Machine Module API Documentation#
The machine module contains functions related to specific hardware boards. Most functions in this module allow direct and unrestricted access to and control of hardware components on the system. Improper use may lead to motherboard malfunction, system crashes, or even hardware damage in extreme cases.
API Introduction#
reset Method#
machine.reset()
Immediately resets the SoC (System on Chip).
bootloader Method#
machine.bootloader()
Enter the boot loader.
mem_copy Method#
machine.mem_copy(dst, src, size)
Copies a specified amount of data from the source memory address to the destination memory address.
  • dst: Destination address.
  • src: Source address.
  • size: Number of bytes to copy.
temperature Method#
temp = machine.temperature()
Get chip temperature from tsensor.
Temperature.
chipid Method#
chipid = machine.chipid()
get chip ID
bytearray, lenght 32.
