K230 Product Full Datasheet#
Document version: V1.0 Release date: 2023-7-6
The products, services or features you purchase shall be subject to the commercial contracts and terms of Canaan Creative CO., LTD. (the “Company”) and its affiliates, and all or part of the products, services or features described in this document may not be within the scope of your purchase or use. Unless otherwise agreed in the contract, the Company does not provide any express or implied representations or warranties as to the correctness, reliability, completeness, merchantability, fitness for a particular purpose and non-aggression of any statements, information, or content in this document.Unless otherwise agreed, this document is intended as a guide for use only.
Trademark Notice#
“Canaan” and other Canaan trademarks are trademarks of Canaan Creative CO., LTD. and its affiliates. All other trademarks or registered trademarks that may be mentioned in this document are owned by their respective owners.
Copyright©2023 Canaan Creative CO., LTD. This document is only suitable for the development and design of K230 platform, without the written permission of the company, any unit or individual shall not disseminate part or all of the content of this document in any form.
Canaan Creative CO., LTD. Website:canaan-creative.com Business Email:salesAI@canaan-creative.com
Purpose#
This document is intended to provide a full description of the K230 platform and its features.
Intended Audience#
The main people to whom this document (this guide) applies:
Design and maintenance personnel for electronic products
Sales personnel for electronic products
Technical support personnel
Terms#
Revision history#
Version Number |
Modified by |
Revision Date |
Revision Notes |
Ruizheng Li,Heng Wen |
2023-7-6 |
Revised version |
Index#
Chapter 1 Introduction#
1.1 Overview#
1.2 Feature#
1.2.1 CPU subsystem#
CPU0 subsystem
64bit RISC-V processor
Supports maximum 800 MHz working frequency
Supports RISC-V 64GCB instruction set
Cpu contains floating-point units (FPUs)
L1 cache contains 32 KB instruction cache (I-cache) and 32 KB data cache (D-cache)
Integrates with 128 KB L2 cache
Supports memory management unit (MMU)
Integrates with the interrupt controller (PLIC), which can process 208 interrupt external sources
Supports the Joint Test Action Group (JTAG) debugging interface
Supports WFI
CPU1 subsystem
Supports maximum 1.6 GHz working frequency
Supports RISC-V Vector Extension 1.0 specification
128bits vector-process-unit
Integrates with 256 KB L2 cache
Supports WFI
1.2.2 KPU subsystem#
Support INT8 and INT16
Support weight sparse compression
Typical network performance:
Resnet 50 ≥ 85fps @INT8
Mobilenet_v2 ≥ 670fps @INT8
YoloV5S ≥ 38fps @INT8
Support TensorFlow / PyTorch / TFLite / PaddlePaddle / ONNX
Support quantization toolchain and profiling tools
Loss of quantization accuracy <1%
Support Abs, Acos, Acosh, And, ArgMax, ArgMin, Asin, Asinh, Add, AveragePool, BatchNormalization, Cast, Ceil, Celu, Clip, Concat, Constant, ConstantOfShape, Conv, ConvTranspose, Cos, Cosh, CumSum, DepthToSpace, DequantizeLinear, Div, Dropout, Elu, Equal, Exp, Erf, Expand, Flatten, Floor, Gather, GatherElements, GatherND, Gemm, GlobalAveragePool, GlobalMaxPool, Greater, GreaterOrEqual, Hardmax, HardSigmoid, HardSwish, Identity, InstanceNormalization, LpNormalization, LeakyRelu, Less, LessOrEqual, Log, LogSoftmax, LRN, LSTM, MatMul, MaxPool, Max, Min, Mod, Mul, Neg, Not, OneHot, Pad, Pow, PRelu, QuantizeLinear, QLinearConv, QLinearMatmul, RandomNormal, RandomNormalLike, RandomUniform, RandomUniformLike, Range, ReduceL1, ReduceL2, ReduceLogSum, ReduceLogSumExp, ReduceMax, ReduceMean, ReduceMin, ReduceProd, ReduceSum, ReduceSumSquare, Relu, Reshape, Resize, ReverseSequence, Round, ScatterND, Selu, Shape, Sin, Sinh, Sigmoid, Sign, Size, Slice, Softmax, Softplus, Softsign, SpaceToDepth, Split, Sqrt, Squeeze, Sub, Sum, Tanh, Tile, TopK, Transpose, Upsample, Unsqueeze, Where
1.2.3 2D Engine#
2D GDMA Engine
X-Mirror/Y-Mirror/Rotation(90/180/270)
Typical image rotation capability:
2 x 1080*1280 YUV400 @15fps + 1 x 1080*1920 YUV420 @30fps
Provides one physical DMA channel
The axi data width is 64-bit
Supports configurable axi transaction outstanding numbers: the max outstanding number is 8
Supports data transfer with the linked list
Supports configurable weight-based channel priority arbitration
Supports lowpower mode:each channel supports auto clock gate
Supports configurable image row stride
The maximum image resolution supports 64Kx64K
The data width of the image pixel supports 8/16/24/32bits
Max Burst length can be set to 8 or 4 for non-24bit width pixel, and 12 for 24bit pixel
Non AI 2D
Support OSD mode
Support CSC mode
Support draw border mode
Support corp operation
Independent AI 2D Engine
Affine/Crop/Resize/Padding/Shift
Resize
Crop
Affine
The calculation of resize and affine coordinates supports opencv’s round, as well as ceil and floor
Pad
Support four edge parts to complement constant pads, the pad value can be specified, and the maximum number of pads on a single side is 1023
CSC
Both input and output images support the following formats
YUV420_NV12
YUV420_NV12
YUV420_I420
YUV400
RGB_packed
NCHW
Shift
RAW16 input -> shift to RAW8 output
Support CPU to read internal registers
The accelerator can access the system SRAM(2MB).
