K230 SDK EVB Board Demo User Guide
Contents
K230 SDK EVB Board Demo User Guide#
This document introduces the demo functions provided by the K230 SDK and their usage. The executable programs on rt-smart are all compiled into the small core/sharefs directory by default. When testing the large core program, you need to wait for the small core to fully start, then enter the /sharefs/app directory in the large core’s msh to test. The audio and video resource files used in each test demo can be obtained from the following link: https://kendryte-download.canaan-creative.com/k230/downloads/test_resource/
Demo Introduction#
Display_demo#
Introduction to display_demo#
The VO (Video Output) module actively reads video and graphic data from the corresponding position in the memory and outputs video and graphics through the corresponding display device. The chip supports display/write-back devices, video layers, and graphic layers.
Feature Description#
Video output includes three use cases: a self-test mode for DSI, a binding test for VO and VVI, and a frame insertion test for the VO layer.
Dependency Resources#
A screen is needed.
Usage Instructions#
Compilation#
Execution#
To run the DSI self-test mode demo:
./sample_vo.elf 2
A color bar image will be displayed on the screen, as shown below:
Auto-generated background pattern description
  1. To run the VO and VVI binding demo:
    ./sample_vo.elf 9
    Press Enter once to start sending ARGB data from VVI, press Enter again to exit the program. The display effect alternates between red, green, and blue primary colors, as shown below:
    Image description
  2. To run the VO layer frame insertion demo:
    ./sample_vo.elf 7
    After executing the command, press Enter once to insert an image from the user layer, press Enter again to exit the program. The display effect is as follows:
    Image description
Venc_demo#
Introduction to Venc_demo#
The Venc demo encodes the graphics received by VI and can add frames and OSD overlays to the input image. It supports H.264/H.265/JPEG encoding protocols. The encoding results can be stored as files, exported locally, and played using video software.
A camera is needed.
Usage Instructions#
mpp_demo Execution#
After executing ./sample_venc.elf -h, the usage instructions for the demo will be output, as follows:
index:
    0) H.265e.
    1) JPEG encode.
    2) OSD + H.264e.
    3) OSD + Border + H.265e.
sensor_index: see vicap doc
The sensor_index value can be found in the k230_docs/zh/01_software/board/mpp/K230_Camera_Sensor_Adaptation_Guide.md document under the description of k_vicap_sensor_type, with a default value of 7.
MAPI Encoding Demo#
The sample_venc default sensor type is IMX335_MIPI_2LANE_RAW12_1920X1080_30FPS_LINEAR. Currently, this demo supports 3-channel encoding. The sensor type and other parameters can be modified via command-line arguments, as described below:
  1. Check if the k_ipcm module is loaded on the small core side using lsmod. If not, execute insmod k_ipcm.ko to load the k_ipcm module.
  2. Start the inter-core communication process on the large core side by executing ./sample_sys_inif.elf.
  3. On the small core side, in the /mnt directory, execute ./sample_venc. By default, it performs 1-channel H.264 video encoding with a resolution of 1280x720. The generated stream file is stored in the /tmp directory. To pass parameters, refer to the following parameter description:
                            see vicap doc
                     -t or --type [type_index]
                            0: h264 type
                            1: h265 type
                            2: jpeg type
You can stop the execution using ctrl+c. Depending on the encoding type, different stream files will be generated in the specified output directory on the small core. For H.264 type, a file like stream_chn0.264 will be generated, where 0 represents channel 0; For H.265 type, a file like stream_chn0.265 will be generated, where 0 represents channel 0; For JPEG type, files like chn0_0.jpg will be generated, representing the 0th image of channel 0, with 10 JPEG images generated by default.
Viewing Results#
The output files can be exported locally and viewed using video playback software.
Nonai_2d_demo#
Introduction to Nonai_2d_demo#
The Nonai_2d demo implements image overlay functionality on input files.
Nonai_2d performs image overlay operations by reading YUV (I420 format) files.
None.
Usage Instructions#
Input parameters are as follows:
Parameter
Default Value
-i
Input file name
-w
Image width
-h
Image height
-o
Output file name
Execution#
Viewing Results#
The output file can be exported locally and viewed using YUV playback software.
Vdec_demo#
Introduction to Vdec_demo#
The Vdec demo implements video decoding functionality. It supports H.264/H.265/JPEG decoding. The supported input data formats are .264/.264/.jpeg.
The Vdec demo decodes stream files and displays the decoded output on the screen.
None.
Usage Instructions#
Execution#
Executing ./sample_vdec.elf -help shows the configurable parameters and their descriptions, with default values as shown in the table below:
Parameter
Default Value
i
Input file name, with extensions .264/.265/.jpg
VO connector type, refer to VO document description
The type value is described in the k230_docs/zh/01_software/board/mpp/K230_Video_Output_API_Reference.md document under the description of k_connector_type, set to 0.
Viewing Results#
Audio_demo#
Introduction to audio_demo#
The audio demo implements audio input and output functions by calling API interfaces. Audio input includes I2S and PDM modules, and audio output includes the I2S module. The demo includes use cases for individually testing audio input or output, as well as use cases for simultaneously testing audio input and output.
Audio Input#
Audio input captures ambient sound and saves it to a file for analysis to determine if it is functioning correctly.
