K230 nncase Development Guide#
What is nncase#
nncase is a neural network compiler designed for AI accelerators. Currently supported targets include CPU/K210/K510/K230, etc.
Features provided by nncase:
Supports multi-input multi-output networks and multi-branch structures
Static memory allocation, no heap memory required
Operator fusion and optimization
Supports float and uint8/int8 quantized inference
Supports post-training quantization using floating-point models and quantization calibration sets
Flat model, supports zero-copy loading
Supported neural network model formats by nncase:
TFLite
ONNX
nncase Architecture#
The nncase software stack includes two parts: compiler and runtime.
Compiler: Used to compile neural network models on a PC, ultimately generating kmodel files. It mainly includes modules such as importer, IR, Evaluator, Quantize, Transform optimization, Tiling, Partition, Schedule, and Codegen.
Importer: Imports models from other neural network frameworks into nncase
IR: Intermediate Representation, divided into Neutral IR (device-independent) imported by the importer and Target IR (device-specific) generated by lowering the Neutral IR
Evaluator: Provides interpretation execution capabilities for IR, often used in scenarios such as Constant Folding/PTQ Calibration
Transform: Used for IR transformation and graph traversal optimization
Quantize: Post-training quantization, adds quantization tags to the tensors to be quantized, collects tensor data ranges by calling the Evaluator for interpretation execution based on the input calibration set, inserts quantization/dequantization nodes, and finally optimizes to eliminate unnecessary quantization/dequantization nodes
Tiling: Due to the limited memory capacity of NPU, large computations need to be split. Additionally, choosing Tiling parameters when there is a large amount of data reuse in computations can impact latency and bandwidth
Partition: Splits the graph according to ModuleType, each subgraph corresponds to a RuntimeModule, and different types of RuntimeModules correspond to different Devices (CPU/K230)
Schedule: Generates the computation order and allocates buffers based on the data dependency relationships in the optimized graph
Codegen: Calls the codegen corresponding to each subgraph’s ModuleType to generate RuntimeModules
Runtime: Integrated into the user’s App, providing functions such as loading kmodel, setting input data, executing KPU, and retrieving output data.
Development Environment#
Operating System#
Supported operating systems include Ubuntu 18.04/Ubuntu 20.04
Software Environment#
No. |
Software |
Version |
1 |
python |
3.6/3.7/3.8/3.9/3.10 |
2 |
pip |
>=20.3 |
3 |
numpy |
1.19.5 |
4 |
onnx |
1.9.0 |
5 |
onnx-simplifier |
0.3.6 |
6 |
Onnxoptimizer |
0.2.6 |
7 |
Onnxruntime |
1.8.0 |
8 |
dotnet-runtime |
7.0 |
Hardware Environment#
K230 evb
Model Compilation APIs (Python)#
nncase provides Python APIs for compiling neural network models on a PC
Supported Operators#
TFLite Operators#
Operator |
Is Supported |
ABS |
Yes |
ADD |
Yes |
ARG_MAX |
Yes |
ARG_MIN |
Yes |
AVERAGE_POOL_2D |
Yes |
BATCH_MATMUL |
Yes |
CAST |
Yes |
CEIL |
Yes |
CONCATENATION |
Yes |
CONV_2D |
Yes |
