
Wave_read or Wave_write class object
Success
Others
Failure, raises an exception
wave.Wave_read#
The Wave_read class provides methods for obtaining metadata from a WAV file (such as sample rate, sample points, number of channels, and sampling precision) and reading WAV audio data from the file.
get_channels#
Get the number of channels.
Syntax
get_channels()
>0
Success
Failure
get_sampwidth#
Get the sample byte length.
Syntax
get_sampwidth()
>0 (Valid range [1, 2, 3, 4] corresponding to sampling precision [8, 16, 24, 32])
Success
Failure
get_framerate#
Get the sample rate.
Syntax
get_framerate()
>0 (Valid range (8000~192000))
Success
Failure
read_frames#
Read frame data.
Syntax
read_frames(nframes)
Parameter Name
Input/Output
nframes
Length of frames to read (number of channels × sampling precision per sample point / 8)
Input
bytes sequence
wave.Wave_write#
The Wave_write class provides methods for setting metadata for a WAV file (such as sample rate, sample points, number of channels, and sampling precision) and saving PCM audio data to a WAV file.
set_channels#
Set the number of channels.
Syntax
set_channels(nchannels)
Parameter Name
Input/Output
nchannels
Number of channels
Input
set_sampwidth#
Set the sample byte length.
Syntax
set_sampwidth(sampwidth)
Parameter Name
Input/Output
sampwidth
Sample byte length, valid range [1, 2, 3, 4] corresponding to sampling precision [8, 16, 24, 32]
Input
set_framerate#
Set the sample rate.
Syntax
set_framerate(framerate)
Parameter Name
Input/Output
framerate
Sample rate [8000~192000]
Input
write_frames#
Write audio data.
Syntax
write_frames(data)
Parameter Name
Input/Output
Audio data (bytes sequence)
Input
pyaudio#
The pyaudio module is used for audio processing, responsible for capturing and playing binary PCM audio data. To play WAV format files or save captured data as WAV files, it needs to be used in conjunction with the wave library, as detailed in the Example Programs section.
pyaudio.PyAudio#
Responsible for managing multiple audio input and output channels, each channel is represented as a Stream class object.
open#
Open a stream.
Syntax
open(*args, **kwargs)
Variable parameters, refer to [Stream.__init__].
py:class:Stream
Success
Others
close#
Close a stream.
Syntax
close(stream)
This function will call the close method in the Stream object and remove the Stream object from the PyAudio object. Therefore, this function can be omitted, and the Stream.close method can be called directly.
terminate#
Release audio resources. This function must be called to release audio resources when PyAudio is no longer in use. If a vb block is allocated in the default constructor, it should be released in this function.
Syntax
terminate()
pyaudio.Stream#
The Stream class object is used to manage a single audio input or output channel.
__init__#
Constructor.
Syntax
__init__(
            PA_manager,
            rate,
            channels,
            format,
            input=False,
            output=False,
            input_device_index=None,
            output_device_index=None,
            enable_codec=True,
            frames_per_buffer=1024,
            start=True,
            stream_callback=None)
Parameter Name
Input/Output
PA_manager
PyAudio class object
Input
rate
Sample rate
Input
channels
Number of channels
Input
format
Sample point byte length
Input
input
Is it audio input, default is False
Input
output
Is it audio output, default is False
Input
input_device_index
Input channel index [0,1], default is None (use default channel 0)
Input
output_device_index
Output channel index [0,1], default is None (use default channel 0)
Input
enable_codec
Enable codec, default is True
Input
frames_per_buffer
Frames per buffer
Input
start
Start immediately, default is True
Input
stream_callback
Input/Output callback function
Input
start_stream#
Start the stream.
Syntax
start_stream()
stop_stream#
Stop the stream.
Syntax
stop_stream()
read#
Read audio data.
Syntax
read(frames)
Parameter Name
Input/Output
frames
Number of frames
Input
bytes
Read audio data
write#
Write audio data.
Syntax
write(data)
Parameter Name
Input/Output
Input
volume#
Get or set the volume.
