K230 Audio API Reference#
The products, services, or features you purchase are subject to the commercial contracts and terms of Beijing Canaan Creative Information Technology Co., Ltd. (hereinafter referred to as “the Company”) and its affiliated companies. All or part of the products, services, or features described in this document may not be within the scope of your purchase or use. Unless otherwise agreed in the contract, the Company does not provide any express or implied statements or warranties regarding the accuracy, reliability, completeness, merchantability, fitness for a particular purpose, and non-infringement of any representations, information, or content in this document. Unless otherwise agreed, this document is for use as a reference guide only.
Trademark Statement#
Copyright © 2023 Beijing Canaan Creative Information Technology Co., Ltd. All rights reserved. Without the written permission of the Company, no unit or individual is allowed to excerpt, copy, or disseminate part or all of the content of this document in any form.
Table of Contents#
The AUDIO module includes four sub-modules: audio input, audio output, audio encoding, and audio decoding, as well as control of the built-in audio codec.
Intended Audience#
Technical Support Engineers
Abbreviation Definitions#
Abbreviation |
ai |
Audio Input Module |
ao |
Audio Output Module |
aenc |
Audio Encoding Module |
adec |
Audio Decoding Module |
Document Version |
Author |
Date |
Initial version |
Sun Xiaopeng |
2023/3/7 |
V1.1 |
1) Added support for i2s built-in codec 2) Added support for pdm single/dual channel 3) Added support for different sampling precision (16/24/32) for ai and ao 4) API interface unchanged, added parameter attributes, improved documentation. |
Sun Xiaopeng |
2023/3/27 |
V1.1.1 |
Added audio encoding and decoding API interfaces, added sound quality enhancement API interfaces kd_mpi_ai_set_vqe_attr/kd_mpi_ai_get_vqe_attr, and explanations. |
Sun Xiaopeng/Cui Yan |
2023/4/12 |
V1.2 |
Modified sound quality enhancement API interfaces kd_mpi_ai_set_vqe_attr/kd_mpi_ai_get_vqe_attr, added audio encoding and decoding mapi interface functions |
2023/4/27 |
V1.3 |
1) Added built-in Audio Codec API interfaces |
Sun Xiaopeng |
2023/5/10 |
v1.4 |
1) i2s supports single and dual channel input and output, modified k_audio_i2s_attr attributes, added snd_mode attribute. 2) Added built-in Audio Codec API interfaces: including volume acquisition and reset related interfaces: k_acodec_get_gain_micl/k_acodec_get_gain_micr/k_acodec_get_adcl_volume/k_acodec_get_adcr_volume/k_acodec_get_alc_gain_micl/k_acodec_get_alc_gain_micr/k_acodec_get_gain_hpoutl/k_acodec_get_gain_hpoutr/k_acodec_get_dacl_volume/k_acodec_get_dacr_volume/k_acodec_reset |
Sun Xiaopeng |
2023/6/15 |
V1.5 |
1) Added control for selecting single channel for audio input and output |
Sun Xiaopeng |
2024/6/5 |
V1.6 |
1) Optimized audio 3A interface |
Sun Xiaopeng |
2024/11/4 |
1. Overview#
1.1 Overview#
The audio module includes four sub-modules: audio input (ai), audio output (ao), audio encoding (aenc), and audio decoding (adec), as well as support for the built-in analog audio codec. The audio input module includes two types of audio interfaces, i2s and pdm, working with pdma for memory copying. It supports digital microphones (pdm/i2s) and analog audio codec (i2s) sound source input, with an internal analog audio codec that supports sound quality enhancement (VQE) processing: 3A (AEC echo cancellation, ANR noise reduction, AGC automatic gain control). The audio output module supports the i2s audio interface, working with pdma for memory copying, and can connect external data speakers or analog audio codecs for sound output. The audio encoding and decoding modules currently support G711 format audio encoding and decoding functions and support external codec registration.
The audio module is split into multiple sub-modules, with low-coupling data flow transmission between modules. This design meets the existing multimedia business requirements under MAIX3. The following diagram analyzes the usage scenario of the audio module in a voice intercom business. The audio data collected by the audio input module is encoded by the audio encoding module and then sent to the remote end through the network. The audio encoded data obtained from the remote end is decoded by the audio decoding module and then played through the audio output module.
1.2 Function Description#
1.2.1 Audio Input#
The audio input module (AI) mainly implements the configuration and activation of audio input devices and the acquisition of audio frame data.
The audio input module supports i2s and pdm protocol interfaces. i2s supports simultaneous collection of up to 2 dual-channel audio streams, and pdm supports simultaneous collection of up to 8 single-channel audio streams. Detailed i2s and pdm features are as follows:
i2s audio interface
Data sampling rates support 8kHz/12kHz/16kHz/24kHz/32kHz/44.1kHz/48kHz/96kHz/192kHz, with sampling precision supporting 16/24/32bit.