COS |
Yes |
CUSTOM |
Yes |
DEPTHWISE_CONV_2D |
Yes |
DIV |
Yes |
EQUAL |
Yes |
EXP |
Yes |
EXPAND_DIMS |
Yes |
FLOOR |
Yes |
FLOOR_DIV |
Yes |
FLOOR_MOD |
Yes |
FULLY_CONNECTED |
Yes |
GREATER |
Yes |
GREATER_EQUAL |
Yes |
L2_NORMALIZATION |
Yes |
LEAKY_RELU |
Yes |
LESS |
Yes |
LESS_EQUAL |
Yes |
LOG |
Yes |
LOGISTIC |
Yes |
MAX_POOL_2D |
Yes |
MAXIMUM |
Yes |
MEAN |
Yes |
MINIMUM |
Yes |
MUL |
Yes |
NEG |
Yes |
NOT_EQUAL |
Yes |
PAD |
Yes |
PADV2 |
Yes |
MIRROR_PAD |
Yes |
PACK |
Yes |
POW |
Yes |
REDUCE_MAX |
Yes |
REDUCE_MIN |
Yes |
REDUCE_PROD |
Yes |
RELU |
Yes |
PRELU |
Yes |
RELU6 |
Yes |
RESHAPE |
Yes |
RESIZE_BILINEAR |
Yes |
RESIZE_NEAREST_NEIGHBOR |
Yes |
ROUND |
Yes |
RSQRT |
Yes |
SHAPE |
Yes |
SIN |
Yes |
SLICE |
Yes |
SOFTMAX |
Yes |
SPACE_TO_BATCH_ND |
Yes |
SQUEEZE |
Yes |
BATCH_TO_SPACE_ND |
Yes |
STRIDED_SLICE |
Yes |
SQRT |
Yes |
SQUARE |
Yes |
SUB |
Yes |
SUM |
Yes |
TANH |
Yes |
TILE |
Yes |
TRANSPOSE |
Yes |
TRANSPOSE_CONV |
Yes |
QUANTIZE |
Yes |
FAKE_QUANT |
Yes |
DEQUANTIZE |
Yes |
GATHER |
Yes |
GATHER_ND |
Yes |
ONE_HOT |
Yes |
SQUARED_DIFFERENCE |
Yes |
LOG_SOFTMAX |
Yes |
SPLIT |
Yes |
HARD_SWISH |
Yes |
ONNX Operators#
Operator |
Is Supported |
Abs |
Yes |
Acos |
Yes |
Acosh |
Yes |
And |
Yes |
ArgMax |
Yes |
ArgMin |
Yes |
Asin |
Yes |
Asinh |
Yes |
Add |
Yes |
AveragePool |
Yes |
BatchNormalization |
Yes |
Cast |
Yes |
Ceil |
Yes |
Celu |
Yes |
Clip |
Yes |
Compress |
Yes |
Concat |
Yes |
Constant |
Yes |
ConstantOfShape |
Yes |
Conv |
Yes |
ConvTranspose |
Yes |
Cos |
Yes |
Cosh |
Yes |
CumSum |
Yes |
DepthToSpace |
Yes |
DequantizeLinear |
Yes |
Div |
Yes |
Dropout |
Yes |
Elu |
Yes |
Exp |
Yes |
Expand |
Yes |
Equal |
Yes |
Erf |
Yes |
Flatten |
Yes |
Floor |
Yes |
Gather |
Yes |
GatherElements |
Yes |
GatherND |
Yes |
Gemm |
Yes |
GlobalAveragePool |
Yes |
GlobalMaxPool |
Yes |
Greater |
Yes |
GreaterOrEqual |
Yes |
GRU |
Yes |
Hardmax |
Yes |
HardSigmoid |
Yes |
HardSwish |
Yes |
Identity |
Yes |
InstanceNormalization |
Yes |
LayerNormalization |
Yes |
LpNormalization |
Yes |
LeakyRelu |
Yes |
Less |
Yes |
LessOrEqual |
Yes |
Log |
Yes |
LogSoftmax |
Yes |
LRN |
Yes |
LSTM |
Yes |
MatMul |
Yes |
MaxPool |
Yes |
Max |
Yes |
Min |
Yes |
Mul |
Yes |
Neg |
Yes |
Not |
Yes |
OneHot |
Yes |
Pad |
Yes |
Pow |
Yes |
PRelu |
Yes |
QuantizeLinear |
Yes |
RandomNormal |
Yes |
RandomNormalLike |
Yes |
RandomUniform |
Yes |
RandomUniformLike |
Yes |
ReduceL1 |
Yes |
ReduceL2 |
Yes |
ReduceLogSum |
Yes |
ReduceLogSumExp |
Yes |
ReduceMax |
Yes |
ReduceMean |
Yes |
ReduceMin |
Yes |
ReduceProd |
Yes |
ReduceSum |
Yes |
ReduceSumSquare |
Yes |
Relu |
Yes |
Reshape |
Yes |
Resize |
Yes |
ReverseSequence |
Yes |
RoiAlign |
Yes |
Round |
Yes |
Rsqrt |
Yes |
Selu |
Yes |
Shape |
Yes |
Sign |
Yes |
Sin |
Yes |
Sinh |
Yes |
Sigmoid |
Yes |
Size |
Yes |
Slice |
Yes |
Softmax |
Yes |
Softplus |
Yes |
Softsign |
Yes |
SpaceToDepth |
Yes |
Split |
Yes |
Sqrt |
Yes |
Squeeze |
Yes |
Sub |
Yes |
Sum |
Yes |
Tanh |
Yes |
Tile |
Yes |
TopK |
Yes |
Transpose |
Yes |
Trilu |
Yes |
ThresholdedRelu |
Yes |
Upsample |
Yes |
Unsqueeze |
Yes |
Where |
Yes |
APIs#
Currently, the model compilation APIs support deep learning models in TFLite/ONNX formats.
