How to Run Sample Programs#
This document explains in detail how to enable, build, and run sample programs in the K230 RTOS SDK, and how to configure auto-start on boot.
Enable Sample Programs#
Open the Configuration Menu#
Run the following command from the SDK root directory (~/rtos_k230) to enter the interactive configuration interface:
make menuconfig
Enable Compilation of Samples#
The SDK has been refactored so that all sample configurations are accessed through a unified entry point:
RT-Smart UserSpace Examples Configuration
Configure in the following order:
  1. Enable the master switch first:
    You need to disable CanMV Components Configuration.
  2. Then enable sub-switches by category (select as needed):
    Enable 3rd-party examples
    Enable build peripheral examples
    Enable MPP examples
    Enable build ai examples
    Enable build integrated examples
  3. If you enable a category (e.g. Enable MPP examples), go into its submenu to check specific samples (e.g. sample_venc, sample_vdec, etc.).
Notes:
  • The old paths RT-Smart Configuration > Enable build Rtsmart examples and MPP Configuration > Enable build MPP samples are no longer the primary entry points for samples.
  • The master sample switch depends on !SDK_ENABLE_CANMV. If you are using the CanMV solution, switch to the RTOS path as described in the build guide before this menu appears.
Build Sample Programs#
Standalone Build (For Debugging)#
To build a single sample independently, go into its directory and run:
cd src/rtsmart/examples/integrated_poc  # example path
make clean && make                      # clean and rebuild
make smart_ipc
Notes:
  • ELF files produced by a standalone build must be manually copied to the board (see step 3.2).
  • Ensure the corresponding category and specific sample are enabled in RT-Smart UserSpace Examples Configuration before building.
Automatic Deployment via Image#
When using make for a full build, RT-Smart samples are packaged into the image at /sdcard/app/examples/ by default. After logging in to the board via serial port, run them directly:
cd /sdcard/app/examples
# Run a sample (example)
./integrated_poc/smart_ipc.elf
Manual Deployment of Standalone-Built Samples#
  1. Copy the generated ELF file (e.g. integrated_poc.elf) to the board using a card reader or MTP.
  2. Run it via the serial terminal:
    /sdcard/app/examples/integrated_poc.elf
run smart ipc
Serial Connection Tips:
  • Use PuTTY or Minicom to connect to the board’s serial port (baud rate: 115200).
  • On Linux the serial device is usually /dev/ttyUSB0; on Windows it is COMx.
Configure Auto-Start on Boot#
Set the Startup Command#
  1. In make menuconfig, navigate to:
    RT-Smart Configuration > Startup command
  2. Startup command is a runtime command string. Enter the absolute path to the sample program (e.g. /sdcard/app/examples/integrated_poc/smart_ipc.elf).
  3. If you are configuring Fast Boot Configuration > Fast boot file path, you can use an absolute path or the ${SDK_*} variables exported by tools/mkenv.mk (e.g. ${SDK_BUILD_IMAGES_DIR}). You also need to update the auto-start command, replacing the ELF path with /bin/preload.
Verify Auto-Start#
After rebooting the board, the sample program will start automatically. Confirm it is working via logs or peripheral behavior.
Frequently Asked Questions#
  1. The sample is not in /sdcard/app/examples
    • Check that the master switch in RT-Smart UserSpace Examples Configuration is enabled.
    • Check that the relevant category (e.g. MPP/AI/Integrated) and the specific sample are selected.
    • Re-run make and ensure there are no build errors.
  2. No output on serial port
    • Confirm the serial cable is properly connected.
    • Check that the baud rate and terminal settings match.
Following the steps above, you can quickly master the complete workflow for running K230 RTOS SDK sample programs.
