RTOS Display Support List#
Display / Panel Support List#
The display-related configuration in the current SDK is located at MPP Configuration -> Display Configuration.
Note: The support list is continuously updated with each SDK release. Always refer to
src/rtsmart/mpp/Kconfigin the current source tree for the authoritative list.
Display Driver Layer#
HDMI display driver:
MPP_ENABLE_DSI_HDMILCD display driver:
MPP_ENABLE_DSI_LCDSPI LCD display driver:
MPP_ENABLE_SPI_LCDQSPI LCD display driver:
MPP_ENABLE_QSPI_LCDOSPI LCD display driver:
MPP_ENABLE_OSPI_LCDVirtual display driver:
MPP_DSI_ENABLE_VIRT
Panel / Bridge Chip Driver Layer#
HDMI bridge: LT9611 (
MPP_DSI_ENABLE_HDMI_LT9611)LCD panel: HX8399 (
MPP_DSI_ENABLE_LCD_HX8399)LCD panel: ST7701 (
MPP_DSI_ENABLE_LCD_ST7701)LCD panel: ILI9806 (
MPP_DSI_ENABLE_LCD_ILI9806)LCD panel: ILI9881 (
MPP_DSI_ENABLE_LCD_ILI9881)LCD panel: NT35516 (
MPP_DSI_ENABLE_LCD_NT35516)LCD panel: NT35532 (
MPP_DSI_ENABLE_LCD_NT35532)LCD panel: GC9503 (
MPP_DSI_ENABLE_LCD_GC9503)LCD panel: ST7102 (
MPP_DSI_ENABLE_LCD_ST7102)LCD panel: AML020T (
MPP_DSI_ENABLE_LCD_AML020T)LCD panel: JD9852 (
MPP_DSI_ENABLE_LCD_JD9852)SPI LCD panel: ST7789 (
MPP_SPI_ENABLE_LCD_ST7789)
How to Enable a Specific Display Panel in Firmware#
In the SDK root directory, run:
make menuconfig
Navigate to:
Enable the display driver that matches your hardware connection and configure the corresponding pins:
HDMI path: enable
Enable HDMI Display DriverMIPI DSI LCD path: enable
Enable LCD Display DriverSPI/QSPI/OSPI LCD path: enable the corresponding SPI/QSPI/OSPI driver switch
Supply the required configuration for the driver type:
HDMI: typically configure
DSI-HDMI Reset GPIOandDSI-HDMI I2c BusMIPI DSI LCD: typically configure
DSI-LCD Reset GPIOandDSI-LCD BackLight GPIOSPI/QSPI/OSPI LCD: also configure
Data/Command GPIO,Chip Select GPIO,Reset GPIO,Backlight GPIO, the bus, and FPIOA pin mapping
In the same menu, select the corresponding panel driver:
HDMI: typically
Enable HDMI Display Panel Driver LT9611MIPI LCD: select the actual panel (e.g. HX8399/ST7701/ILI9881)
SPI LCD: select
Enable SPI LCD Panel Driver ST7789
Save the configuration and rebuild:
time make log
How to Verify Display Configuration on the RTOS Side#
1) Ensure MPP samples are enabled and built#
Under RT-Smart UserSpace Examples Configuration, enable at least:
Enable MPP examplesOne or more VO/display-related samples (e.g.
sample_vo_video,sample_vo_osd)
2) Locate runnable samples on the board#
cd /sdcard/app/examples
find mpp -name "*.elf" | grep -Ei "vo|vicap|player" | head
FAQ#
Display fails to initialize (black screen)#
Check in order:
Does the driver path match the hardware (HDMI / MIPI LCD / SPI LCD)?
Is the panel model configured correctly?
Do the Reset/Backlight GPIO, I2C bus, and SPI/QSPI/OSPI pin assignments match the hardware?
Is the board power supply stable and is the display cable properly connected?
References#
Adding a new display driver:
advanced_development_guide/how_to_add_display.mdSample run instructions:
how_to_run_samples.md