CompileOptions#
Description:
The CompileOptions class is used to configure nncase compilation options. The descriptions of each attribute are as follows:
Attribute Name |
Type |
Required |
target |
string |
Yes |
Specifies the compilation target, such as ‘cpu’ or ‘k230’ |
dump_ir |
bool |
No |
Specifies whether to dump IR, defaults to False |
dump_asm |
bool |
No |
Specifies whether to dump asm assembly files, defaults to False |
dump_dir |
string |
No |
Specifies the directory to dump files when dump_ir or other dump options are enabled, defaults to “” |
input_file |
string |
No |
Specifies the parameter file path when the ONNX model exceeds 2GB, defaults to “” |
preprocess |
bool |
No |
Specifies whether to enable preprocessing, defaults to False. The following parameters are effective only when |
input_type |
string |
No |
Specifies the input data type when preprocessing is enabled, defaults to “float”. When |
input_shape |
list[int] |
No |
Specifies the shape of the input data when preprocessing is enabled, defaults to []. When |
input_range |
list[float] |
No |
Specifies the floating-point range of the input data after dequantization when preprocessing is enabled, defaults to []. When |
input_layout |
string |
No |
Specifies the layout of the input data, defaults to “” |
swapRB |
bool |
No |
Specifies whether to reverse the data in the |
mean |
list[float] |
No |
Mean value for preprocessing normalization, defaults to [0,0,0] |
std |
list[float] |
No |
Standard deviation for preprocessing normalization, defaults to [1,1,1] |
letterbox_value |
float |
No |
Specifies the fill value for letterbox preprocessing, defaults to 0 |
output_layout |
string |
No |
Specifies the layout of the output data, defaults to “” |
shape_bucket_enable |
bool |
Yes |
Specifies whether to enable ShapeBucket functionality, defaults to False. Effective when |
shape_bucket_range_info |
Dict[str, [int, int]] |
Yes |
Specifies the range of variables in each dimension of the input shape, minimum value must be greater than or equal to 1 |
shape_bucket_segments_count |
int |
Yes |
Specifies the number of segments to divide the input variable’s range |
shape_bucket_fix_var_map |
Dict[str, int] |
No |
Specifies fixed values for variables in the shape dimension information |
Preprocessing Workflow#
Currently, custom preprocessing order is not supported. You can configure the required preprocessing parameters based on the following workflow diagram.
(shape = input_shape
Parameter explanations:
input_rangespecifies the floating-point range after dequantization when the input data type is fixed-point.a. If the input data type is uint8 and the range is [0,255], setting
input_rangeto [0,255] means dequantization only converts the data type from uint8 to float32. Themeanandstdparameters should still be specified based on data in the range [0,255].b. If the input data type is uint8 and the range is [0,255], setting
input_rangeto [0,1] means dequantization will convert fixed-point data to floating-point data in the range [0,1]. Themeanandstdparameters should be specified based on data in the range [0,1].graph TD; NewInput_uint8("NewInput_uint8
[input_type:uint8]") --input_range:0,1 -->dequantize_1["Dequantize"]--float range:0,1--> OldInput_float32input_shapespecifies the shape of the input data, andinput_layoutspecifies its layout. It currently supports both string (e.g.,"NHWC","NCHW") and index formats. Non-4D data processing is also supported. When configured as a string,input_layoutspecifies the layout of the input data. When configured as an index,input_layoutspecifies the permutation parameter for aTransposeoperation.
Similarly, output_layout can be configured as shown below.
NHWC"); end
Dynamic Shape Parameters#
ShapeBucket is a solution for dynamic shapes that optimizes based on the range of input lengths and the specified number of segments. This feature is disabled by default and needs to be enabled through the corresponding option. Apart from specifying the relevant field information, the rest of the compilation process is the same as compiling a static model.
ONNX
In the shape information of a model, some dimensions may be variable names. For example, consider an ONNX model with the following inputs:
tokens: int64[batch_size, tgt_seq_len] step: float32[seq_len, batch_size]
The shape information contains three variables: seq_len, tgt_seq_len, and batch_size. Although batch_size is a variable, it is fixed to 3 in actual use. Therefore, add batch_size = 3 to fix_var_map to fix this dimension to 3 during runtime. The variables seq_len and tgt_seq_len are dynamic and need to be configured with their actual ranges in range_info. segments_count specifies the number of segments to divide the range into, which will proportionally increase the compilation time.
