Quick Start Guide for K230 AI Inference Process#
Tutorial Video for this Chapter: K230 Development Board Tutorial - Quick Start AI Inference Process on Bilibili
This chapter supports Linux+RT-Smart dual system and pure RT-Smart single system. For the system image compilation process, refer to [Compile K230_SDK](./Development Basics.md#make_image).
This chapter introduces the complete process of AI inference on the K230, providing a general overview of the AI inference process based on K230. It includes video capture, image preprocessing, model inference, post-processing, and display.
  • Video Input: VI (Video Input), video capture
  • Video Output: VO (Video Output), display
This chapter includes two implementations of the K230 AI inference process: AI inference based on OpenCV (C++) and AI inference based on ulab (MicroPython). Each corresponds to a subchapter, with detailed implementations described in the respective subchapters.
Detailed Code Implementation: k230_AI_Demo_Code_Flow_Introduction
AI Inference Process Based on OpenCV (C++)#
The K230 AI inference based on OpenCV (C++) briefly introduces the process of video capture, image preprocessing (OpenCV), model inference, post-processing, and display using the C++ language.
Video Capture#
Video Capture: (Video Input, VI) is related to the camera. This subsection briefly introduces the overall process of setting up the camera, starting the camera, capturing a frame from the camera, and stopping the camera using C++; for detailed information, see K230_VICAP_API Reference.md, K230_VICAP_SENSOR_Parameter Partition Reference.md, K230_Camera_Sensor Adaptation Guide.md.
This section takes CANMV-K230-V1.x as an example to explain the corresponding display parameter settings; for other development board settings, refer to vi_vo.h .
1. Setting Camera Properties:
  • Set the sensor to output two channels;
  • One channel is for display, with the output size set to 1080p and the image format as PIXEL_FORMAT_YVU_PLANAR_420, directly bound to the VO;
  • The other channel is for AI computation, with the output size set to 720p and the image format as PIXEL_FORMAT_BGR_888_PLANAR (actually rgb, chw, uint8);
Create Camera (sensor) Output Buffer (VB): Used to store the two outputs from the camera
//vi_vo.h
/***************************unfixed: may need modification for different AI Demos***********************/
#define SENSOR_CHANNEL (3)     // Number of channels
#define SENSOR_HEIGHT (720)    // sensor ch1 output height, AI input
#define SENSOR_WIDTH (1280)    // sensor ch1 output width, AI input
#define ISP_CHN0_WIDTH  (1920) // sensor ch0 output width, VO
#define ISP_CHN0_HEIGHT (1080) // sensor ch0 output height, VO
/***************************fixed: no modification needed***********************************/
config.max_pool_cnt = 64;
//VB for YUV420SP output
config.comm_pool[0].blk_size = VICAP_ALIGN_UP((ISP_CHN0_WIDTH * ISP_CHN0_HEIGHT * 3 / 2), VICAP_ALIGN_1K);
//VB for RGB888 output
config.comm_pool[1].blk_cnt = 5;
config.comm_pool[1].blk_size = VICAP_ALIGN_UP((SENSOR_HEIGHT * SENSOR_WIDTH * 3 ), VICAP_ALIGN_1K);
if (ret) {
    return ret;
Set Camera Properties: Set sensor_type; generally, no need to change the camera, no modification needed.
//vi_vo.h
vicap_dev = VICAP_DEV_ID_0;
if (ret) {
    return ret;
dev_attr.cpature_frame = 0;
if (ret) {
    return ret;
Set Camera Channel 0 Properties: Set camera channel 0 resolution to 1080p and format to PIXEL_FORMAT_YVU_PLANAR_420; bind camera channel 0 to display; generally, only chn_attr.out_win.width, chn_attr.out_win.height, and chn_attr.pix_format need attention, no other modifications needed.
//vi_vo.h
/***************************unfixed: may need modification for different AI Demos******************/
//set chn0 output yuv420sp
chn_attr.chn_enable = K_TRUE;
chn_attr.pix_format = PIXEL_FORMAT_YVU_PLANAR_420;
chn_attr.buffer_num = VICAP_MAX_FRAME_COUNT;        //at least 3 buffers for ISP
chn_attr.buffer_size = config.comm_pool[0].blk_size;
vicap_chn = VICAP_CHN_ID_0;
printf("sample_vicap ...kd_mpi_vicap_set_chn_attr, buffer_size[%d]\n", chn_attr.buffer_size);
if (ret) {
    return ret;
//bind vicap chn 0 to VO
vo_mpp_chn.mod_id = K_ID_VO;
sample_vicap_bind_vo(vicap_mpp_chn, vo_mpp_chn);
printf("sample_vicap ...dwc_dsi_init\n");
Set Camera Channel 1 Properties: Set channel 1 resolution to 720p and format to PIXEL_FORMAT_BGR_888_PLANAR.
//vi_vo.h
//set chn1 output rgb888p
chn_attr.out_win.width = SENSOR_WIDTH ;
chn_attr.out_win.height = SENSOR_HEIGHT;
chn_attr.pix_format = PIXEL_FORMAT_BGR_888_PLANAR;
chn_attr.buffer_num = VICAP_MAX_FRAME_COUNT;//at least 3 buffers for ISP
chn_attr.buffer_size = config.comm_pool[1].blk_size;
if (ret) {
    return ret;
Initialize and Start the Camera:
//vi_vo.h
if (ret) {
    // goto err_exit;
printf("sample_vicap ...kd_mpi_vicap_start_stream\n");
if (ret) {
    // goto err_exit;
Usage Example:
//main.cc
vivcap_start();
**2. Retrieving Camera Images:
Temporary Camera Data Address: Create a vaddr to temporarily store the latest data from the camera. It matches the size of camera channel 1.