Audio input includes tests for the I2S and PDM modules. The demo captures 15 seconds of audio data, and the captured file format is WAV, which can be played directly using VLC. The I2S audio input has 2 groups, with the demo defaulting to using group 0 for audio input. The PDM audio input has 4 groups, with the demo defaulting to using group 0 for audio input.
Audio Output#
Audio output plays a WAV file, and the sound can be heard through headphones to determine if it is functioning correctly.
Audio output only includes the I2S module test. The demo tests the audio output function by playing a WAV file. Different audio format WAV files can be uploaded to test the audio output function. The I2S audio output has 2 groups, with the demo defaulting to using group 0 for audio output.
Audio Input and Output#
  1. Test the i2s module functionality: Real-time collection of ambient sound through i2s audio input and output through i2s audio output. You can listen to the ambient sound in real-time using headphones.
  2. Test the pdm module functionality: Real-time collection of ambient sound through pdm audio input and output through i2s audio output. You can listen to the ambient sound in real-time using headphones.
Audio Codec#
Notes#
  1. The built-in codec supports a maximum sampling precision of 24bit; 32bit is not supported. Therefore, when testing i2s audio input and output using the built-in codec, only 16/24 bit sampling precision is supported.
  2. The audio sub-board i2s loopback test only supports 32bit sampling precision. The reason is as follows:
    The audio sub-board uses the MSM261S3526Z0CM silicon microphone for collection, which is in I2S Philips format. The audio sub-board output uses the codec tm8211, which is in i2s right-aligned format with 16bit sampling. Since the i2s module uses the same ws for transmission and reception, only one i2s alignment format can be configured when running simultaneously. To correctly collect audio data, the i2s transmission and reception are configured to I2S Philips format to adapt to the MSM261S3526Z0CM silicon microphone. However, the output is in right-aligned format, so the output data loses precision. But using 32bit precision for transmission and reception is not affected by the i2s alignment format, so there is no impact.
    If testing audio input or output separately, it is not affected by sampling precision, and 16/24/32bit are all supported.
  3. When collecting audio using the audio sub-board, the supported sampling rate range is (8k~48k).
    The audio sub-board collection module uses the MSM261S3526Z0CM silicon microphone, with a maximum clock of 4MHz. When the sampling rate is 96k (6.144MHz) and 192k (12.288MHz), the collected sound from the audio sub-board will be abnormal.
  1. Audio testing depends on the audio sub-board.
The audio sub-board schematic is as follows:
Diagram, schematic
Diagram, schematic
When testing i2s input and output, the audio sub-board can be connected as follows using jumper caps:
Jumper caps for i2s
For pdm audio collection, when collecting data from the 0th or 1st pdm channel, it does not conflict with i2s pins.
When using the 2nd and 3rd pdm channels, jumper caps are needed to switch to pdm channel mode, as follows:
Jumper caps for pdm
Usage Instructions#
Compilation#
  2. Set up the sharefs environment, as reading and writing files depend on sharefs.
Execution#
After entering the rt-smart system, navigate to the /sharefs directory. sample_audio.elf is the test demo.
  • You can input ./sample_audio.elf -help to view the demo usage method.
  • Use the -type option to test different module functions.
  • Use the -samplerate option to configure different sampling rates for audio input and output (8k-192k), with a default of 44.1k.
  • Use the -enablecodec option to use the built-in codec or external audio sub-board.
  • Use the -loglevel option to set the kernel log level.
  • Use the -bitwidth option to set audio sampling precision (16/24/32).
  • Use the -filename option to load or save wav/g711 files.
Text description auto-generated
I2S Audio Input Test#
  • Input ./sample_audio.elf -type 0 to collect 15s of pcm audio data.
  • Use the -samplerate option to select the sampling rate for audio collection.
  • Use the -bitwidth option to set the sampling precision.
  • Use the -enablecodec option to set whether to use the built-in codec.
  • Use the -filename option to save data to a file. After collecting 15s of data, the demo automatically exits.
The demo implementation idea: This test collects data by looping the API functions: kd_mpi_ai_get_frame and kd_mpi_ai_release_frame. Note that the ai dev number corresponding to i2s is 0.
i2s input
PDM Audio Input Test#
  • Input ./sample_audio.elf -type 1 to collect 15s of pcm audio data.
  • Use the -enablecodec option to set whether to use the built-in codec. After collecting 15s of data, the demo automatically exits and saves the data to a file.
The demo implementation idea: This test collects data by looping the API functions: kd_mpi_ai_get_frame and kd_mpi_ai_release_frame. Note that the ai dev number corresponding to pdm is 1.
pdm in log
I2S Audio Output Test#
Supports playing wav files, which need to be copied to the sharefs path. This demo will loop playback of the wav file (any other wav file can also be used). Users can press any key to exit the function test.
The demo implementation idea: This test outputs sound in real-time by looping the API function: kd_mpi_ao_send_frame.
Input ./sample_audio.elf -type 3 -bitwidth 32 to test audio input and output functionalities in real-time through the API interface.
The overall functionality of audio input and output is tested by calling the API interface: kd_mpi_ai_get_frame to get audio data and kd_mpi_ao_send_frame to output audio data. Users can press any key to exit the function test. During the test, the timestamp information collected by ai is output in real-time.
