功能介绍#
模块依赖#
操作系统#
表 2-1 飞线关系
Link1  |
Link2  |
Link3  |
Link4  |
Link5  |
K230排针  |
J5 PIN16 (5V)  |
J8 PIN9 (GPIO34)  |
WiFi排针  |
J6 PIN1 (5V)  |
J2 PIN3 (SDIO_INT_OUT)  |
J2 PIN4 (TX)  |
J2 PIN5 (RX)  |
J2 PIN6 (GND)  |
TTL-USB  |
RX  |
TX  |
GND  |
模块配置#
设备树修改#
配置引脚function#
&iomux {
pinctrl-names = "default";
pinctrl-0 = <&pins>;
pins: iomux_pins {
pinctrl-single,pins = <
配置GPIO控制器#
gpio52: gpio52@9140c000 {
#address-cells = <1>;
#size-cells = <0>;
interrupt-controller;
interrupt-parent = <&intc>;
#interrupt-cells = <2>;
port52: gpio-controller@0 {
gpio-controller;
#gpio-cells = <2>;
nr-gpios = <1>;
reg-bank = <0>;
id = <52>;
配置SDHCI1参数#
sdcard: sdhci1@91581000 {
interrupts = <144>;
clock-names = "core", "bus";
max-frequency = <50000000>;
bus-width = <4>;
//cd-gpios = <>;
no-1-8-v;
cap-sd-highspeed;
sdhci,auto-cmd12;
status = "okay";
内核配置项#
使能kprobes:
|| [*] Kprobes
将cfg80211编入内核,注意需要选中 cfg80211 wireless extensions compatibility:
│ --- Wireless │ │
│ │ <*> cfg80211 - wireless configuration API │ │
│ │ [ ] nl80211 testmode command │ │
│ │ [ ] enable developer warnings │ │
│ │ [ ] cfg80211 certification onus │ │
│ │ [*] enable powersave by default │ │
│ │ [ ] cfg80211 DebugFS entries │ │
│ │ [*] support CRDA │ │
│ │ [*] cfg80211 wireless extensions compatibility │ │
│ │ [ ] lib80211 debugging messages │ │
│ │ < > Generic IEEE 802.11 Networking Stack (mac80211)
│ --- Wireless LAN │ │
│ │ [ ] mac80211-based legacy WDS support │ │
│ │ [ ] ADMtek devices │ │
│ │ [*] Aich devices │ │
│ │ <M> Aich AiW4211LV10 (SDIO) support │
│ │ [ ] Atheros/Qualcomm devices │ │
│ │ [ ] Atmel devices │ │
│ │ [ ] Broadcom devices │ │
│ │ [ ] Cisco devices │ │
│ │ [ ] Intel devices │ │
│ │ [*] Intersil devices │ │
│ │ <*> IEEE 802.11 for Host AP (Prism2/2.5/3 and WEP/TKIP/CCMP)
│ │ [ ] Support downloading firmware images with Host AP driver │ │
│ │ [ ] Marvell devices │ │
│ │ [ ] MediaTek devices │ │
│ │ [ ] Microchip devices
SDIO主控增加扫描接口#
if (mmc == NULL) {
return -EINVAL;
mmc_detect_change(mmc, 0);
if (!IS_ERR(priv->bus_clk))
if (err)
goto err_clk;
模块编译#
模块启动#
WiFi固件#
驱动加载#
网络配置#
API参考#
config接口#
API#
配置WiFi工作参数:
配置目标AP的名称、密码、认证及加密方式
配置WiFi休眠等级,苏醒周期以及可唤醒的gpio
配置tcp keepalive时间参数等
数据结构#
wifi_config_t#
unsigned int config_mask;
wifi_sleep_t sleep;
wifi_connect_t conn;
wifi_keepalive_t keepalive;
} wifi_config_t;
表 6-1 wifi_config_t结构体成员
成员  |
说明  |
config_mask  |