// main.cc
// allocate memory for sensor
size_t paddr = 0;
void *vaddr = nullptr;
size_t size = SENSOR_CHANNEL * SENSOR_HEIGHT * SENSOR_WIDTH;
int ret = kd_mpi_sys_mmz_alloc_cached(&paddr, &vaddr, "allocate", "anonymous", size);
if (ret)
    std::cerr << "physical_memory_block::allocate failed: ret = " << ret << ", errno = " << strerror(errno) << std::endl;
    std::abort();
Reading the Latest Frame:
  • Dump: Read a frame of image from camera channel 1, i.e., dump a frame of data from VB to dump_info.
  • Map: Map the DDR address (physical address) corresponding to dump_info to the current system address (virtual address) for access.
  • Convert to cv::Mat: Convert the camera data to cv::Mat, sensor (rgb, chw) -> cv::Mat (bgr, hwc); converting the camera data to cv::Mat is not mandatory, but it is done here to explain it in a more familiar way (cv::Mat).
//vi_vo.h
// VB for RGB888 output
//main.cc
while (!isp_stop)
    cv::Mat ori_img;
    // sensor to cv::Mat
        // Read a frame of image from camera channel 1, i.e., dump a frame of data from VB to dump_info
        if (ret) {
            continue;
        // Map the DDR address (physical address) corresponding to dump_info to the current system (virtual address) for access
        // vbvaddr is changing in real-time, so it's best to copy the latest data to a fixed address vaddr for access by other parts
        memcpy(vaddr, (void *)vbvaddr, SENSOR_HEIGHT * SENSOR_WIDTH * 3);
        // Convert camera data to cv::Mat, sensor (rgb, chw) -> cv::Mat (bgr, hwc)
        cv::Mat image_r = cv::Mat(SENSOR_HEIGHT, SENSOR_WIDTH, CV_8UC1, vaddr);
        cv::Mat image_g = cv::Mat(SENSOR_HEIGHT, SENSOR_WIDTH, CV_8UC1, vaddr + SENSOR_HEIGHT * SENSOR_WIDTH);
        cv::Mat image_b = cv::Mat(SENSOR_HEIGHT, SENSOR_WIDTH, CV_8UC1, vaddr + 2 * SENSOR_HEIGHT * SENSOR_WIDTH);
        std::vector<cv::Mat> color_vec(3);
        color_vec.clear();
        color_vec.push_back(image_b);
        color_vec.push_back(image_g);
        color_vec.push_back(image_r);
        cv::merge(color_vec, ori_img);
    // Use the current frame data
        // Release the current frame of the sensor
        if (ret) {
**3. Stopping the Camera:
//vi_vo.h
int vivcap_stop()
    // Stop the camera
    printf("sample_vicap ...kd_mpi_vicap_stop_stream\n");
    int ret = kd_mpi_vicap_stop_stream(vicap_dev);
    if (ret) {
        return ret;
    // Release camera resources
    if (ret) {
        return ret;
    // Unbind VI and VO
    sample_vicap_unbind_vo(vicap_mpp_chn, vo_mpp_chn);
    /* Allow one frame time for the VO to release the VB block */
    k_u32 display_ms = 1000 / 33;
    usleep(1000 * display_ms);
    // Exit VB
    ret = kd_mpi_vb_exit();
    if (ret) {
        printf("sample_vicap, kd_mpi_vb_exit failed.\n");
        return ret;
Simply call in main.cc:
//main.cc
vivcap_start();
vivcap_stop();
Preprocessing#
Resize the current frame data.
//main.cc
while (!isp_stop)
    cv::Mat ori_img;        // ori: uint8, chw, rgb
    // pre_process, cv::Mat((1280,720), bgr, hwc) -> kmodel((224,224), rgb, hwc)
    cv::Mat pre_process_img;
        cv::Mat rgb_img;
        cv::cvtColor(ori_img, rgb_img, cv::COLOR_BGR2RGB);
        cv::resize(rgb_img, pre_process_img, cv::Size(kmodel_input_width, kmodel_input_height), cv::INTER_LINEAR);
    // A general implementation has been provided in ai_base.cc and open-source code will be provided in Chapter 6
    // set kmodel input
        runtime_tensor tensor0 = kmodel_interp.input_tensor(0).expect("cannot get input tensor");
        auto in_buf = tensor0.impl()->to_host().unwrap()->buffer().as_host().unwrap().map(map_access_::map_write).unwrap().buffer();
        memcpy(reinterpret_cast<unsigned char *>(in_buf.data()), pre_process_img.data, sizeof(uint8_t) * kmodel_input_height * kmodel_input_width * 3);
        hrt::sync(tensor0, sync_op_t::sync_write_back, true).expect("sync write_back failed");
Model Inference#
After setting the model input, perform model inference to get the inference results.
//main.cc
string kmodel_path = argv[1];
cout << kmodel_path << endl;
float cls_thresh = 0.5;
// kmodel interpreter, constructed from the kmodel file, responsible for model loading, input/output settings, and inference
interpreter kmodel_interp;
// load model
kmodel_interp.load_model(ifs).expect("Invalid kmodel");
// inputs init
for (size_t i = 0; i < kmodel_interp.inputs_size(); i++)
    auto desc = kmodel_interp.input_desc(i);
    auto shape = kmodel_interp.input_shape(i);
    kmodel_interp.input_tensor(i, tensor).expect("cannot set input tensor");
auto shape0 = kmodel_interp.input_shape(0);      // nhwc
int kmodel_input_height = shape0[1];
int kmodel_input_width = shape0[2];
// outputs init
for (size_t i = 0; i < kmodel_interp.outputs_size(); i++)
    auto desc = kmodel_interp.output_desc(i);
    auto shape = kmodel_interp.output_shape(i);
    kmodel_interp.output_tensor(i, tensor).expect("cannot set output tensor");
while (!isp_stop)
    cv::Mat ori_img;
    // pre_process
    // set kmodel input
    // kmodel run
    kmodel_interp.run().expect("error occurred in running model");
    // get kmodel output
    vector<float *> k_outputs;
        for (int i = 0; i < kmodel_interp.outputs_size(); i++)
            auto out = kmodel_interp.output_tensor(i).expect("cannot get output tensor");
            k_outputs.push_back(p_out);
Post-processing#
Post-process the model results and store the results in results.
