Display Module API Manual#
Attention
This module has significant changes starting from firmware version V0.7. If you are using firmware prior to V0.7, please refer to the old version of the documentation.
This manual is intended to guide developers on using the Micro Python API to call the CanMV Display module for image display functionality.
To add a custom screen, refer to RTOS SDK / How to Add Panel.
API Introduction#
init#
Initializes the Display path, including the VO module, DSI module, and LCD/HDMI.
Syntax
init(type, width=0, height=0, fps=0, flag=0, osd_num=1, to_ide=False, quality=90)
Parameter Name
Input / Output
Notes
Display device type
Input
Required
Resolution width
Input
Optional, default value depends on type
Resolution height
Input
fps
Display frame rate
Input
Only supported by some display device types
flag
Display flag
Input
osd_num
Number of OSD layers supported in show_image
Input
Larger values occupy more memory, default is 1
to_ide
Whether to transfer screen display to IDE display
Input
Occupies more memory when enabled, implemented via WBC function
quality
Sets JPEG compression quality
Input
Effective only when to_ide=True, range [10-100], default 90
deinit#
Performs deinitialization. The deinit method will shut down the entire Display path, including the VO module, DSI module, and LCD/HDMI.
Syntax
deinit()
inited#
Queries whether the Display module has been initialized.
Syntax
inited()
bool
True indicates initialized, False indicates not initialized
config_layer#
Configures the properties of a display layer. This method is typically called before binding a layer to set the layer’s display parameters.
Syntax
config_layer(rect, pix_format, layer, alpha=255, flag=0)
Parameter Name
Input / Output
Notes
rect
Display area (x, y, w, h)
Input
Required, tuple format
pix_format
Image pixel format
Input
See pix_format
layer
Display layer ID
Input
Required, specifies the layer to configure
alpha
Layer blending transparency
Input
Range 0-255, default 255 (opaque)
flag
Display flag
Input
Default 0
int
Configured layer ID
bind_layer#
Binds the output of the sensor or vdec module to the screen display. This allows continuous image display without manual intervention.
Syntax
bind_layer(src, rect, pix_format, layer, alpha=255, flag=0)
Parameter Name
Input / Output
Notes
src
Source channel info (mod, dev, chn)
Input
Obtainable via sensor.bind_info(), tuple format
rect
Input
pix_format
Image pixel format
Input
layer
Display layer to bind to
Input
Can be bound to video or osd layer
alpha
Input
flag
Display flag
Input
Default 0
unbind_layer#
Unbinds the binding relationship of a specified layer.
Syntax
unbind_layer(layer)
Parameter Name
Input / Output
Notes
layer
Display layer ID
Input
Required
bool
True indicates successful unbinding, False indicates failure
disable_layer#
Disables the specified display layer.
Syntax
disable_layer(layer)
Parameter Name
Input / Output
Notes
layer
Display layer ID
Input
Required
show_image#
Displays an image on the screen.
Syntax
show_image(img, x=0, y=0, layer=Display.LAYER_OSD0, alpha=None, pixel_format=None, flag=0)
Parameter Name
Input / Output
Notes
Image object to display
Input
Required
x
X value of the starting coordinate
Input
Default 0
y
Y value of the starting coordinate
Input
Default 0
layer
Display on the specified layer
Input
Only supports OSD layers, default LAYER_OSD0
alpha
Input
Range 0-255, None means use the layer’s original setting
pixel_format
Image pixel format
Input
None means use the image’s original format, see pix_format
flag
Display flag
Input
Default 0
width#
Gets the display width of the screen or a specified layer.
Syntax
width(layer=None)
Parameter Name
Input / Output
Notes
layer
Specifies the display layer to query
Input
Optional, if not passed, returns the screen resolution width
Width of the screen or specified layer, in pixels
height#
Gets the display height of the screen or a specified layer.
Syntax
height(layer=None)
Parameter Name
Input / Output
Notes
layer
Input
Optional, if not passed, returns the screen resolution height
Height of the screen or specified layer, in pixels
fps#
Gets the current display frame rate.
