TCP-Client Example Explanation#
Environment Preparation#
To ensure a smooth demonstration of TCP communication, we need to confirm that the following environment is correctly configured:
Hardware Connection#
Ensure that your CanMV development board and computer are connected to the same router or switch via an Ethernet cable to form a local area network.
Ensure the router or switch is working properly to guarantee network connection stability.
Disable Firewall#
To avoid the firewall blocking TCP communication, it is recommended to temporarily disable the computer’s firewall.
Tool Preparation#
Download and install NetAssist Network Debugging Assistant as a network communication testing tool to help send and receive network data.
Obtain IP Address#
Open the Command Prompt (CMD), enter
ipconfig, and query and record the IP address of the computer’s network card for subsequent configuration and testing.
Client Code Analysis#
Import Necessary Libraries#
import network
import socket
network: Used for network interface operations, such as configuring IP addresses and checking network status.
socket: Provides the Socket interface for network communication.
time: Provides functions related to time, such as delay (
sleep).
Define Client Function#
def client():
# ... (subsequent code)
The
clientfunction contains the main logic of the TCP client.
Configure Network Interface#
if is_wlan:
sta = network.WLAN(0)
print(sta.status())
print(sta.ifconfig())
ip = sta.ifconfig()[0]
return ip
a = network.LAN()
if not a.active():
a.ifconfig("dhcp")
print(a.ifconfig())
ip = a.ifconfig()[0]
return ip
Configure the network interface based on the parameters, as follows:
WLAN Mode:
If
is_wlan=True, configure the wireless network interface (WLAN) and connect to the Wi-Fi with SSID “Canaan” and password “Canaan314”.Wait and check if a valid IP address is assigned, then return the IP.
LAN Mode:
If
is_wlan=False, configure the wired network interface (LAN), enable DHCP to automatically obtain an IP address, and return the IP.
Create Socket#
Create a Socket object using IPv4 (
AF_INET) and TCP (SOCK_STREAM) protocol.
Obtain Server Address and Port#
addr = ai[0][-1] # Extract address and port
Use
getaddrinfoto obtain the server’s IP address and port number, and extract the address information.
Connect to Server#
s.connect(addr)
s.close()
print("Connection error:", e)
return
Try to connect to the server. If the connection fails, print the error message and close the connection.
Send Data#
for i in range(10):
print("Sending:", message)
s.sendall(message.encode())
time.sleep(0.2)
Send 10 test messages in a loop, using the
sendallmethod to ensure each message is completely sent.
Close Socket#
s.close()
Close the Socket to release resources, indicating the client has ended the connection.
Complete Code Example#
import network
import socket
import os, time
if is_wlan:
print(sta.status())
return ip
a = network.LAN()
if not a.active():
a.ifconfig("dhcp")
print(a.ifconfig())
return ip
def client():
network_use_wlan(True)
print("Address infos:", ai)
addr = ai[0][-1]
print("Connecting to:", addr)
s.connect(addr)
s.close()
return
for i in range(10):
time.sleep(0.2)
s.close()
print("Connection closed.")
client()
Running Results and Operation Instructions#
Open the NetAssist Network Debugging Assistant, configure it as a TCP server, and wait for the connection:
Modify the server’s IP and port number in the code:
Run the client code, and NetAssist will display the messages sent by the client:
