TCP-Client Example Explanation#
Environment Preparation#
To ensure a smooth demonstration of TCP communication, we need to confirm that the following environment is correctly configured:
Hardware Connection#
  • Ensure that your CanMV development board and computer are connected to the same router or switch via an Ethernet cable to form a local area network.
  • Ensure the router or switch is working properly to guarantee network connection stability.
Disable Firewall#
  • To avoid the firewall blocking TCP communication, it is recommended to temporarily disable the computer’s firewall.
Tool Preparation#
Obtain IP Address#
  • Open the Command Prompt (CMD), enter ipconfig, and query and record the IP address of the computer’s network card for subsequent configuration and testing.
Client Code Analysis#
Import Necessary Libraries#
import network
import socket
  • network: Used for network interface operations, such as configuring IP addresses and checking network status.
  • socket: Provides the Socket interface for network communication.
  • time: Provides functions related to time, such as delay (sleep).
Define Client Function#
def client():
    # ... (subsequent code)
  • The client function contains the main logic of the TCP client.
Configure Network Interface#
    if is_wlan:
        sta = network.WLAN(0)
        print(sta.status())
        print(sta.ifconfig())
        ip = sta.ifconfig()[0]
        return ip
        a = network.LAN()
        if not a.active():
        a.ifconfig("dhcp")
        print(a.ifconfig())
        ip = a.ifconfig()[0]
        return ip
Configure the network interface based on the parameters, as follows:
  1. WLAN Mode:
    • If is_wlan=True, configure the wireless network interface (WLAN) and connect to the Wi-Fi with SSID “TEST” and password “12345678”.
    • Wait and check if a valid IP address is assigned, then return the IP.
  2. LAN Mode:
    • If is_wlan=False, configure the wired network interface (LAN), enable DHCP to automatically obtain an IP address, and return the IP.
Create Socket#
  • Create a Socket object using IPv4 (AF_INET) and TCP (SOCK_STREAM) protocol.
Obtain Server Address and Port#
addr = ai[0][-1]  # Extract address and port
  • Use getaddrinfo to obtain the server’s IP address and port number, and extract the address information.
Connect to Server#
    s.connect(addr)
    s.close()
    print("Connection error:", e)
    return
  • Try to connect to the server. If the connection fails, print the error message and close the connection.
Send Data#
for i in range(10):
    print("Sending:", message)
    s.sendall(message.encode())
    time.sleep(0.2)
  • Send 10 test messages in a loop, using the sendall method to ensure each message is completely sent.
Close Socket#
s.close()
  • Close the Socket to release resources, indicating the client has ended the connection.
Complete Code Example#
import network
import socket
import os, time
    if is_wlan:
        print(sta.status())
        return ip
        a = network.LAN()
        if not a.active():
        a.ifconfig("dhcp")
        print(a.ifconfig())
        return ip
def client():
    network_use_wlan(True)
    print("Address infos:", ai)
    addr = ai[0][-1]
    print("Connecting to:", addr)
        s.connect(addr)
        s.close()
        return
    for i in range(10):
        time.sleep(0.2)
    s.close()
    print("Connection closed.")
client()
Running Results and Operation Instructions#
  1. Open the NetAssist Network Debugging Assistant, configure it as a TCP server, and wait for the connection:
../../_images/image-20240722152102440.png
  1. Modify the server’s IP and port number in the code:
  1. Run the client code, and NetAssist will display the messages sent by the client:
../../_images/image-20240722151843380.png