//main.cc
vector<cls_res> results;
while (!isp_stop)
    cv::Mat ori_img;
    // pre_process
    // set kmodel input
    // kmodel run
    // post process
    results.clear();
        float* output0 = k_outputs[0];
        // softmax
        float sum = 0.0;
        for (int i = 0; i < labels.size(); i++){
            sum += exp(output0[i]);
        int max_index;
            output0[i] = exp(output0[i]) / sum;
        max_index = std::max_element(output0, output0 + labels.size()) - output0;
        cls_res b;
        if (output0[max_index] >= cls_thresh)
            b.label = labels[max_index];
            b.score = output0[max_index];
            results.push_back(b);
Display#
Display (Video Output, VO) is related to display settings and overlay. This subsection briefly introduces the overall process of display settings and overlay using C++; for detailed information, see K230_Video_Output_API Reference.md
  • Display Settings: Set display size and format.
  • Display Overlay: The display consists of two layers. The lower layer (original image layer) directly displays the camera output, while the upper layer (OSD layer) is used for drawing boxes, points, writing text, etc.
1. Display Settings: Set display size and format.
//vi_vo.h
static k_s32 sample_connector_init(void)
    k_connector_type connector_type = LT9611_MIPI_4LAN_1920X1080_30FPS;
static k_s32 vo_layer_vdss_bind_vo_config(void)
    sample_connector_init();
    // config layer
    info.act_size.width = ISP_CHN0_WIDTH; // ISP_CHN0_HEIGHT; // 1080; // 640; // 1080;
    info.act_size.height = ISP_CHN0_HEIGHT; // ISP_CHN0_WIDTH; // 1920; // 480; // 1920;
**2. Display Overlay: Since the camera and display channels are bound, we cannot directly manipulate the VO. Therefore, we use an overlay method for display.
Original Image Layer: The camera (VI) channel 0 is bound to the display (VO) channel 1. As the camera starts, the data from camera channel 0 will automatically flow to VO channel 1.
//vi_vo.h
//bind vicap chn 0 to vo
OSD Layer: After drawing boxes, points, and writing text on cv::Mat, insert the data into the corresponding VO channel.
// vi_vo.h
#define osd_id                              K_VO_OSD3
#define ISP_CHN0_WIDTH                      (1920) // sensor ch0 output width, vo
#define ISP_CHN0_HEIGHT                     (1080) // sensor ch0 output height, vo
#define osd_width                           (1920)
#define osd_height                          (1080)
k_vb_blk_handle vo_insert_frame(k_video_frame_info *vf_info, void **pic_vaddr)
    k_u64 phys_addr = 0;
    k_u32 *virt_addr;
    k_vb_blk_handle handle;
    k_s32 size;
    if (vf_info == NULL)
        return K_FALSE;
    if (vf_info->v_frame.pixel_format == PIXEL_FORMAT_ABGR_8888 || vf_info->v_frame.pixel_format == PIXEL_FORMAT_ARGB_8888)
        size = vf_info->v_frame.height * vf_info->v_frame.width * 4;
    else if (vf_info->v_frame.pixel_format == PIXEL_FORMAT_RGB_565 || vf_info->v_frame.pixel_format == PIXEL_FORMAT_BGR_565)
        size = vf_info->v_frame.height * vf_info->v_frame.width * 2;
    else if (vf_info->v_frame.pixel_format == PIXEL_FORMAT_ABGR_4444 || vf_info->v_frame.pixel_format == PIXEL_FORMAT_ARGB_4444)
    else if (vf_info->v_frame.pixel_format == PIXEL_FORMAT_RGB_888 || vf_info->v_frame.pixel_format == PIXEL_FORMAT_BGR_888)
        size = vf_info->v_frame.height * vf_info->v_frame.width * 3;
    else if (vf_info->v_frame.pixel_format == PIXEL_FORMAT_ARGB_1555 || vf_info->v_frame.pixel_format == PIXEL_FORMAT_ABGR_1555)
    else if (vf_info->v_frame.pixel_format == PIXEL_FORMAT_YVU_PLANAR_420)
        size = vf_info->v_frame.height * vf_info->v_frame.width * 3 / 2;
    size = size + 4096;         // Force 4K alignment, should be removed later
    printf("vb block size is %x \n", size);
    handle = kd_mpi_vb_get_block(g_pool_id, size, NULL);
        return K_FAILED;
    phys_addr = kd_mpi_vb_handle_to_phyaddr(handle);
    if (phys_addr == 0)
        return K_FAILED;
    virt_addr = (k_u32 *)kd_mpi_sys_mmap(phys_addr, size);
    // virt_addr = (k_u32 *)kd_mpi_sys_mmap_cached(phys_addr, size);
    if (virt_addr == NULL)
        return K_FAILED;
    vf_info->mod_id = K_ID_VO;
    vf_info->pool_id = g_pool_id;
    vf_info->v_frame.phys_addr[0] = phys_addr;
        vf_info->v_frame.phys_addr[1] = phys_addr + (vf_info->v_frame.height * vf_info->v_frame.stride[0]);
    *pic_vaddr = virt_addr;
    printf("phys_addr is %lx g_pool_id is %d \n", phys_addr, g_pool_id);
    return handle;
Usage Example:
// main.cc
// osd create
k_video_frame_info vf_info;
void *pic_vaddr = NULL;
memset(&vf_info, 0, sizeof(vf_info));
vf_info.v_frame.width = osd_width;
vf_info.v_frame.height = osd_height;
vf_info.v_frame.stride[0] = osd_width;
vf_info.v_frame.pixel_format = PIXEL_FORMAT_ARGB_8888;
block = vo_insert_frame(&vf_info, &pic_vaddr);
while (!isp_stop)
    cv::Mat ori_img;
    // pre_process
    // set kmodel input
    // kmodel run
    // post process
    results.clear();
    // draw result to vo
        // draw osd
                // draw cls
                double fontsize = (osd_frame.cols * osd_frame.rows * 1.0) / (1100 * 1200);
                    cv::putText(osd_frame, text, cv::Point(1, 40), cv::FONT_HERSHEY_SIMPLEX, 0.8, cv::Scalar(255, 255, 255, 0), 2);
        // insert osd to vo
            kd_mpi_vo_chn_insert_frame(osd_id+3, &vf_info);
            printf("kd_mpi_vo_chn_insert_frame success \n");
Complete Code#
For detailed operations and running instructions, refer to Chapter 6. Here, the focus is on the code flow.