Support software reset through configuration register
Support clk gating
NOTE
Note1: The highest source image resolution supports 4K
Note2: All configured ddr addresses follow 16B align, which is friendly to performance
Note3: A configuration register cannot exceed 1KB
Note4: When configuring cpu, configure 32bit each time, and configure 4 times for each 128bit, and must configure 4 times, the order is from low to high; when configuring GNNE, configure 128bit at a time
1.2.4 DPU (Depth Processing Unit)#
Using 3D structured light depth calculation
The maximum resolution of the landscape image is 1920*1080, and the maximum resolution of the portrait image is 1080*1440
Typical performance is 1280*800@30fps, 1280*1080@15fps,1920*1080@9fps
Both read and write AXI bus support crop
Support standard axi-4 protocol, data bit width 64bit, address bit width 32bit, burst_length up to 16, read and write outstanding up to 8
Support standard apb3.0 protocol, data bit width 32bit, address bit width 32bit
Img_check: The precision of the input speckle image is int8, the precision of the output calculation result is int1, and it supports output after downsampling
LCN: The precision of the input speckle image is int8, and the precision of the output calculation result is int12, which supports normalized calculation of the source image
SAD: Input the normalized speckle image/reference image, the accuracy is int12, the output row and column parallax accuracy is int16, support Init_SAD single/double layer enable, support SAD double layer enable, and support the first layer input of Init_SAD/SAD is involved in the calculation after 1/2 downsampling
Post_proc: The precision of the input column parallax is int16, the precision of the output calculation result is int1, supports Post_proc enable, and supports Post_proc inner mask denoising enable
Align: The precision of input column parallax is int16, the precision of mask is int1, the precision of output depth/disparity map is int16, the precision of input/output infrared map is int8, supports height block processing parallax/infrared alignment, supports parallax/infrared Alignment enable, support Align inner parallax denoising enable, support parallax/infrared up and down sampling enable, support Disp2depth enable
Support normal calculation end interrupt, timeout interrupt, instruction exception interrupt, configuration instruction overflow interrupt, AXI write response exception interrupt
Support independent soft reset, interrupt clear operation
1.2.5 Memory#
DDR
16-bit per channel LPDDR4, two channels, the max speed is 3200Mbps
32-bit LPDDR3 supported,the max speed is 2133Mbps
Maximum capacity: 2GB
Scalable 1:1/1:2 frequency ratio architecture. We setting 1:2 frequency ratio
For LPDDR3 configurations, direct software request control or programmable internal control for ZQ short calibration cycles
For LPDDR3 configurations, support for ZQ long calibration after self-refresh exit
For LPDDR4 configurations, direct software request control or programmable internal control for ZQ calibration cycles
For LPDDR4 configurations, support for ZQ calibration after SR-Powerdown exit
Dynamic scheduling to optimize bandwidth and latency
For maximum SDRAM efficiency, commands are executed out-of-order
Hardware configurable and software programmable Quality of Service (QoS) support
Programmable support for all of the following SDRAM data-bus widths: Full data-bus width or Half of the full data-bus width
Supports max to 2 ranks
Control options to avoid starvation of lower priorities
Guaranteed coherency for write-after-read (WAR) and read-after-write (RAW) hazards (always on the HIF interface and on the AXI interface only if appropriate hardware configuration parameter and software register are set)
Write combine to allow multiple writes to the same address to be combined into a single write to SDRAM; supported for same starting address
Supports automatic SDRAM power-down entry and exit caused by lack of transaction arrival for a programmable time
Supports automatic Clock Stop (LPDDR3/LPDDR4) entry and exit caused by lack transaction arrival
Supports automatic low power mode operation caused by lack of transaction arrival for a rogrammable time through the Hardware Low Power Interface
Flexible address mapper logic to allow application specific mapping of row, column, bank, and rank bits
Leverages out of order requests with CAM to maximize throughput
APB interface for the software accessible registers
5 host ports using AMBA AXI
Automatic periodic retraining through PHY MASTER Interface
Support for:
(LPDDR3, LPDDR4) Command Bus eye training relative to CK
Write Leveling to compensate for CK-DQS timing skew
Write Training: DQS to DQ Two modes of training are available in LPDDR4:
Command-based FIFO WR/RD with user patterns
An internal DQS clock tree oscillator, to determine the need for, and the magnitude of, required periodic training
Data bus VREFDQ training
Read training( DQ bit deskew training using DRAM mode registers and DQS to DQ eye centering training using DRAM array)
LVSTL IO calibration and ODT calibration
Support for a SW controllable DQ bit and AC bit swizzling
Firmware-based 2D eye mapping diagnostic tool allows measuring 2D eye for every bit of the bus at both DRAM and host receivers
Direct override programming available for all VREF, ODT, drive strength, and timing delays to facilitate debug and characterization
SRAM
SRAM:2MB (shared sram)+2MB (default for KPU)
The shared 2MB sram provides access to CPU/KPU/decompression and other modules
The shared 2MB sram has two independent 128bit AXI4 Slave buses. Burst supports incremental, fixed, and wrap. The maximum burst length is 16. Exclusive transmission is not supported. The maximum outstanding read and write are 16 respectively
The shared 2MB sram is divided into two groups. The first group is shared by KPU port0, axi slave0, axi slave1, and decompression module. When decompression does not work, KPU port0 has the highest priority, followed by axi slave0/axi slave1. The other group of KPU port1, axi slave 0, and axi slave 1 are shared. KPU port1 has the highest priority
The decompression module shares 768KB SRAM to cache the decompression process data
Flash
Supports the SPI NOR flash and SPI NAND flash
Supports the read and write operations in internal DMA mode for the SPI NAND flash and the SPI NOR flash.
Support Enhanced (Dual/Quad/Octal) SPI features:
Programmble address,instruction,wait cycles,and data frame size
Dual Data Rate(DDR) support
Read Data Strobe support for DDR transfer
Data item size(4 to 32bits)-Item size of each data transfer under control of the programmer
Execute In Place(XIP) mode support:
AHB address is mapped to SPI NOR flash address directly
Read and write SPI NOR flash directly
Read and write SPI NAND flash need to operate according to the NAND flash operation requirement
Except XIP mode, all operations need to operate according to the flash operation requirement
Programmable delay on the sample time of received serial data bit(rxd)
Programmable clock bit rate
The latency of strb can be adjusted
Note:
1.2.6 system component#
RMU
Reset management module (RMU) is responable for power on reset deglitch, manage wdt reset,chip soft reset and generate sub-module reset
Reset glitch length less than 8ms will be filtered
Manage two watchdog reset and generate soc reset
Manage software soc reset request and generate soc reset
Manage sub-module software reset request and generate sub-module reset
CMU
Clock management module (CMU) is designed to manage generation of sub-module and system clock、clock division、clock switch and clock gating
The clock source include external 24MHz OSC and four internal PLLs
CPU1 and KPU module support DVFS. Their frequency should meet current voltage
When CPU1 and KPU use the same clock source, their frequency can be changed synchronously
When CPU1 and KPU use different clock source, their frequency can be changed independently
PWR
Power control module (PWR) is used for power control of SOC and sub-module
There are five power mode : Power on, sleep0, sleep1, standby, powerdown
There are three kinds of wakeup source : GPIO, PMU and timer
Each power domain can be controlled to power down、power up 、clock gating according to defferent application
Interrupt
K230 supports 208 interrupt sources
PDMA
PDMA (Peripheral Direct Memory Access) supports the data transfer between peripheral ports and DDR/SRAM
PDMA provides 8 channels to transfer different transactions, with 64-byte data buffer per channel
It supports up to 35 peripheral ports through channel configuration
Low power IDLE state of each channel can be set by shutting down corresponding clock
A 64-bit AXI4 master is used to transfer different channel transactions
The priority of each transaction is configured with each channel. Transactions with high priority gets high chance to be transferred
Peripheral data address can only be accessed in 4 bytes aligned with strobe signal to indicate the lower 1/2/4 byte(s) are used, and only fixed address is supported
SDMA
Provides four DMA channels:ch0,ch1,ch2 and ch3
The max axi burst length is 16
Supports configurable axi transaction outstanding numbers: the max outstanding number of ch0,ch2,ch3 is 2, the max outstanding number of ch1 is 16
Supports configurable data endian
Supports specified data transfer for decompression module using ch0 and ch1
General-puspose timers
APB interface supports APB3
Up to six programmable timers
Configurable timer width: 8 to 32 bits
Support for two operation modes: free-running and user-defined count
Support for independent clocking of timers
Configurable polarity for each individual interrupt
Configurable option for a single or combined interrupt output flag
Configurable option to have read/write coherency registers for each timer
connfigurable option to include timer toggle output, which toggles whenever timer counter reloads
Configurable option to enable programmable pulse-width modulation of timer toggle outputs
Configurable option to include pulse width modulation of timer toggle output with 0% and 100% duty cycle.
Can be used to count external input signal with frequency less than 1MHz and ducy cycle from 0~100%
Stc timer
64 bit timer width
3 configurable timescale : 27MHz, 1MHz, 90KHz
Configurable enable、load、clear control register
Apb 3.0 interface
One timer can be used for video-input/video-output and audio synchronization.
One timer is used for cpu0 and one timer is used for cpu1.