Image description
I2S Audio Input and Output Module System Binding Test#
Input ./sample_audio.elf -type 4 to test audio input and output functionalities in real-time by binding the ai and ao modules.
The overall functionality of audio input and output is tested by calling the system binding API interface: kd_mpi_sys_bind to bind the ai and ao modules. Users can press any key to exit the function test.
PDM Audio Input, I2S Output API Interface Test#
Input ./sample_audio.elf -type 5 -bitwidth 32 to test audio input and output functionalities in real-time through the API interface.
pdm in i2s out log
PDM Audio Input, I2S Output System Binding Test#
Input ./sample_audio.elf -type 6 -bitwidth 32 to test audio input and output functionalities in real-time by binding the ai and ao modules.
pdm in is2 out bind
Encoding Test#
Collect ai data and encode it to save to a file. Encoding and decoding only support g711a/u, 16bit.
System binding method: ./sample_audio.elf -type 7 -bitwidth 16 -enablecodec 1 -filename /sharefs/i2s_codec.g711a
audio enc bind log
API interface method: ./sample_audio.elf -type 9 -bitwidth 16 -enablecodec 1 -filename /sharefs/i2s_codec.g711a
audio enc log
Decoding Test#
Read file data and decode it for playback. Encoding and decoding only support g711a/u, 16bit.
System binding method: ./sample_audio.elf -type 8 -filename /sharefs/gyz.g711a -enablecodec 1 -bitwidth 16
audio dec bind
API interface method: ./sample_audio.elf -type 10 -filename /sharefs/gyz.g711a -enablecodec 1 -bitwidth 16
audio dec
Full Audio Process Test#
  1. Recording module ai->aenc->file and playback module file->adec->ao two paths run simultaneously, simulating a voice intercom scenario. Use the built-in codec with 16bit precision for simulation. Use -filename to choose the file to be played, in g711a format, and -samplerate to choose the sampling precision. The recording file name is the playback file name followed by _rec: for example, if -filename is /sharefs/test.g711a, the recording file name will be /sharefs/test.g711a_rec.
Image description
  1. ai->aenc, adec->ao two paths binding loopback test. Use the built-in codec with 16bit precision for simulation.
Simultaneously test the timestamp of the stream after g711 encoding.
Image description
Input cat /proc/umap/sysbind to view the system binding between modules.
Image description
MAPI Audio Test#
Ensure the inter-core communication process is started on the large core: execute on the large core: /bin/sample_sys_init.elf & Ensure the small core loads the inter-core communication driver module: insmod /mnt/k_ipcm.ko
  • You can input /mnt/sample_audio -help to view the demo usage method.
  • Use the -enablecodec option to use the built-in codec or external audio sub-board, with the built-in codec used by default.
  • Use the -filename option to load or save g711 files.
  • Use the -channels option to specify the number of channels.
image-20230530101801685
  • ai->aenc test
Execute the command on the small core: /mnt/sample_audio -type 0 -filename test.g711a, press the q key to exit the test. The demo can collect audio data in real-time, encode it into g711a format, and save it to a file.
image-20230530102014642
  • adec->ao test
Execute the command on the small core: /mnt/sample_audio -type 1 -filename tes.g711a, press the q key to exit the test. The demo can loop decode and play local g711a format files.
Translation to English#
image-20230530102747862
  • ai->aenc adec->ao loopback test
Execute the command on the small core: /mnt/sample_audio -type 2, press the q key to exit the test. The demo can collect audio data in real-time, encode it into g711a format, and then decode the g711a format data for playback output. image-20230530102916366
Vicap_demo#
Introduction to vicap_demo#
The vicap demo implements camera data collection and preview functionality by calling the mpi interface.
The current version supports image collection and preview for three camera modules: OV9732, OV9286, and IMX335. It supports up to three data streams per camera and up to three camera data inputs.
Camera module
Usage Instructions#
Compilation#
  1. Execute make mpp-clean && rt-smart && make build-image in the k230_sdk directory to compile the modifications into the SD card image. The image file sysimage-sdcard.img will be generated in the k230_sdk/output/k230_evb_defconfig/images/ directory.
Execution#
  2. Mount this directory to the small core Linux /sharefs via NFS.
  3. On the large core, navigate to /sharefs using the cd /sharefs command.
When the sample_vicap command is entered, the following prompt information is printed:
Options:
 -mode:         vicap work mode[0: online mode, 1: offline mode. only offline mode supports multiple sensor input]     default 0
 -ofmt:         the output pixel format[0: yuv, 1: rgb888, 2: rgb888p, 3: raw], only channel 0 supports raw data, default yuv
Parameter description:
Parameter Name
Optional Values
-dev
0: vicap device 0, 1: vicap device 1, 2: vicap device 2.
Specifies the vicap device to use. The system supports up to three vicap devices. By specifying the device number, the binding relationship between the sensor and different vicap devices is achieved. For example: -dev 1 -sensor 0 means binding the OV9732 1280x720 RGB image output to vicap device 1.
-mode
Specifies the work mode of the vicap device. Currently supports online and offline modes. For multiple sensor inputs, it must be specified as offline mode.