Here is an example of the corresponding compilation parameters:
TFLite
Unlike ONNX models, TFLite models do not currently label dimension names in the shape. Currently, only one dimension in the input can be dynamic, and it is uniformly named as -1. The configuration is as follows:
After configuring these options, the entire compilation process is the same as for a static shape model.
Parameter Configuration Example#
Instantiate CompileOptions and configure the attribute values.
compile_options.target = "cpu" # "k230"
compile_options.dump_ir = True # if False, will not dump the compile-time result.
# preprocess args
compile_options.input_layout = "NHWC" # "NHWC" "NCHW"
compile_options.std = [1,1,1]
compile_options.output_layout = "NHWC" # "NHWC" "NCHW"
# Dynamic shape args
ImportOptions#
Description:
The ImportOptions class is used to configure nncase import options.
Definition:
class ImportOptions:
def __init__(self) -> None:
pass
Instantiate ImportOptions and configure attribute values.
#import_options
PTQTensorOptions#
Description:
The PTQTensorOptions class is used to configure nncase PTQ options.
Name |
Type |
Required |
samples_count |
int |
No |
Specifies the number of samples used for the quantization calibration set |
calibrate_method |
string |
No |
Specifies the quantization method, options are ‘NoClip’ and ‘Kld’, default is ‘Kld’ |
finetune_weights_method |
string |
No |
Specifies whether to fine-tune weights, options are ‘NoFineTuneWeights’ and ‘UseSquant’, default is ‘NoFineTuneWeights’ |
quant_type |
string |
No |
Specifies the data quantization type, options are ‘uint8’, ‘int8’, ‘int16’ |
w_quant_type |
string |
No |
Specifies the weight quantization type, options are ‘uint8’, ‘int8’, ‘int16’ |
No |
The above two types cannot both be ‘int16’ |
quant_scheme |
string |
No |
Path to the quantization parameter configuration file |
quant_scheme_strict_mode |
bool |
No |
Whether to strictly follow quant_scheme for quantization |
export_quant_scheme |
bool |
No |
Whether to export the quantization parameter configuration file |
export_weight_range_by_channel |
bool |
No |
Whether to export weights quantization parameters in |
For detailed usage of mixed quantization, see MixQuant Guide
# ptq_options
ptq_options.samples_count = 6
ptq_options.quant_scheme = ""
compiler.use_ptq(ptq_options)
set_tensor_data#
Description:
Sets tensor data.
Definition:
[Parameters]
Name |
Type |
data |
List[List[np.ndarray]] |
Calibration data |
[Return Value]
# ptq_options
Compiler#
Description:
The Compiler class is used to compile neural network models.
Definition:
class Compiler:
_target: _nncase.Target
_compiler: _nncase.Compiler
_module: IRModule
import_tflite#
Description:
Imports a TFLite model.
Definition:
[Parameters]
Name |
Type |
model_content |
byte[] |
The content of the model |
import_options |
ImportOptions |
Import options |
[Return Value]
import_onnx#
Description:
Imports an ONNX model.
Definition:
[Parameters]
Name |
Type |
model_content |
byte[] |
import_options |
ImportOptions |
Import options |
[Return Value]
use_ptq#
Description:
Sets PTQ configuration options.
Quantization is mandatory for K230 by default.
Definition:
[Parameters]
Name |
Type |
ptq_options |
PTQTensorOptions |
PTQ configuration options |
[Return Value]
compile#
Description:
Compiles the neural network model.
Definition:
compile()
[Parameters]
[Return Value]
compiler.compile()
gencode_tobytes#
Description:
Generates kmodel byte stream.
Definition:
gencode_tobytes()
[Parameters]
[Return Value]
bytes[]
f.write(kmodel)
Examples#
The following examples use models and Python compilation scripts.
The original model files are located in
/path/to/k230_sdk/src/big/nncase/examples/modelsThe Python compilation scripts are located in
/path/to/k230_sdk/src/big/nncase/examples/scripts
Compiling a TFLite Model#
The mbv2_tflite.py script is as follows:
import argparse
import numpy as np
from PIL import Image
import nncase
model_content = f.read()
return model_content
data = []
for i in range(batch):
return data
def main():
args = parser.parse_args()
dump_dir = 'tmp/mbv2_tflite'
# compile_options
# compiler
# import
# ptq_options
# compile
compiler.compile()
# kmodel
f.write(kmodel)
if __name__ == '__main__':
main()
Run the following command to compile the mobilenetv2 TFLite model with the target set to k230:
Compiling an ONNX Model#
For ONNX models, it is recommended to use the ONNX Simplifier to simplify the model before using nncase to compile it.
