K230 SDK User Guide#
SDK Software Architecture Overview#
The K230 SDK is a software development kit for the K230 development board, containing the source code, toolchain, and other related resources needed for dual-core heterogeneous system development based on Linux & RT-smart.
The K230 SDK software architecture is shown in Figure 1-1:
logo
Figure 1-1 K230 SDK Software Architecture Diagram
Supported Hardware#
For hardware information on the K230 platform, refer to the directory: 00_hardware. The hardware information documents for different motherboards are as follows:
Motherboard Type
Hardware Reference Directory
K230-USIP-LP3-EVB
For specific hardware information, refer to: 00_hardware/K230_LP3
K230-USIP-LP4-EVB
For specific hardware information, refer to: 00_hardware/K230_LP4
K230-SIP-LP3-EVB
For specific hardware information, refer to: 00_hardware/K230D
CanMV-K230
CanMV-K230D-Zero
Compilation Environment#
Host Environment
Docker Compilation Environment
The SDK provides a dockerfile to generate a docker image for compiling the SDK
Ubuntu 20.04.4 LTS (x86_64)
The SDK can be compiled in the Ubuntu 20.04 environment
The K230 SDK needs to be compiled in a Linux environment. The SDK supports compilation in a Docker environment, and the SDK development package includes a dockerfile (tools/docker/Dockerfile) to generate the Docker image. For detailed dockerfile usage and compilation steps, see section 4.3.1.
The Docker image used by the SDK is based on Ubuntu 20.04. If not using the Docker compilation environment, you can refer to the dockerfile content in the Ubuntu 20.04 host environment, install the relevant host packages and toolchains, and then compile the SDK.
The K230 SDK has not been verified in other Linux versions of host environments, and it is not guaranteed that the SDK can be compiled in other environments.
SDK Development Package#
The K230 SDK is released in the form of a compressed package, or you can download it using the git clone https://github.com/kendryte/k230_sdk command.
Board Preparation#
This section takes the K230-USIP-LP3-EVB and CanMV-K230 motherboards as examples.
CanMV-K230#
Please prepare the following hardware:
  • CanMV-K230
  • At least one Type-C USB cable
  • One Ethernet cable (optional)
  • One HDMI cable
  • SD card
  • HDMI-compatible monitor
Note: The CanMV-K230 motherboard shares a Type-C port for power and serial communication, as shown below:
Diagram
K230-USIP-LP3-EVB#
  • K230-USIP-LP3-EVB
  • At least two Type-C USB cables
  • Type-C USB to Ethernet adapter (optional)
  • SD card (optional)
Note: The recommended model for the Type-C USB to Ethernet adapter is https://item.jd.com/5326738.html.
Refer to the “K230 DEMO BOARD Resource Usage Instructions” to prepare the development board.
Serial Port#
The K230 motherboard provides two debug serial ports via USB. To use the debug serial ports on Windows, you need to install the USB to serial driver. The driver download link is as follows:
After installing the driver, power on the board, connect the PC to the debug serial port of the motherboard using a Type-C data cable, and you should see two USB serial devices as shown below:
Diagram
Figure 2-1 USB Serial Devices
In the example above, COM47 is the debug serial port for the small core, and COM48 is the debug serial port for the large core.
Serial port baud rate settings: 115200 8N1
SDK Installation Preparation#
Install SDK#
The K230 SDK development package is released in the form of a compressed package for use in a Linux environment.
SDK Directory Structure#
The K230 SDK directory structure is shown below:
k230_sdk
├── configs
│   ├── k230_evb_defconfig
│   └── k230_evb_usiplpddr4_defconfig
│   └── k230d_defconfig
├── Kconfig
├── LICENSE
├── Makefile
├── parse.mak
├── README.md
├── repo.mak
├── src
│   ├── big
│      ├── mpp
│      ├── rt-smart
│      └── unittest
│   ├── common
│      ├── cdk
│      └── opensbi
│   ├── little
│      ├── buildroot-ext
│      ├── linux
│      └── uboot
│   └── reference
│       ├── ai_poc
│       ├── business_poc
│       └── fancy_poc
├── board
│   ├── common
│      ├── env
│      └── gen_image_cfg
│      ├── gen_image_script
│      └── post_copy_rootfs
│   ├── k230_evb_doorlock
│   └── k230_evb_peephole_device
└── tools
    ├── docker
       └── Dockerfile
    ├── doxygen
    ├── firmware_gen.py
    └── get_download_url.sh
The purpose of each directory is described as follows:
  • configs: Stores the board-level default configurations of the SDK, mainly including information such as reference board type, toolchain path, memory layout planning, and storage planning configuration.
  • src: Source code directory, divided into three directories: large core code (big), common components (common), and small core code (little).
    Large core code includes: rt-smart operating system code, mpp code, unittest code.
    Common components include: cdk code and opensbi code.
    Small core code includes: linux kernel code, buildroot code, uboot code.
  • tools: Stores various tools, scripts, etc., such as kconfig, doxygen, dockerfile, etc.
  • board: Environment variables, image configuration files, file systems, etc.
SDK Compilation#
SDK Compilation Introduction#
The K230 SDK supports one-click compilation of large and small core operating systems and common components, generating image files that can be burned for deployment to the development board for startup and operation. The username of the Linux system on the device is root without a password.
SDK Configuration#
The K230 SDK uses Kconfig as the SDK configuration interface, and the default board-level configurations supported are placed in the configs directory.
Some Configuration File Descriptions#
k230_evb_defconfig: Default SDK configuration file based on K230 USIP LP3 EVB.
k230_evb_usiplpddr4_defconfig: Default SDK configuration file based on K230 USIP LP4 EVB.
k230d_defconfig: Default SDK configuration file based on K230-SIP-LP3-EVB.
k230_evb_nand_defconfig: Default SDK configuration file for generating nand images based on K230 USIP LP3 EVB.
k230_canmv_defconfig: Default SDK configuration file based on CanMV-K230 V1.0/V1.1.
k230_evb_doorlock_defconfig: Default SDK configuration file for door lock POC based on K230 USIP LP3 EVB.
k230_evb_peephole_device_defconfig: Default SDK configuration file for peephole POC based on K230 USIP LP3 EVB.
k230d_doorlock_defconfig: Default SDK configuration file for door lock POC based on K230-SIP-LP3-EVB.
k230_canmv_v2_defconfig: Default SDK configuration file based on Canmv-K230 V2.0 board.
k230_canmv_only_rtt_defconfig: RT-Thread system configuration file based on Canmv-K230 V1.0/V1.1 board.
k230_canmv_v2_only_rtt_defconfig: RT-Thread system configuration file based on Canmv-K230 V2.0 board.
k230d_canmv_only_rtt_defconfig: RT-Thread system configuration file based on CanMV-K230-Zero board.
Compile SDK#
Compilation Steps#
Note: The commands in this section are for reference only. Please replace the file names according to the actual situation.
Step 1: Download the code
make prepare_sourcecode will download both Linux and RT-Smart toolchain, buildroot package, and AI package from Microsoft Azure cloud server with CDN. The download time may vary based on your network connection speed.
make CONF=k230_evb_defconfig  # Compile image for K230-USIP-LP3-EVB board
#make CONF=k230_evb_usiplpddr4_defconfig  # Compile image for K230-USIP-LP4-EVB board
#make CONF=k230d_defconfig  # Compile image for K230-SIP-LP3-EVB board
#make CONF=k230_evb_nand_defconfig  # Compile nand image for K230-USIP-LP3-EVB board
  • To compile the image for the K230-USIP-LP4-EVB board, use the make CONF=k230_evb_usiplpddr4_defconfig command.
  • To compile the image for the K230-USIP-LP3-EVB board, use the make CONF=k230_evb_defconfig command.
  • To compile the image for the K230-SIP-LP3-EVB board, use the make CONF=k230d_defconfig command.
  • To compile the NAND image for the K230-USIP-LP3-EVB board, use the make CONF=k230_evb_nand_defconfig command.
  • To compile the image for the CanMV-K230 board, use the make CONF=k230_canmv_defconfig command.
Note: The SDK does not support multi-process compilation, so do not add multi-process compilation parameters like -j32.
Compilation Output#
After the compilation is complete, you can find the output products in the output/xx_defconfig/images directory. Example:
Text Description Automatically Generated
Figure 4-1 Compilation Output
The image files in the images directory are explained as follows:
  • sysimage-sdcard.img — Non-secure boot image for SD and eMMC.
  • sysimage-sdcard.img.gz — Compressed non-secure boot image for SD and eMMC (gzip compressed package of sysimage-sdcard.img), needs to be decompressed before burning.
  • sysimage-sdcard_aes.img.gz — AES secure boot image compressed package for SD and eMMC, needs to be decompressed before burning.
  • sysimage-sdcard_sm.img.gz — SM secure boot image compressed package for SD and eMMC, needs to be decompressed before burning.
Secure images are not generated by default. If secure images are needed, refer to section 4.3.4 to enable secure images.
The compilation output for the large core system is placed in the images/big-core directory.
The compilation output for the small core system is placed in the images/little-core directory.
Non-Quick Boot Image#
By default, the SDK compiles a quick boot image (U-Boot directly starts the system and does not enter the U-Boot command line). If you need to enter the U-Boot command line, refer to the following to disable the CONFIG_QUICK_BOOT configuration:
In the SDK main directory, execute make menuconfig, select board configuration, and uncheck the quick boot configuration option.
To convert a non-quick boot system to a quick boot system: enter the U-Boot command line and execute setenv quick_boot true; saveenv;.
Secure Image#
By default, the SDK does not generate secure images. If secure images are needed, refer to the following to add the CONFIG_GEN_SECURITY_IMG configuration:
In the SDK main directory, execute make menuconfig, select board configuration, and check the create security image option.
Debug Image#
By default, the SDK generates a release image. If a debug image is needed, refer to the following to add the CONFIG_BUILD_DEBUG_VER configuration:
In the SDK main directory, execute make menuconfig, select build debug/release version, and check the debug option.
SDK Image Burning#
Depending on the hardware characteristics and software requirements of different boards, choose the supported image burning method.
The CanMV-K230 board only supports SD card image booting.
SD Card Image Burning#
Burning on Ubuntu#
ls -l /dev/sd*
After inserting the SD card into the host, enter again:
ls -l /dev/sd*
to view the storage devices at this time. The newly added device is the SD card device node.
Assuming /dev/sdc is the SD card device node, execute the following command to burn the SD card:
Note: sysimage-sdcard.img can be the sysimage-sdcard.img file in the images directory or the decompressed file of the sysimage-sdcard_aes.img.gz, sysimage-sdcard.img.gz, or sysimage-sdcard_sm.img.gz files.
Burning on Windows#
On Windows, you can use the Rufus tool to burn the TF card (Rufus tool download link: http://rufus.ie/downloads/).
  1. Insert the TF card into the PC, then start the Rufus tool and click the “Select” button on the tool interface to choose the firmware to be burned. rufus-flash-from-file
  2. Click the “Start” button to begin burning. The burning process will display a progress bar, and it will indicate “Ready” when the burning is complete.
eMMC Image Burning Reference#
Burning eMMC on Linux#
  1. Download the compressed image package to the SD card. Boot Linux from the SD card. In Linux, you can refer to the following commands to download the compressed image package to the SD card:
ifconfig eth0 up; udhcpc; mount /dev/mmcblk1p4 /mnt; cd /mnt/;
  1. Decompress the package to eMMC: gunzip sysimage-sdcard.img.gz -c > /dev/mmcblk0
  2. Switch to eMMC boot and restart the board.
Burning eMMC in U-Boot#
  1. Download the sysimage-sdcard.img.gz image to memory:
usb start; dhcp; tftp 0x9000000 10.10.1.94:wjx/sysimage-sdcard.img.gz;
# Note: Replace 0x9000000 based on memory size, e.g., if memory is only 128MB, replace it with 0x2400000
  1. Write the image to eMMC:
  1. Restart the board.
Spinor Image Burning Reference#
Burning in U-Boot#
  1. Download the sysimage-spinor32m.img image to memory:
usb start; dhcp; tftp 0x9000000 10.10.1.94:wjx/sysimage-spinor32m.img;
  1. Write the image to SPI NOR flash:
sf probe 0:0; sf erase 0 0x2000000; sf write 0x$fileaddr 0 0x$filesize; sf remove;
Burning Spinor on Linux#
  1. Download the spinor image sysimage-spinor32m.img to the SD card.
Boot Linux from the SD card. In Linux, you can refer to the following commands to download the image to the SD card:
  1. Refer to the following command to write the image to SPI NOR flash:
[root@canaan /mnt]# flashcp -v sysimage-spinor32m.img /dev/mtd9
[root@canaan /mnt]#
  1. Switch to SPI NOR boot and restart the board.
Spinor Image Description#
Due to the small size of the spinor flash, Linux has removed ko files and RT-Thread has removed some demo programs.
Spinand Image Burning Reference#
Burning in U-Boot#
  1. Download the sysimage-spinand32m.img image to memory:
  1. Write the image to SPI NAND flash:
mtd erase spi-nand0 0 0x2000000; mtd write spi-nand0 0x$fileaddr 0 0x$filesize;
SDK Boot Medium Partition and Modification#
SPI NOR#
Default SPI NOR Partition#
image-spi_nor_default_part
SPI NOR Partition
Content
Start Addr
Size
Size MB
Size
Primary U-Boot
0x0
512KB
0.5
512KB
Secondary U-Boot
0x80000
0x160000
1.375
1.375MB
U-Boot Env Vars
0x1e0000
128KB
0.125
128KB
Quick Boot Params
0x200000
512KB
0.5
512KB
Face Features
0x280000
512kB
0.5
512kB
Calibration Params
0x300000
256KB
0.25
256KB
AI Model
0x340000
3MB
3
3MB
Speckle
0x640000
2MB
2MB
RT-Thread
0x840000
0x1c0000
1.75
1.75MB
RT-Thread App
0xa00000
0x5c0000
5.75
3.75MB
Linux
0xfc0000
0x700000
7
7MB
Rootfs
0x16c0000
0xb00000
13
13MB
Partition Modification and Implementation Description#
In the SDK main directory, execute make menuconfig —> storage configurations —> spi nor partition config to modify the partition (interface shown below). After modification, execute make build-image.
image-image-menuconfig_spi_nor_part
Detailed implementation of partition modification through menuconfig:
After configuring with make menuconfig, a .config file is generated (partial content shown below):
The tools/menuconfig_to_code.sh script will dynamically modify the Linux device tree and board/common/gen_image_cfg/genimage-spinor.cfg file based on these definitions (key script shown below):
    flash {}
    partition quick_boot_cfg {
    partition face_db {
    partition sensor_cfg {
    partition ai_mode {
    partition speckle_cfg {
    partition rtt {
    partition rtt_app {
        image = "${rtapp_data_file}"
    partition linux {
    partition rootfs_ubi {
        image = "rootfs.ubi"
Finally, genimage will parse the board/common/gen_image_cfg/genimage-spinor.cfg file and generate the correct image.
genimage --rootpath little-core/rootfs/ --tmppath genimage.tmp --inputpath images --outputpath images --config board/common/gen_image_cfg/genimage-spinor.cfg
Partition Data Format and Generation Process#
Currently, the data in parameter partitions such as quick boot parameters, facial features, calibration parameters, AI models, speckle, RTT, and RTApp are not encrypted. The format and generation process are as follows:
image-20230705151949318
The main generation script is as follows:
# For more detailed generation details, please read the gen_cfg_part_bin function in the board/common/gen_image_script/gen_image_comm_func.sh script
${k230_gzip} -f -k ${filename}  # gzip
sed -i -e "1s/\x08/\x09/"  ${filename}.gz
# add uboot head
${mkimage} -A riscv -O linux -T firmware -C gzip -a ${add} -e ${add} -n ${name}  -d ${filename}.gz  ${filename}.gzu;
python3  ${firmware_gen}   -i ${filename}.gzu -o fh_${filename} ${arg}; # add k230 firmware head
The corresponding execution process prints as follows:
##  + k230_priv_gzip -n8 -f -k speckle.bin
##  + sed -i -e '1s/\x08/\x09/' speckle.bin.gz
##  + mkimage -A riscv -O linux -T firmware -C gzip -a 0x14040000 -e 0x14040000 -n speckle -d speckle.bin.gz speckle.bin.gzu
##  Image Name:   speckle
##  Created:      Wed Jul  5 15:37:49 2023
##  Image Type:   RISC-V Linux Firmware (gzip compressed)
##  Data Size:    45 Bytes = 0.04 KiB = 0.00 MiB
##  Load Address: 14040000
##  Entry Point:  14040000
##  + python3 /home/wangjianxin/k230_sdk/tools/firmware_gen.py -i speckle.bin.gzu -o fh_speckle.bin -n
##  the magic is:  b'K230'
##  ----- NO ENCRYPTION + HASH-256 -----
##  the encryption type:  0
##  mesg_hash:  b'3543e2038aedad88a29f8ee98983064367cc79f6e709ed7571df9b391884b8b1'
When U-Boot starts, it will parse and verify the parameter partitions (quick boot parameters, facial features, calibration parameters, AI models, speckle, RTT, RTApp) data and load the parsed raw data into the correct memory locations.
The memory locations for each parameter partition can be configured via make menuconfig -> Memory configuration (reference interface below):
image-20230705153242437
Special Notes on RTApp and AI Model Partitions#
The app in the RTApp partition cannot be executed repeatedly. The purpose of designing this partition is to save memory. After executing the app in this partition once, the memory may be released and cannot be executed again.
During compilation, the pointers to the model files in the large core ROMFS file system will be modified to the AI model area (see the script below). The usage method is the same as using ordinary files.
# For details, see the board/common/gen_image_script/gen_image.sh file
for f in ${all_kmode};
    do
    done
Verified SPI NOR Models#
  • gd25lx256e
SD and eMMC#
Default SD and eMMC Partitions#
image-20230705100321637
SD/eMMC Default Partitions
Content
Start Addr
Size
Size MB
Size
MBR Partition Table
0x0
0x100000
1MB
Primary U-Boot
0x100000
0x80000
0.5
512KB
Backup Primary Boot
0x180000
0x60000
0.375
384KB
U-Boot Environment Vars
0x1e0000
0x20000
0.125
128KB
Secondary U-Boot
0x200000
0x800000
0.5
8MB
RTT
0xa00000
0x1400000
20
20MB
Linux
0x1e00000
0x6200000
98
98MB
Rootfs
0x8000000
0x5000000
80
80MB
Test Partition
0xd000000
0x10000000
256
256MB
SD and eMMC Partition Modification#
If partitioning is required, modify the board/common/gen_image_cfg/genimage-sdcard.cfg file. After modification, execute make build-image.
SPI NAND#
Default SPI NAND Partitions#
image-20230705111015174
SPI NAND Partitions
Content
Start Addr
Size
Start Addr
Size MB
Size
Primary U-Boot
0x0
512KB
0x0
0.5
512KB
Secondary U-Boot
0x80000
0x160000
0x80000
1.375
1.375MB
0x1e0000
128KB
0x1e0000
0.125
128KB
RTT
0x200000
0x800000
0x200000
8
8MB
Linux
0xa00000
0x700000
0xa00000
7
7MB
Rootfs
0x1100000
0xf00000
0x1100000
15
15MB
SPI NAND Partition Modification#
If partitioning is required, modify the board/common/gen_image_cfg/genimage-spinand.cfg file. After modification, execute make build-image.
