AI Demo Documentation
Contents
AI Demo Documentation#
AI Demo Application#
The K230 supports a wide range of AI applications. To facilitate user trial experiences, the CanMV K230 image comes with several built-in AI Demo applications. These are categorized into single-model and multi-model applications, covering various fields such as object, face, hand, body, license plate, OCR, audio (KWS, TTS), and more. Users can easily run these applications by opening the source code with CanMV IDE. The source code for AI Demo applications is located in the /CanMV/sdcard/examples/05-AI-Demo directory. Below is the list of AI Demo applications; note that some demos cannot run on the K230D chip due to memory limitations. Please refer to the compatibility list.
Demo Name
Scene
Task Type
K230
K230D
body_seg
Human body parts segmentation
Single model task
dynamic_gesture
Dynamic gesture recognition
Multi-model task
eye_gaze
Watching estimate
Multi-model task
face_detection
Face detection
Single model task
face_landmark
Key parts of the face
Multi-model task
face_mesh
Face 3D mesh
Multi-model task
face_parse
Face analysis
Multi-model task
face_pose
Face posture
Multi-model task
face_registration
Face registration
Multi-model task
face_recognition
Face recognition
Multi-model task
face_registration_lite
Lightweight face registration
Multi-model task
face_recognition_lite
Lightweight face recognition
Multi-model task
Falldown_detection
Fall detection
Single model task
finger_guessing
Rock-scissors game
Multi-model task
hand_detection
Palm detection
Single model task
hand_keypoint_class
Key points classification of palm
Multi-model task
hand_keypoint_detection
Palm key point detection
Multi-model task
hand_recognition
Gesture recognition
Multi-model task
keyword_spotting
Keyword awakening
Single model task
multi_kws
Multi-command keyword wake up
Single model task
licence_det
License plate inspection
Single model task
licence_det_rec
License plate recognition
Multi-model task
nanotracker
Single-target tracking
Multi-model task
object_detect_yolov8n
yolov8n target detection
Single model task
ocr_det
OCR detection
Single model task
ocr_rec
OCR recognition
Multi-model task
person_detection
Human body test
Single model task
person_kp_detect
Human key points detection
Multi-model task
puzzle_game
Jigsaw puzzle game
Multi-model task
segment_yolov8n
yolov8 segmentation
Single model task
self_learning
Self-study
Single model task
space_resize
Local amplifier
Multi-model task
tts_zh
Chinese text to pronunciation
Multi-model task
yolo11n_obb
yolo11n Oriented Bounding Boxes
Single model task
yolov8n_obb
yolov8n Oriented Bounding Boxes
Single model task
To run the above demos on the K230D chip development board, you need to change the display_mode in __main__ to lcd to adapt the display output, and also reduce the resolution as per the comments. Some demos cannot run on the K230D, see the table above for details.
AI Demo Development Framework Introduction#
AI Demo Development Framework#
To help users simplify the development of AI components, we have built a supporting AI development framework based on the API interface provided by K230_CanMV. The framework structure is shown in the diagram below:
The Camera outputs two streams of images by default: one in YUV420SP format (Sensor.YUV420SP) is directly provided to the Display for display; the other in RGBP888 format (Sensor.RGBP888) is used for AI processing. The AI is mainly responsible for the pre-processing, inference, and post-processing workflow of tasks. After processing, the results are drawn on the OSD image instance and sent to the Display for overlay display.
The PipeLine process encapsulation mainly simplifies the development process of visual tasks. You can use ‘get_frame’ to get a frame for machine vision processing; if you want to customize the AI process, refer to face_detection. For audio-related AI, refer to the keyword_spotting and tts_zh examples in the demo.
Interface Encapsulation#
For user convenience, we have encapsulated common functions for obtaining images from the Camera, AI2D pre-processing, and kmodel model inference based on the framework above. For encapsulated interfaces, please refer to: AI Demo API
Application Methods and Examples#
Users can write custom task classes inheriting from AIBase according to specific AI scenarios. Tasks can be divided into four categories: single-model tasks, multi-model tasks, custom pre-processing tasks, and no pre-processing tasks. Different tasks require different code implementations, as shown in the diagram below:
Different Task Types
Introduction to different tasks:
Task Type
Task Description
Code Description
Single-Model Task
This task has only one model, focusing on the model’s pre-processing, inference, and post-processing. Pre-processing uses Ai2d, possibly with one or multiple Ai2d instances. Post-processing is customized based on the scenario.
Write a custom task class, focusing on config_preprocess, postprocess, and other methods like draw_result. If multiple Ai2d instances are used, override preprocess to set the computation process of pre-processing stages.
Custom Pre-Processing Task
This task has one model, focusing on pre-processing, inference, and post-processing. Pre-processing does not use Ai2d; it can be customized with ulab.numpy. Post-processing is customized based on the scenario.
Write a custom task class, focusing on preprocess, postprocess, and other methods like draw_result.
No Pre-Processing Task
This task has one model and requires no pre-processing. Focus on inference and post-processing. Usually part of a multi-model task, using the output of the previous model as input. Post-processing is customized based on needs.
Write a custom task class, focusing on run (the entire inference process, including preprocess, inference, postprocess), postprocess, and other methods like draw_results.
Multi-Model Task
This task includes multiple models, possibly in series or other combinations. Each model is essentially one of the first three types, unified in a complete task class.
Write multiple sub-model task classes. Different sub-model tasks refer to the first three task definitions. Different tasks focus on different methods. Write a multi-model task class to unify sub-model task classes for the entire scenario.