The yolov5s_onnx.py script is as follows:
import argparse
import numpy as np
import onnxsim
import onnx
import nncase
input_tensors = [
# input
inputs = []
input_dict = {}
input_dict['name'] = e.name
inputs.append(input_dict)
return onnx_model, inputs
input_shapes = {}
for input in inputs:
return model_file
data = []
return data
data = []
return data
def main():
dump_dir = 'tmp/yolov5s_onnx'
os.makedirs(dump_dir)
# onnx simplify
# compile_options
# compiler
# import
# ptq_options
# compile
compiler.compile()
# kmodel
f.write(kmodel)
main()
Run the following command to compile the ONNX model with the target set to k230:
root@c285a41a7243:/mnt/src/big/nncase/examples# python3 ./scripts/yolov5s_onnx.py --target k230 --model models/yolov5s.onnx --dataset calibration_dataset
Simulator APIs (Python)#
In addition to model compilation APIs, nncase also provides inference APIs that allow you to run compiled kmodel on a PC to verify if the nncase inference results are consistent with the runtime results of the corresponding deep learning framework.
APIs#
MemoryRange#
Description:
The MemoryRange class is used to represent a memory range.
Definition:
.def_property(
[Attributes]
Name |
Type |
location |
int |
Memory location: 0 for input, 1 for output, 2 for rdata, 3 for data, 4 for shared_data |
dtype |
Python data type |
Data type |
start |
int |
Memory start address |
size |
int |
Memory size |
mr = nncase.MemoryRange()
RuntimeTensor#
Description:
The RuntimeTensor class is used to represent a runtime tensor.
Definition:
datatype,
.unwrap_or_throw();
arr.inc_ref();
return tensor;
return py::array(
to_dtype(tensor.datatype()),
tensor.shape(),
src_buffer.data());
[Attributes]
Name |
Type |
dtype |
Python data type |
Data type of the tensor |
shape |
list |
Shape of the tensor |
from_numpy#
Description:
Constructs a RuntimeTensor object from a numpy.ndarray.
Definition:
from_numpy(py::array arr)
[Parameters]
Name |
Type |
arr |
numpy.ndarray |
[Return Value]
RuntimeTensor
copy_to#
Description:
Copies a RuntimeTensor.
Definition:
copy_to(RuntimeTensor to)
[Parameters]
Name |
Type |
to |
RuntimeTensor |
[Return Value]
to_numpy#
Description:
Converts a RuntimeTensor to a numpy.ndarray object.
Definition:
to_numpy()
[Parameters]
[Return Value]
Simulator#
Description:
The Simulator class is used to run kmodel inference on a PC.
Definition:
.def(py::init())
[Attributes]
Name |
Type |
inputs_size |
int |
Number of inputs |
outputs_size |
int |
Number of outputs |
sim = nncase.Simulator()
load_model#
Description:
Loads a kmodel.
Definition:
load_model(model_content)
[Parameters]
Name |
Type |
model_content |
byte[] |
kmodel byte stream |
[Return Value]
sim.load_model(kmodel)
get_input_desc#
Description:
Gets the description of the input at the specified index.
Definition:
get_input_desc(index)
[Parameters]
Name |
Type |
index |
int |
Index of the input |
[Return Value]
MemoryRange
get_output_desc#
Description:
Gets the description of the output at the specified index.
Definition:
get_output_desc(index)
[Parameters]
Name |
Type |
index |
int |
Index of the output |
[Return Value]
MemoryRange
get_input_tensor#
Description:
Gets the RuntimeTensor of the input at the specified index.
Definition:
get_input_tensor(index)
[Parameters]
Name |
Type |
index |
int |
Index of the input tensor |
[Return Value]
RuntimeTensor
set_input_tensor#
Description:
Sets the RuntimeTensor of the input at the specified index.
Definition:
[Parameters]
Name |
Type |
index |
int |
tensor |
RuntimeTensor |
Input tensor |
[Return Value]
get_output_tensor#
Description:
Gets the RuntimeTensor of the output at the specified index.
Definition:
get_output_tensor(index)
[Parameters]
Name |
Type |
index |
int |
Index of the output tensor |
[Return Value]
RuntimeTensor
set_output_tensor#
Description:
Sets the RuntimeTensor of the output at the specified index.