vi_vo.h
/* Copyright (c) 2023, Canaan Bright Sight Co., Ltd
 * Redistribution and use in source and binary forms, with or without
 * modification, are permitted provided that the following conditions are met:
 * 1. Redistributions of source code must retain the above copyright
 * notice, this list of conditions and the following disclaimer.
 * 2. Redistributions in binary form must reproduce the above copyright
 * notice, this list of conditions and the following disclaimer in the
 * documentation and/or other materials provided with the distribution.
 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
 * CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES,
 * INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
 * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
 * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
 * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
 * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
 * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
 * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
 * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
 * NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
 * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include <chrono>
#include <fstream>
#include <iostream>
#include <thread>
#include <atomic>
#include "mpi_sys_api.h"
/* vicap */
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <string.h>
#include <sys/mman.h>
#include "k_module.h"
#include "k_type.h"
#include "k_vb_comm.h"
#include "k_video_comm.h"
#include "k_sys_comm.h"
#include "mpi_vb_api.h"
#include "mpi_vicap_api.h"
#include "mpi_isp_api.h"
#include "k_vo_comm.h"
#include "mpi_vo_api.h"
#include "vo_test_case.h"
#include "k_connector_comm.h"
#include "mpi_connector_api.h"
#include "k_autoconf_comm.h"
/***************************unfixed:不同AI Demo可能需要修改*******************/
//不同的宏对应不同开发板
#if defined(CONFIG_BOARD_K230_CANMV)
#define vicap_install_osd                   (1)
#elif defined(CONFIG_BOARD_K230D_CANMV)
#define SENSOR_HEIGHT (720 / 2)
#define SENSOR_WIDTH (1280 / 2)
#define ISP_CHN0_WIDTH  (800)
#define ISP_CHN0_HEIGHT (480)
#define osd_width                           (480)
#define osd_height                          (800)
#elif defined(CONFIG_BOARD_K230_CANMV_01STUDIO)
#else
#define SENSOR_CHANNEL (3)     // isp通道数
#define SENSOR_HEIGHT (1280)  // isp高度,ai输入,竖屏
#define SENSOR_WIDTH (720)    // isp宽度,ai输入,竖屏
#define ISP_CHN0_WIDTH  (1088)//(1920)
#define ISP_CHN0_HEIGHT (1920)//(1080)
#define osd_width                           (1080)
#define osd_height                          (1920)
#endif
/***************************fixed:无需修改***********************************/
k_vb_config config;
k_vicap_dev vicap_dev;
k_vicap_chn vicap_chn;
k_vicap_dev_attr dev_attr;
k_vicap_chn_attr chn_attr;
k_mpp_chn vicap_mpp_chn;
k_mpp_chn vo_mpp_chn;
k_video_frame_info dump_info;
k_vo_draw_frame vo_frame = (k_vo_draw_frame) {
    1,
    16,
    16,
    128,
    128,
static k_vb_blk_handle block;
k_u32 g_pool_id;
int vo_creat_layer_test(k_vo_layer chn_id, layer_info *info)
    k_vo_video_layer_attr attr;
    // check layer
    if ((chn_id >= K_MAX_VO_LAYER_NUM) || ((info->func & K_VO_SCALER_ENABLE) && (chn_id != K_VO_LAYER0))
            || ((info->func != 0) && (chn_id == K_VO_LAYER2)))
        printf("input layer num failed \n");
        return -1 ;
    // check scaler
    // set offset
    attr.display_rect = info->offset;
    // set act
    attr.img_size = info->act_size;
    // sget size
    info->size = info->act_size.height * info->act_size.width * 3 / 2;
    //set pixel format
    attr.pixel_format = info->format;
    if (info->format != PIXEL_FORMAT_YVU_PLANAR_420)
        printf("input pix format failed \n");
        return -1;
    // set stride
    attr.stride = (info->act_size.width / 8 - 1) + ((info->act_size.height - 1) << 16);
    // set function
    attr.func = info->func;
    // set scaler attr
    attr.scaler_attr = info->attr;
    // set video layer atrr
    kd_mpi_vo_set_video_layer_attr(chn_id, &attr);
    // enable layer
    kd_mpi_vo_enable_video_layer(chn_id);
    k_u32 *virt_addr;
    k_s32 size;
        return K_FALSE;
    size = size + 4096;         // 强制4K ,后边得删了
        return K_FAILED;
    if (phys_addr == 0)
        return K_FAILED;
        return K_FAILED;
    return handle;
k_u32 vo_creat_osd_test(k_vo_osd osd, osd_info *info)
    k_vo_video_osd_attr attr;