-sensor
0: ov9732@1280x720, 1: ov9286_ir@1280x720, 2: ov9286_speckle@1280x720, 3: imx335_2lan@1920x1080, 4: imx335_2lan@2592x1944, 5: imx335_4lan@2592x1944
Specifies the type of sensor to use. The current system supports three types of image output: OV9732 1280x720 RGB image output, OV9286 1280x720 infrared image output, OV9286 1280x720 speckle image output. The IMX335 outputs RGB images.
-chn
0: vicap device output channel 0, 1: vicap device output channel 1, 2: vicap device output channel 2.
Specifies the output channel of the vicap device. A vicap device supports up to three outputs, only channel 0 supports RAW image format output.
-ow
Specifies the output image width, default is the input image width. The width needs to be aligned to 16 bytes. If the default width exceeds the maximum display output width, the display output width will be used as the final output width. If the output width is smaller than the input image width and the ox or oy parameters are not specified, it defaults to scaled output.
-oh
Specifies the output image height, default is the input image height. If the default height exceeds the maximum display output height, the display output height will be used as the final output height. If the output height is smaller than the input image height and the ox or oy parameters are not specified, it defaults to scaled output.
-ox
Specifies the horizontal starting position of the image output. If this parameter is greater than 0, crop operation will be performed.
-oy
Specifies the vertical starting position of the image output. If this parameter is greater than 0, crop operation will be performed.
-crop
0: Disable crop function, 1: Enable crop function
-ofmt
-preview
0: Disable preview display, 1: Enable preview display
Specifies the output image preview display function. Default is enabled. Currently supports up to 2 output image previews simultaneously.
-rotation
0: rotate 0 degrees, 1: rotate 90 degrees, 2: rotate 180 degrees, 3: rotate 270 degrees, 4: unsupported rotation, 17 use gdma rotate 90 degrees, 18 use gdma rotate 180 degrees, 19 use gdma rotate 270 degrees
Specify the rotation angle of the preview display window. only the first output image window supports the vo rotation function, all output image window supports gdma rotation function.
Example 1:
Description: Binds OV9732@1280x720 RGB to vicap device 0, and enables vicap device output channels 0 and 1. Channel 0 output size defaults to input image size (1280x720), channel 1 output image size is 640x480.
Example 2:
Description: Three-way input and output. Binds OV9732@1280x720 RGB to vicap device 0 and sets channel 0 output size to 1080x720; binds OV9286@1280x720 infrared to vicap device 1 and sets channel 0 output size to 1080x720; binds OV9286@1280x720 speckle to vicap device 2 and sets channel 0 output size to 1080x720 (no preview).
DMA_demo#
Introduction to DMA_demo#
Non-binding Mode#
DMA channels 0-3 are GDMA, channels 4-7 are SDMA.
  • Channel 0 continuously inputs images with a resolution of 1920x1080, 8bit, YUV400, single-channel mode, rotates 90 degrees and outputs, and compares with golden data.
  • Channel 1 continuously inputs images with a resolution of 1280x720, 8bit, YUV420, dual-channel mode, rotates 180 degrees and outputs, and compares with golden data.
  • Channel 2 continuously inputs images with a resolution of 1280x720, 10bit, YUV420, triple-channel mode, x-mirror, y-mirror and outputs, and compares with golden data.
  • Channel 4 performs 1D mode cyclic transfer of a segment of data, and compares with golden data after the transfer is complete.
  • Channel 5 performs 2D mode cyclic transfer of a segment of data, and compares with golden data after the transfer is complete.
Binding Mode#
Uses VVI as DMA simulated input. Channel 0 of VVI device 0 is bound to DMA channel 0, and channel 1 of VVI device 0 is bound to DMA channel 1. VVI inputs a 640x320, YUV400, 8bit, rotated 90° image to channel 0 every second, and inputs a 640x320, YUV400, 8bit, rotated 180° image to channel 1.
Includes DMA device attribute configuration, channel attribute configuration, graphic input, output, release, and pipeline binding functions.
Usage Instructions#
Compilation#
Execution#
  1. Non-binding mode demo run
/bin/sample_dma.elf
Test information will be displayed on the screen, input q to end the run.
  1. Binding mode demo run
/bin/sample_dma_bind.elf
DPU_demo#
Introduction to dpu_demo#
Non-binding Mode#
Parses parameters from the configuration file and configures the DPU’s device and channel attributes, reads and configures reference and template images from the specified path, loops input of infrared and speckle images, obtains results and checks if the calculations are correct.
Binding Mode#
Parses parameters from the configuration file and configures the DPU’s device and channel attributes, reads and configures reference and template images from the specified path, binds the pipeline using VVI as the simulated front-end, inputs infrared and speckle images, DPU calculates the results, user space obtains the results and saves the depth map as a file (the depth map can be opened with appropriate software), press q to exit the program.
Includes configuration file parsing, device and channel attribute configuration, device and channel start and stop, user space input data, output results, release results, and pipeline binding input and output.
Usage Instructions#
Compilation#
Refer to the README.md in the SDK for the software compilation environment. Since this module requires dependent files, the following steps need to be performed during compilation:
Execution#
  1. The configuration files and input/output golden data required for the demo are stored in the k230_sdk/test_resource/dpu directory. To facilitate use, you can copy the entire dpu folder to the /sharefs/ directory (refer to the corresponding documentation for the use of sharefs). After copying, the /sharefs/dpu/ directory will exist in the large core.