Single-Model Task#
The pseudocode structure for a single-model task is as follows:
from libs.AI2D import Ai2d
from libs.Utils import *
import nncase_runtime as nn
import ulab.numpy as np
import image
import gc
import sys
# Custom AI task class, inheriting from AIBase
class MyAIApp(AIBase):
        # Call the constructor of the base class
        # Model file path
        # Model input resolution
        # Image resolution from sensor to AI, align width to 16
        # Display resolution, align width to 16
        # Enable debug mode
        self.debug_mode = debug_mode
        # Instantiate Ai2d for model pre-processing
        self.ai2d = Ai2d(debug_mode)
        # Set input and output format and type for Ai2d
    # Configure pre-processing operations, using resize here. Ai2d supports crop/shift/pad/resize/affine. See /sdcard/libs/AI2D.py for code.
            # Initialize ai2d pre-processing configuration, default to sensor size to AI, can modify input size by setting input_image_size
            # Configure resize pre-processing method
            # Build pre-processing workflow
    # Customize post-processing for the current task, results is a list of model output arrays, need to override based on actual task
           pass
    # Draw results on the screen, need to write according to the task
            pass
    # Display mode, default "hdmi", can choose "hdmi" or "lcd"
    display_mode="hdmi"
    if display_mode=="hdmi":
        display_size=[1920,1080]
        display_size=[800,480]
    # Set model path, replace with the current task model
    rgb888p_size = [1920, 1080]
    ###### Other Parameters ########
    # Initialize PipeLine for image processing workflow
    pl.create()  # Create PipeLine instance
    # Initialize custom AI task instance
    my_ai.config_preprocess()  # Configure pre-processing
        os.exitpoint()                      # Check for exit signal
        with ScopedTiming("total",1):
            img = pl.get_frame()            # Get current frame data
            res = my_ai.run(img)            # Infer current frame
            my_ai.draw_result(pl, res)      # Draw result
            pl.show_image()                 # Show result
            gc.collect()                    # Garbage collection
    my_ai.deinit()                          # Deinitialize
    pl.destroy()                            # Destroy PipeLine instance
Below is an example code for face detection:
import ujson
from time import *
import utime
import image
import random
import gc
import sys
import aidemo
#Custom Face Detection Class, inheriting from the AIBase class
        super().__init__(kmodel_path, model_input_size, rgb888p_size, debug_mode)  # Call the constructor of the base class
        self.kmodel_path = kmodel_path  # Model file path
        self.model_input_size = model_input_size  # Model input resolution
        self.confidence_threshold = confidence_threshold  # Confidence threshold
        self.nms_threshold = nms_threshold  # NMS (Non-Maximum Suppression) threshold
        self.anchors = anchors  # Anchor data, used for object detection
        self.rgb888p_size = [ALIGN_UP(rgb888p_size[0], 16), rgb888p_size[1]]  # Image resolution from sensor to AI, aligned to 16 in width
        self.display_size = [ALIGN_UP(display_size[0], 16), display_size[1]]  # Display resolution, aligned to 16 in width
        self.debug_mode = debug_mode  # Whether to enable debug mode
        self.ai2d = Ai2d(debug_mode)  # Instantiate Ai2d for model pre-processing
        self.ai2d.set_ai2d_dtype(nn.ai2d_format.NCHW_FMT, nn.ai2d_format.NCHW_FMT, np.uint8, np.uint8)  # Set input and output format and type for Ai2d
    # Configure pre-processing operations, using pad and resize here. Ai2d supports crop/shift/pad/resize/affine. See the code in /sdcard/app/libs/AI2D.py.
        with ScopedTiming("set preprocess config", self.debug_mode > 0):  # Timer, enabled if debug_mode is greater than 0
            ai2d_input_size = input_image_size if input_image_size else self.rgb888p_size  # Initialize ai2d pre-processing configuration, default to sensor size to AI, can modify input size by setting input_image_size
            top, bottom, left, right = self.get_padding_param()  # Get padding parameters
            self.ai2d.pad([0, 0, 0, 0, top, bottom, left, right], 0, [104, 117, 123])  # Pad the edges
            self.ai2d.resize(nn.interp_method.tf_bilinear, nn.interp_mode.half_pixel)  # Resize the image
            self.ai2d.build([1,3,ai2d_input_size[1],ai2d_input_size[0]],[1,3,self.model_input_size[1],self.model_input_size[0]])  # Build the pre-processing workflow
    # Customize post-processing for the current task, results is a list of model output arrays, using the face_det_post_process interface from the aidemo library here
            if len(post_ret) == 0:
                return post_ret
                return post_ret[0]
    # Draw detection results on the screen
            if dets:
                pl.osd_img.clear()  # Clear the OSD image
                for det in dets:
                    # Convert the coordinates of the detection box to coordinates under the display resolution
                    pl.osd_img.draw_rectangle(x, y, w, h, color=(255, 255, 0, 255), thickness=2)  # Draw a rectangle
                pl.osd_img.clear()
    def get_padding_param(self):
        dst_w = self.model_input_size[0]  # Model input width
        dst_h = self.model_input_size[1]  # Model input height
        ratio_w = dst_w / self.rgb888p_size[0]  # Width scaling ratio
        ratio_h = dst_h / self.rgb888p_size[1]  # Height scaling ratio
        ratio = min(ratio_w, ratio_h)  # Take the smaller scaling ratio
        new_w = int(ratio * self.rgb888p_size[0])  # New width
        new_h = int(ratio * self.rgb888p_size[1])  # New height
        dw = (dst_w - new_w) / 2  # Width difference
        dh = (dst_h - new_h) / 2  # Height difference
        top = int(round(0))
        left = int(round(0))
    # Display mode, default is "hdmi", you can choose "hdmi" or "lcd"
    display_mode="hdmi"
    # k230 remains unchanged, k230d can be adjusted to [640,360]
    # Set model path and other parameters
    # Other parameters
    confidence_threshold = 0.5
    nms_threshold = 0.2
    anchor_len = 4200
    det_dim = 4
    # Initialize custom face detection instance
    face_det.config_preprocess()  # Configure pre-processing
            res = face_det.run(img)         # Infer current frame
            face_det.draw_result(pl, res)   # Draw result
    face_det.deinit()                       # Deinitialize
The pseudocode for multiple Ai2d instances is as follows:
import image
import gc
import sys
# Custom AI task class, inheriting from AIBase class
        # Model file path
    # Configure pre-processing operations, using resize and crop here. Ai2d supports crop/shift/pad/resize/affine. See the code in /sdcard/libs/AI2D.py.
