How to Flash Firmware#
This document describes how to flash firmware to a K230 development board via USB. It applies to both K230 RTOS firmware and CanMV/MicroPython firmware. Whether the firmware runs RTOS or MicroPython does not change how to enter USB flashing mode or use the flashing tool.
All tools flash through K230 USB Boot Device. When SDCARD is selected as the target medium, the SD card is still written through the development board’s USB interface.
Quick Start#
Tool Selection#
Use Case
Tool
Initial flashing and daily use
K230BurningTool
Graphical interface, recommended for most users; also supports flashing multiple devices simultaneously
Terminal or CI automation
k230_flash
C++ command-line tool, no Python environment required
Python scripting or secondary development
k230_flash_py
Provides a Python command-line tool and API
Ordinary users can simply use K230BurningTool. Command-line or Python versions are only needed for unattended flashing, CI integration, or secondary development; please refer to the project links in the table for specific usage instructions.
K230BurningTool Shortest Workflow#
  1. Prepare firmware in *.kdimg format or an unpacked *.img file that matches the development board model, memory configuration, and boot medium.
  2. Download and launch the tool from the K230 Tool Download Page or K230BurningTool Releases.
  3. Hold down the development board’s BOOT button, connect the USB cable, and power on. Release BOOT after the computer detects the device.
  4. If Windows cannot recognize K230 USB Boot Device, use Zadig to install the WinUSB driver for the device.
  5. Open the firmware in the tool, select the correct target medium, and click Start and Confirm in order; after completion, reset the development board or power it on again.
If you can complete the steps above, you do not need to read the remaining operational details. Continue reading below when you need to confirm the image format, target medium, driver, or complete GUI steps.
Detailed Description#
Flashing Preparation#
Before starting, please prepare firmware that matches the development board model, memory configuration, and boot medium:
  • When compiling with the SDK, the image is usually located in the output/<defconfig>/images/ directory.
  • When using CanMV/MicroPython, you can use an image compiled with the SDK or the corresponding firmware provided by the development board vendor.
Image Format#
  • *.kdimg: Contains partition information; it is recommended to use K230BurningTool for direct flashing.
  • *.img, *.bin: Raw images; K230BurningTool supports flashing both.
  • *.gz, *.tgz, *.zip: CanMV/MicroPython firmware may be released as compressed archives; decompress it before using K230BurningTool.
The same development board may provide both RTOS and CanMV/MicroPython firmware. Please verify the firmware name before flashing, and do not write firmware for other board models or other memory (voltage) configurations to the device.
Target Media#
The commonly used firmware boot media for K230 are as follows:
  • EMMC: Connected to the eMMC of the K230.
  • SDCARD: Connected to the SD card of the K230.
  • SPI_NAND: NAND Flash connected to the SPI bus.
  • SPI_NOR: NOR Flash connected to the SPI bus.
Before flashing, please confirm the target media based on the development board schematic or board documentation. If the wrong one is selected, the tool usually reports Device Can't find Medium as Configured.
In K230BurningTool, when the target is eMMC, SD card, SPI NAND, or SPI NOR, select EMMC, SDCARD, SPI_NAND, or SPI_NOR, respectively.
Please use a USB cable that supports data transfer, ensure stable power supply during flashing, and do not unplug the device or storage media.
If an SD Card/TF Card is used, it needs to be inserted into the board and confirmed to be properly seated (merely placing it in the slot is not sufficient).
Entering USB Flashing Mode#
It is recommended to perform these steps while the development board is powered off:
  1. Press and hold the BOOT button on the development board.
  2. Connect the development board to the computer using a USB cable and power it on.
  3. Release the BOOT button after the computer detects the device.
If the development board is already powered on, you can also follow the steps below:
  1. Press and hold the BOOT button.
  2. Press the RESET button.
  3. Release the RESET button.
  4. Finally, release the BOOT button.
After successfully entering flashing mode, K230 USB Boot Device will appear in Windows Device Manager. The USB VID of this device is 29f1, and the PID is 0230.
Install USB Driver#
Windows#
If Device Manager does not recognize K230 USB Boot Device, you need to install the WinUSB driver when using it for the first time:
  1. Download and run Zadig.
  2. Select Options > List All Devices.
  3. Select K230 USB Boot Device in the device list. The device may also appear as Unknown Device; in this case, verify VID 29f1 and PID 0230.
  4. Select WinUSB under Driver. If it is already installed, you can choose to reinstall it.
  5. Click Install Driver and wait for the installation to complete.
  6. Unplug and reconnect the device, and confirm that Device Manager displays K230 USB Boot Device (WinUSB).
zadig
Install the WinUSB driver only for K230 USB Boot Device. Do not modify the CanMV device driver displayed during normal operation, as this may affect USB communication in CanMV IDE or MicroPython.
Linux#
Linux typically does not require additional drivers. If a regular user does not have USB access permission, create /etc/udev/rules.d/99-k230.rules with the following content:
SUBSYSTEM=="usb", ATTRS{idVendor}=="29f1", ATTRS{idProduct}=="0230", MODE="0666"
Reload the rules, then unplug and reconnect the development board:
sudo udevadm control --reload-rules
sudo udevadm trigger
macOS#
macOS usually requires no additional configuration. If the tool indicates that libusb is missing, you can install it using Homebrew:
brew install libusb
Frequently Asked Questions#
The tool cannot detect the development board#
  • Enter USB flashing mode again by following the BOOT + power-on sequence.
  • Windows users should confirm that the device uses the WinUSB driver and verify VID 29f1 and PID 0230.
  • Try a different USB cable, USB port, or computer that supports data transfer.
  • Linux users should check the udev rules; they can also temporarily run the command using sudo to determine whether it is a permissions issue.
Prompt Timeout for Waiting Device Plugin#
The tool did not detect a device in BootROM mode within the waiting period. Press and hold BOOT, power on again, and start flashing once more.
Message Device Can't find Medium as Configured#
  • Check whether the selected target medium matches the development board hardware.
  • When flashing the SD card, power off, reinsert the SD card securely, and try again.
Flashing succeeds but the development board cannot boot#
  • Confirm that the image matches the current development board model, memory configuration, and runtime environment (RTOS or CanMV/MicroPython).
  • Confirm that the boot medium matches the target medium selected during flashing.
  • When using an SD card, reinsert the card or replace it with a reliable SD card.
  • Reset the development board or power it off and back on.