Timer used for video/audio synchronization provides two sets of timer value, one is old value and the other is latest value
Watchdog
APB3 interface support
Watchdog counter width of 32 bits
Counter counts down from a preset value to 0 to indicate the occurrence of a timeout
If a timeout occurs the watchdog can perform one of the following operations:
Generate a system reset
First generate an interrupt and even if it is cleared (or not) by the service routine by the time a second timeout occurs then generate a system reset
Programmable reset pulse length
RTC
Typical working frequency: external clock source 32768 Hz
Involved in the work mode: normal working mode, independent power supply working mode
Interface type: APB3.0 interface
Support calendar initial value configuration, configuration items including year, month, day, week, when, minutes and seconds
Can read less than 1 second counter count, and the initial values can be configured, minimum scale unit for each calibration cycle of the crystals
Support disruption: a timer interrupt (configurable project includes year, month, day, week,, minutes and seconds), the interrupt for level interrupts, need to register to clear; Periodic interruption (including annual, monthly, daily, weekly, every hour, every minute, every second, every 1/8 of a second, 1/64 of a second trigger interrupt) the interrupts for pulse, pulse width is two 32768 hz clock cycles
Typical application scenario: calendar, timing interrupt trigger interrupt trigger, cycle
Other features: a regular in the system domain, need external power supply; A low speed clock of 32768Hz is required
Mailbox
Bus interface: Mailbox with APB 3.0 interface
Data bit width: 32bit, configurable via APB bus
Configuring the clock: configuring the clock to be the pclk clock
Support for hardware locks
Support for cpu0_sys and cpu1_sys to send interrupts to each other
Support for register configuration and status reading of submodules
Temperature Sensor
±3°C Accuracy Without Trimming
Supply voltages: VDD 0.72-0.88V, VDDA 1.62-1.98V
Temperature Measurement Range: -40 ~ 125℃
1.2.6 Video input#
Compatible with MIPI 1.2 RX protocol, max up to three 2lane sensors or one 4lane sensor and one 2lane sensor
3 x MIPI CSI
Support sensor slave mode
Support flash trigger mode which support both follow-strobe mode and pwm mode
Support structured light sensor and can separate the IR data and speckle data to different DVP interface.
Support timestamp
Support HDR sensor
Support hardware discard frame
8/10/12/16 Bit Bayer RAW
1.2.7 ISP#
Total throughput:8MP@30fps
Auto Focus measurement (AF)
Auto White Balance measurement (AWB)
Auto Exposure measurement (AE)
Advanced 2DNR spatial noise reduction
Advanced 3DNR: spatial and temporal noise reduction
WDR in single wide dynamic frame
Multi-exposure HDR (Native/Built-in HDR interface, 12~16-bit HDR input). The performance is up to 2960x1666@60fps for DOL2 and 1920x1080@90fps for DOL3 HDR.
CPD, compand function to support native HDR sensor which performs HDR merging in sensor
Variable sensor interface for RGB-Bayer Sensors, DOL or stagger HDR sensors
20-bit HDR Processing, includes multi exposure stitching and local tone mapping
Test Pattern Generator (TPG)
Black level Compensation
Sensor Linear Correction
Defect Pixel Cluster Correction (DPCC)
Green Equalization
Lens Shade Correction (De-Vignetting)
De-warping, including fisheye correction, wide field of view (FOV) correction, keystone correction and scaling and 4PTZ view
Digital Gain
2-Stage Adaptive Noise Filter (Noise reduction, Sharpness, Blurring)
Enhanced Color Interpolation (Bayer De-mosaic filter)
Chromatic Aberration Correction (CAC)
Color Correction (Xtalk) Matrix (CCM)
Color Space Conversion (CSC)
Programmable gamma correction for sensor adaptation and display correction
Histogram Calculation
Anti-flicker
Cropping of the output picture (to crop interpolation artifacts), also used for windowing
Color Processing: Contrast, Saturation, Brightness, Hue (CPROC)
Sharpen/Blur Filter
Flash light control
Mechanical shutter control
Image size: horizontal size multiple of 8 and vertical size multiple of 4
Enhanced Chroma Noise Reduction (CNR)
Video Stabilization (VSM)
Multi-Context Management to support three sensors within a single ISP Core (MCM). In MCM mode, only DVP0 supports HDR
1.2.8 Video output#
1 x MIPI DSI, 1 x 4 lane or 1 x 2 lane
Resolution: 2MP@60fps
Support up to 13 layers, including 4 video layers, 8 OSD layers and 1 background layer.
Support all common output picture formats: UXVGA (1600x1200), SXVGA (1280x1024), 1080p, 720p
Video Layer 0:
support scaling up and scaling down function
support 2-plane, YUV420 data format input
support configurable start pixel & start line input
Support 90 °, 180 °, 270 ° rotation
Support x-mirror/y-mirror function.
Video Layer 1:
support 90 °, 180 °, 270 ° rotation
Video Layer 2 & Layer 3:
Support 2-plane, YUV420 & YUV422 data format input
Support configurable start pixel & start line input
Do not support scaling function
8 OSD layers support 1 or 2 plane ARGB formats:
RGB888 with separate alpha channel
RGB565 with separate alpha channel
ARGB8888
ARGB4444
ARGB1555
Monochrome(8-bit)
Display mix:
OSD layer support configurable global alpha blending or pixel by pixel alpha mode
Video layer only support configurable global alpha
Configurable output size and position for each layer
Support vsync interrupt, DPI interface underrun interrupt and configurable output line number interrupt
Support configurable color space conversion, yuv2rgb or rgb2yuv
Support gamma correction on RGB data before output
Support dither function
When not using scaling, it is recommended to use layer1 (supports rotation but not scaling)/layer2 (does not support rotation and scaling)/layer3 (does not support rotation and scaling). The video layer can only use three layers
When scaling is necessary and layer0 is required, the maximum frame rate at 1080p is 20fps, and 30 frames can be supported at 720p
1.2.9 video codec#
Maximum encoding performance up to 8MP@20fps
Stride support.
Horizontal and vertical mirroring.
CBR / VBR / CQP / ROI encoding
Support for optional rotation of the source frame in 90 degree steps before encoding. Note If YUV422 is rotated by 90 degrees or 270 degrees and not converted to YUV420, the result is encoded as YUV440.
1-plane YUV422, scan-line format, interleaved in YUYV or UYVY order. Note YUV422 inputs can be converted to YUV420 format.
1-plane RGB, 8-bit, byte address order RGBA, BGRA, ARGB, or ABGR.
2-plane YUV420, scan-line format, chroma interleaved in UV or VU order.
3-plane YUV420, scan-line format.
3-plane YUV420 10-in-16 bit scan line format. Note Support for 3-plane formats is included to help you with testing. Do not use these for maximum performance.
YUV420 10-bit, P010, little endian, MSB aligned.
YUV420 10-bit, 2 × 2 tile format.
Supported codecs
HEVC (H.265) Main.
HEVC (H.265) Main 10 Profile.
H.264 Baseline Profile (BP).
H.264 Main Profile (MP).
H.264 High Profile (HP).
H.264 High 10 Profile.
JPEG, baseline sequential, YUV420 and YUV422. Note Only the JPEG codec can encode YUV422.
MJPEG
The encoded bitstream complies with the HEVC (H.265) Main Profile.
Maximum frame width of 4,096 pixels.
Maximum frame height of 4,096 pixels.
8-bit or 10-bit sample depth with I and P frames.
Progressive encoding with 64 × 64 CTU size.
Tiled mode, up to four tiles, horizontal splits only.
Wavefront parallel encoding.
The Motion Estimation (ME) search window is ±128 pixels horizontally, ±64 pixels vertically. - ME search down to Quarter Picture ELement (QPEL) resolution.
8 × 8, 16 × 16, and 32 × 32 luma intra-modes.