            # Configure crop pre-processing method
    # Assume this task requires crop and resize pre-processing, the order is resize first then crop, this order does not match ai2d's processing order, so two Ai2d instances are needed to handle them separately
        return [crop_tensor]
           pass
            pass
    # Override deinit to release multiple ai2d resources
    def deinit(self):
            del self.ai2d_resize
            del self.ai2d_crop
            super().deinit()
    display_mode="hdmi"
    ###### Other parameters ########
Custom Pre-processing Task#
For AI tasks that require rewriting the pre-processing (not using the provided ai2d class, writing pre-processing manually), the pseudocode is as follows:
import image
import gc
import sys
# Custom AI Task Class, Inheriting from AIBase Base Class
        # Model file path
    # For AI tasks that do not use ai2d for pre-processing, use the encapsulated interface or ulab.numpy to implement pre-processing, need to override this function in the subclass
        # Note custom pre-processing
        return [tensor]
           pass
            pass
    # Display mode, default "hdmi", can choose "hdmi" and "lcd"
    display_mode="hdmi"
Example of Keyword Spotting with Keyword “XiaonanXiaonan”#
from libs.Utils import ScopedTiming
from media.pyaudio import *                     # Audio module
from media.media import *                       # Software abstraction module, mainly encapsulates media data link and media buffer
import media.wave as wave                       # wav audio processing module
import nncase_runtime as nn                     # nncase runtime module, encapsulates kpu (kmodel inference) and ai2d (image pre-processing acceleration) operations
import ulab.numpy as np                         # Similar to python numpy operations, but with some different interfaces
import aidemo                                   # aidemo module, encapsulates ai demo related pre-processing, post-processing, etc.
import time                                     # Time statistics
import struct                                   # Byte character conversion module
import gc                                       # Garbage collection module
import os,sys                                   # Operating system interface module
# Custom keyword spotting class, inheriting from AIBase base class
class KWSApp(AIBase):
        super().__init__(kmodel_path)  # Call the constructor of the base class
        self.threshold=threshold
    # Custom pre-processing, return model input tensor list
        pcm_data_list=[]
        # Get audio stream data
            # Organize every two bytes into a signed integer, then convert it to a float, which is the sampled data for one sample, added to the current frame (0.3s) data list
        # Process pcm data into feature vectors for model input
    # Custom post-processing for the current task, results is a list of model output arrays
            logits_np = results[0]
            self.cache_np= results[1]
            max_p = np.max(max_logits)
            idx = np.argmax(max_logits)
            # If the score is greater than the threshold and idx==1 (i.e., contains the wake word), play the reply audio
                return 1
                return 0
    nn.shrink_memory_pool()
    # Other parameters
    THRESH = 0.5                # Detection threshold
    SAMPLE_RATE = 16000         # Sampling rate 16000Hz, i.e., 16000 samples per second
    CHANNELS = 1                # Number of channels 1 for mono, 2 for stereo
    FORMAT = paInt16            # Audio input/output format paInt16
    CHUNK = int(0.3 * 16000)    # Number of frames to read audio data each time, set to 0.3s frames 16000*0.3=4800
    reply_wav_file = "/sdcard/examples/utils/wozai.wav"         # kws wake word reply audio path
    # Initialize audio pre-processing interface
    fp = aidemo.kws_fp_create()
    # Initialize audio stream
    p = PyAudio()
    p.initialize(CHUNK)
    MediaManager.init()    # vb buffer initialization
    # Used to collect real-time audio data
    # Used to play reply audio
    # Initialize custom keyword spotting instance
                pcm_data=input_stream.read()
                res=kws.run(pcm_data)
                if res:
                    while wav_data:
                        output_stream.write(wav_data)
                    time.sleep(1) # Time buffer for playing reply sound
                    wf.close()
                    print("Deactivated!")