  2. Copy k230_sdk/src/big/mpp/userapps/sample/elf/sample_dpu.elf to the /sharefs/ directory.
  3. Non-binding mode demo run
    Test information will be displayed on the screen, and the run will end after 10 frames. In the above command, the parameter /sharefs/dpu/ can be set according to the actual path where the user’s configuration files are stored.
  4. Binding mode demo run
    Test information will be displayed on the screen, input q to end the run. In the above command, the parameter /sharefs/dpu/ can be set according to the actual path where the user’s configuration files are stored.
UVC_demo#
Introduction to uvc_demo#
The uvc demo treats the K230 development board as a USB camera. When connected to a PC via a USB cable, the PC’s player can display the real camera’s image.
The current version supports bulk transfer and ISO transfer.
The current version only supports 640x480 NV12 format images and 1280x720 H264/MJPEG format images.
Supports PID, VID, and device name configuration through modification of shell scripts.
Camera module, OV9732/IMX335 camera.
PC camera application or PotPlayer software installed.
Usage Instructions#
Compilation#
  1. The source code for the small core user program is located at cdk/user/mapi/sample/camera.
  2. The small core driver program is located at linux/drivers/usb/dwc2.
  3. The small core driver program is located at linux/drivers/usb/gadget.
  4. The large core program involves the mpp repository and cdk.
The large core RTT implements the camera driver functionality.
The small core Linux implements the USB driver functionality and obtains camera images from the large core through mapi.
Refer to K230_USB Application Practical_UVC Transmission of YUV and Encoded Streams.
Execution#
After entering the large core rt-smart system, navigate to the /bin directory and execute:
./canaan-camera.sh start otg0
./camera -t 7
Connect the USB0 of the development board to the PC using a type-C USB cable, and use PotPlayer to play the camera.
By default, BULK transfer is used. You can switch to ISO transfer using the following commands:
./canaan-camera.sh stop
./camera -i -t 7
The -t option is used to specify the vicap sensor type. Refer to the k230_docs/zh/01_software/board/mpp/K230_Camera_Sensor适配指南.md document for the description of k_vicap_sensor_type. The default value is 7.
In PotPlayer, go to Options -> Device -> Camera interface, Video Capture Device -> Device, select UVC Camera Video Capture Device -> Format, select H264 1280*720 30(P 16:9) or MJPG 1280*720 30(P 16:9) or NV12 640*360p 30(P 16:9)
USB_demo#
Introduction to USB_demo#
The USB demo currently supports four functionalities.
Since the upgrade function of K230 can only use USB0, USB0 is set as a device to simulate a USB drive and a mouse/keyboard. The jumper cap should not connect pin1/pin2 of J5, as the device cannot enable 5V power supply.
As a host, it can connect to a USB drive and a mouse/keyboard. The jumper cap needs to connect pin3/pin4 of J5 to enable 5V power supply.
The USB demo functionality is integrated into the Linux system.
Usage Instructions#
Simulate a USB Drive as a Device#
# Allocate a memory space as the disk space for the simulated USB drive.
2+0 records in
2+0 records out
mkfs.fat 4.1 (2017-01-24)
# Use the FAT partition of the SD/eMMC as the disk space for the simulated USB drive.
Connect USB0 of the development board to the PC using a type-C cable. The PC will display a connected USB drive.
Connect a USB Drive as a Host#
The K230 development board connects USB1 to a USB drive using a Type-C to Type-A adapter.
Simulate a Mouse/Keyboard as a Device#
The K230 development board connects USB0 to another computer using a Type-C cable for testing.
# Follow the prompts to input corresponding operations, such as -123 -123, to see the mouse pointer move on the PC.
# Follow the prompts to input corresponding operations, which will simulate keyboard input on the PC. For example, a b c --return
Connect a Mouse/Keyboard as a Host#
The K230 development board connects USB1 to a mouse or keyboard using a Type-C to Type-A adapter.
# Use the following command to determine the event corresponding to the input device. If the K230 development board is not connected to a screen, connecting a mouse or keyboard will change the corresponding event.
U: Uniq=
H: Handlers=event2
B: PROP=0
B: EV=17
B: KEY=ffff0000 0 0 0 0
B: REL=1943
B: MSC=10
# Click or move the mouse, and the corresponding display will appear in the serial port.
# Press different keys on the keyboard, and the corresponding display will appear in the serial port.
GPU_demo#
Introduction to GPU_demo#
  • tiger: Draws a vector illustration of a tiger.
The GPU demo mainly covers three functionalities: vector drawing, linear gradient (implemented through pattern), and color lookup table.
Writable file system.
Usage Instructions#
Navigate to a writable directory and execute the program.
tiger#
Run the tiger command. After execution, a tiger.png file will be generated in the current directory, as shown below:
Tiger Image
linearGrad#
Run the linearGrad command. After execution, a linearGrad.png file will be generated in the current directory, as shown below:
Linear Gradient
imgIndex#
Run the imgIndex command. After execution, four image files will be generated in the current directory, as shown below:
index1
index2
index4
index8
vglite_drm#
Run the vglite_drm command. The GPU will display the pattern on the LCD screen, and pressing the Enter key again will display the next pattern, as shown below:
First Pattern
Second Pattern
vglite_cube#
Run the vglite_cube command. The GPU will display a rotating cube on the LCD screen, as shown below:
Cube
During the demo run, the kernel will print a lot of messages. If you do not want to display these messages, you can reduce the kernel print level:
sysctl -w kernel.printk=6
DRM Display Demo#
Introduction to the Demo#
This demo runs on the Linux system of the K230 small core and displays images on the screen.