4 × 4, 8 × 8, and 16 × 16 chroma intra-modes.
8 × 8, 16 × 16, and 32 × 32 inter-modes.
8 × 8, 16 × 16, and 32 × 32 transform size for luma.
4 × 4, 8 × 8, and 16 × 16 transform size for chromas.
Skipped CUs, Merge modes.
Deblocking.
Sample Adaptive Offset (SAO).
Constrained intra-prediction selectable.
Fixed Quantization Parameters (QP) operation or rate-controlled operation.
Rate controlled based on bitrate and buffer size settings. This is also known as leaky bucket.
Long term reference frame.
Selectable intra-frame refresh interval.
Encoders do not prevent the output from exceeding the maximum number of bits per CTU.
H.264 encoding features
The encoded bitstream complies with the Baseline, Main, High, and High 10 Profiles.
I and P frames.
Progressive encoding.
Context Adaptive Binary Arithmetic Coding (CABAC) or Context Adaptive Variable Length Coding (CAVLC) entropy coding. Note B frames are not supported with CAVLC entropy coding.
ME search down to Quarter Picture Element (QPEL) resolution.
All 4 × 4, 8 × 8, 16 × 16 luma, and 8 × 8 chroma intra-modes evaluated.
8 × 8, and 16 × 16 inter-modes.
4 × 4 and 8 × 8 transform.
Skipped macroblocks.
Deblocking.
Fixed QP operation or rate-controlled operation.
Escaping to prevent Network Abstraction Layer (NAL) unit start code emulation. This is always enabled and is independent of the NAL packet format setting. For more information, see ITU-T H.264 Annex B. Note Encoders do not prevent the output from exceeding the maximum number of bits per macroblock.
Maximum decoding performance up to 8MP@40fps
Supported source frame output formats are:
2 plane YUV420 scan line format, chroma interleaved in UV or VU order.
3 plane YUV420 scan line format. Note Support for 3-plane formats is included to help you with testing. Do not use these for maximum performance.
YUV420 10 bit, P010, little endian, MSB aligned.
YUV420 10 bit, 2 × 2 tile format. Note The YUV buffer and stride must have correct alignment for maximum performance.
Stride support for scan-line formats only.
Support for rotation of the decoded frame in 90 degree steps before output.
Support for downscaling the decoded frame horizontally and vertically by a factor of 2 or 4.
Support for downscaling the decoded frame horizontally and vertically by any factor individually. The smallest resolution can be 2 x 2 pixels.
Support for output of average frame luminance and chrominance for each 32 x 32 pixel block, for every output display frame.
Supported codecs
HEVC (H.265) Main/Main10.
H.264 Baseline, Main, High, and High10 Progressive Profile.
JPEG, baseline sequential, YUV420 and YUV422. Note Only the JPEG codec can decode YUV422.
The decoder is fully compliant to the Main and Main10 Profiles.
Maximum frame width is 4,096 pixels.
Maximum frame height is 4,096 pixels.
Error concealment is performed in case of bit errors.
Stream parameter information is output.
H.264 decoding features
Baseline, Main, High, and High 10 progressive Profiles.
For progressive streams
Average bitrates up to 100MBit/s.
For interlaced streams
Average bitrates up to 50MBit/s.
A maximum frame width of 2,048 pixels.
A maximum frame height of 4,096 pixels.
Stream parameter information is output. Escaping to prevent NAL unit start code emulation is always expected. This is independent of the NAL packet format setting. For more information, see ITU T H.264 Annex B.
JPEG decoding features
Average bitrates up to 20MBit/s.
Support for 4:2:0 output by the video encoder, baseline sequential YYYYCbCr interleaved MCU format only.
Support for 4:2:2 output by the video encoder, baseline sequential YYCbCr interleaved MCU format only.
Maximum frame width is 8,192 pixels.
Maximum frame height is 8,192 pixels.
1.2.10 2.5D GPU#
Support following Hardware Components
Command list based DMAs, Fire and Forgot Control mechanism to minimize CPU overhead
Primitive Rasterizer, 16x Anti-aliasing without performance drop.
Texture Mapping Unit, 4 Texel/cycle in Bi-linear filter
Hardware composition, Frame buffer compression
Tessellation, No CPU Involved in Bezier Curve generation
Alpha blending
Support Image Transformation
Texture mapping, Point sampling, Bilinear filtering
Blit support, Stretch (independently on x and y axis)
Rotation any angle, Mirroring, FP24 coordinate precision, no precision difference in any degree rotation
2.5D Perspective Correct Projections
Configurable Coordinate Systems and Transformations (3x3 matrix)
Scissoring and viewport clipping, Mage Interpolation, Paint
Odd/even and non-zero fill rules
Support draw engine
Pixel / Line drawing with any degree
Gradient Filled rectangles
Triangles, Polygon
Path Generation
Linear gradient paint paths
Support following Color Formats
32-bit RGBA8888 / BGRA8888 / ABGR8888
16-bit RGBA5551 / RGB565
8-bit Α8 / L8 / RGB332, 4-bit A4 / L4 & 2-bit A2 / L2 & 1-bit A1 / L1
1/2/4/8-bit index format
Support Antialiasing
16x MSAA(4x4), no quality difference betwwen horizon and vertical direction
8x MSAA(4x2), low cost version, horizon quality is better than veritical directon
1.2.11 Audio#
Audio codec inside
2 DAC channels for stereo playback with sample rate 8-192Khz
2 ADC channels for stereo recording from microphone with sample rate 8-192Khz
Audio codec support Automatic Level Control (ALC) function to adjust the signal level,which is input into ADC
Maximum 8 x PDM DMIC inputs
I2S interface supports 2x2 expansion
Support master mode, which means clock(pdm_clk and i2s_sclk) and ws(only I2S) are output from audio.
I2S input, pdm input and I2s output audio modes can work simultaneously
APB2.0 interface is used to configure registers, and read/write PCM data. The default frequency of configurable APB working clock PCLK is 100MHz, and the data interface is 32 bits
PCM data can be transferred by PDMA. Burst length in PDMA is configurable
The audio module can start working again after being disabled and re-enabled
The audio module can start working again after asserting reset and de-asserting reset
PDM audio
PDM audio input with data sampling rate of 2.048/2.8224 MHz, 1-bit data width, sampling clock rate of 0.256MHz/0.384MHz/0.512MHz/0.768MHz/1.024MHz/1.4112MHz/1.536MHz/2.048MHz/2.8224MHz/3.072MHz/4.096MHz/5.6448MHz/6.144MHz/12.288MHz/24.576MHz, corresponding PCM sampling rate of 8kHz/12kHz/16kHz/24kHz/32kHz/44.1kHz/48kHz/96kHz/192kHz
Oversampling rate is configurable with x128, x64 and x32
1-4 IOs are used for input PDM audio
The input can be configured with 1-8 PDM channels. It supports left/right mono mode and dual mode of PDM. All IO channel modes are unified. The maximum number of IO in dual mode is 4
The serial numbers of enabled channels are from small to big. Random enabling of each channel is not supported
The skew between PDM input data and pdm_clk is up to 18 PCLK cycles
Conversion from input PDM audio data to PCM audio data
I2S audio
PCM audio in I2S Phillips, left-aligned and right-aligned format
I2S audio input/output with data sampling rate of 8kHz/12kHz/16kHz/24kHz/32kHz/44.1kHz/48kHz/96kHz/192kHz, and data width of 32 bits. The valid data width(32/24/20/16/12bits) needs to be customized. The sampling clock rate supports 2×32(data width)×data sampling rate
1-2 IO to input, and 1-2 IO to output I2S audio data. The full-duplex mode is supported
Connect to on-chip or off-chip i2s codec to input and output audio data
Each RX/TX channel FIFO depth is 8. FIFO threshold can be configured
DMA mode enable and disable
IO number and left/right channel flag can be fetched from higher bits of data when valid data width is less than 32bits in DMA mode
1.2.12 peripheral#
UART
Support 5 UART interface
9-bit serial data support
False start bit detection
Programmable fractional baud rate support
APB data bus widths of 32
Additional DMA interface signals for compatibility with DMA interface, DMA interface signal active low
Transmit and receive FIFO depths of 32, Supports 32x32-bit transmit first-in, first-out (FIFO) and 32x32-bit RX FIFO, Internal FIFO (RAM)
Busy functionality
Functionality based on the 16550 industry standard
Programmable character properties, such as:
Number of data bits per character (5-8)
Optional parity bit (with odd, even select or Stick Parity)
Number of stop bits (1, 1.5 or 2)
Line break generation and detection
DMA signaling with two programmable modes
Prioritized interrupt identification
Programmable FIFO enable/disable
Separate system resets for each clock domain to prevent metastability
I2C
Support 5 I2C interface
Two-wire I2C serial interface–consists of a serial data line (SDA) and a serial clock (SCL)
Three speeds:
Standard mode (0 to 100 Kb/s)
Fast mode (≤400 Kb/s) or fast mode plus (≤1000 Κb/s)
High-speed mode (≤3.4 Mb/s)
Clock synchronization
Master I2C
7- or 10-bit addressing
7- or 10-bit combined format transfers
Bulk transmit mode
Transmit and receive buffers
32x32 bits TX FIFOs and 64x8 bits RX FIFOs
Interrupt or polled-mode operation
Handles Bit and Byte waiting at all bus speeds
DMA operation.