        sys.print_exception(e)                  # Print exception information
    finally:
        input_stream.stop_stream()
        output_stream.stop_stream()
        input_stream.close()
        output_stream.close()
        p.terminate()
        MediaManager.deinit()              # Release vb buffer
        aidemo.kws_fp_destroy(fp)
        kws.deinit()                       # Deinitialize
No Pre-processing Task#
For AI tasks that do not require pre-processing (direct input inference), the pseudocode is as follows:
import image
import gc
import sys
        # Model file path
    # Custom post-processing for the current task, results is a list of model output arrays, needs to be rewritten based on the actual task
           pass
    # For AI tasks without preprocessing, this function needs to be overridden in the subclass
    def run(self, inputs_np):
        # First convert ulab.numpy.ndarray list to tensor list
        tensors = []
        for input_np in inputs_np:
        # Call the inference function in AIBase for model inference
        results = self.inference(tensors)
        # Call the postprocess method of the current subclass for custom post-processing
        outputs = self.postprocess(results)
        return outputs
    # Draw results on the screen, needs to be written according to the task
            pass
    display_mode = "hdmi"
    if display_mode == "hdmi":
        display_size = [1920, 1080]
        display_size = [800, 480]
    my_ai = MyAIApp(kmodel_path, model_input_size=[320, 320], rgb888p_size=rgb888p_size, display_size=display_size, debug_mode=0)
    my_ai.config_preprocess()  # Configure preprocessing
For example, in the single-object tracking module (nanotracker.py), the tracking module only needs the output of the template model and real-time inference model as the input for the tracking model, without requiring preprocessing:
class TrackerApp(AIBase):
    def __init__(self, kmodel_path, crop_input_size, thresh, rgb888p_size=[1280,720], display_size=[1920,1080], debug_mode=0):
        super().__init__(kmodel_path, rgb888p_size, debug_mode)
        # kmodel path
        # Crop model input size
        self.crop_input_size = crop_input_size
        # Tracking box threshold
        self.thresh = thresh
        # Tracking box width and height adjustment coefficient
        self.CONTEXT_AMOUNT = 0.5
        # Video output VO resolution, aligned to 16 in width
        # Debug mode
        # Optional
    # Optional
            pass
    # Override the run function, because there is no preprocessing, so the original run operation which includes preprocess->inference->postprocess is not suitable, here it only includes inference->postprocess
    def run(self, input_np_1, input_np_2, center_xy_wh):
        input_tensors = []
        results = self.inference(input_tensors)
        return self.postprocess(results, center_xy_wh)
    # Custom post-processing, results is a list of model output arrays, here using aidemo's nanotracker_postprocess function
    def postprocess(self, results, center_xy_wh):
            det = aidemo.nanotracker_postprocess(results[0], results[1], [self.rgb888p_size[1], self.rgb888p_size[0]], self.thresh, center_xy_wh, self.crop_input_size[0], self.CONTEXT_AMOUNT)
            return det
Multi-Model Task#
Here is an example of dual-model cascade inference, with the pseudocode as follows:
import image
import gc
import sys
# Custom AI task class, inheriting from AIBase base class
class MyAIApp_1(AIBase):
        # Model file path
        # Instantiate Ai2d for model preprocessing
    # Configure preprocessing operations, using resize here. Ai2d supports crop/shift/pad/resize/affine. Check /sdcard/libs/AI2D.py for specific code.
            # Initialize ai2d preprocessing configuration, default is the size from sensor to AI, can modify input size by setting input_image_size
            # Configure resize preprocessing method
            # Build preprocessing workflow
            self.ai2d.build([1,3,ai2d_input_size[1],ai2d_input_size[0]], [1,3,self.model_input_size[1],self.model_input_size[0]])
           pass
class MyAIApp_2(AIBase):
        # Model file path
           pass
class MyApp:
    def __init__(self, kmodel1_path, kmodel2_path, kmodel1_input_size, kmodel2_input_size, rgb888p_size, display_size, debug_mode):
        # Create instances for two model inferences
        self.app_1 = MyAIApp_1(kmodel1_path, kmodel1_input_size, rgb888p_size, display_size, debug_mode)
        self.app_2 = MyAIApp_2(kmodel2_path, kmodel2_input_size, rgb888p_size, display_size, debug_mode)
    # Write the run function, specific code should be written according to AI task requirements, here is just an example
    def run(self, input_np):
        outputs_1 = self.app_1.run(input_np)
        outputs_2 = []
        for out in outputs_1:
            out_2 = self.app_2.run(input_np)
            outputs_2.append(out_2)
        return outputs_1, outputs_2
    # Draw
    def draw_result(self, pl, outputs_1, outputs_2):
        pass
    ###### Other functions ########
    # Omitted
    kmodel1_input_size = [320, 320]
    kmodel2_input_size = [48, 48]
    # Omitted
    my_ai = MyApp(kmodel1_path, kmodel2_path, kmodel1_input_size, kmodel2_input_size, rgb888p_size=rgb888p_size, display_size=display_size, debug_mode=0)
            outputs_1, outputs_2 = my_ai.run(img)  # Infer current frame
            my_ai.draw_result(pl, outputs_1, outputs_2)  # Draw result
    my_ai.app_1.deinit()                    # Deinitialize
    my_ai.app_2.deinit()
For example code, please refer to the license plate detection and recognition: burn the firmware, open the IDE, select File -> Open File, and choose the corresponding script according to the following path: This PC -> CanMV -> sdcard -> examples -> 05-AI-Demo -> licence_det_rec.py.
Reference Documents#
K230 CanMV Documentation#
Documentation link: Welcome to K230 CanMV’s documentation! — K230 CanMV 文档 (canaan-creative.com)
Ulab Library Support#
Link: ulab – Manipulate numeric data similar to numpy — Adafruit CircuitPython 9.1.0-beta.3 documentation
GitHub Link: v923z/micropython-ulab: a numpy-like fast vector module for micropython, circuitpython, and their derivatives (github.com)
AI Demo#
To run the above demos on the K230D chip development board, you need to change the display_mode in __main__ to lcd to adapt to the display output. Additionally, you need to reduce the resolution as per the comments. Some demos may not run on the K230D, please refer to the table above for details.