    // set attr
    attr.global_alptha = info->global_alptha;
    if (info->format == PIXEL_FORMAT_ABGR_8888 || info->format == PIXEL_FORMAT_ARGB_8888)
        info->size = info->act_size.width  * info->act_size.height * 4;
        info->stride  = info->act_size.width * 4 / 8;
    else if (info->format == PIXEL_FORMAT_RGB_565 || info->format == PIXEL_FORMAT_BGR_565)
        info->size = info->act_size.width  * info->act_size.height * 2;
        info->stride  = info->act_size.width * 2 / 8;
    else if (info->format == PIXEL_FORMAT_RGB_888 || info->format == PIXEL_FORMAT_BGR_888)
        info->size = info->act_size.width  * info->act_size.height * 3;
        info->stride  = info->act_size.width * 3 / 8;
    else if(info->format == PIXEL_FORMAT_ARGB_4444 || info->format == PIXEL_FORMAT_ABGR_4444)
    else if(info->format == PIXEL_FORMAT_ARGB_1555 || info->format == PIXEL_FORMAT_ABGR_1555)
    else
        printf("set osd pixel format failed  \n");
    attr.stride = info->stride;
    kd_mpi_vo_set_video_osd_attr(osd, &attr);
    kd_mpi_vo_osd_enable(osd);
void sample_vicap_install_osd(void)
    osd_info osd;
    osd.act_size.width = osd_width ;
    osd.act_size.height = osd_height;
    osd.offset.x = 0;
    osd.offset.y = 0;
    osd.global_alptha = 0xff;
    // osd.global_alptha = 0x32;
    osd.format = PIXEL_FORMAT_ARGB_8888;//PIXEL_FORMAT_ARGB_4444; //PIXEL_FORMAT_ARGB_1555;//PIXEL_FORMAT_ARGB_8888;
    vo_creat_osd_test(osd_id, &osd);
void vo_osd_release_block(void)
    if(vicap_install_osd == 1)
        kd_mpi_vo_osd_disable(osd_id);
        kd_mpi_vb_release_block(block);
    k_u32 ret = 0;
    k_s32 connector_fd;
    k_connector_type connector_type = ST7701_V1_MIPI_2LAN_480X800_30FPS;
#else
    k_connector_type connector_type = HX8377_V2_MIPI_4LAN_1080X1920_30FPS;
#endif
    //connector get sensor info
    if (ret) {
        return ret;
    if (connector_fd < 0) {
        return K_ERR_VO_NOTREADY;
    // set connect power
    // connector init
    layer_info info;
    k_vo_layer chn_id = K_VO_LAYER1;
    #if defined(CONFIG_BOARD_K230D_CANMV)
    info.act_size.width = ISP_CHN0_HEIGHT;//1080;//640;//1080;
    info.act_size.height = ISP_CHN0_WIDTH;//1920;//480;//1920;
    info.func = K_ROTATION_90;
    #else
    // config lyaer
    info.act_size.width = ISP_CHN0_WIDTH;//ISP_CHN0_HEIGHT;//1080;//640;//1080;
    info.act_size.height = ISP_CHN0_HEIGHT;//ISP_CHN0_WIDTH;//1920;//480;//1920;
    info.func = 0;//K_ROTATION_180;////K_ROTATION_90;
    #endif
    info.global_alptha = 0xff;
    vo_creat_layer_test(chn_id, &info);
        sample_vicap_install_osd();
    //exit ;
static void sample_vicap_bind_vo(k_mpp_chn vicap_mpp_chn, k_mpp_chn vo_mpp_chn)
    k_s32 ret;
    if (ret) {
    return;
static void sample_vicap_unbind_vo(k_mpp_chn vicap_mpp_chn, k_mpp_chn vo_mpp_chn)
    k_s32 ret;
    ret = kd_mpi_sys_unbind(&vicap_mpp_chn, &vo_mpp_chn);
    if (ret) {
    return;
int vivcap_start()
    k_s32 ret = 0;
    k_u32 pool_id;
    k_vb_pool_config pool_config;
    printf("sample_vicap ...\n");
    sensor_type = OV_OV5647_MIPI_CSI2_1920X1080_30FPS_10BIT_LINEAR_V2;
    sensor_type = OV_OV5647_MIPI_1920X1080_30FPS_10BIT_LINEAR;
    #else
    sensor_type = IMX335_MIPI_2LANE_RAW12_2592X1944_30FPS_LINEAR;
    #endif
    config.comm_pool[0].blk_cnt = 4;
    #else
    #endif
    if (ret) {
        return ret;
    if (ret) {
        return ret;
    ret = kd_mpi_vb_init();
    if (ret) {
        return ret;
    printf("sample_vicap ...kd_mpi_vicap_get_sensor_info\n");
    // dwc_dsi_init();
    vo_layer_vdss_bind_vo_config();
        pool_config.blk_size = VICAP_ALIGN_UP((osd_width * osd_height * 4 * 2), VICAP_ALIGN_1K);
        pool_config.blk_cnt = 2;
        pool_id = kd_mpi_vb_create_pool(&pool_config);      // osd0 - 3 argb 320 x 240
        g_pool_id = pool_id;
        #else
        pool_config.blk_cnt = 4;
        #endif
        printf("--------aa--------------g_pool_id is %d pool_id is %d \n",g_pool_id, pool_id);
    if (ret) {
        return ret;
    dev_attr.acq_win.h_start = 0;
    dev_attr.acq_win.v_start = 0;
    #if defined (CONFIG_BOARD_K230_CANMV)  || defined(CONFIG_BOARD_K230_CANMV_V2) || defined(CONFIG_BOARD_K230D_CANMV) || defined(CONFIG_BOARD_K230_CANMV_01STUDIO)
    dev_attr.acq_win.width = ISP_INPUT_WIDTH;
    dev_attr.acq_win.height = ISP_INPUT_HEIGHT;
    #else
    dev_attr.acq_win.width = 2592;//SENSOR_HEIGHT;
    dev_attr.acq_win.height = 1944;//SENSOR_WIDTH;