Definition:
[Parameters]
Name |
Type |
index |
int |
tensor |
RuntimeTensor |
Output tensor |
[Return Value]
run#
Description:
Runs kmodel inference.
Definition:
run()
[Parameters]
[Return Value]
sim.run()
Examples#
Precondition: The yolov5s_onnx.py script has already compiled the yolov5s.onnx model.
The yolov5s_onnx_simu.py script is located in the /path/to/k230_sdk/src/big/nncase/examples/scripts subdirectory and contains the following content:
import copy
import argparse
import numpy as np
import onnx
import onnxruntime as ort
import nncase
def cosine(gt, pred):
def main():
# cpu inference
output_names = []
model_input_type = np.float32
cpu_results = []
# create simulator
# read kmodel
# load kmodel
# read input.bin
# set input for simulator
# simulator inference
nncase_results = []
sim.run()
# compare
main()
Run the inference script:
Comparison of nncase simulator and CPU inference results:
KPU Runtime APIs (C++)#
Introduction#
KPU Runtime APIs are used to load kmodel on AI devices, set input data, execute KPU/CPU computation, and get output data, etc.
Currently, only C++ APIs are provided. The relevant header files and static libraries are located in the /path/to/k230_sdk/src/big/nncase/riscv64 directory.
$ tree -L 3 riscv64/
riscv64/
├── gsl
│ └── gsl-lite.hpp
├── nncase
│ ├── include
│ │ └── nncase
│ └── lib
│ ├── cmake
│ ├── libfunctional_k230.a
│ ├── libnncase.rt_modules.k230.a
│ └── libNncase.Runtime.Native.a
└── rvvlib
├── include
│ ├── k230_math.h
│ ├── nms.h
│ └── rvv_math.h
└── librvv.a
8 directories, 8 files
APIs#
hrt::create#
Description:
Creates a runtime_tensor.
Definition:
(3) NNCASE_API result<runtime_tensor> create(typecode_t datatype, dims_t shape, strides_t strides, gsl::span<gsl::byte> data, bool copy, memory_pool_t pool = pool_shared_first, uintptr_t physical_address = 0) noexcept;
[Parameters]
Name |
Type |
datatype |
typecode_t |
Data type, e.g., dt_float32, dt_uint8 |
shape |
dims_t |
data |
gsl::span<gsl::byte> |
User data buffer |
copy |
bool |
Whether to copy |
pool |
memory_pool_t |
Memory pool type, default is pool_shared_first |
physical_address |
uintptr_t |
Physical address specified by the user |
[Return Value]
// create input tensor
hrt::sync#
Description:
Synchronizes the cache of the tensor.
For user input data, this interface’s
sync_write_backshould be called to ensure the data is flushed to DDR.For GNNE/AI2D computation output data, the GNNE/AI2D runtime has already performed
sync_invalidateby default.
Definition:
Parameters:
Name |
Type |
tensor |
runtime_tensor |
The tensor to operate on |
op |
sync_op_t |
force |
bool |
Whether to force execution |
Return Value:
result<void>
interpreter::load_model#
Description:
Loads a kmodel.
Definition:
Parameters:
Name |
Type |
buffer |
gsl::span <const gsl::byte> |
kmodel buffer |
Return Value:
result<void>
interpreter interp;
interpreter::inputs_size#
Description:
Gets the number of model inputs.
Definition:
Parameters:
Return Value:
size_t
interpreter::outputs_size#
Description:
Gets the number of model outputs.
Definition:
Parameters:
Return Value:
size_t
interpreter::input_shape#
Description:
Gets the shape of the specified input.
Definition:
Parameters:
Name |
Type |
index |
size_t |
Return Value:
runtime_shape_t
interpreter::output_shape#
Description:
Gets the shape of the specified output.
Definition:
Parameters:
Name |
Type |
index |
size_t |
Return Value:
runtime_shape_t
interpreter::input_tensor#
Description:
Gets/Sets the input tensor at the specified index.
Definition:
Parameters:
Name |
Type |
index |
size_t |
tensor |
runtime_tensor |
The runtime tensor for input |
Return Value:
(1) result<runtime_tensor>
(2) result<void>
// set input
interpreter::output_tensor#
Description:
Gets/Sets the output tensor at the specified index.
Definition:
Parameters:
Name |
Type |
index |
size_t |
tensor |
runtime_tensor |
The runtime tensor for output |
Return Value:
(2) result<void>
// get output
interpreter::run#
Description:
Executes KPU computation.