  1. DRM supports operations on 5 layers, including 1 video layer and 4 OSD layers.
LCD screen.
Usage Instructions#
Compilation#
Execution#
modetest -M canaan-drm -D 0 -a -s 38@36:1080x1920-30  -P 31@36:1080x1920@NV12 -v -F smpte
After executing the above command, a color bar will be displayed on the LCD screen, as shown below:
Image Description
LVGL Demo#
This demo runs on the Linux system of the K230 small core and displays a configuration interface on the screen, which supports touch operations.
LCD screen.
  1. Supports button and slider functionalities.
  2. Supports touch functionality.
Usage Instructions#
Compilation#
Execution#
lvgl_demo_widgets
After executing the above command, a configuration interface will be displayed on the LCD screen, which can be configured through the touchscreen, as shown below:
Image Description
RTSP Streaming Demo#
This demo supports simultaneous streaming of audio and video streams to an RTSP server, using the mapi venc&aenc interface to encode audio and video. After streaming, the URL can be pulled for playback. Currently, this demo supports streaming and pulling for up to 3 URLs.
A USB to Ethernet adapter is needed to connect the development board to a network cable.
Usage Instructions#
Compilation#
Refer to the README.md in the release SDK software package for compilation instructions. In the Docker environment, compile cdk-user, and the executable program rtsp_demo will be generated in k230_sdk/src/common/cdk/user/out/little.
Execution#
By default, rtsp_demo uses the sensor type IMX335_MIPI_2LANE_RAW12_1920X1080_30FPS_LINEAR. You can modify the sensor type and other parameters through command-line arguments. Detailed instructions are as follows:
  2. On the large core side, start the inter-core communication process by executing /sharefs/app/sample_sys_init.elf.
  3. On the small core side, navigate to the /mnt directory and execute ./rtsp_demo. By default, it streams one H.265 video stream with a resolution of 1280x720. For parameter descriptions, see below. When streaming MJPEG streams, the maximum supported resolution is currently 2032x1944, and the minimum resolution is 640x480.
                    -s: the sensor type:
                        see vicap doc
                    -w: the video encoder width
                    -h: the video encoder height
                    -a: audio input type (0: mic input, 1: headphone input), default 0.
The sensor type values can be found in the k230_docs/zh/01_software/board/mpp/K230_Camera_Sensor适配指南.md document under the description of k_vicap_sensor_type. The audio input type can be selected as onboard mic or headphone input.
After rtsp_demo runs successfully on the small core, it will print a URL in the form of rtsp://ip:8554/session0, where 0 represents the first stream. You can use VLC to pull the stream from the URL for playback. To stop the stream, first stop VLC from pulling the stream, then execute ctrl+c to stop rtsp_demo.
FaceAeDemo#
Demo Introduction#
This demo is used on the large core and is a demo for joint debugging of VICAP, KPU, VO (video output), and AERoi. It can appropriately adjust the face exposure brightness through the face detection interface.
Compilation#
  1. First, refer to the README.md in the release SDK package and use Docker to compile the image.
  2. After compilation, the sample (sample_face_ae.elf) will be stored by default in the path k230_sdk/src/big/mpp/userapps/sample/elf.
  3. Since the KPU linkage requires the use of the detection model test.kmodel, the compiled path is k230_sdk/src/big/mpp/userapps/sample/elf.
Execution#
After starting the development board, enter the small core /mnt directory, add the inter-core communication module, start inter-core communication, and create a shared file system. Share sample_face_ae.elf and test.kmodel with the large core through the small core shared file system. You can transfer files to the small core file system through methods such as mounting or TFTP. Currently, the default files are already stored in the small core ~ directory.
cd /mnt
insmod k_ipcm.ko
mkdir /sharefs
cp test.kmodel /sharefs/
./sharefs &
After the small core starts sharefs, the large core shared file system will obtain the sample and kmodel.
cd /sharefs
./sample_face_ae.elf test.kmodel 1 # arg1: model name, arg2: enable face ae
Wait for initialization to complete and prompt any letter + enter.
Type 'a', press enter, and run the face ae demo.
After successful execution, the physical address of each frame of the image will be printed.
DPU_Vicap_demo#
Demo Introduction#
The demo process is as follows:
  1. Start VICAP.
  2. Dump a frame of speckle image in user space.
  3. Send the speckle image obtained from VICAP to DMA for 90-degree rotation processing.
  4. Get the rotated image from DMA in user space.
  5. Send the rotated image from DMA to DPU for depth processing.
  6. Get the depth image processed by DPU in user space.
  7. Save it as a file in the large and small core shared directory /sharefs. You can share this file to the server through mnt and use tools to view the depth image.
ISP captures images, DMA performs image rotation, and DPU performs depth processing.
Calibration files are needed, including configuration files and reference image files. The configuration files and reference image files need to match the sensor. The configuration files and reference image files are located in the path k230_sdk/test_resource/dpu, and these files only correspond to sensor1.
