Image Compilation#
Pre-built images can be downloaded from the K230 Linux SDK Image Center.
The K230 Linux SDK is a Buildroot-based Linux image build kit. This document provides two build methods:
  • Direct Native Compilation: Manually set up the environment on Ubuntu
  • Build with Docker: No need to install any build dependencies, one command completes the build
Direct Native Compilation#
This SDK compilation has only been verified on ubuntu 20.04, 22.04, 24.04, other versions may have issues
Get the Code#
git clone --depth=1 git@github.com:kendryte/k230_linux_sdk.git  #If github is unstable, replace with git clone --depth=1 git@gitee.com:kendryte/k230_linux_sdk.git
# git clone --depth=1 git@gitee.com:kendryte/k230_linux_sdk.git
cd k230_linux_sdk
Install Cross Toolchain#
sudo make toolchain_and_depend
This command installs GCC and the dependency packages required by the SDK. For details, see tools/install_toolchain_and_depend.sh.
Install ILP32 Toolchain (Optional)#
Only required for the k230d_canmv_ilp32_defconfig configuration:
wget -c https://github.com/ruyisdk/riscv-gnu-toolchain-rv64ilp32/releases/download/2024.06.25/riscv64ilp32-elf-ubuntu-22.04-gcc-nightly-2024.06.25-nightly.tar.gz
mkdir -p /opt/toolchain/riscv64ilp32-elf-ubuntu-22.04-gcc-nightly-2024.06.25/
tar -xvf riscv64ilp32-elf-ubuntu-22.04-gcc-nightly-2024.06.25-nightly.tar.gz \
    -C /opt/toolchain/riscv64ilp32-elf-ubuntu-22.04-gcc-nightly-2024.06.25/
Build#
The build consists of three steps, executed in order:
  1. make <defconfig>: Select the build configuration; this only needs to be done once. See the configuration files in the buildroot-overlay/configs/ directory
  2. make source: Download the open-source software archives required by the configuration (optional; this step can be skipped if the source packages have already been prepared manually)
  3. make: Perform the build
The reference commands are as follows:
make k230d_canmv_defconfig && make source && make            # k230d canmv 镜像(内核和根文件系统均为 64 位)
# make k230_canmv_01studio_defconfig && make source && make  # 01Studio 板子
# make k230_canmv_defconfig && make source && make           # k230 canmv 镜像
# make k230d_canmv_ilp32_defconfig && make source && make    # k230d canmv 32 位根文件系统
Build Output#
output/xxx_defconfig/images/sysimage-sdcard.img.gz
Need to decompress before flashing.
Building with Docker#
Use the preconfigured k230-builder image, which includes all toolchains and build dependencies. The only prerequisite is installing Docker.
Prerequisites#
  • Install Docker
    # Ubuntu/Debian
    sudo apt install docker.io
    sudo usermod -aG docker $USER && newgrp docker
    For other systems, refer to the official Docker documentation.
  • Configure Git user information
    git config --global user.email "you@example.com"
    git config --global user.name "Your Name"
  • Configure SSH keys (if cloning via SSH, optional)
Install the k230 command#
curl -fsSL https://www.kendryte.com/misc/install.sh | bash
source ~/.bashrc
After installation, run k230 pull to pull the Docker image (first time depends on network, approximately 1GB+).
Quick Start#
# 1) Clone the code
# Or clone from GitHub
# git clone --depth=1 git@github.com:kendryte/k230_linux_sdk.git
cd k230_linux_sdk
# 2) Pull the Docker image
k230 pull
# 3) Download toolchains (only needed the first time)
k230 download-toolchains TC2
# 4) Build (the CONF parameter specifies the configuration name)
k230 make k230_canmv_defconfig
# 5) Build
k230 make
After the build completes, the image output is in the output/<conf>/images/ directory.
Building ILP32 (32-bit Root Filesystem)#
The ILP32 configuration requires downloading the TC4 toolchain additionally:
k230 download-toolchains TC4
k230 make k230d_canmv_ilp32_defconfig
k230 make
Common Commands#
k230 list-toolchains                      # List available toolchains
k230 download-toolchains TC4              # Download the ILP32 toolchain (optional)
k230 make CONF=k230_canmv_defconfig       # Build with the specified configuration
k230 bash                                 # Enter the container terminal
k230 pull                                 # Update the k230-builder image
For available configuration names, see the buildroot-overlay/configs/ directory in the source code.
Git and SSH#
k230 automatically mounts the host’s ~/.ssh and ~/.gitconfig into the container, so git clone works directly without additional configuration.
Frequently Asked Questions#
k230 command not found#
Run source ~/.bashrc or re-login to the terminal. Make sure ~/.local/bin is in $PATH.
Toolchain download failure#
The toolchains are stored in the Docker Volume k230_toolchains. The initial download is large. If the network is unstable, you can download in batches:
k230 download-toolchains TC2     # Download TC2 first
k230 download-toolchains TC4     # Then download TC4
Docker permission denied#
newgrp docker