    #endif
    if (ret) {
        return ret;
    chn_attr.out_win.h_start = 0;
    chn_attr.out_win.v_start = 0;
    #if defined(CONFIG_BOARD_K230_CANMV)  || defined(CONFIG_BOARD_K230_CANMV_V2) || defined(CONFIG_BOARD_K230D_CANMV) || defined(CONFIG_BOARD_K230_CANMV_01STUDIO)
    #else
    // chn_attr.crop_win = dev_attr.acq_win;
    chn_attr.crop_win.h_start = 768;
    chn_attr.crop_win.v_start = 16;
    chn_attr.crop_win.width = ISP_CHN0_WIDTH;
    chn_attr.crop_win.height = ISP_CHN0_HEIGHT;
    #endif
    if (ret) {
        return ret;
    #else
    #endif
    if (ret) {
        return ret;
    // set to header file database parse mode
    if (ret) {
        printf("sample_vicap, kd_mpi_vicap_set_database_parse_mode failed.\n");
        return ret;
    printf("sample_vicap ...kd_mpi_vicap_init\n");
    if (ret) {
        // goto err_exit;
    if (ret) {
        // goto err_exit;
    return ret;
int vivcap_stop()
    if (ret) {
        return ret;
    if (ret) {
        return ret;
    /*Allow one frame time for the VO to release the VB block*/
    if (ret) {
        return ret;
void yuv_rotate_90(char *des, char *src,int width,int height)
    int n = 0;
    int hw = width>>1;
    int hh = height>>1;
    int size = width * height;
    int hsize = size>>2;
    int pos = 0;
    for(int i = width-1;i >= 0;i--)
        pos = 0;
        for(int j= 0;j < height;j++)
            des[n++]= src[pos+i];
            pos += width;
main.cc
#include <iostream>
#include <thread>
#include <map>
#include <nncase/runtime/runtime_tensor.h>
#include "vi_vo.h"
using namespace nncase;
using cv::Mat;
using std::cerr;
using std::cout;
using std::endl;
using namespace std;
 * @brief Classification result structure
typedef struct cls_res
    float score; // Classification score
    string label; // Classification label result
} cls_res;
std::atomic<bool> isp_stop(false);
void video_proc_cls(char *argv[])
    vivcap_start();
    // osd set
    // alloc memory for sensor
    size_t paddr = 0;
    if (ret)
        std::abort();
    cout << "kmodel_path : " << kmodel_path << endl;
    // We have encapsulated the relevant implementation in ai_base.cc, here for simplicity
    // load model
    // inputs init
    // outputs init
    std::vector<std::string> labels = {"bocai", "changqiezi", "huluobo", "xihongshi", "xilanhua"};
    while (!isp_stop)
        cv::Mat ori_img;
            // Read a frame of image from the camera
            if (ret) {
                continue;
            // Map the DDR address of the current frame from the camera to the current system for access
            color_vec.clear();
        // pre_process
            cv::Mat rgb_img;
        // set kmodel input
        // kmodel run
        // post process
        results.clear();
            float sum = 0.0;
            int max_index;
            cls_res b;
                    // draw cls
                    for (int i = 0; i < results.size(); i++)
            // insert osd to vo
                kd_mpi_vo_chn_insert_frame(osd_id + 3, &vf_info);  // K_VO_OSD0
            if (ret) {
    vo_osd_release_block();
    vivcap_stop();
    // free memory
    ret = kd_mpi_sys_mmz_free(paddr, vaddr);
    if (ret)
        std::cerr << "free failed: ret = " << ret << ", errno = " << strerror(errno) << std::endl;
        std::abort();
    if (argc != 2)
        cout << "Model inference parameter explanation:"
             << "<kmodel_path>" << endl
             << "Options:" << endl
             << "  kmodel_path     Path of the Kmodel\n"
             << "\n"
             << endl;
        return -1;
    std::thread thread_isp(video_proc_cls, argv);
    while (getchar() != 'q')
        usleep(10000);
    isp_stop = true;
    thread_isp.join();
AI Inference Process Based on ulab (MicroPython)#
The K230 AI inference based on ulab (MicroPython) briefly introduces the process of video capture, image preprocessing (ulab), model inference, post-processing (ulab), and display using the MicroPython language.
Video Capture#
Video Capture: (Video Input, VI) is related to the camera. This subsection briefly introduces the overall process of setting up the camera, starting the camera, capturing a frame from the camera, and stopping the camera using MicroPython.
Create Camera (sensor) Output Buffer (VB): Already encapsulated in the C++ underlying implementation, no need to worry about it in the MicroPython implementation.