Verified SPI NAND Models#
  • w25n01gw
SDK Memory Configuration#
Run make menuconfig -> Memory configuration under k230_sdk to configure the memory space used by each area. You can also directly compile configs/k230_evb_defconfig to modify. The descriptions of each area are as follows:
CONFIG_MEM_TOTAL_SIZE="0x20000000"      # Total memory capacity          Not configurable
CONFIG_MEM_PARAM_BASE="0x00000000"      # Parameter partition start address Not configurable
CONFIG_MEM_PARAM_SIZE="0x00100000"      # Parameter partition size       Not configurable
CONFIG_MEM_IPCM_BASE="0x00100000"       # Inter-core communication start address Not configurable
CONFIG_MEM_IPCM_SIZE="0x00100000"       # Inter-core communication shared memory size Not configurable
CONFIG_MEM_RTT_SYS_BASE="0x00200000"    # Large core RTT start address   Configurable
CONFIG_MEM_RTT_SYS_SIZE="0x07E00000"    # Large core RTT address range   Configurable
CONFIG_MEM_AI_MODEL_BASE="0x1FC00000"   # AI model loading start address Configurable
CONFIG_MEM_AI_MODEL_SIZE="0x00400000"   # AI model loading address range Configurable
CONFIG_MEM_LINUX_SYS_BASE="0x08000000"  # Small core Linux start address Configurable
CONFIG_MEM_LINUX_SYS_SIZE="0x08000000"  # Small core Linux address range Configurable
CONFIG_MEM_MMZ_BASE="0x10000000"        # MMZ shared memory start address Configurable
CONFIG_MEM_MMZ_SIZE="0x0FC00000"        # MMZ shared memory range        Configurable
CONFIG_MEM_BOUNDARY_RESERVED_SIZE="0x00001000"  # Isolation zone         Not configurable
The CONFIG_MEM_LINUX_SYS_BASE address needs to be 2MB aligned.
SDK Board Debugging#
The CanMV-K230 board’s default debug port is a serial port. For debugging, please refer to the SDK FAQ.
Preparation for Debugging#
  1. Download the T-Head-DebugServer software and the “DebugServer User Guide v5.6” from T-Head’s OCC platform https://occ.t-head.cn/community/download, and install the T-Head-DebugServer software on your PC following the “DebugServer User Guide v5.6”.
图形用户界面, 文本, 应用程序 描述已自动生成
  1. Prepare the T-Head CKLink, USB cable, and K230 EVB board as shown below:
图片包含 游戏机, 电缆, 电路 描述已自动生成
Debugging#
  1. Connect the CKLink, K230 EVB board, and PC as shown below, then power on the EVB.
电子仪器被放在电脑旁边 中度可信度描述已自动生成
  1. Open the T-Head DebugServer software on the PC. If the connection is successful, you will see output similar to the image below. If the connection fails, refer to the “DebugServer User Guide v5.6” to troubleshoot. 文本 描述已自动生成
  2. On the server where the code is compiled, start riscv64-unknown-linux-gnu-gdb and execute the target remote xx.xx.xx.xx:1025 command to connect to the board. Once connected, you can perform GDB debugging. 文本 描述已自动生成
SDK Boot#
With the default compiled image, after burning it to the board, the large core will automatically run a facial detection program, and the display will show images captured by the camera. After booting, you can enter ‘q’ on the large core console to exit the program.
  1. If the EVB series board is not connected to the IMX335 camera, the auto-start program will report an error and exit automatically. Press Enter to return to the console.
  2. To disable the auto-start function of the large core, comment out the content in k230_sdk/src/big/rt-smart/init.sh.
K230 Debian and Ubuntu Image Instructions#
For the image and build methods, refer to K230_debian_ubuntu.md.
