Display Module API Manual#
Attention
This module has significant changes starting from firmware version V0.7. If you are using firmware prior to V0.7, please refer to the old version of the documentation.
This manual is intended to guide developers on using the Micro Python API to call the CanMV Display module for image display functionality.
API Introduction#
init#
Initializes the Display path, including the VO module, DSI module, and LCD/HDMI. Must be called before MediaManager.init()
Syntax
init(type=None, width=None, height=None, osd_num=1, to_ide=False, fps=None, quality=90)
Parameter Name
Input / Output
Notes
Display device type
Input
Required
Resolution width
Input
Default value depends on type
Resolution height
Input
osd_num
Number of layers supported in show_image
Input
The larger the number, the more memory it occupies
to_ide
Whether to transfer screen display to IDE display
Input
Occupies more memory when enabled
fps
Display frame rate
Input
Only supports VIRT type
quality
Sets Jpeg compression quality
Input
Only effective when to_ide=True, range [10-100]
show_image#
Displays an image on the screen.
Syntax
show_image(img, x=0, y=0, layer=None, alpha=255, flag=0)
Parameter Name
Input / Output
Notes
Image to display
Input
x
X value of the starting coordinate
Input
y
Y value of the starting coordinate
Input
layer
Display on the specified layer
Input
Only supports OSD layer, for multiple layers set osd_num in init
alpha
Layer blending alpha
Input
flag
Display flag
Input
deinit#
Performs deinitialization. The deinit method will shut down the entire Display path, including the VO module, DSI module, and LCD/HDMI. Must be called before MediaManager.deinit() Must be called after sensor.stop()
Syntax
deinit()
bind_layer#
Binds the output of the sensor or vdec module to the screen display. This allows continuous image display without manual intervention. Must be called before init
Syntax
Parameter Name
Input / Output
Notes
src
Output information of sensor or vdec
Input
Obtainable via sensor.bind_info()
dstlayer
Display layer to bind to display layer
Input
Can be bound to video or osd layer
rect
Display area
Input
pix_format
Image pixel format
Input
alpha
Input
flag
Display flag
Input
LAYER_VIDEO1 not supported
Data Structure Description#
type#
Type
Resolution
(width x height @ fps)
Notes
LT9611
1920x1080@30
Default value
1280x720@30
640x480@60
HX8377
1080x1920@30
Default value
ST7701
800x480@30
Default value
Can be set to portrait mode 480x800
854x480@30
Can be set to portrait mode 480x854
VIRT
640x480@90
Default value
IDE debugging only, does not display content on an external screen
Users can customize resolution (64x64)-(4096x4096) and frame rate (1-200)
layer#
K230 provides support for 2 video layers and 4 OSD layers. Listed as follows:
Display Layer
Notes
LAYER_VIDEO1
Only usable in bind_layer
LAYER_VIDEO2
LAYER_OSD0
Supports use in show_image and bind_layer
LAYER_OSD1
LAYER_OSD2
LAYER_OSD3
flag#
Flag
Notes
FLAG_ROTATION_0
Rotate 0 degrees
FLAG_ROTATION_90
Rotate 90 degrees
FLAG_ROTATION_180
Rotate 180 degrees
FLAG_ROTATION_270
Rotate 270 degrees
FLAG_MIRROR_NONE
No mirroring
FLAG_MIRROR_HOR
Horizontal mirroring
FLAG_MIRROR_VER
Vertical mirroring
FLAG_MIRROR_BOTH
Horizontal and vertical mirroring
Sample Program#
The following is a sample program:
from media.display import *  # Import the display module to use display related interfaces
from media.media import *    # Import the media module to use media related interfaces
import os, time, image       # Import the image module to use image related interfaces
# Use LCD as display output
# Initialize media manager
# Create an image for drawing
img.clear()
img.draw_string_advanced(0, 0, 32, "Hello World!,你好世界 ! ! ! ", color=(255, 0, 0))
Display.show_image(img)
        time.sleep(1)
    print(" User stopped:", e)
    print(f" Exception: {e}")