Programmable SDA hold time (tHD;DAT)
Bus clear feature
Device ID feature
Support for APB data bus widths of 32 bits
PWM
Support 6 channel
Interface of APB 3.0, width 32 bit data; Slave Error response is not supported
Support arbitrary duty ratio
Support programmable output waveform (support two adjacent channel output waveform and even)
Support produce periodic pulse signal of pulse signal and one-time
Precise interruption generator can be used as a cycle
Support output burr elimination
GPIO (multiplexed with function pins):
64 x GPIO + 8 x PMU GPIO
50 x GPIO + 6 x PMU GPIO(SIP)
Separate data registers and data direction registers for each signal
Configurable hardware and software control for each signal, or for each bit of each signal Separate auxiliary data input, data output, and data control for each I/O in Hardware Control mode. As output, each GPIO can be set to 0 or 1 separately.
Independently controllable signal bits
Configurable interrupt mode for GPIO group0 and GPIO group1. As input, each GPIO pin can act as an interrupt source. IO both edge interrupts.
Configurable debounce logic with an external slow clock to debounce interrupts
Option to generate single or multiple interrupts
Configurable reset values on output signals
Configurable synchronization of interrupt signals
32-bit APB width
USB
Support 2 USB 2.0 OTG
Support for the following speeds:High-Speed (HS, 480-Mbps),Full-Speed (FS, 12-Mbps) and Low-Speed (LS, 1.5-Mbps) modes
Multiple options available for low power operations
DMA mode access support on the application side
Supports up to 6 bidirectional endpoints, including control endpoint 0
Supports the Keep-Alive in Low-Speed mode and SOFs in High/Full-Speed modes
The USB 2.0 modules supports the following transfer types:Control transfer,Bulk transfer,Interrupt transfer,isochronous transfer
Internal DMA mode has two modes of operation: Buffer DMA mode and Scatter/Gather DMA mode
Total Data FIFO RAM Depth is 3072
Not support ADP/HNP/SRP/Battery Charger
SD/EMMC
Support 2 SDxC: SD3.01, eMMC 5.0
The eMMC/SD/SDIO controller features as below.
Supports SD memory and SD Input/Output (SDIO) digital interface protocol, and compliant with SD HCI specification
Uses the same SD-HCI register set for eMMC transfers
Supports eMMC protocols including eMMC 5.1
Supports SD-HCI Host version 3 mode or less
Supports the following data transfer types for SD, eMMC modes:
CPU
SDMA
ADMA2
ADMA3
Supports independent controller, AMBA Slave interface and Master Interface clocks
Supports gating of controller base clock if Host Controller is inactive
Support context aware functional clock gates
Applications can gate the slave interface clock if Host Controller is inactive
Supports interrupt enabling and masking
Supports Command Queuing Engine (CQE) and compliant with eMMC CQ HCI
Programmable scheduler algorithm selection of task execution
Supports data prefetch for back-to-back WRITE operations
Supports auto-tuning
Support clock gating
Support features for interfaces
SD
Supports 4-bit interface
Supports UHS-I mode
Supports Default Speed (DS), high-speed (HS), SDR12, SDR25, SDR50 and SDR104 speed modes
Supports SDIO read wait
Supports SDIO card interrupts in both 1-bit and 4-bit modes
Wake up on card interrupt
eMMC
Supports 4-bit/8-bit interface
Supports legacy, high-speed SDR, high-speed DDR, HS200, and HS400 speed modes
Supports boot operation and alternative boot operation
SPI
Support 3 SPI interface : 1 x OSPI + 2 x QSPI
Supports AHB Slave Interface for software programming(AMBA 3)
Supports AXI Master Interface for Internal DMA transfers
AMBA 3 AXI
AXI data width : 64
AXI address width : 32
Supports two separate FIFOs. One acts as an RX FIFO and the other one acts as a TX FIFO. Each of them is 256-location deep
Enhanced SPI features (Dual/Quad/Octal for OSPI, Dual/Quad for QSPI)
Supports programmable serial data frame length: 4 bits to 32 bits
1.2.13 security#
Support PUF / OTP / TRNG
Support following symmetric algorithm
AES128/192/256
CMAC128/192/256
SM4-128
Support following asymmetric algorithm
RSA-1024/2048/3072/4096
RSA encrypt/decrypt/signature/verify
ECC-163/233/283/409/571/192/224/256/384/521
ECDSA-233/283/409/571/224/256/384/521
ECC CDH-163/233/283/409/571/192/224/256/384/521
SM2 encrypt/decrypt/signature/verify
Support following hash algorithm
HMAC
SHA224/256/384/512, SHA_512/224, SHA_512/256
SM3
TRNG
160Mbps@20Mhz
Stabilization time minimum than 50us
OTP program region has raw OTP density 32Kbits, with security protection
Support security boot with signature
1.2.14 PMU#
Support RTC function in 32Khz
Support the default 6 inputs and 2 outputs
Support IO configurable, reusable as GPIOs, the highest rate of up to 25 MHZ
Support a set of long and short press detection function which can be used as system shutdown or wakeup signal
Support a set of edge number counter which can be regularly cleared
Support two sets of edge and level detection with debounce function
Support four groups of edge and level detection
Support configurable interrupt operation
Support 512 bits system log when it is been shutdown
Support two sets of output IOs with configurable delay time
1.2.15 Others#
decompression
Decompression accelerator is mainly used to implement hardware GZIP decompression function.
Decompression bandwidth ≥ 400MB/s
Support GZIP file format version 4.3
Support DEFLATE compressed file version 1.3
The maximum dictionary size is 32KB
Support the minimum word matching length of 3Byte and the maximum word matching length of 258Byte
Only dynamic huffman compression mode is supported
Support data stream CRC32 verification
Support hardware to automatically generate dynamic huffman tree
The APB3 register interface is used to configure the startup decompression accelerator
Request the DMA controller to transfer large blocks through hardware, and request to transfer 32Kbyte at most once
FFT/IFFT
Support maximum 4096 point fft, ifft calculation
Support int16 calculation accuracy, the real and imaginary parts of input and output are both in int16 format
Support the standard axi4 slave interface, which is used for parameter configuration and data transfer.