Syntax
volume(vol=None, channel=LEFT_RIGHT)
Parameter Name
Input/Output
vol
Set volume value
Input
channel
Channel selection: LEFT(left channel), RIGHT(right channel), LEFT_RIGHT(left and right channels)
Input
When setting the volume, return value: None When getting the volume, return value: tuple
enable_audio3a#
Enable audio 3A.
Syntax
enable_audio3a(audio3a_value)
Parameter Name
Input/Output
audio3a_value
Audio 3A enable options: AUDIO_3A_ENABLE_ANS (noise suppression), AUDIO_3A_ENABLE_AGC (automatic gain control), AUDIO_3A_ENABLE_AEC (echo cancellation)
Input
audio3a_send_far_echo_frame#
Send far-end reference audio (i.e., audio played by the near-end speaker), used only in the echo cancellation (AEC) scenario of audio 3A.
Syntax
audio3a_send_far_echo_frame(frame_data, data_len)
Parameter Name
Input/Output
frame_data
Far-end reference audio data (bytes sequence)
Input
data_len
Data length
Input
Example Programs#
Example of Capturing Audio and Saving as a WAV File#
from media.media import *   # Import media module for initializing vb buffer
from media.pyaudio import * # Import pyaudio module for audio capture and playback
import media.wave as wave   # Import wav module for saving and loading wav audio files
def exit_check():
        print("user stop: ", e)
        return True
    return False
def play_audio(filename):
        wf = wave.open(filename, 'rb')  # Open wav file
        CHUNK = int(wf.get_framerate() / 25)  # Set audio chunk size
        p = PyAudio()
        MediaManager.init()  # Initialize vb buffer
        # Create audio output stream, set audio parameters from wav file
                        channels=wf.get_channels(),
                        rate=wf.get_framerate(),
                        output=True, frames_per_buffer=CHUNK)
        # Set volume of audio output stream
        stream.volume(vol=85)
        data = wf.read_frames(CHUNK)  # Read one frame of data from wav file
        while data:
            stream.write(data)  # Write frame data to audio output stream
            if exit_check():
        print(f"Exception {e}")
    finally:
        stream.stop_stream()  # Stop audio output stream
        stream.close()        # Close audio output stream
        p.terminate()         # Release audio object
        wf.close()            # Close wav file
        MediaManager.deinit() # Release vb buffer
    print("Audio example starts")
    play_audio('/sdcard/examples/test.wav')  # Play WAV file
    print("Audio example completed")
Example of Playing a WAV File#
def exit_check():
        return True
    return False
    CHUNK = 44100 // 25  # Set audio chunk size
    FORMAT = paInt16     # Set sampling precision, supports 16bit(paInt16)/24bit(paInt24)/32bit(paInt32)
    CHANNELS = 2         # Set number of channels, supports mono(1)/stereo(2)
    RATE = 44100         # Set sampling rate
        p = PyAudio()
        # Create audio input stream
                        channels=CHANNELS,
                        rate=RATE,
                        input=True,
        stream.volume(vol=70, channel=LEFT)
        stream.volume(vol=85, channel=RIGHT)
        print("volume:", stream.volume())
        # Enable audio 3A feature: Automatic Noise Suppression (ANS)
        stream.enable_audio3a(AUDIO_3A_ENABLE_ANS)
        frames = []
        # Capture audio data and store in list
            data = stream.read()
            frames.append(data)
            if exit_check():
        # Save data from list to wav file
        wf = wave.open(filename, 'wb')  # Create wav file
        wf.set_channels(CHANNELS)       # Set wav number of channels
        wf.set_sampwidth(p.get_sample_size(FORMAT))  # Set wav sampling precision
        wf.set_framerate(RATE)          # Set wav sampling rate
        wf.write_frames(b''.join(frames))  # Store wav audio data
    finally:
        stream.stop_stream()  # Stop capturing audio data
        stream.close()        # Close audio input stream
    record_audio('/sdcard/examples/test.wav', 5)  # Record WAV file
Summary#
Through this manual, developers can easily use the CanMV audio module to achieve audio playback and capture functions. This module combines the advantages of the wave and pyaudio libraries, providing convenient interfaces and clear API documentation, making it easy to quickly develop and apply audio-related projects.
