How to Run Example Programs#
This document details how to enable, compile, and run example programs in the K230 RTOS SDK, and configure them to start automatically on boot.
Enabling Example Programs#
Entering the Configuration Menu#
Execute the following command in the SDK root directory (~/rtos_k230) to enter the interactive configuration interface:
make menuconfig
Enabling Build Examples#
The current SDK has refactored the example configuration, and the unified entry is:
RT-Smart UserSpace Examples Configuration
It is recommended to configure in the following order:
  1. First enable the master switch:
    You need to disable CanMV Components Configuration
  2. Then enable sub-switches by category (select as needed):
    Enable 3rd-party examples
    Enable build peripheral examples
    Enable MPP examples
    Enable build ai examples
    Enable build integrated examples
  3. If a certain category is enabled (for example, Enable MPP examples), continue to enter that submenu to check specific samples (such as sample_venc, sample_vdec, etc.).
Notes:
  • The old paths RT-Smart Configuration > Enable build Rtsmart examples and MPP Configuration > Enable build MPP samples are no longer the main example entries.
  • The example master switch depends on !SDK_ENABLE_CANMV; if you use the CanMV solution, you need to switch to the RTOS path according to the build guide before this menu will appear.
Compile Example Programs#
Individual Build (Debug Scenarios)#
If you need to compile a specific example individually, navigate to the corresponding directory and run the build:
cd src/rtsmart/examples/integrated_poc  # Example path
make clean && make                      # Clean and rebuild
make smart_ipc
Notes:
  • The ELF file generated by individual compilation needs to be manually copied to the development board (see Step 3.2).
  • Make sure the corresponding category and specific sample have been enabled in RT-Smart UserSpace Examples Configuration before compiling.
Running Example Programs#
Automatic Deployment via Image#
If you use make for the overall compilation, RT-Smart examples will be packaged by default into the /sdcard/app/examples/ directory of the image. After logging into the development board via serial port, you can directly execute:
cd /sdcard/app/examples
# Run example (example)
./integrated_poc/smart_ipc.elf
Manually Deploying Individually Compiled Examples#
  1. Copy the generated ELF file (such as integrated_poc.elf) to the development board via a card reader or mtp:
  2. Run via serial port terminal:
    /sdcard/app/examples/integrated_poc.elf
run smart ipc
Serial Port Connection Tips:
  • Use PuTTY or Minicom to connect to the development board’s serial port (baud rate is 115200).
  • The serial port device name is usually /dev/ttyUSB0 on Linux, and COMx on Windows.
Configure Boot Auto-Start Example#
Set Startup Command#
  1. In make menuconfig, navigate to:
    RT-Smart Configuration > Rtsmart auto execute command string
  2. When auto-starting from a regular file system, disable Fast Boot Configuration and fill in the absolute path and arguments of the example program on the board.
  3. During Fast Boot auto-start, enter the host-side ELF path in Fast Boot Configuration > Fast boot file path, and set the auto-run command to @preload, with the arguments following it. @preload is an internal trigger marker, not the /bin/preload file, and cannot be run as a regular msh command.
For complete configuration, Secure Boot restrictions, and troubleshooting, see How to Use Fast Boot and Configure RT-Smart Auto-Run.
Verify Auto-Start#
After restarting the development board, the example program will run automatically. You can check the logs or peripheral indicators to confirm whether it is effective.
Frequently Asked Questions#
  1. Examples not appearing in /sdcard/app/examples directory
    • Check whether the RT-Smart UserSpace Examples Configuration main switch has been enabled.
    • Check whether the corresponding category (e.g., MPP/AI/Integrated) and specific samples have been selected.
    • Re-run make and ensure there are no compilation errors.
  2. No serial port output
    • Confirm that the serial cable is properly connected; when using an external USB-to-serial module, first check Serial Level and Adapter Module Safety.
    • Check whether the baud rate matches the terminal configuration.
By following the steps above, you can quickly master the complete operation workflow of the K230 RTOS SDK example programs.