Usage Instructions#
Compilation#
  1. Place the configuration files and reference image files in the directory k230_sdk/src/big/rt-smart/userapps/root/bin/dpu, as shown below: conf_file
  2. Execute the compilation command make in the k230_sdk directory.
  3. After compilation, the demo file sample_dpu_vicap.elf will be in the directory k230_sdk/src/big/mpp/userapps/sample/elf. The system image file sysimage-sdcard.img will be in the directory k230_sdk/output/k230_evb_defconfig/images.
For more detailed compilation process, refer to the README.md in the release SDK package.
Execution#
  1. Mount NFS using the following commands:
    ifconfig eth0 up
    udhcpc
    # Replace the IP address and path below with your server's IP and path
    mount -t nfs 10.10.1.94:/home/user/nfs /sharefs -o nolock
    After mounting successfully, the /sharefs directory can be seen on both the large and small cores. Copy the compiled demo sample_dpu_vicap.elf to the server’s NFS directory (here it is /home/user/nfs). At this point, the corresponding elf file can also be seen in the large core RTT’s /sharefs.
  2. Use the command ./sample_dpu_vicap.elf -dev 0 -sensor 2 -chn 0 -preview 1 -rotation 1 to start the demo. The output print information is as follows:
    run
  3. Input d, the output print information is as follows:
    save
  4. Input q to exit the program.
  5. At this point, the depth_out.bin file is in the /sharefs directory. This file is the depth image file output by DPU, which can be opened and viewed using appropriate software.
Results#
  1. The actual scene is as follows:
    real
  2. The speckle image captured by the sensor is as follows:
    vicap
  3. The speckle image rotated 90 degrees clockwise by DMA is as follows:
    dma
  4. The depth image result output by DPU is as follows:
    dpu
VICAP_DMA_DPU_demo#
Demo Introduction#
  1. Bind VICAP to DMA, and DMA to DPU.
  2. Start DPU, DMA, and VICAP.
  3. ISP sends the speckle image to DMA, DMA rotates it 90 degrees and sends it to DPU, DPU performs depth processing and prints the depth image address on the screen.
Usage Instructions#
Compilation#
  3. After compilation, the demo file sample_vdd_r.elf will be in the directory k230_sdk/src/big/mpp/userapps/sample/elf. The system image file sysimage-sdcard.img will be in the directory k230_sdk/output/k230_evb_defconfig/images.
Execution#
    ifconfig eth0 up
    udhcpc
    After mounting successfully, the /sharefs directory can be seen on both the large and small cores. Copy the compiled demo sample_vdd_r.elf to the server’s NFS directory (here it is /home/user/nfs). At this point, the corresponding elf file can also be seen in the large core RTT’s /sharefs.
  2. Use the command ./sample_vdd_r.elf to start the demo.
  3. Input q to stop the demo and save the depth image as a file in /sharefs, named depthout.bin.
  4. You can use appropriate software to view the depth image.
  5. The results are as follows:
    depth
Voice Intercom Demo#
Demo Introduction#
This demo is used to demonstrate the bidirectional transmission and processing of audio data (the current version implements part of the voice intercom functionality).
Voice intercom involves two ends, both of which can collect, encode, and send audio data to the other end in real-time, and can also receive and decode the audio data from the other end for output. The current implementation refers to ONVIF and extends the backchannel on the RTSP protocol to support sending audio data from the client to the server. In the following text, server and client refer to the two ends of the voice intercom.
The currently implemented functions are as follows:
  1. The audio stream format is G711 mu-Law.
  2. The server end implements real-time audio collection, encoding, and sending, as well as receiving audio data from the client through the backchannel for decoding and output. The receiving end has not implemented a jitter buffer.
  3. The client end implements receiving, decoding, and playing audio streams, as well as real-time audio collection, G711 mu-Law encoding, and sending to the server end through the backchannel. The receiving end has not implemented a jitter buffer.
  4. Only one-to-one intercom is supported (only one backchannel is supported).
  5. Echo cancellation is not supported (the device side needs to output audio to headphones, and cannot use external speakers).
Two K230 devices are needed. Connect the development boards to the same local area network through a USB-to-Ethernet adapter.
Usage Instructions#
Compilation#
Refer to the README.md in the release SDK package for instructions. In the Docker environment, compile cdk-user, and the executable programs rtsp_server and backchannel_client will be generated in k230_sdk/src/common/cdk/user/out/little.
rtsp_server Parameter Description#
Parameter Name
Parameter Range
Default Value
h
Print command line parameter information
v
Whether to create a video session
t
Encoding type
h264, h265
h265
w
Video encoding width
[640, 1920]
1280
h
Video encoding height
[480, 1080]
720
b
Video encoding bitrate
2000
a
Voice change setting
[-12, 12]
s
Sensor type
See camera sensor documentation
7
The sensor type can be found in the k230_docs/zh/01_software/board/mpp/K230_Camera_Sensor适配指南.md document under the description of k_vicap_sensor_type.
