UVC API Manual#
The UVC module provides USB camera detection, configuration, and image capture functionality, supporting single-camera operation.
API Reference#
UVC.probe - Detect Camera#
Function Checks whether a USB camera is connected to the system (currently supports single-camera detection only).
Syntax
from media.uvc import UVC
plugin, devname = UVC.probe()
Return Values
Parameter
Type
plugin
bool
True if camera is detected, False otherwise
devname
str
Camera device information in “Manufacturer#Product” format
Example
plugin, devinfo = UVC.probe()
print(f"Camera detection: {'Connected' if plugin else 'Not connected'}, Device info: {devinfo}")
UVC.video_mode - Video Mode Operations#
Function Constructs or retrieves the current video mode configuration.
Syntax
# Get current mode
mode = UVC.video_mode()
# Create new configuration
mode = UVC.video_mode(width, height, format, fps)
Parameter
Type
int
Resolution width in pixels
int
Resolution height in pixels
format
int
Image format (see constant definitions)
fps
int
Frame rate in fps
Return Value Returns a uvc_video_mode object.
UVC.list_video_mode - List Supported Modes#
Function Retrieves all video modes supported by the camera.
Syntax
modes = UVC.list_video_mode()
Return Value Returns a list of supported uvc_video_mode objects.
Example
    print(f"Mode {i}: {mode.width}x{mode.height} {mode.format}@{mode.fps}fps")
UVC.select_video_mode - Select Video Mode#
Function Sets the camera output mode.
Syntax
Parameter
Type
uvc_video_mode
Video mode configuration to set
Return Values
Parameter
Type
succ
bool
True if setting was successful
actual_mode
uvc_video_mode
The actual mode that was applied
UVC.start - Start Video Stream#
Function Starts the camera video stream output.
Syntax
Parameter
Type
delay_ms
int
Delay in milliseconds to wait for UVC camera data output (default: 0)
cvt
bool
Whether to hardware-decode snapshot images to NV12 format (default: True)
Return Value Returns True if the stream started successfully.
UVC.stop - Stop Video Stream#
Function Stops the video stream and releases resources.
Syntax
UVC.stop()
UVC.snapshot - Capture Frame#
Function Captures a single frame from the video stream.
Syntax
frame = UVC.snapshot(timeout_ms=1000)
Parameter
Type
timeout_ms
int
Timeout in milliseconds for frame capture (default: 1000)
Return Value Returns image data in NV12 Frame format (if hardware decoding enabled) or JPEG/YUV422 format.
Data Structures#
uvc_video_mode Structure#
class uvc_video_mode:
    width: int    # Resolution width in pixels
    height: int   # Resolution height in pixels
    format: int   # Image format (see constants)
    fps: int      # Frame rate in fps
Constant Definitions#
Constant
Value
UVC.FORMAT_MJPEG
MJPG compressed format (recommended for low bandwidth)
UVC.FORMAT_UNCOMPRESS
YUV422 uncompressed format (requires higher bandwidth)
Best Practices#
Software Decoding Example#
import time, os, urandom, sys, gc
from media.display import *
from media.uvc import *
DISPLAY_HEIGHT = 480
# use lcd as display output
# init media manager
    plugin, dev = UVC.probe()
    if plugin:
UVC.start(cvt = False)
fps = time.clock()
    fps.tick()
    img = UVC.snapshot()
    if img is not None:
            img = img.to_rgb565()
            Display.show_image(img)
            img.__del__()
            gc.collect()
        except OSError as e:
            pass
    print(f"fps: {fps.fps()}")
# deinit display
UVC.stop()
time.sleep_ms(100)
# release media buffer
Hardware Decoding Example#
from nonai2d import CSC
    if plugin:
    time.sleep_ms(100)
UVC.start(cvt = True)
clock = time.clock()
    clock.tick()
    img = None
    while img is None:
        except:
            print("drop frame")
            continue
    img = csc.convert(img)
    img.__del__()
    gc.collect()
    print(f"fps: {clock.fps()}")
# deinit display
csc.destroy()
UVC.stop()
time.sleep_ms(100)
