UVC API Manual#
The UVC module provides USB camera detection, configuration, and image capture functionality, supporting single-camera operation.
API Reference#
UVC.probe - Detect Camera#
Function Checks whether a USB camera is connected to the system (currently supports single-camera detection only).
Syntax
from media.uvc import UVC
plugin, devname = UVC.probe()
Return Values
Parameter |
Type |
plugin |
bool |
True if camera is detected, False otherwise |
devname |
str |
Camera device information in “Manufacturer#Product” format |
Example
plugin, devinfo = UVC.probe()
print(f"Camera detection: {'Connected' if plugin else 'Not connected'}, Device info: {devinfo}")
UVC.video_mode - Video Mode Operations#
Function Constructs or retrieves the current video mode configuration.
Syntax
# Get current mode
mode = UVC.video_mode()
# Create new configuration
mode = UVC.video_mode(width, height, format, fps)
Parameter |
Type |
int |
Resolution width in pixels |
int |
Resolution height in pixels |
format |
int |
Image format (see constant definitions) |
fps |
int |
Frame rate in fps |
Returns a uvc_video_mode object.
UVC.list_video_mode - List Supported Modes#
Function Retrieves all video modes supported by the camera.
Syntax
modes = UVC.list_video_mode()
Returns a list of supported uvc_video_mode objects.
Example
print(f"Mode {i}: {mode.width}x{mode.height} {mode.format}@{mode.fps}fps")
UVC.select_video_mode - Select Video Mode#
Function Sets the camera output mode.
Syntax
Parameter |
Type |
mode |
uvc_video_mode |
Video mode configuration to set |
Return Values
Parameter |
Type |
succ |
bool |
True if setting was successful |
actual_mode |
uvc_video_mode |
The actual mode that was applied |
UVC.start - Start Video Stream#
Function Starts the camera video stream output.
Syntax
Parameter |
Type |
delay_ms |
int |
Delay in milliseconds to wait for UVC camera data output (default: 0) |
cvt |
bool |
Whether to hardware-decode snapshot images to NV12 format (default: True) |
Return Value Returns True if the stream started successfully.
UVC.stop - Stop Video Stream#
Function Stops the video stream and releases resources.
Syntax
UVC.stop()
UVC.snapshot - Capture Frame#
Function Captures a single frame from the video stream.
Syntax
frame = UVC.snapshot(timeout_ms=1000)
Parameter |
Type |
timeout_ms |
int |
Timeout in milliseconds for frame capture (default: 1000) |
Return Value Returns image data in NV12 Frame format (if hardware decoding enabled) or JPEG/YUV422 format.
Data Structures#
uvc_video_mode Structure#
class uvc_video_mode:
width: int # Resolution width in pixels
height: int # Resolution height in pixels
format: int # Image format (see constants)
fps: int # Frame rate in fps
Constant Definitions#
Constant |
Value |
UVC.FORMAT_MJPEG |
1 |
MJPG compressed format (recommended for low bandwidth) |
UVC.FORMAT_UNCOMPRESS |
2 |
YUV422 uncompressed format (requires higher bandwidth) |
Recommended Workflow#
Detect camera (
probe())List supported modes (
list_video_mode())Select an appropriate mode (
select_video_mode())Start video stream (
start())Capture images (
snapshot())Stop video stream (
stop())
Best Practices#
Software Decoding Example#
from media.display import *
from media.uvc import *
DISPLAY_HEIGHT = 480
# Initialize LCD display
# Initialize media manager
# Detect camera
plugin, dev = UVC.probe()
if plugin:
print(f"Detected USB Camera: {dev}")
# Set video mode
print(f"Mode selection: {'Success' if succ else 'Failed'}, Actual mode: {mode}")
# Start video stream
UVC.start()
img = UVC.snapshot()
if img is not None:
img = img.to_rgb565() # Convert to RGB565 format
Display.show_image(img) # Display image
finally:
# Cleanup resources
UVC.stop()
time.sleep_ms(100)
Hardware Decoding Example#
from nonai2d import CSC # Hardware Color Space Converter
# Initialize hardware color space converter
# Detect camera
if plugin:
time.sleep_ms(100)
# Set video mode
# Start video stream with hardware decoding
UVC.start(cvt=True)
clock = time.clock() # For FPS calculation
clock.tick()
if img is not None:
img = csc.convert(img) # Hardware color space conversion
print(f"Current FPS: {clock.fps()}")
finally:
# Cleanup resources
csc.destroy()
UVC.stop()
time.sleep_ms(100)