  • The other channel is for AI computation, with the output size set to (224, 224), and the image format as PIXEL_FORMAT_RGB_888_PLANAR;
from media.sensor import * # Import the sensor module to use sensor-related interfaces
from media.display import * # Import the display module to use display-related interfaces
from media.media import * # Import the media module to use media-related interfaces
from time import *
import gc
# Display output size
DISPLAY_HEIGHT = 1080
# Size of the RGB888P image obtained by AI
OUT_RGB888P_WIDTH = ALIGN_UP(1280, 16)
OUT_RGB888P_HEIGH = 720
def sensor_init():
    # Initialize and configure the sensor
    sensor = Sensor()
    sensor.reset()
    # Set mirror
    sensor.set_hmirror(False)
    # Set flip
    sensor.set_vflip(False)
    # Directly output channel 0 to the display VO, format is YUV420
    sensor.set_framesize(width = DISPLAY_WIDTH, height = DISPLAY_HEIGHT)
    sensor.set_pixformat(PIXEL_FORMAT_YUV_SEMIPLANAR_420)
    # Output channel 2 to AI for algorithm processing, format is RGB888
    sensor.set_framesize(width = OUT_RGB888P_WIDTH, height = OUT_RGB888P_HEIGH, chn=CAM_CHN_ID_2)
    sensor.set_pixformat(PIXEL_FORMAT_RGB_888_PLANAR, chn=CAM_CHN_ID_2)
    # Bind the output of channel 0 to the display
    # Set LT9611 display, default is 1920x1080
    Display.init(Display.LT9611, to_ide = True)
        # Initialize media
        # Start the sensor
        sensor.run()
        rgb888p_img = None
        while  True:
            # Capture camera data
            rgb888p_img = sensor.snapshot(chn=CAM_CHN_ID_2)
            # ************ After obtaining a frame of image, subsequent AI processing can be performed ************
        print(f"An error occurred during running: {e}")
    finally:
        # Stop the camera output
        sensor.stop()
        # Deinitialize the display device
        # Release media buffer
        gc.collect()
        nn.shrink_memory_pool()
    return 0
sensor_init()
Preprocessing#
from media.sensor import * # Import the camera module to use camera-related interfaces
from time import *
import nncase_runtime as nn # Import the nn module to use nn-related interfaces
import ulab.numpy as np # Import the np module to use np-related interfaces
import gc
def cls_test():
    print("cls_test start")
    # Initialize AI2D
    ai2d = nn.ai2d()
    # Set the input and output data format and data type for ai2d
    # Set resize preprocessing
    # Build preprocessing with input and output tensor shapes
    ai2d_builder = ai2d.build([1, 3, OUT_RGB888P_HEIGH, OUT_RGB888P_WIDTH], [1, 3, 224, 224])
    sensor = Sensor()
    sensor.reset()
    # Set mirror
    # Set flip
        # Initialize media
        # Start the sensor
        sensor.run()
        rgb888p_img = None
            # For RGB888 planar
                # Convert image to numpy.ndarray
                ai2d_input = rgb888p_img.to_numpy_ref()
                # Create tensor from numpy.ndarray
                ai2d_input_tensor = nn.from_numpy(ai2d_input)
                # Initialize preprocessing output
                data = np.ones((1, 3, 224, 224), dtype=np.uint8)
                # Convert numpy.ndarray to tensor
                ai2d_out = nn.from_numpy(data)
                # Execute preprocessing
                ai2d_builder.run(ai2d_input_tensor, ai2d_out)
                # Convert tensor to numpy.ndarray
                ai2d_out_np = ai2d_out.to_numpy()
                # Print preprocessing shape
                print(ai2d_out_np.shape)
    finally:
        sensor.stop()
        gc.collect()
        time.sleep(1)
    print("cls_test end")
    return 0
cls_test()
Note: For this classification model, it is necessary to first obtain the original image, resize the original image to (224, 224), and then feed it to the model. For MicroPython development, resizing can be achieved using the ai2d module.
We can also directly set the camera data resolution fed to the AI to (224, 224), as shown in the code below:
from time import *
import gc
OUT_RGB888P_WIDTH = ALIGN_UP(224, 16)
OUT_RGB888P_HEIGH = 224
def cls_test():
    sensor = Sensor()
    sensor.reset()
    # Set mirror
    # Set flip
        # Initialize media
        # Start the sensor
        sensor.run()
        rgb888p_img = None
            # For RGB888 planar
                input_img = rgb888p_img.to_numpy_ref()
                # Print shape
                print(input_img.shape)
    finally:
        sensor.stop()
        gc.collect()
        time.sleep(1)
    return 0
cls_test()
Inference#
from time import *
import gc
kmodel_path = "/sdcard/app/tests/ai_test_kmodel/veg_cls.kmodel"
def cls_test():
    # Initialize AI2D
    ai2d = nn.ai2d()
    # Initialize kpu
    kpu = nn.kpu()
    # Load the model
    kpu.load_kmodel(kmodel_path)
    sensor = Sensor()
    sensor.reset()
    # Set mirror
    # Set flip
        # Initialize media
        # Start the sensor
        sensor.run()
        rgb888p_img = None
        # Bind the output of ai2d preprocessing to the input of kmodel
        kpu.set_input_tensor(0, ai2d_out)
            # For RGB888 planar
                # Run kpu inference
                kpu.run()
                # Get the inference output tensor of kmodel, which may have multiple outputs, thus returning a list
                results = []
                    # Get the i-th output of kmodel
                    output_data = kpu.get_output_tensor(i)
                    result = output_data.to_numpy()
                    # Print shape
                    print(result.shape)
                    # Add to list
                    results.append(result)
                    del output_data
    finally:
        del ai2d_input_tensor
        del ai2d_out
        sensor.stop()
        gc.collect()
        time.sleep(1)
    return 0
cls_test()
Note: For tensor-type data, please manually release it after allocation.