The input supports RIRI…., RRRR…. (singal real part), RRRR…IIII… format arrangement, and the output supports RIRI…., RRRR…IIII… format arrangement
It adopts the calculation method of base 2-time decimation, and there is only one butterfly operator inside
A single clock domain design is adopted, and the bus clock is also used as the operation clock
The calculation time of 4096-point fft/ifft is controlled within 1ms, including the total overhead of data movement, calculation, and interrupt interaction
Support interrupt mask, original interrupt query
Fastboot: 3A first picture ≤ 400ms
Working environment temperature: -40 ~ 85°C
1.3 Block Diagram#
2.1 K230#
2.2 K230D#
2.3 Pin information description#
3.1 Absolute Max Rating#
Power Parameter |
Min |
Max |
Units |
PMU |
AVDD1P8_RTC |
-0.1 |
1.98 |
V |
PMU |
AVDD1P8_LDO |
-0.1 |
1.98 |
V |
CORE |
VDD0P8_CORE |
-0.1 |
0.88 |
V |
CPU |
VDD0P8_CPU |
-0.1 |
0.88 |
V |
KPU |
VDD0P8_KPU |
-0.1 |
0.88 |
V |
DDR |
VDD0P8_DDR_CORE |
-0.1 |
0.88 |
V |
DDR |
VDD1P1_DDR_IO |
-0.1 |
1.21/1.32/1.485 |
V |
DDR |
VAA_DDR |
-0.1 |
1.98 |
V |
IO |
VDDIO3P3_0 |
-0.1 |
1.98/3.63 |
V |
IO |
VDDIO3P3_1 |
-0.1 |
1.98/3.63 |
V |
IO |
VDDIO3P3_2 |
-0.1 |
1.98/3.63 |
V |
IO |
VDDIO3P3_3 |
-0.1 |
1.98/3.63 |
V |
IO |
VDDIO3P3_4 |
-0.1 |
1.98/3.63 |
V |
IO |
VDDIO3P3_5 |
-0.1 |
1.98/3.63 |
V |
USB |
AVDD3P3_USB |
-0.1 |
3.63 |
V |
USB |
AVDD1P8_USB |
-0.1 |
1.98 |
V |
PLL |
AVDD0P8_PLL |
-0.1 |
0.88 |
V |
MIPI |
AVDD0P8_MIPI |
-0.1 |
0.88 |
V |
MIPI |
AVDD1P8_MIPI |
-0.1 |
1.98 |
V |
ADC |
AVDD1P8_ADC |
-0.1 |
1.98 |
V |
AUDIO CODEC |
AVDD1P8_CODEC |
-0.1 |
1.98 |
V |
MMC |
VDD3P3_SD |
-0.1 |
3.63 |
V |
SYSTEM |
VDD1P8 |
-0.1 |
1.98 |
V |
K230D LPDDR4 |
VDD1P8_DDR_VDD1 |
-0.1 |
1.98 |
V |
K230D LPDDR4 |
VDD1P1_DDR_VDD2 |
-0.1 |
1.21 |
V |
K230D LPDDR4 |
VDD1P1_DDR_VDDQ |
-0.1 |
1.21 |
V |
3.2 Recommended Operating Condition#
Module |
Parameter |
Min |
Typical |
Max |
Units |
PMU |
AVDD1P8_RTC |
1.674 |
1.8 |
1.98 |
V |
PMU |
AVDD1P8_LDO |
1.674 |
1.8 |
1.98 |
V |
CORE |
VDD0P8_CORE |
0.72 |
0.8 |
0.88 |
V |
CPU |
VDD0P8_CPU |
0.72 |
0.8 |
0.88 |
V |
KPU |
VDD0P8_KPU |
0.72 |
0.8 |
0.88 |
V |
DDR |
VDD0P8_DDR_CORE |
0.744 |
0.8 |
0.88 |
V |
DDR |
VDD1P1_DDR_IO |
1.06/1.14/1.283 |
1.1/1.2/1.35 |
1.21/1.32/1.485 |
V |
DDR |
VAA_DDR |
1.674 |
1.8 |
1.98 |
V |
IO |
VDDIO3P3_0 |
1.62/2.97 |
1.8/3.3 |
1.98/3.63 |
V |
IO |
VDDIO3P3_1 |
1.62/2.97 |
1.8/3.3 |
1.98/3.63 |
V |
IO |
VDDIO3P3_2 |
1.62/2.97 |
1.8/3.3 |
1.98/3.63 |
V |
IO |
VDDIO3P3_3 |
1.62/2.97 |
1.8/3.3 |
1.98/3.63 |
V |
IO |
VDDIO3P3_4 |
1.62/2.97 |
1.8/3.3 |
1.98/3.63 |
V |
IO |
VDDIO3P3_5 |
1.62/2.97 |
1.8/3.3 |
1.98/3.63 |
V |
USB |
AVDD3P3_USB |
3.07 |
3.3 |
3.63 |
V |
USB |
AVDD1P8_USB |
1.674 |
1.8 |
1.98 |
V |
PLL |
AVDD0P8_PLL |
0.72 |
0.8 |
0.88 |
V |
MIPI |
AVDD0P8_MIPI |
0.744 |
0.8 |
0.88 |
V |
MIPI |
AVDD1P8_MIPI |
1.674 |
1.8 |
1.98 |
V |
ADC |
AVDD1P8_ADC |
1.62 |
1.8 |
1.98 |
V |
AUDIO CODEC |
AVDD1P8_CODEC |
1.62 |
1.8 |
1.98 |
V |
MMC |
VDD3P3_SD |
2.7 |
3.3 |
3.63 |
V |
SYSTEM |
VDD1P8 |
1.62 |
1.8 |
1.98 |
V |
K230D LPDDR4 |
VDD1P8_DDR_VDD1 |
1.7 |
1.8 |
1.98 |
V |
K230D LPDDR4 |
VDD1P1_DDR_VDD2 |
1.06 |
1.1 |
1.21 |
V |
K230D LPDDR4 |
VDD1P1_DDR_VDDQ |
1.06 |
1.1 |
1.21 |
V |
3.3 DC Characteristics#
3.3.1 Electrical Characteristics for General IO#
3.3.2 Electrical Characteristics for PLL#
Parameter |
Min |
Type |
Max |
Units |
Fref |
Divided reference frequency range |
488K |
4G |
Hz |
Fout |
Total output frequency range |
50M |
NA |
4G |
Hz |
Fvco |
VCO frequency range |
800M |
NA |
4G |
Hz |
Tlt |
Lock time |
500 |
div referency clock cycle |
Ijitter |
input jitter |
2% |
3.3.3 Electrical Characteristics for DDR#
Parameter |
Symbol |
Unit |
Minimum |
Typical |
Maximum |
Vref input leakage current |
IIZ |
uA |
50 |
BP_DAT input leakage current |
IIZ |
uA |
50 |
Input high voltage for BP_DAT* |
VIH-DC |
V |
Vref+0.02 |
Input low voltage for BP_DAT* |
VIL-DC |
V |
Vref-0.02 |
Differential input voltage for abs(DQS_t – DQS_c) |
VID-DC |
V |
0.1 |
Note: |
BP_DAT represent the DDR_DQ Pins
BP_A represent the DDR_CA Pins
Parameter |
Symbol |
Unit |
Minimum |
Typical |
Maximum |
Input capacitance DQ |
CpadDQ |
pF |
1.54 |
1.62 |
1.76 |
Input capacitance DQS |
CpadDQS |
pF |
1.44 |
1.56 |
1.66 |
Input capacitance,address/cmd |
CpadAC |
pF |
1.71 |
1.81 |
1.94 |
Note: |
This is specified at the top level of the DBYTE and ACX4 blocks. It does not include any customer-supplied routing between these blocks and the C4 bump.