Syntax
fps()
int
Current display frame rate, in fps
writeback#
Queries or sets the WriteBack (WBC) function status. The WBC function is used to capture screen display content, typically for transmission to IDE display.
Syntax
writeback(enable=None)
Parameter Name
Input / Output
Notes
enable
Sets the WBC function status
Input
Optional, True to enable, False to disable. If no parameter is passed, queries the current status
bool
Returns current WBC status when querying; returns operation result when setting
writeback_dump#
Captures one frame of display content from WBC. Requires to_ide=True to be set in init and the WBC function to be enabled.
Syntax
writeback_dump(timeout=1000)
Parameter Name
Input / Output
Notes
timeout
Timeout in milliseconds
Input
Default 1000ms
object
Returns an object containing video frame information
Data Structure Description#
type#
Type
Parameter Value
Notes
VIRT
640x480@90
Default
IDE debugging only, not shown on external screens. Custom resolutions (64x64)-(4096x4096) and frame rates (1-200) supported.
DEBUGGER
For debugging screens
ST7701
Display.init(Display.ST7701, width = 800, height = 480)
Default
800x480
Display.init(Display.ST7701, width = 480, height = 800)
480x800
Display.init(Display.ST7701, width = 854, height = 480)
854x480
Display.init(Display.ST7701, width = 480, height = 854)
480x854
Display.init(Display.ST7701, width = 640, height = 480)
640x480
Display.init(Display.ST7701, width = 480, height = 640)
480x640
Display.init(Display.ST7701, width = 368, height = 544)
368x544
Display.init(Display.ST7701, width = 544, height = 368)
544x368
HX8399
Display.init(Display.HX8399, width = 1920, height = 1080)
Default
1920x1080
Display.init(Display.HX8399, width = 1080, height = 1920)
1080x1920
ILI9806
Display.init(Display.ILI9806, width = 800, height = 480)
Default
800x480
Display.init(Display.ILI9806, width = 480, height = 800)
480x800
LT9611
Display.init(Display.LT9611, width = 1920, height = 1080, fps = 30)
Default
1920x1080@30
Display.init(Display.LT9611, width = 1920, height = 1080, fps = 60)
1920x1080@60
Display.init(Display.LT9611, width = 1280, height = 720, fps = 60)
1280x720@60
Display.init(Display.LT9611, width = 1280, height = 720, fps = 50)
1280x720@50
Display.init(Display.LT9611, width = 1280, height = 720, fps = 30)
1280x720@30
Display.init(Display.LT9611, width = 640, height = 480, fps = 60)
640x480@60
ILI9881
Default
1280x800
800x1280
NT35516
Display.init(Display.NT35516, width=960, height=536)
Default
960x536
Display.init(Display.NT35516, width=536, height=960)
536x960
NT35532
Display.init(Display.NT35532, width=1920, height=1080)
Default
1920x1080
Display.init(Display.NT35532, width=1080, height=1920)
1080x1920
GC9503
Display.init(Display.GC9503, width=800, height=480)
Default
800x480
Display.init(Display.GC9503, width=480, height=800)
480x800
ST7102
Display.init(Display.ST7102, width=640, height=480)
Default
640x480
Display.init(Display.ST7102, width=480, height=640)
480x640
AML020T
Display.init(Display.AML020T, width=480, height=360)
Default
480x360
Display.init(Display.AML020T, width=360, height=480)
360x480
JD9852
Display.init(Display.JD9852, width=320, height=240)
Default
320x240
Display.init(Display.JD9852, width=240, height=320)
240x320
ST7789
Display.init(Display.ST7789, width=320, height=240)
Default
320x240
