How to Build Firmware#
The K230 RTOS SDK is a multi-repository integrated development suite managed by repo, including core components such as U-Boot, OpenSBI, RT-Smart, and MPP. This document provides two build methods:
  • Build using Docker (recommended): No need to install any build dependencies; one command completes the build
  • Native build directly: Manually set up the environment on Ubuntu 20.04
Direct Local Compilation#
Docker compilation is recommended. Only refer to the following manual setup process when Docker is unavailable.
System Requirements#
  • Operating System: Ubuntu 20.04 LTS (x86_64)
  • Memory: ≥ 2GB
  • Disk: ≥ 10GB
Install System Dependencies#
sudo dpkg --add-architecture i386
sudo apt update
sudo apt install -y --no-install-recommends \
    sudo vim wget curl git git-lfs openssh-client net-tools sed tzdata expect \
    make cmake binutils build-essential gcc g++ bash patch perl tar cpio unzip \
    file bc bison flex autoconf automake python3 python3-pip python3-dev \
    lib32z1 libncurses5-dev fakeroot pigz tree doxygen gawk pkg-config \
    libssl-dev libc6-dev-i386 libncurses5:i386 libconfuse-dev python-is-python3 scons libyaml-dev mtools
sudo apt clean
Configure Python Environment#
pip3 config set global.index-url https://pypi.tuna.tsinghua.edu.cn/simple
Install the repo Tool#
mkdir -p ~/.bin
chmod a+rx ~/.bin/repo
echo 'export PATH="$HOME/.bin:$PATH"' >> ~/.bashrc
source ~/.bashrc
Download Code and Compile#
mkdir -p ~/rtos_k230 && cd ~/rtos_k230
# Download from Gitee (Domestic, requires SSH key)
repo init -u git@gitee.com:canmv-k230/manifest.git --repo-url=git@gitee.com:canmv-k230/git-repo.git
# Download from GitHub (International)
# repo init -u https://github.com/canmv-k230/manifest --repo-url=https://github.com/canmv-k230/git-repo.git
repo sync -j $(nproc)
# Download toolchain (first time only)
make dl_toolchain
# Select board configuration and compile
make k230_rtos_01studio_defconfig
time make
Building RTOS Image from CanMV defconfig#
Some boards only have k230_canmv_*_defconfig and do not have a corresponding k230_rtos_*_defconfig. You can build a pure RTOS image based on the CanMV defconfig:
make k230_canmv_xxx_defconfig
make menuconfig
In menuconfig:
  1. Disable CanMV Components Configuration
  2. Enable RT-Smart UserSpace Examples Configuration > Enable xxxx examples as needed
  3. To build custom applications, enable the corresponding switch under Applications Configuration
After saving, compile:
make
To save as a new defconfig:
make savedefconfig
# Save the generated configuration to configs/ for team reuse
Build Output#
The generated firmware images are located in output/<defconfig>/images/, common files include:
  • *.img: SD card burning or command-line burning
  • *.kdimg: K230BurningTool USB burning or OTA upgrade
Directory Structure#
rtos_k230/
├── boards/          # Board Support Package (BSP), power, pins, DDR, etc. configuration
├── configs/         # defconfig configuration entry
├── output/          # Build output (organized by defconfig directory)
├── src/
│   ├── applications # User-defined applications
│   ├── opensbi/     # OpenSBI (secondary boot)
│   ├── rtsmart/     # RT-Smart kernel, drivers, MPP, examples
│   ├── uboot/       # U-Boot
│   └── canmv/       # CanMV components
└── tools/           # Build scripts, kconfig, toolchain management
Key Directories#
Directory
Final flashable images
configs/
Default configuration templates (all options seen by make list-def)
src/rtsmart/examples/
Official example source code
src/applications/
User-defined application entry
tools/
Build infrastructure (make menuconfig, make list-def, etc.)
FAQ#
k230 command not found#
Run source ~/.bashrc or re-login to the terminal. Verify that ~/.local/bin is in $PATH.
repo sync fails#
  1. Check your network connection; users in China should use the Gitee repository
  2. Retry: k230 repo sync -j4 --fail-fast
  3. Verify that the Gitee SSH key is configured and the corresponding private key exists under ~/.ssh
Toolchain download fails#
The toolchains are stored in the Docker Volume k230_toolchains. The initial download is large, and you can download in batches when the network is unstable:
k230 download-toolchains TC1     # Download TC1 first
k230 download-toolchains TC3     # Then download TC3
Docker permission denied#
sudo usermod -aG docker $USER
newgrp docker
Next Steps#