Definition:
result<void> run() noexcept;
Parameters:
Return Value:
result<void>
// run
Example#
#include <chrono>
#include <fstream>
#include <iostream>
#define USE_OPENCV 1
#define preprocess 1
#if USE_OPENCV
#endif
using namespace nncase;
#define INPUT_HEIGHT 224
#define INPUT_WIDTH 224
#define INPUT_CHANNELS 3
template <class T>
ifs.seekg(0, ifs.end);
size_t len = ifs.tellg();
ifs.seekg(0, ifs.beg);
ifs.close();
return vec;
ifs.read(buffer, len);
ifs.close();
std::vector<std::string> vec;
vec.reserve(1024);
std::ifstream fp(file_name);
std::string label;
while (getline(fp, label))
vec.push_back(label);
return vec;
template<typename T>
T denominator{ 0 };
denominator += dst[i];
dst[i] /= denominator;
#if USE_OPENCV
std::vector<uint8_t> vec;
cv::split(img, rgbChannels);
return vec;
#endif
// load kmodel
interpreter interp;
// Load kmodel from memory
// Load kmodel from file stream
// create output tensor
// set input data
#if USE_OPENCV
cv::resize(img, img, cv::Size(INPUT_WIDTH, INPUT_HEIGHT), cv::INTER_NEAREST);
#else
#endif
// run
size_t counter = 1;
// get output data
// postprocess softmax by cpu
size_t idx = it - buf;
// load label
if (argc != 4)
return -1;
if (ret)
return -2;
AI2D Runtime APIs (C++)#
Introduction#
AI2D Runtime APIs are used to configure AI2D parameters on AI devices, generate related register configurations, execute AI2D computations, etc. Please read the last section Precautions before use.
Supported Format Conversions#
Input Format |
Output Format |
Remarks |
YUV420_NV12 |
RGB_planar/YUV420_NV12 |
YUV420_NV21 |
RGB_planar/YUV420_NV21 |
YUV420_I420 |
RGB_planar/YUV420_I420 |
YUV400 |
YUV400 |
NCHW(RGB_planar) |
NCHW(RGB_planar) |
RGB_packed |
RGB_planar/RGB_packed |
RAW16 |
RAW16/8 |
Depth map, performs shift operation |
Function Descriptions#
Function |
Remarks |
Affine Transformation |
Supports input formats YUV420, YUV400, RGB (planar/packed); supports depth map RAW16 format; supports output formats YUV400, RGB, depth map |
Crop/Resize/Padding |
Supports input YUV420, YUV400, RGB; supports depth map RAW16 format; Resize supports intermediate NCHW arrangement format; supports output formats YUV420, YUV400, RGB |
Only supports constant padding |
Shift |
Supports input format Raw16; supports output format Raw8 |
Sign Bit |
Supports signed and unsigned input |
APIs#
ai2d_format#
Description:
ai2d_format is used to configure the optional data formats for input and output.
Definition:
enum class ai2d_format
YUV420_NV12 = 0,
YUV420_NV21 = 1,
YUV420_I420 = 2,
NCHW_FMT = 3,
RGB_packed = 4,
RAW16 = 5,
ai2d_interp_method#
Description:
ai2d_interp_method is used to configure the optional interpolation methods.
Definition:
enum class ai2d_interp_method
tf_nearest = 0,
tf_bilinear = 1,
cv2_nearest = 2,
cv2_bilinear = 3,
ai2d_interp_mode#
Description:
ai2d_interp_mode is used to configure the optional interpolation modes.
Definition:
enum class ai2d_interp_mode
none = 0,
align_corner = 1,
half_pixel = 2,
ai2d_pad_mode#
Description:
ai2d_pad_mode is used to configure the optional padding modes. Currently, only constant padding is supported.
Definition:
enum class ai2d_pad_mode
constant = 0,
copy = 1,
mirror = 2,
ai2d_datatype_t#
Description:
ai2d_datatype_t is used to set the data types during the AI2D computation process.
Definition:
struct ai2d_datatype_t
ai2d_format src_format;
ai2d_format dst_format;
datatype_t src_type;
datatype_t dst_type;
Parameters:
Name |
Type |
src_format |
ai2d_format |
Input data format |
dst_format |
ai2d_format |
Output data format |
src_type |
datatype_t |
Input data type |
dst_type |
datatype_t |
Output data type |
src_loc |
ai2d_data_loc |
Input data location, default is DDR |
dst_loc |
ai2d_data_loc |
Output data location, default is DDR |
ai2d_crop_param_t#
Description:
ai2d_crop_param_t is used to configure parameters related to cropping.