Display.init(Display.ST7789, width=240, height=320)
240x320
layer#
K230 provides support for 3 video layers and 4 OSD layers. Classification is as follows:
Display Layer
Constant Name
Supported Formats
Video Layer 1
Display.LAYER_VIDEO1
Recommended for video data
Only supports YUV420SP
Video Layer 2
Display.LAYER_VIDEO2
Video Layer 3
Display.LAYER_VIDEO3
OSD Layer 0
Display.LAYER_OSD0
Graphics overlay layer
Only supports RGB color space
OSD Layer 1
Display.LAYER_OSD1
OSD Layer 2
Display.LAYER_OSD2
OSD Layer 3
Display.LAYER_OSD3
flag#
Flag
Constant Name
No Rotation
Display.FLAG_ROTATION_NONE or 0
No rotation
Rotate 0 degrees
Display.FLAG_ROTATION_0
Rotate 0 degrees
Rotate 90 degrees
Display.FLAG_ROTATION_90
Rotate 90 degrees
Rotate 180 degrees
Display.FLAG_ROTATION_180
Rotate 180 degrees
Rotate 270 degrees
Display.FLAG_ROTATION_270
Rotate 270 degrees
No Mirror
Display.FLAG_MIRROR_NONE or 0
No mirroring
Horizontal Mirror
Display.FLAG_MIRROR_HOR
Horizontal mirroring
Vertical Mirror
Display.FLAG_MIRROR_VER
Vertical mirroring
Horizontal and Vertical Mirror
Display.FLAG_MIRROR_BOTH
Simultaneous horizontal and vertical mirroring
pix_format#
Color Format
Constant Name
Grayscale
image.GRAYSCALE or PIXFORMAT_GRAYSCALE
8-bit grayscale format, 1 byte per pixel
RGB565
image.RGB565 or PIXFORMAT_RGB565
RGB format, 16 bits/pixel (5:6:5)
ARGB8888
image.ARGB8888 or PIXFORMAT_ARGB8888
ARGB format, 32 bits/pixel (A:R:G:B)
ABGR8888
image.ABGR8888 or PIXFORMAT_ABGR8888
ABGR format, 32 bits/pixel (A:B:G:R)
RGBA8888
image.RGBA8888 or PIXFORMAT_RGBA8888
RGBA format, 32 bits/pixel (R:G:B:A)
BGRA8888
image.BGRA8888 or PIXFORMAT_BGRA8888
BGRA format, 32 bits/pixel (B:G:R:A)
RGB888
image.RGB888 or PIXFORMAT_RGB888
RGB format, 24 bits/pixel (R:G:B)
BGR888
image.BGR888 or PIXFORMAT_BGR888
BGR format, 24 bits/pixel (B:G:R)
Notes#
  1. Layer Support: show_image only supports OSD layers. To use multiple OSD layers, set the osd_num parameter in init.
  2. Image Size: When calling show_image, the image size cannot exceed the screen resolution.
  3. Rotation Handling: Some screen types (such as ST7701’s 368x544 mode) have differences between hardware size and application size; the API automatically handles this conversion.
  4. WBC Function: To use writeback_dump to capture screen content, you must set to_ide=True in init.
Example Programs#
Basic Display Example#
from media.display import *
import os, time, image
# Use LCD as display output
# Initialize media manager
# Create an image for drawing
img.clear()
img.draw_string_advanced(0, 0, 32, "Hello World! 你好世界!!!", color=(255, 0, 0))
Display.show_image(img)
        time.sleep(1)
    print("User stopped:", e)
    print(f"Exception: {e}")
Sensor Binding Example#
from media.sensor import *
# Initialize sensor
sensor = Sensor()
sensor.reset()
sensor.set_framesize(width=800, height=480)
sensor.set_pixformat(Sensor.RGB565)
# Get sensor binding information
# Configure and bind display layer
Display.config_layer(rect=(0, 0, 800, 480),
                     pix_format=bind_info[2],
                     layer=Display.LAYER_VIDEO1)
Display.bind_layer(src=bind_info[0],
                   rect=bind_info[1],
# Initialize display
Display.init(Display.ST7701, width=800, height=480)
# Start sensor
sensor.run()
        time.sleep(1)
except KeyboardInterrupt:
    print("User stopped")
finally:
    sensor.stop()