Effective parallel capacitance when ODT of 60ohm is enabled。
Parameter |
Symbol |
Unit |
Minimum |
Maximum |
M_DQ edge arrival relative to M_DQS,800MT/s |
tDQSDQRead800 |
UI |
-0.39 |
0.39 |
M_DQ edge arrival relative to M_DQS,1066MT/s |
tDQSDQRead1066 |
UI |
-0.38 |
0.38 |
M_DQ edge arrival relative to M_DQS,1333MT/s |
tDQSDQRead1333 |
UI |
-0.37 |
0.37 |
M_DQ edge arrival relative to M_DQS,1600MT/s |
tDQSDQRead1600 |
UI |
-0.36 |
0.36 |
M_DQ edge arrival relative to M_DQS,1866MT/s |
tDQSDQRead1866 |
UI |
-0.35 |
0.35 |
M_DQ edge arrival relative to M_DQS,2133MT/s |
tDQSDQRead2133 |
UI |
-0.34 |
0.34 |
M_DQ edge arrival relative to M_DQS,2400MT/s |
tDQSDQRead2400 |
UI |
-0.33 |
0.33 |
M_DQ edge arrival relative to M_DQS,2667MT/s |
tDQSDQRead2667 |
UI |
-0.32 |
0.32 |
M_DQ edge arrival relative to M_DQS,3200MT/s |
tDQSDQRead3200 |
UI |
-0.31 |
0.31 |
Note:
This timing parameter applies to all BP_DAT DQ bits within a related DQ byte
A larger range implies more margin for channel and DRAM timing effects
Per lane deskew training can correct for static skew, up to deskew limits
Refer to the receiver timing budget in the Signal and Power Integrity Application Note for more information
Parameter |
Symbol |
Unit |
Minimum |
Typical |
Maximum |
Reference voltage |
Vref |
V |
Variable |
DC reference voltage error |
VrefDC-err |
VDDQ |
-0.75% |
0.75% |
On-die termination (ODT) programmable resistances |
RTT |
ohm |
open, 240,120, 80, 60,48, 40 |
ODT low-level (0.5*VDDQ) largesignal resistance |
RODT-L/RTT |
0.9 |
1.0 |
1.1 |
ODT mid-level (0.8*VDDQ) largesignal resistance |
RODT-M/RTT |
0.8 |
1.05 |
ODT high-level (1.1*VDDQ) largesignal resistance |
RODT-H/RTT |
0.75 |
1.05 |
Parameter |
Symbol |
Unit |
Minimum |
Typical |
Maximum |
Reference voltage |
VrefAC-err |
VDDQ |
-0.25% |
0.25% |
Low-speed Input high voltage for BP_DAT (logic 1) |
VIH-ACLS |
V |
Vref + 0.070 |
VDDQ +0.15 |
Low-speed Input low voltage for BP_DAT (logic 0) |
VIL-ACLS |
V |
-0.15 |
Vref - 0.070 |
High-speed input high voltage for BP_DAT (logic 1) |
VIH-ACHS |
V |
Vref + 0.070 |
Vref + 0.440 |
High-speed input low voltage for BP_DAT (logic 0) |
VIL-ACHS |
V |
Vref - 0.440 |
Vref - 0.070 |
ODT low-level (0.5*VDDQ) smallsignal resistance |
RODTss-M /RTT |
0.95 |
1.75 |
ODT mid-level (0.8*VDDQ) smallsignal resistance |
RODTss-M /RTT |
0.85 |
1.05 |
ODT high-level (1.1*VDDQ) smallsignal resistance |
RODTss-H /RTT |
0.75 |
1.05 |
Input crossing voltage for differential signals DQS* |
VIX |
mV |
VDQSavg-75 |
VDQSavg |
VDQSavg +75 |
Parameter |
Symbol |
Unit |
Minimum |
Typical |
Maximum |
Reference voltage |
Vref |
V |
Variable |
VrefDC-err |
VDDQ |
-0.75% |
0.75% |
RTT |
ohm |
ODT mid-level (0.25*VDDQ) largesignal resistance |
RODT-M/RTT |
0.8 |
1.1 |
ODT high-level (0.5*VDDQ) largesignal resistance |
RODT-H/RTT |
0.9 |
1.0 |
1.1 |
Parameter |
Symbol |
Unit |
Minimum |
Typical |
Maximum |
Reference voltage |
VrefAC-err |
VDDQ |
-0.25% |
0.25% |
VIH-ACLS |
V |
Vref + 0.070 |
VDDQ +0.15 |
VIL-ACLS |
V |
-0.15 |
Vref - 0.070 |
VIH-ACHS |
V |
Vref + 0.070 |
Vref + 0.440 |
VIL-ACHS |
V |
Vref - 0.440 |
Vref - 0.070 |
ODT mid-level (0.25*VDDQ) smallsignal resistance |
RODTss-M /RTT |
0.9 |
1.1 |
ODT high-level (0.5*VDDQ) smallsignal resistance |
RODTss-H /RTT |
0.95 |
1.75 |
VIX |
mV |
VDQSavg-75 |
VDQSavg |
VDQSavg +75 |
3.3.4 Electrical Characteristics for MIPI DSI#
Symbol |
Parameter |
Condition |
Minimum |
Typical |
Maximum |
Unit |
Vslew |
Supplies slew rate |
0.1 |
V/μs |
Symbol |
Parameter |
Condition |
Minimum |
Typical |
Maximum |
Unit |
Apply to CLKP/N and DATAP/N Inputs |
VI |
Input signal voltage range |
-50 |
1350 |
mV |
ILEAK |
Input leakage current |
VGNDSH(min) ≤ VI ≤ VGNDSH(max) + VOH(absmax) Lane module in LP receive mode |
-10 |
10 |
μA |
VGNDSH |
Ground shift |
-50 |
50 |
mV |
VOH(absmax) |
Maximum transient output voltage level |
-0.15 |
1.45 |
V |
tVOH(absmax) |
Maximum transient time above VOH(absmax) |
20 |
ns |
Symbol |
Parameter |
Condition |
Minimum |
Typical |
Maximum |
Unit |
|VOD| |
HS Transmit Differential output voltage magnitude |
80 Ω ≤ RL ≤ 125 Ω Note: can be programmed using test control register 0x24(cb_sel_v400_prog[2:0]). |
140 |
200 |
270 |
mV |
∆|VOD| |
Change in Differential output voltage magnitude between logic states |
80 Ω ≤ RL ≤ 125 Ω |
14 |
mV |
VCMTX |
Steady-state common-mode output voltage |
80 Ω ≤ RL ≤ 125 Ω |
150 |
200 |
250 |
mV |
∆VCMTX(1,0) |
Changes in steady-state common-mode output voltage between logic states |
80 Ω ≤ RL ≤ 125 Ω |
5 |
mV |
VOHHS |
HS output high voltage |
80 Ω ≤ RL ≤ 125 Ω |
360 |
mV |
ZOS |
Single-ended output impedance |
40 |
50 |
62.5 |
Ω |
∆ZOS |
Single-ended output impedance mismatch |
10 |
Symbol |
Parameter |
Minimum |
Typical |
Maximum |
Unit |
VOL |
Output low-level SE voltage |
-50 |
50 |
mV |
VOH |
Output high-level SE voltage |
1.1 |
1.2 |
1.3 |
V |
ZOLP |
110 |
Ω |
∆ZOLP(01,10) |
Single-ended output impedance mismatch driving opposite level |
20 |
∆ZOLP(00,11) |
Single-ended output impedance mismatch driving same level |
5 |
Symbol |
Parameter |
Minimum |
Typical |
Maximum |
Unit |
VIL |