Please download the latest version of the firmware according to your development board type from the K230 MicroPython Image Download List and K230D MicroPython Image Download List and complete the burning process. For burning instructions, please refer to the documentation: Burn Firmware.
After the image burning is complete, connect the IDE. For IDE usage instructions, refer to the documentation: How to Use IDE.
Dynamic Gesture Recognition#
Demo Description#
Dynamic gesture recognition implements the recognition of five dynamic gestures, which include: waving up, waving down, waving left, waving right, and pinching with fingers.
Code#
Open the IDE, select File -> Open File, and choose the corresponding script according to the following path: This PC -> CanMV -> sdcard -> examples -> 05-AI-Demo -> dynamic_gesture.py. You can refer to the source code displayed in the IDE. Click the run button at the bottom left of the IDE to demonstrate the demo.
Demonstration Effect#
Please point your palm at the camera. After the corresponding direction of the palm appears in the upper left corner of the screen, make actions of waving left, right, up, down, or pinching with five fingers. The recognized action will display the category of the dynamic gesture and mark it with an arrow.
Gaze Estimation#
Demo Description#
Gaze estimation predicts the eye gaze direction based on facial features. This application uses a dual-model approach, first performing face detection, then predicting the gaze direction of the detected face, and marking it with an arrow on the screen.
Code#
Open the IDE, select File -> Open File, and choose the corresponding script according to the following path: This PC -> CanMV -> sdcard -> examples -> 05-AI-Demo -> eye_gaze.py. You can refer to the source code displayed in the IDE. Click the run button at the bottom left of the IDE to demonstrate the demo.
The original image is as follows:
eye_gaze
Here, the demonstration effect is given using the 01studio LCD screen (800*480) as an example. Please change the display_mode in the __main__ function to lcd and run it. The HDMI effect is similar.
eye_gaze_res
Face Detection#
Demo Description#
The face detection application detects every face in the video and marks it with a detection box, while also marking the five key points of each face: left eyeball, right eyeball, nose tip, left mouth corner, and right mouth corner.
Code#
Open the IDE, select File -> Open File, and choose the corresponding script according to the following path: This PC -> CanMV -> sdcard -> examples -> 05-AI-Demo -> face_detection.py. You can refer to the source code displayed in the IDE. Click the run button at the bottom left of the IDE to demonstrate the demo.
face_det
face_det_res
Facial Key Points#
Demo Description#
The facial key points application is a dual-model application. First, it performs face detection on each frame of the video, then recognizes 106 key points for each detected face, and draws the contours of the face, mouth, eyes, nose, and eyebrow regions based on these key points.
Code#
Open the IDE, select File -> Open File, and choose the corresponding script according to the following path: This PC -> CanMV -> sdcard -> examples -> 05-AI-Demo -> face_landmark.py. You can refer to the source code displayed in the IDE. Click the run button at the bottom left of the IDE to demonstrate the demo.
face_landmark
face_landmark_res
Face 3D Mesh#
Demo Description#
The face 3D mesh is a multi-model application. First, it performs face detection on each frame of the video, then uses a face alignment model (3DDFA, 3D Dense Face Alignment) for face alignment, and finally uses a face mesh model for face 3D mesh reconstruction to obtain the mesh of each face in the image.
Code#
Open the IDE, select File -> Open File, and choose the corresponding script according to the following path: This PC -> CanMV -> sdcard -> examples -> 05-AI-Demo -> face_mesh.py. You can refer to the source code displayed in the IDE. Click the run button at the bottom left of the IDE to demonstrate the demo.
face_mesh
face_mesh_res
Face Parsing#
Demo Description#
Face parsing (also known as face segmentation) is a dual-model application. First, it performs face detection, then implements segmentation of different parts of the face. Face segmentation includes pixel-level classification of parts such as eyes, nose, and mouth, with different regions marked in different colors on the screen.
Code#
Open the IDE, select File -> Open File, and choose the corresponding script according to the following path: This PC -> CanMV -> sdcard -> examples -> 05-AI-Demo -> face_parse.py. You can refer to the source code displayed in the IDE. Click the run button at the bottom left of the IDE to demonstrate the demo.
face_parse
face_parse_res
Face Pose#
Demo Description#
Face pose is a dual-model application. First, it performs face detection on each frame of the video, then predicts the face orientation for each detected face. Face orientation is represented using Euler angles (roll/yaw/pitch), where roll indicates the degree of head shaking left or right, yaw indicates the degree of head rotation left or right, and pitch indicates the degree of head nodding up or down. This application visualizes face orientation on the screen by constructing a projection matrix.
Code#
Open the IDE, select File -> Open File, and choose the corresponding script according to the following path: This PC -> CanMV -> sdcard -> examples -> 05-AI-Demo -> face_pose.py. You can refer to the source code displayed in the IDE. Click the run button at the bottom left of the IDE to demonstrate the demo.
face_pose
face_pose_res
Face Registration#
Demo Description#
Face registration is a pre-task for face recognition, where each image containing a face in the face database is characterized, and the face features are written into the face database directory as a bin file for the face recognition program to call. The output face feature dimension of face registration is 512.
