K230 nncase FAQ#
Error Installing whl Package#
  • A:Upgrade pip pip install --upgrade pip
2.Error Compiling Model#
  • A: This exception indicates that the XXX operator is not yet supported. You can submit a feature request in the nncase Github Issue. For a list of supported operators, please refer to the ***_ops.md document in the nncase repository. If XXX belongs to FAKE_QUANT, DEQUANTIZE, QUANTIZE, etc., it indicates that the current model is a quantized model, which nncase currently does not support. Please use a floating-point model to compile the kmodel.
  • A: Modify the value of 128 to a larger value using sudo gedit /proc/sys/fs/inotify/max_user_instances.
  • A: You need to install dotnet-sdk-7.0. Do not install it in the anaconda virtual environment.
    • Linux:
      sudo apt-get update
      If the error persists after installation, configure the dotnet environment variable.
    • Windows: Please refer to the official Microsoft documentation.
  • A:You need to install nncase-kpu
    • Linux:pip install nncase-kpu
    • Windows:Download the corresponding version of the whl package from the nncase GitHub tags page and then install it using pip.
      Before installing nncase-kpu, check the nncase version, and then install the nncase-kpu that matches the nncase version.
       Version: 2.8.0
Errors During Inference#
Or the following cases:
  • "Input/output error."
  • A:Add the installation path of nncase to the PATH environment variable and check if the nncase and nncase-kpu versions are consistent. If they are inconsistent, install the same version of the Python package using pip install nncase==x.x.x.x nncase-kpu==x.x.x.x.
Errors During Inference on K230 Development Board#
  • A: The input data is incorrect during inference and does not match the shape and type of the model input nodes. When configuring preprocessing parameters during model compilation, the shape and type information of the model input nodes will be updated accordingly. Please generate the input data according to the input_shape and input_type configured during model compilation.
std::bad_alloc#
  • A: This is usually due to memory allocation failure. The following checks can be made:
  • Check if the generated kmodel exceeds the available memory of the current system.
  • Check if the App has memory leaks.
terminate:Invalid kmodel#
When loading the kmodel with the following code, this custom exception is thrown.
