How to Flash Firmware#
This document assumes you have completed compilation and obtained image files in output/<defconfig>/images/.
Common Image File Types#
  • *.kdimg - recommended for K230BurningTool (USB)
  • *.img - recommended for SD card writing and some command-line flashing tools
K230 supports four boot media: eMMC, SD card, SPI Nor Flash, and SPI Nand Flash. Firmware can be flashed using two methods:
  • USB flashing - direct USB connection to the device
  • SD card flashing - write image to SD card and boot from it
For serial and USB connection, refer to the K230 Development Board documentation.
USB Flashing#
Three Methods to Enter Flashing Mode#
  1. No valid firmware on default boot media
    • Example: fresh eMMC with no prior firmware, or SD card removed
  2. Force boot mode via Boot button
    • Hold the board’s Boot button while powering on to force flashing mode
  3. Trigger via terminal command
    • Run on an already-booted RtSmart terminal:
      reboot_to_upgrade
    • The device will automatically reboot into flashing mode
Note If reboot_to_upgrade does not enter flashing mode, use the latest flashing tool to flash the patch file: K230 Patch/K230D Patch
Using K230BurningTool (GUI Tool)#
  • Download: K230BurningTool
  • Features: supports multi-device flashing with intuitive interface
  • Steps:
    1. Connect device and enter flashing mode
    2. Select firmware file (recommended *.kdimg)
    3. Click Start Flashing; after completion, click Confirm to proceed
Using K230-Flash (Command-line Tool)#
  • Installation:
    pip install k230-flash
  • Features: based on Kburn and Python, suitable for automated operations
  • Example usage:
    # Linux / macOS
    k230_flash -m EMMC 0 output/<defconfig>/images/<your_image>.img
    # Windows
    k230_flash.exe -m EMMC 0 output\<defconfig>\images\<your_image>.img
SD Card Flashing#
Using Rufus or balenaEtcher#
Important .kdimg format only supports K230BurningTool and cannot be written via SD card tools.
Summary#
  • USB flashing: quick device update, recommended K230BurningTool or K230-Flash
  • SD card flashing: for devices without USB or bulk writing scenarios, use Rufus or balenaEtcher