Code#
Open the IDE, select File -> Open File, and choose the corresponding script according to the following path: This PC -> CanMV -> sdcard -> examples -> 05-AI-Demo -> face_registration.py. You can refer to the source code displayed in the IDE. Click the run button at the bottom left of the IDE to demonstrate the demo.
Register images with faces as face features and store them in the face feature library. Below is one of the face images:
id_2
Face Recognition#
Demo Description#
The face recognition application performs face identity recognition on each frame of the video based on the information from face registration. If the recognized face is in the registration database, it labels the recognized face’s identity information; otherwise, it displays “unknown.”
Code#
Open the IDE, select File -> Open File, and choose the corresponding script according to the following path: This PC -> CanMV -> sdcard -> examples -> 05-AI-Demo -> face_recognition.py. You can refer to the source code displayed in the IDE. Click the run button at the bottom left of the IDE to demonstrate the demo.
The registered face original image is as follows:
face_recognition
face_recognition_res
Fall Detection#
Demo Description#
The fall detection application detects whether there is a human in each frame of the video and checks for the fall status of the human. If not fallen, it marks “NoFall”; if fallen, it marks “Fall.”
Code#
Open the IDE, select File -> Open File, and choose the corresponding script according to the following path: This PC -> CanMV -> sdcard -> examples -> 05-AI-Demo -> falldown_detect.py. You can refer to the source code displayed in the IDE. Click the run button at the bottom left of the IDE to demonstrate the demo.
falldown_det
falldown_det_res
Rock-Paper-Scissors Game#
Demo Description#
The rock-paper-scissors game is a fun game based on hand applications. First, ensure there are no other palms on the screen, then one hand enters the camera to show rock/paper/scissors. The machine will also randomly show rock/paper/scissors, and the winner is determined by the best of three rounds.
Code#
Open the IDE, select File -> Open File, and choose the corresponding script according to the following path: This PC -> CanMV -> sdcard -> examples -> 05-AI-Demo -> finger_guessing.py. You can refer to the source code displayed in the IDE. Click the run button at the bottom left of the IDE to demonstrate the demo.
Initially, ensure the camera range is blank. One hand enters the camera while showing rock/paper/scissors. The rule is best of three. Please experience it yourself.
Palm Detection#
Demo Description#
The palm detection application detects the presence of palms in each frame of the video and marks the palm detection box on the screen.
Code#
Open the IDE, select File -> Open File, and choose the corresponding script according to the following path: This PC -> CanMV -> sdcard -> examples -> 05-AI-Demo -> hand_detection.py. You can refer to the source code displayed in the IDE. Click the run button at the bottom left of the IDE to demonstrate the demo.
hand_det
hand_det_res
Palm Key Point Classification#
Demo Description#
The palm key point classification application is a dual-model task. First, it detects the palms present in the video, then performs key point regression on the detected palms. After obtaining the key point information, it distinguishes different gestures by calculating the angle information between fingers. It currently supports 9 gestures as shown below.
Supported Gesture Illustration
Code#
Open the IDE, select File -> Open File, and choose the corresponding script according to the following path: This PC -> CanMV -> sdcard -> examples -> 05-AI-Demo -> hand_keypoint_class.py. You can refer to the source code displayed in the IDE. Click the run button at the bottom left of the IDE to demonstrate the demo.
hand_kp_cls
hand_kp_cls_res
Palm Key Point Detection#
Demo Description#
Palm key point detection is a dual-model task. First, it detects the palm in each frame of the video, then performs key point regression on each detected palm to obtain the positions of 21 palm skeletal key points. These key points and their connections are displayed on the screen.
Code#
Open the IDE, select File -> Open File, and choose the corresponding script according to the following path: This PC -> CanMV -> sdcard -> examples -> 05-AI-Demo -> hand_keypoint_detection.py. You can refer to the source code displayed in the IDE. Click the run button at the bottom left of the IDE to demonstrate the demo.
hand_kp_det
hand_kp_det_res
Demo Description#
The gesture recognition application is a classification-based task. First, it detects the palm in each frame of the video, then classifies the detected palm to recognize the gesture. This example supports three gestures as shown below.
Gesture Recognition
Code#
Open the IDE, select File -> Open File, and choose the corresponding script according to the following path: This PC -> CanMV -> sdcard -> examples -> 05-AI-Demo -> hand_recognition.py. You can refer to the source code displayed in the IDE. Click the run button at the bottom left of the IDE to demonstrate the demo.
hand_rec
hand_rec_res
Keyword Spotting#
Demo Description#
The keyword spotting application is a typical audio application. After the application starts, wake it up by saying “Xiao Nan, Xiao Nan” near the microphone. Once the wake word is recognized, it will respond with “I’m here.” Other audio data collection applications can also refer to this application.
Code#
Open the IDE, select File -> Open File, and choose the corresponding script according to the following path: This PC -> CanMV -> sdcard -> examples -> 05-AI-Demo -> keyword_spotting.py. You can refer to the source code displayed in the IDE. Click the run button at the bottom left of the IDE to demonstrate the demo.
Please approach the microphone and wake it up with “Xiao Nan, Xiao Nan.” After waking up, the K230 will respond with “I’m here!”
License Plate Detection#
Demo Description#
The license plate detection application detects license plates appearing in the video and marks them with detection boxes on the screen.
Code#
Open the IDE, select File -> Open File, and choose the corresponding script according to the following path: This PC -> CanMV -> sdcard -> examples -> 05-AI-Demo -> licence_det.py. You can refer to the source code displayed in the IDE. Click the run button at the bottom left of the IDE to demonstrate the demo.
