K230 nncase FAQ#
Error Installing whl Package#
A:Upgrade pip
pip install --upgrade pip
2.Error Compiling Model#
A: This exception indicates that the
XXXoperator is not yet supported. You can submit a feature request in the nncase Github Issue. For a list of supported operators, please refer to the***_ops.mddocument in the nncase repository. IfXXXbelongs to FAKE_QUANT,DEQUANTIZE,QUANTIZE, etc., it indicates that the current model is a quantized model, whichnncasecurrently does not support. Please use a floating-point model to compile thekmodel.
A: Modify the value of 128 to a larger value using
sudo gedit /proc/sys/fs/inotify/max_user_instances.
A: You need to install dotnet-sdk-7.0. Do not install it in the
anacondavirtual environment.Linux:
If the error persists after installation, configure the
dotnetenvironment variable.export DOTNET_ROOT=/usr/share/dotnet
Windows: Please refer to the official Microsoft documentation.
A:You need to install nncase-kpu
Linux:
pip install nncase-kpuWindows:Download the corresponding version of the whl package from the nncase GitHub tags page and then install it using pip.
Before installing nncase-kpu, check the nncase version, and then install the nncase-kpu that matches the nncase version.
Errors During Inference#
Or the following cases:
"Input/output error."
A:Add the installation path of nncase to the PATH environment variable and check if the nncase and nncase-kpu versions are consistent. If they are inconsistent, install the same version of the Python package using
pip install nncase==x.x.x.x nncase-kpu==x.x.x.x.root@a52f1cacf581:/mnt# pip list | grep nncase nncase 2.1.1.20230721 nncase-kpu 2.1.1.20230721
Errors During Inference on K230 Development Board#
A: The input data is incorrect during inference and does not match the shape and type of the model input nodes. When configuring preprocessing parameters during model compilation, the shape and type information of the model input nodes will be updated accordingly. Please generate the input data according to the
input_shapeandinput_typeconfigured during model compilation.
std::bad_alloc#
A: This is usually due to memory allocation failure. The following checks can be made:
Check if the generated kmodel exceeds the available memory of the current system.
Check if the App has memory leaks.
terminate:Invalid kmodel#
When loading the kmodel with the following code, this custom exception is thrown.
A: In the absence of other issues, this is due to the mismatch between the nncase version used to compile the
kmodeland the current SDK version. Please refer to the SDK and nncase version correspondence and follow the guide to update the nncase runtime library to resolve the issue.