Definition:
struct ai2d_crop_param_t
bool crop_flag = false;
int32_t start_x = 0;
int32_t start_y = 0;
int32_t width = 0;
int32_t height = 0;
Parameters:
Name |
Type |
crop_flag |
bool |
Whether to enable cropping |
start_x |
int |
Starting pixel in the width direction |
start_y |
int |
Starting pixel in the height direction |
int |
Crop length in the width direction |
int |
Crop length in the height direction |
ai2d_shift_param_t#
Description:
ai2d_shift_param_t is used to configure parameters related to shifting.
Definition:
struct ai2d_shift_param_t
bool shift_flag = false;
int32_t shift_val = 0;
Parameters:
Name |
Type |
shift_flag |
bool |
Whether to enable shifting |
shift_val |
int |
Number of bits to shift right |
ai2d_pad_param_t#
Description:
ai2d_pad_param_t is used to configure parameters related to padding.
Definition:
struct ai2d_pad_param_t
bool pad_flag = false;
runtime_paddings_t paddings;
Parameters:
Name |
Type |
pad_flag |
bool |
Whether to enable padding |
paddings |
runtime_paddings_t |
Padding for each dimension, shape= |
pad_mode |
ai2d_pad_mode |
Padding mode, only constant padding is supported |
pad_val |
std::vector<int32_t> |
Padding value for each channel |
ai2d_resize_param_t#
Description:
ai2d_resize_param_t is used to configure parameters related to resizing.
Definition:
struct ai2d_resize_param_t
bool resize_flag = false;
Parameters:
Name |
Type |
resize_flag |
bool |
Whether to enable resizing |
interp_method |
ai2d_interp_method |
Interpolation method for resizing |
interp_mode |
ai2d_interp_mode |
Resize mode |
ai2d_affine_param_t#
Description:
ai2d_affine_param_t is used to configure parameters related to affine transformations.
Definition:
struct ai2d_affine_param_t
bool affine_flag = false;
uint32_t cord_round = 0;
uint32_t bound_ind = 0;
int32_t bound_val = 0;
uint32_t bound_smooth = 0;
std::vector<float> M;
Parameters:
Name |
Type |
affine_flag |
bool |
Whether to enable affine transformations |
interp_method |
Interpolation method used for affine transformations |
cord_round |
uint32_t |
Integer boundary, 0 or 1 |
bound_ind |
uint32_t |
Boundary pixel mode, 0 or 1 |
bound_val |
uint32_t |
Boundary fill value |
bound_smooth |
uint32_t |
Boundary smoothing, 0 or 1 |
M |
std::vector<float> |
Vector corresponding to the affine transformation matrix. For affine transformation \(Y=\[a_0, a_1; a_2, a_3\] \cdot X + \[b_0, b_1\]\), \(M=\{a_0,a_1,b_0,a_2,a_3,b_1\}\) |
ai2d_builder::ai2d_builder#
Description:
Constructor for ai2d_builder.
Definition:
Parameters:
Name |
Type |
input_shape |
dims_t |
Input shape |
output_shape |
dims_t |
Output shape |
ai2d_dtype |
ai2d_datatype_t |
AI2D data type |
crop_param |
ai2d_crop_param_t |
Crop parameters |
shift_param |
ai2d_shift_param_t |
Shift parameters |
pad_param |
ai2d_pad_param_t |
Pad parameters |
resize_param |
ai2d_resize_param_t |
Resize parameters |
affine_param |
ai2d_affine_param_t |
Affine parameters |
Return Value:
ai2d_builder::build_schedule#
Description:
Generates the parameters required for AI2D computation.
Definition:
Parameters:
Return Value:
result<void>
ai2d_builder::invoke#
Description:
Configures the registers and starts the AI2D computation.
Definition:
Parameters:
Name |
Type |
input |
runtime_tensor |
Input tensor |
output |
runtime_tensor |
Output tensor |
Return Value:
result<void>
// run ai2d
Example#
// input tensor
// output tensor
// config ai2d
// run
// compare
if (!ret)
else
Notes#
Affine and Resize functions are mutually exclusive and cannot be enabled simultaneously.
The input format for the Shift function can only be Raw16.
The pad value is configured per channel, and the number of elements in the list should be equal to the number of channels.
In the current version, when only one AI2D function is needed, other parameters also need to be configured, with the flag set to false, and other fields do not need to be configured.
When configuring multiple functions, the execution order is Crop->Shift->Resize/Affine->Pad. Ensure the parameters match accordingly.