Please find license plate images for detection yourself. This example involves license plate privacy, so no demonstration effect is provided.
License Plate Recognition#
Demo Description#
The license plate recognition application is a dual-model task. First, it detects license plates in the video, then recognizes each detected license plate and displays the recognized content near the corresponding detection box.
Code#
Open the IDE, select File -> Open File, and choose the corresponding script according to the following path: This PC -> CanMV -> sdcard -> examples -> 05-AI-Demo -> licence_det_rec.py. You can refer to the source code displayed in the IDE. Click the run button at the bottom left of the IDE to demonstrate the demo.
Please find license plate images for recognition yourself. This example involves license plate privacy, so no demonstration effect is provided.
Single Object Tracking#
Demo Description#
The single object tracking application tracks and recognizes the registered object within the target box. After starting the application, wait for a while. During this time, place the object to be tracked (preferably with a different color from the background) in the target box. Once registration is complete, it will automatically enter tracking mode, and the moving target box will follow the object.
Code#
Open the IDE, select File -> Open File, and choose the corresponding script according to the following path: This PC -> CanMV -> sdcard -> examples -> 05-AI-Demo -> nanotracker.py. You can refer to the source code displayed in the IDE. Click the run button at the bottom left of the IDE to demonstrate the demo.
nanotracker
nanotracker_res
YOLOv8n Object Detection#
Demo Description#
The YOLOv8n object detection application uses the YOLOv8n model to detect 80 categories from the COCO dataset, and the detection results are marked on the screen with detection boxes.
Code#
Open the IDE, select File -> Open File, and choose the corresponding script according to the following path: This PC -> CanMV -> sdcard -> examples -> 05-AI-Demo -> object_detect_yolov8n.py. You can refer to the source code displayed in the IDE. Click the run button at the bottom left of the IDE to demonstrate the demo.
yolov8n_det
yolov8n_det_res
OCR Detection#
Demo Description#
The OCR detection application detects text appearing in the video, and the detection results are marked on the screen with detection boxes.
Code#
Open the IDE, select File -> Open File, and choose the corresponding script according to the following path: This PC -> CanMV -> sdcard -> examples -> 05-AI-Demo -> ocr_det.py. You can refer to the source code displayed in the IDE. Click the run button at the bottom left of the IDE to demonstrate the demo.
ocr_det
ocr_det_res
OCR Recognition#
Demo Description#
The OCR recognition application is a dual-model task. First, it detects text in each frame of the video, then recognizes the detected text, and finally marks the detection box on the screen and adds the recognized text content near the detection box.
Code#
Open the IDE, select File -> Open File, and choose the corresponding script according to the following path: This PC -> CanMV -> sdcard -> examples -> 05-AI-Demo -> ocr_rec.py. You can refer to the source code displayed in the IDE. Click the run button at the bottom left of the IDE to demonstrate the demo.
ocr_rec
ocr_rec_res
Human Detection#
Demo Description#
The human detection application detects people in the video and marks them on the screen with detection boxes.
Code#
Open the IDE, select File -> Open File, and choose the corresponding script according to the following path: This PC -> CanMV -> sdcard -> examples -> 05-AI-Demo -> person_detection.py. You can refer to the source code displayed in the IDE. Click the run button at the bottom left of the IDE to demonstrate the demo.
person_det
person_det_res
Human Key Point Detection#
Demo Description#
The human key point detection application uses the YOLOv8n-pose model to detect human poses, resulting in the positions of 17 human skeletal key points, which are connected with lines of different colors and displayed on the screen.
Code#
Open the IDE, select File -> Open File, and choose the corresponding script according to the following path: This PC -> CanMV -> sdcard -> examples -> 05-AI-Demo -> person_keypoint_detect.py. You can refer to the source code displayed in the IDE. Click the run button at the bottom left of the IDE to demonstrate the demo.
person_kp_det
person_kp_det_res
Puzzle Game#
Demo Description#
The puzzle game is a hand-based fun game. When the application starts, ensure there are no palms in the camera range and wait for the screen to initialize. On the left is a randomly scrambled puzzle, and on the right is the target puzzle. When a palm enters, open the thumb and middle finger. The yellow dot between the fingers is used to locate the moving block. Quickly pinch the two fingers together and then open them again. The yellow dot turns blue, and the corresponding block moves to the adjacent empty space.
Code#
Open the IDE, select File -> Open File, and choose the corresponding script according to the following path: This PC -> CanMV -> sdcard -> examples -> 05-AI-Demo -> puzzle_game.py. You can refer to the source code displayed in the IDE. Click the run button at the bottom left of the IDE to demonstrate the demo.
Here, the demonstration effect is given using the 01studio LCD screen (800*480) as an example. Please change the display_mode in the __main__ function to lcd and run it. The HDMI effect is similar. Keep a certain distance from the camera, open the thumb and middle finger, and pinch the thumb and middle finger around the empty block. The empty block and the current block will swap positions.
puzzle_game_res
YOLOv8n Segmentation#
Demo Description#
The YOLOv8n segmentation application uses the YOLOv8n model to segment objects from 80 categories of the COCO dataset appearing in the video, displaying them as a mask on the screen.