Execution#
For ease of description, the board running the server is named board A, and the board running the client is named board B:
  1. First, run rtsp_server on board A, with microphone input and headphone output.
  2. Then, run backchannel_client on board B, with microphone input and headphone output.
Specific execution steps on board A:
  1. After starting the development board, enter the /mnt directory on the small core:
  2. Execute on the small core: insmod k_ipcm.ko
  3. Execute on the large core: cd /bin; ./sample_sys_init.elf
  4. Execute on the small core: ./rtsp_server (after running rtsp_server, a URL address like rtsp://<server_ip>:8554/BackChannelTest will be printed)
Specific execution steps on board B:
  4. Execute on the small core: ./backclient_test rtsp://<server_ip>:8554/BackChannelTest
The backclient_test execution command is ./backclient_test <rtsp_url> <out_type>, where rtsp_url is the RTSP address, and out_type is the VO output connect type. Refer to the k230_docs/zh/01_software/board/mpp/K230_视频输出_API参考.md document for the description of k_connector_type. The out_type is set to 0 by default.
Depth Map Display Demo#
Demo Introduction#
This demo is used to display the depth map processed by DPU on the screen.
  2. Start DPU, DMA, VICAP, and VO.
  3. ISP sends the speckle image to DMA, DMA rotates it 90 degrees and sends it to DPU, DPU performs depth processing.
  4. Get the depth result in user space.
  5. Send the depth map to VO for display.
Usage Instructions#
Compilation#
  1. Place the configuration files and reference image files in the directory k230_sdk/src/big/rt-smart/userapps/root/bin/dpu.
  3. After compilation, the demo file sample_dpu_vo.elf will be in the directory k230_sdk/src/big/mpp/userapps/sample/elf. In the k230_sdk/output/k230_evb_defconfig/images directory, there will be a system image file named sysimage-sdcard.img.
For more detailed compilation instructions, please refer to the README.md in the release SDK package.
Execution#
  1. Mount NFS. After successful mounting, the /sharefs directory will be visible on both the large and small cores. Copy the compiled demo sample_dpu_vo.elf to the NFS directory on the server. At this point, the corresponding ELF file can also be seen in the /sharefs directory on the large core RTT.
  2. Use the command ./sample_dpu_vo.elf to start the demo. The depth map processed by DPU will be displayed on the screen.
  3. Press ‘q’ to exit the demo.
OTA Remote Upgrade Demo#
Demo Introduction#
OTA stands for Over The Air, which is a technology for downloading updates remotely, as opposed to on-site flashing. It allows updating the device firmware over the network.
  1. The flashing method and firmware updates are stored on a remote server, making it easy to modify.
  2. Supports signed and encrypted upgrade packages to ensure data integrity and security.
  3. Disaster recovery plans are not supported. Common OTA disaster recovery mechanisms include A/B backup schemes or Recovery schemes. K230’s application scenarios may use small-capacity Norflash or large-capacity eMMC. Specific usage scenarios can be developed based on this demo.
Set up an HTTP server, such as using the HFS (HTTP File Server).
Usage Instructions#
Creating an Upgrade Package#
├── ota_package
│   ├── rootfs
│      ├── etc
│      └── mnt
│   └── rtt_system.bin
├── ota_private.pem
├── ota_public.pem
├── ota_upgrade.sh
├── package_kpk.sh
└── README
  1. To create an upgrade package: Enter the k230_sdk/tools/ota directory and execute ./package_kpk.sh. This will generate the ota_package.kpk upgrade package. The ota_package directory should be created by the user and should contain the firmware for the partitions to be upgraded (e.g., rtt_system.bin), as well as the file system of the small core Linux. Note that the upgrade mechanism involves downloading the upgrade package to memory and then decompressing it for flashing. Due to memory capacity limitations, the size of the partition files included in the ota_package should not exceed 20MB. Multiple flashes can be performed if necessary.
  2. For partition firmware of different media, refer to the k230_sdk/tools/gen_image_cfg/xxx.cfg file. Even if some partitions are not visible in the small core Linux system, the entire disk space can be erased and upgraded through offset addresses.
  3. ota_upgrade.sh is the upgrade script executed on the device. If partitions are modified, this script needs to be correspondingly modified.
  4. ota_private.pem is the private key for signing the upgrade package. The public key needs to be compiled or copied to the /etc/ directory on the device. Refer to the README for more details.
Compiling Device-side Programs#
  1. The device-side OTA program is located in buildroot-ext/package/ota. Compiling buildroot will install the OTA program to the /usr/bin directory of the file system, and ota.cfg to the /etc/ directory. The ota.cfg file can be configured with the server-side upgrade package download link and the path to the public key.
Execution#
  1. Open hfs.exe and add a folder from the disk, then copy the upgrade package to this directory.
  2. Ensure that the development board can communicate with the server over the network. Execute ota on the development board to complete the download and upgrade operation.
FFT Demo#
Demo Introduction#
This demo is used to verify the usage of FFT API and test FFT functionality. The code can be found in src/big/mpp/userapps/sample/sample_fft/.
First, perform FFT calculation, then perform IFFT calculation.
Usage Instructions#
Compilation#
Execution#
  1. After both the large and small core systems are up, execute the following command on the large core:
    The large core serial output will be as follows:
        max diff 0003 0001
        max diff 0003 0002
        max diff 0003 0001
        max diff 0003 0003
        max diff 0005 0002
        max diff 0005 0003
        max diff 0005 0002
