Build Firmware#
K230 RTOS SDK is an SDK package managed by repo, including necessary uboot, opensbi, rtsmart, mpp and other repositories.
Setting Up the Development Environment#
Host Environment
Ubuntu 20.04.4 LTS (x86_64)
The K230 RTOS Only compilation environment is suitable for Ubuntu 20.04 and above.
Currently, the K230 RTOS Only SDK has only been verified to compile under Linux environment, other Linux versions have not been tested, so compatibility on other systems cannot be guaranteed.
Local Build Environment#
  • Update APT sources (optional)
  • Install necessary dependencies
  apt-get clean all && \
  apt-get update && \
  • Update PIP sources (optional)
  • Install Python dependencies
pip3 install -U pyyaml pycryptodome gmssl
  • Install the repo tool
mkdir -p ~/.bin
chmod a+rx ~/.bin/repo
source ~/.bashrc
Compilation Process#
Source Code Download#
The source code of K230-RTOS-Only is hosted on Github and Gitee. Users can download the source code using the repo tool.
# It is recommended to create a new directory in the user root directory and then download the code
# Download the SDK from GitHub, using the https protocol
repo init -u https://github.com/canmv-k230/manifest -b master --repo-url=https://github.com/canmv-k230/git-repo.git
# Or download the SDK from gitee, using the ssh protocol. Gitee needs to log in to the account and upload the ssh public key.
repo init -u git@gitee.com:canmv-k230/manifest.git -b master --repo-url=git@gitee.com:canmv-k230/git-repo.git
# Synchronize code
repo sync
Code Preparation#
When compiling for the first time, you need to download the toolchain. The following command only needs to be executed once.
# Download the toolchain when running for the first time
make dl_toolchain
Compilation#
Select the corresponding board configuration file according to actual needs, and then start compiling.
# List available configuration options
make list_def
# Select the corresponding board configuration file
make xxxx_defconfig
# Start compilation
time make log
After compilation, the image files will be generated in the ~/canmv_k230/output/xxxx/xxx.img directory.
If you don’t want to compile CanMV, you need to modify the configuration to disable only that module.
make menuconfig
# Disable the CanMV module
disable canmv
Code Directory Description#
canmv_k230
├── boards
├── configs
├── include
├── output
├── src
│   ├── applications
│   ├── opensbi
│   ├── rtsmart
│   └── uboot
└── tools
Directory structure description:
  1. boards: Board-related files
  2. configs: List of configuration files
  3. include: Automatically generated header files
  4. output: Compiled files, including images and temporary files
  5. src/applications: User applications
  6. src/opensbi: OpenSBI-related files
  7. src/rtsmart: RT-Smart and MPP-related files
  8. src/uboot: U-Boot-related files
  9. scripts: Compilation system-related scripts