Code#
Open the IDE, select File -> Open File, and choose the corresponding script according to the following path: This PC -> CanMV -> sdcard -> examples -> 05-AI-Demo -> segment_yolov8n.py. You can refer to the source code displayed in the IDE. Click the run button at the bottom left of the IDE to demonstrate the demo.
yolov8n_seg
yolov8n_seg_res
Self-Learning#
Demo Description#
Self-learning is a feature-based classification method. First, set the labels in the code and specify the names of the items to be collected. Then start the application and place the items to be collected in the feature collection box as prompted on the screen. Once feature collection is complete, it automatically enters recognition mode. Place the item to be recognized in the collection box, and it will be compared with the registered items for feature comparison, completing classification based on similarity.
Code#
Open the IDE, select File -> Open File, and choose the corresponding script according to the following path: This PC -> CanMV -> sdcard -> examples -> 05-AI-Demo -> self_learning.py. You can refer to the source code displayed in the IDE. Click the run button at the bottom left of the IDE to demonstrate the demo.
The images of the apple and banana to be learned are as follows:
apple
banana
Here, the demonstration effect is given using the 01studio LCD screen (800*480) as an example. Please change the display_mode in the __main__ function to lcd and run it. The HDMI effect is similar. Follow the screen prompts to place the apple and banana in the box for learning, then automatically enter recognition mode. The object in the box will be recognized as an apple or banana, and a similarity score will be given.
self_learning_res
Local Magnifier#
Demo Description#
The local magnifier is a fun application based on hand features. After starting the application, ensure one hand is inside the camera. Pinch the thumb and middle finger together, position it at a certain location, and open the two fingers. The enlarged image of that area will be displayed near the fingers.
Code#
Open the IDE, select File -> Open File, and choose the corresponding script according to the following path: This PC -> CanMV -> sdcard -> examples -> 05-AI-Demo -> space_resize.py. You can refer to the source code displayed in the IDE. Click the run button at the bottom left of the IDE to demonstrate the demo.
Here, the demonstration effect is given using the 01studio LCD screen (800*480) as an example. Please change the display_mode in the __main__ function to lcd and run it. The HDMI effect is similar. Pinch the thumb and middle finger, place them in the frame, then open and close the fingers, and a small surrounding area will zoom in and out.
space_resize_res
Text-to-Speech (Chinese)#
Demo Description#
Text-to-Speech (TTS, Chinese) is a typical audio application. You can modify the text in the main function, and after the audio is generated, you can listen to it through headphones. This application takes a relatively long time, and the complete audio playback time is also quite long, depending on the length of the generated text.
Code#
Open the IDE, select File -> Open File, and choose the corresponding script according to the following path: This PC -> CanMV -> sdcard -> examples -> 05-AI-Demo -> tts_zh.py. You can refer to the source code displayed in the IDE. Click the run button at the bottom left of the IDE to demonstrate the demo.
Please insert headphones or speakers, run the program, and the generated audio will play after completion. Please experience it yourself!
Human body segmentation#
demo description#
The human body segmentation task divides the entire human body into 15 parts and represents it in different colors.
Code#
Open the IDE, select File->Open File, and select the corresponding script to open according to the following path:This computer -> CanMV->sdcard->examples->05-AI-Demo->body_seg.py, you can refer to the source code displayed by the IDE. Click the Run button in the lower left corner of the IDE to demonstrate the demo.
Multiple command word spotting#
demo description#
Multi-command word spotting is an extended version of keyword wakeup, which supports xiaonanxiaonan,go,stop,wow the wake-up of four keywords is suitable for scenes controlled by voice commands.
Code#
Open the IDE, select File->Open File, and select the corresponding script to open according to the following path:This computer -> CanMV->sdcard->examples->05-AI-Demo->multi_kws.py, you can refer to the source code displayed by the IDE. Click the Run button in the lower left corner of the IDE to demonstrate the demo.
Lightweight version of face registration#
demo description#
The lightweight version of face registration uses a new face recognition model. Compared with the weight model (44M), its model is less than 3M, which is suitable for the K230D face recognition registration process!
Code#
Open the IDE, select File->Open File, and select the corresponding script to open according to the following path:This computer -> CanMV -> sdcard -> examples -> 05-AI-Demo -> face_registration_lite.py, you can refer to the source code displayed by the IDE. Click the Run button in the lower left corner of the IDE to demonstrate the demo.
Lightweight Face Recognition#
demo description#
The lightweight version of face recognition uses a new face recognition model. Compared with the weight model (44M), its model is less than 3M, which is suitable for face recognition processes with frame rate requirements or K230D!
Code#
Open the IDE, select File->Open File, and select the corresponding script to open according to the following path:This computer -> CanMV->sdcard->examples->05-AI-Demo->face_recognition_lite.py, you can refer to the source code displayed by the IDE. Click the Run button in the lower left corner of the IDE to demonstrate the demo.
YOLO11n Oriented Bounding Boxes#
demo description#
YOLO11n Oriented Bounding Boxes achieves 15 target angle detection, including aircraft, ships, etc.
Code#
Open the IDE, select File->Open File, and select the corresponding script to open according to the following path:This computer -> CanMV->sdcard->examples->05-AI-Demo->yolo11n_obb.py, you can refer to the source code displayed by the IDE. Click the Run button in the lower left corner of the IDE to demonstrate the demo.
YOLOv8n Oriented Bounding Boxes#
demo description#
YOLOv8n Oriented Bounding Boxes achieves 15 target angle detection, including aircraft, ships, etc.
Code#
Open the IDE, select File->Open File, and select the corresponding script to open according to the following path:This computer -> CanMV->sdcard->examples->05-AI-Demo->yolov8n_obb.py, you can refer to the source code displayed by the IDE. Click the Run button in the lower left corner of the IDE to demonstrate the demo.