配置目标项掩码,使能或屏蔽目标项,例如全部配置则:config_mask = CFG_MASK_SLEEP|CFG_MASK_CONNECT|CFG_MASK_KEEPALIVE; CFG_MASK_SLEEP:配置休眠参数,CFG_MASK_CONNECT:配置AP连接参数,CFG_MASK_KEEPALIVE:配置tcp keepalive参数  |
休眠参数  |
AP连接参数  |
tcp keepalive参数  |
wifi_sleep_t#
unsigned int level;
#define WIFI_SLEEP_LIGHT 1
#define WIFI_SLEEP_DEEP 2
#define WIFI_SLEEP_ULTRA 3
unsigned int period;
union
struct {
unsigned int gpio0_wake:1;
unsigned int gpio1_wake:1;
unsigned int gpio2_wake:1;
unsigned int gpio3_wake:1;
unsigned int gpio4_wake:1;
unsigned int gpio5_wake:1;
unsigned int gpio6_wake:1;
unsigned int gpio7_wake:1;
unsigned int gpio8_wake:1;
unsigned int gpio9_wake:1;
unsigned int gpio10_wake:1;
unsigned int gpio11_wake:1;
unsigned int gpio12_wake:1;
unsigned int gpio13_wake:1;
unsigned int gpio14_wake:1;
unsigned int wake_gpios;
} wifi_sleep_t;
表 6-2 wifi_sleep_t结构体成员
成员  |
说明  |
level  |
休眠等级 WIFI_SLEEP_LIGHT:浅睡 WIFI_SLEEP_DEEP:深睡,主要休眠模式 WIFI_SLEEP_ULTRA:超深睡,只有3/5/7/14号gpio可唤醒,目前不使用  |
period  |
苏醒周期,有效数值33~~4000ms。WiFi周期性从休眠态醒来,检测AP是否有发给自己的数据缓存  |
wake_gpios  |
enable或disable可唤醒WiFi的gpio(WiFi侧gpio)  |
wifi_connect_t#
ext_wifi_auth_mode auth;
ext_wifi_pairwise pairwise;
} wifi_connect_t;
表 6-3 wifi_connect_t结构体成元
ssid  |
AP名称  |
auth  |
认证类型 EXT_WIFI_SECURITY_OPEN EXT_WIFI_SECURITY_WEP EXT_WIFI_SECURITY_WPA2PSK EXT_WIFI_SECURITY_WPAPSK_WPA2PSK_MIX EXT_WIFI_SECURITY_WPAPSK EXT_WIFI_SECURITY_WPA EXT_WIFI_SECURITY_WPA2 EXT_WIFI_SECURITY_SAE EXT_WIFI_SECURITY_WPA3_WPA2_PSK_MIX EXT_WIFI_SECURITY_UNKNOWN  |
Key  |
AP密码  |
bssid  |
AP bssid,一般为AP mac地址  |
pairwise  |
加密类型 EXT_WIFI_PARIWISE_UNKNOWN EXT_WIFI_PAIRWISE_AES EXT_WIFI_PAIRWISE_TKIP EXT_WIFI_PAIRWISE_TKIP_AES_MIX  |
wifi_keepalive_t#
unsigned char svrip[16];
unsigned short svrport;
} wifi_keepalive_t;
表 6-4 wifi_keepalive_t结构体成员
svrip  |
server端ip地址  |
svrport  |
server端端口号  |
tcp_keepalive_time  |
TCP层keepalive心跳包常规发送周期,秒  |
tcp_keepalive_intvl  |
TCP层keepalive心跳包无回应之后新的发送周期,秒  |
tcp_keepalive_probes  |
TCP层keepalive心跳包无回应计数超过该阈值之后,判断TCP连接异常,断开重连  |
heartbeat_intvl  |
应用层心跳包发送周期,秒  |
heartbeat_probes  |
应用层心跳包无回应计数超过该阈值之后,判断socket连接异常,断开重连  |
sleep接口#
int kd_wifi_sleep(void)
基本性能测试#
吞吐量测试#
server:iperf -s -i 2
表 7-1 TCP吞吐量粗测数据
WiFi ROLE  |
Bandwidth(Mbits/sec)  |
client  |
12.2  |
server  |
20.3  |
server:iperf -s -i 2 -u
表 7-2 UDP吞吐量粗测数据
WiFi ROLE  |
Jitter(ms)  |
Lost/Total Datagrams  |
client  |
17.8  |
1.341  |
1571/455457 (0.34%)  |
server  |
21.0  |
1.064  |
1/534990 (0.00019%)  |
文件传输测试#