Input low voltage, not in ULPS |
550 |
mV |
VIL-ULPS |
Logic 0 input voltage, ULPS |
300 |
mV |
VIH |
Input high voltage |
740 |
mV |
VHYST |
Input hysteresis |
25 |
mV |
Symbol |
Parameter |
Minimum |
Typical |
Maximum |
Unit |
VILF |
Input low fault threshold |
200 |
mV |
VIHF |
Input high fault threshold |
450 |
mV |
3.3.5 Electrical Characteristics for MIPI CSI#
Symbol |
Parameter |
Condition |
Minimum |
Typical |
Maximum |
Unit |
Vslew |
0.1 |
V/μs |
Symbol |
Parameter |
Minimum |
Typical |
Maximum |
Unit |
Notes |
VPIN |
Pin signal voltage range |
-50 |
1350 |
mV |
ILEAK |
Pin leakage current |
-10 |
10 |
µA |
VGNDSH(min) ≤ VPIN ≤ VGNDSH(max) + VOH(absmax) Lane module in LP receive mode |
VGNDSH |
Ground shift |
-50 |
50 |
mV |
VPIN(absmax) |
-0.15 |
1.45 |
V |
VPIN(absmax) |
20 |
ns |
The voltage overshoot and undershoot beyond the VPIN is only allowed during a single 20ns window after any LP-0 to LP-1 transition or vice versa. For all other situations the voltage overshoot and undershoot must stay within the VPIN range. |
Symbol |
Parameter |
Minimum |
Typical |
Maximum |
Unit |
Notes |
VIDTH |
Differential input high voltage threshold |
70 |
mV |
D-PHY spec 1.1 compatibility mode (<=1.5Gbps) |
VIDTH |
40 |
mV |
In case of High-Speed deskew calibration (>1.5Gbps) |
VIDTL |
Differential input low voltage threshold |
-70 |
mV |
VIDTL |
-40 |
mV |
VIHHS |
Single ended input high voltage |
460 |
mV |
Excluding possible additional RF interference of 100mV peak sine wave beyond 450MHz |
VILHS |
Single ended input low voltage |
-40 |
mV |
VCMRXDC |
Input common mode voltage |
70 |
330 |
mV |
Excluding possible additional RF interference of 100mV peak sine wave beyond 450MHz. This table value includes a ground difference of 50mV between the transmitter and the receiver, the static common-mode level tolerance and variations below 450MHz |
ZID |
Differential input impedance |
80 |
100 |
125 |
Ω |
Symbol |
Parameter |
Minimum |
Typical |
Maximum |
Unit |
VOL |
-50 |
50 |
mV |
VOH |
1.1 |
1.2 |
1.3 |
V |
ZOLP |
110 |
Ω |
∆ZOLP(01,10) |
20 |
∆ZOLP(00,11) |
5 |
Symbol |
Parameter |
Minimum |
Typical |
Maximum |
Unit |
VIL |
Input low voltage |
550 |
mV |
VIH |
740 |
mV |
VIL-ULPS |
300 |
mV |
VHYST |
Input hysteresis |
25 |
mV |
Symbol |
Parameter |
Minimum |
Typical |
Maximum |
Unit |
VILF |
200 |
mV |
VIHF |
450 |
mV |
3.3.6 Electrical Characteristics for USB#
Parameter |
Symbol |
Test Condition |
Min |
Max |
Unit |
High-power Port |
VBUS |
4.75 |
5.25 |
V |
Low-power Port |
VBUS |
4.4 |
5.25 |
V |
High-power Hub Port (out) |
ICCPRT |
500 |
mA |
Low-power Hub Port (out) |
ICCUPT |
100 |
mA |
High-power Function (in) |
ICCHPF |
500 |
mA |
Low-power Function (in) |
ICCLPF |
100 |
mA |
Unconfigured Function/Hub (in) |
ICCINIT |
100 |
mA |
Suspended High-power Device |
ICCSH |
2.5 |
mA |
Suspended Low-power Device |
ICCSL |
500 |
uA |
High (driven) |
VIH |
2 |
V |
High (floating) |
VIHZ |
2.7 |
3.6 |
V |
Low |
VIL |
0.8 |
V |
Differential Input Sensitivity |
VDI |
(D+)-(D-) |
0.2 |
Differential Common Mode Range |
VCM |
Includes VDI range; |
0.8 |
2.5 |
V |
High-speed squelch detection threshold (differential signal amplitude) |
VHSSQ |
specification refers to differential signal amplitude |
100 |
150 |
mV |
High speed disconnect detection threshold (differential signal amplitude) |
VHSDSC |
525 |
625 |
mV |
High-speed differential input signaling levels |
Specified by eye pattern templates |
High-speed data signaling common mode voltage range (guideline for receiver) |
VHSCM |
-50 |
500 |
mV |
Low |
VOL |
0.3 |
V |
High (Driven) |
VOH |
2.8 |
3.6 |
V |
SE1 |
VOSE1 |
0.8 |
V |
Output Signal Crossover Voltage |
VCRS |
1.3 |
2 |
V |
High-speed idle level |
VHSOI |
-10 |
10 |
mV |
High-speed data signaling high |
VHSOH |
360 |
440 |
mV |
High-speed data signaling low |
VHSOL |
-10 |
10 |
mV |
Chirp J level (differential voltage) |
VCHIRPJ |
700 |
1100 |
mV |
Chirp K level (differential voltage) |
VCHIRPK |
-900 |
-500 |
mV |
Downstream Facing Port Bypass Capacitance (per hub) |
CHPB |
VBUS to GND, |
120 |
uF |
Upstream Facing Port Bypass Capacitance |
CRPB |
VBUS to GND |
1 |
10 |
uF |
Downstream Facing Port |
CIND |
150 |
pF |
Upstream Facing Port (w/o cable) |
CINUB |
100 |
pF |
Transceiver edge rate control capacitance |
CEDGE |
75 |
pF |
TDR spec for high-speed termination |
Bus Pull-up Resistor on Upstream Facing Port |
RPU |
1.5 kΩ ±5% |
1.425 |
1.575 |
kΩ |
Bus Pull-down Resistor on Downstream Facing Port |
RPD |
15 kΩ±5% |
14.25 |
15.75 |
kΩ |
Input impedance exclusive of pullup/pulldown (for low-/full speed) |
ZINP |
300 |
kΩ |
Termination voltage for upstream facing port pullup (RPU) |
VTERM |
3 |
3.6 |
V |
Termination voltage in high speed |
VHSTERM |
-10 |
10 |
mV |
3.3.7 Electrical Characteristics for SD/eMMC#
Parameter |
Test conditions |
Min |
Max |
Units |
MMC0_* signals |
Relative to VSS |
-0.3 |
3.63 |
V |
Input High Voltage(ViH) |
Relative to VSS |
1.68 |
V |
Input Low Voltage(ViL) |
Relative to VSS |
0.9 |
V |
VOH |
Relative to VSS |
0.75*VDDIO33 |
V |
VOL |
Relative to VSS |
0.125*VDDIO33 |
V |
Operating temprature rang TJ |
-40 |
125 |
C |