Post-processing#
Perform post-processing on the model results. For example, in classification, apply softmax to the output first and then use argmax to get the class index.
from time import *
import gc
# Softmax function
def softmax(x):
    exp_x = np.exp(x - np.max(x))
    return exp_x / np.sum(exp_x)
def cls_test():
    # Initialize AI2D
    ai2d = nn.ai2d()
    # Initialize kpu
    kpu = nn.kpu()
    # Load the model
    sensor = Sensor()
    sensor.reset()
    # Set mirror
    # Set flip
        # Initialize media
        # Start the sensor
        sensor.run()
        rgb888p_img = None
            # For RGB888 planar
                # Run kpu inference
                kpu.run()
                results = []
                    # Add to list
                    del output_data
                # ****************** Post-processing ********************
                # softmax + argmax
                softmax_res = softmax(results[0][0])
                res_idx = np.argmax(softmax_res)
                # Print class index
                print(res_idx)
    finally:
        del ai2d_out
        sensor.stop()
        gc.collect()
        time.sleep(1)
    return 0
cls_test()
Display#
Display (Video Output, VO) and Display Related Settings. This section briefly introduces the overall process of display settings, resource release, and display overlay based on MicroPython.
  • Display Overlay: The display consists of 2 layers. The lower layer (original image layer) directly displays the camera output, while the upper layer (OSD layer) is used for drawing boxes, points, writing text, etc.
  • Resource Release: Release resources related to the display.
from media.sensor import *  # Import camera module to use camera-related interfaces
from media.display import *  # Import display module to use display-related interfaces
from media.media import *  # Import media module to use media-related interfaces
from time import *
import nncase_runtime as nn  # Import nn module to use nn-related interfaces
import ulab.numpy as np  # Import np module to use np-related interfaces
import gc
# Size of RGB888P image obtained by AI
labels = ["Spinach", "Elongated Eggplant", "Red Amaranth", "Carrot", "Tomato", "Broccoli"]
# Softmax function
def softmax(x):
def cls_test():
    # Initialize AI2D
    ai2d = nn.ai2d()
    # Set ai2d input and output data format and data type
    # Initialize kpu
    kpu = nn.kpu()
    # Load the model
    # Initialize and configure sensor
    sensor = Sensor()
    sensor.reset()
    # Set mirror
    # Set flip
    # Channel 0 directly to display VO, format YUV420
    sensor.set_framesize(width=DISPLAY_WIDTH, height=DISPLAY_HEIGHT)
    # Channel 2 for AI processing, format RGB888
    sensor.set_framesize(width=OUT_RGB888P_WIDTH, height=OUT_RGB888P_HEIGH, chn=CAM_CHN_ID_2)
    # Bind channel 0 output to VO
    sensor_bind_info = sensor.bind_info(x=0, y=0, chn=CAM_CHN_ID_0)
    Display.bind_layer(**sensor_bind_info, layer=Display.LAYER_VIDEO1)
    # Initialize LT9611 display, default 1920x1080
    Display.init(Display.LT9611, to_ide=True)
    # Create OSD image
        # Initialize media
        # Start sensor
        sensor.run()
        rgb888p_img = None
        # Bind ai2d preprocessing output to kmodel input, sharing the same tensor
            # for rgb888planar
                #*************************Preprocessing***********************
                #************************Model Inference**********************
                # Run kpu inference
                kpu.run()
                # Get kmodel output tensor, which may have multiple outputs, hence returned as a list
                results = []
                    # Append to results list
                    del output_data
                #******************Post-processing********************
                # softmax + argmax
                #******************Display*********************
                # Class name
                label = labels[res_idx]
                # Class score
                score = softmax_res[res_idx]
                # Draw text
                text = label + " " + str(score)
                # Clear osd_img
                osd_img.clear()
                # Draw text at position (5, 5), size 32, color (0, 255, 0)
                osd_img.draw_string_advanced(5, 5, 32, text, color=(0, 255, 0))
                Display.show_image(osd_img, 0, 0, Display.LAYER_OSD3)
    finally:
        del ai2d_out
        del kpu
        # Stop camera output
        sensor.stop()
        # Deinitialize display device
        # Deinitialize media buffer
        gc.collect()
        time.sleep(1)
    return 0
cls_test()
Resource Release#
The memory in the main core includes two parts: system memory and GC memory. The former is mainly used for models and some functions within the system, including camera and screen buffers, kmodel, and its inputs and outputs (mmz, released with del); the latter is memory allocated at the interpreter level and can be used for code variables (released with gc.collect()).
1. GC Resource Release:
#classification.py
import gc
def func_a():
    a = []
    for i in range(10000):
        a.append(i)
func_a()
print(gc.mem_free() / 1024 / 1024) #stack mem
print(gc.mem_alloc() / 1024 / 1024)
gc.collect()
2. System Memory Release:
The kmodel module part, kmodel’s input_tensor, output_tensor, and the kmodel itself are all memory allocated by mmz and need to be manually released.
del ai2d_out
del kpu
nn.shrink_memory_pool() # To avoid missing any `del`, traverse all kmodel-related memory and release them
3. Camera, Display, and Media Buffer Release:
sensor.stop()
Complete Code#
Here’s the complete translated code with comments explaining each step, including the encapsulation of AI development steps using classes located in /sdcard/app/libs. Please refer: AI Demo说明文档 — K230 CanMV 文档 (canaan-creative.com)
from time import *
import gc
# Softmax function
def softmax(x):
def cls_test():
    # Initialize AI2D
    ai2d = nn.ai2d()
    # Initialize kpu
    kpu = nn.kpu()
    # Load the model
    sensor = Sensor()
    sensor.reset()
    # Set mirror
    # Set flip
    # Create OSD image
        # Initialize media
        # Start sensor
        sensor.run()
        rgb888p_img = None
            # for rgb888planar
                # Run kpu inference
                kpu.run()
                results = []
                    del output_data
                # softmax + argmax
                # Class name
                # Class score
                # Draw text
                # Clear osd_img
                osd_img.clear()
    finally:
        del ai2d_out
        del kpu
        sensor.stop()
        gc.collect()
        time.sleep(1)
    return 0
cls_test()
