RTOS Display Support List#
Display / Panel Support List#
The display-related configuration in the current SDK is located at MPP Configuration -> Display Configuration.
Note: The support list is continuously updated with each SDK release. Always refer to src/rtsmart/mpp/Kconfig in the current source tree for the authoritative list.
Display Driver Layer#
  • HDMI display driver: MPP_ENABLE_DSI_HDMI
  • LCD display driver: MPP_ENABLE_DSI_LCD
  • SPI LCD display driver: MPP_ENABLE_SPI_LCD
  • QSPI LCD display driver: MPP_ENABLE_QSPI_LCD
  • OSPI LCD display driver: MPP_ENABLE_OSPI_LCD
  • Virtual display driver: MPP_DSI_ENABLE_VIRT
Panel / Bridge Chip Driver Layer#
  • HDMI bridge: LT9611 (MPP_DSI_ENABLE_HDMI_LT9611)
  • LCD panel: HX8399 (MPP_DSI_ENABLE_LCD_HX8399)
  • LCD panel: ST7701 (MPP_DSI_ENABLE_LCD_ST7701)
  • LCD panel: ILI9806 (MPP_DSI_ENABLE_LCD_ILI9806)
  • LCD panel: ILI9881 (MPP_DSI_ENABLE_LCD_ILI9881)
  • LCD panel: NT35516 (MPP_DSI_ENABLE_LCD_NT35516)
  • LCD panel: NT35532 (MPP_DSI_ENABLE_LCD_NT35532)
  • LCD panel: GC9503 (MPP_DSI_ENABLE_LCD_GC9503)
  • LCD panel: ST7102 (MPP_DSI_ENABLE_LCD_ST7102)
  • LCD panel: AML020T (MPP_DSI_ENABLE_LCD_AML020T)
  • LCD panel: JD9852 (MPP_DSI_ENABLE_LCD_JD9852)
  • SPI LCD panel: ST7789 (MPP_SPI_ENABLE_LCD_ST7789)
How to Enable a Specific Display Panel in Firmware#
  1. In the SDK root directory, run:
make menuconfig
  1. Navigate to:
  1. Enable the display driver that matches your hardware connection and configure the corresponding pins:
    • HDMI path: enable Enable HDMI Display Driver
    • MIPI DSI LCD path: enable Enable LCD Display Driver
    • SPI/QSPI/OSPI LCD path: enable the corresponding SPI/QSPI/OSPI driver switch
  2. Supply the required configuration for the driver type:
    • HDMI: typically configure DSI-HDMI Reset GPIO and DSI-HDMI I2c Bus
    • MIPI DSI LCD: typically configure DSI-LCD Reset GPIO and DSI-LCD BackLight GPIO
    • SPI/QSPI/OSPI LCD: also configure Data/Command GPIO, Chip Select GPIO, Reset GPIO, Backlight GPIO, the bus, and FPIOA pin mapping
  3. In the same menu, select the corresponding panel driver:
    • HDMI: typically Enable HDMI Display Panel Driver LT9611
    • MIPI LCD: select the actual panel (e.g. HX8399/ST7701/ILI9881)
    • SPI LCD: select Enable SPI LCD Panel Driver ST7789
  4. Save the configuration and rebuild:
time make log
How to Verify Display Configuration on the RTOS Side#
1) Ensure MPP samples are enabled and built#
Under RT-Smart UserSpace Examples Configuration, enable at least:
  • Enable MPP examples
  • One or more VO/display-related samples (e.g. sample_vo_video, sample_vo_osd)
2) Locate runnable samples on the board#
cd /sdcard/app/examples
find mpp -name "*.elf" | grep -Ei "vo|vicap|player" | head
FAQ#
Display fails to initialize (black screen)#
Check in order:
  1. Does the driver path match the hardware (HDMI / MIPI LCD / SPI LCD)?
  2. Is the panel model configured correctly?
  3. Do the Reset/Backlight GPIO, I2C bus, and SPI/QSPI/OSPI pin assignments match the hardware?
  4. Is the board power supply stable and is the display cable properly connected?
A panel option is not visible in the menu#
Possible causes:
  1. The SDK version does not include that panel driver.
  2. The corresponding display path is not enabled for the current board configuration.
  3. A Kconfig dependency is blocking the option.
References#