Supports 2 configurable IO groups for input/output of I2S audio data, supporting full-duplex mode.
pdm audio interface
Supports PDM audio input, 1-bit width, sampling clock frequencies of 0.256MHz/0.384MHz/0.512MHz/0.768MHz/1.024MHz/1.4112MHz/1.536MHz/2.048MHz/2.8224MHz/3.072MHz/4.096MHz/5.6448MHz/6.144MHz/12.288MHz/24.576MHz, with the input PCM audio sampling rates of 8kHz/12kHz/16kHz/24kHz/32kHz/44.1kHz/48kHz/96kHz/192kHz. Sampling precision supports 16/24/32bit.
Supports oversampling rates of 128, 64, and 32 times.
Supports 1-4 IOs for inputting PDM audio data.
Input supports configurable 1-8 PDM channels, supporting PDM left and right single-channel mode and dual-channel mode. Each IO channel mode is unified, and PDM dual-channel mode uses up to 4 IOs.
Enabled channel numbers are continuous from small to large and do not support random enabling of channels.
1.2.2 Audio Output#
The audio output (AO) mainly implements the activation of audio output devices and the sending of audio frames to the output channel.
The audio output module supports the i2s protocol interface. i2s supports simultaneous output of up to 2 dual-channel audio streams.
i2s audio interface
Data sampling rates support 8kHz/12kHz/16kHz/24kHz/32kHz/44.1kHz/48kHz/96kHz/192kHz, with sampling precision of 16/24/32bit.
1.2.3 Audio Link#
The signal received from the analog microphone by the audio codec is converted to I2S format PCM data and input into the audio’s I2S. The PCM data output by I2S, after passing through the audio codec, is converted to an analog signal and emitted. This mode does not use digital IO, and the fixed I2S sdi0 and sdo0 interfaces are used.
I2S directly connects with external digital microphones and PAs. There are two sets of interfaces to choose from: sdi0, sdo0, and sdi1, sdo1.
External PDM microphones input up to 8 PDM data streams to the audio’s 4 input data interfaces.
Selectable links include:
3 sets of pdm_in + 1 set of i2s_in + 2 sets of i2s out, where 1 set of i2s_in can use the built-in audio codec or external
4 sets of pdm_in + 2 sets of i2s out
2 sets of i2s_in + 2 sets of pdm_in + 2 sets of i2s out
You can use the built-in codec or external devices (audio sub-boards) to test audio-related functions. Using the built-in codec, you can test one set of I2S audio input and output and related audio codec functions. Using the audio sub-board, you can test 2 sets of i2s audio input and output and 4 sets of pdm audio input functions.
1.2.4 Sound Quality Enhancement#
The audio module supports sound quality enhancement processing for audio data, realizing audio 3A functions. Currently supported sampling precision is 16bit, with a supported sampling rate of 16k.
2. API Reference#
2.1 Audio Input#
2.1.1 kd_mpi_ai_set_pub_attr#
Description:
Set AI device attributes.
Syntax:
k_s32 kd_mpi_ai_set_pub_attr([k_audio_dev](#312-k_audio_dev) ai_dev, const [k_aio_dev_attr](#3112-k_aio_dev_attr) *attr);
Parameters:
Parameter |
Input/Output |
ai_dev |
Audio device number. |
Input |
attr |
AI device attribute pointer. |
Input |
Return Value:
Return Value |
Success |
Non-zero |
Failure, see error code |
Requirements:
Header file: mpi_ai_api.h
Library file: libai.a
Notes:
k_aio_dev_attr aio_dev_attr;
memset(&aio_dev_attr, 0, sizeof(aio_dev_attr));
aio_dev_attr.kd_audio_attr.i2s_attr.bit_width = KD_AUDIO_BIT_WIDTH_16;
aio_dev_attr.kd_audio_attr.i2s_attr.point_num_per_frame = 44100 / 25;
if (K_SUCCESS != kd_mpi_ai_set_pub_attr(0, &aio_dev_attr)) {
return K_FAILED;
if (K_SUCCESS != kd_mpi_ai_enable(0)) {
return K_FAILED;
if (K_SUCCESS != kd_mpi_ai_enable_chn(0, 0)) {
return K_FAILED;
2.1.2 kd_mpi_ai_get_pub_attr#
Description:
Get AI device attributes.
Syntax:
k_s32 kd_mpi_ai_get_pub_attr([k_audio_dev](#312-k_audio_dev) ai_dev, [k_aio_dev_attr](#3112-k_aio_dev_attr) *attr);
Parameters:
Parameter |
Input/Output |
ai_dev |
Input |
attr |
Output |
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
2.1.3 kd_mpi_ai_enable#
Description:
Enable AI device.
Syntax:
k_s32 kd_mpi_ai_enable([k_audio_dev](#312-k_audio_dev) ai_dev);
Parameters:
Parameter |
Input/Output |
ai_dev |
Input |
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
2.1.4 kd_mpi_ai_disable#
Description:
Disable AI device.
Syntax:
k_s32 kd_mpi_ai_disable([k_audio_dev](#312-k_audio_dev) ai_dev);
Parameters:
Parameter |
Input/Output |
ai_dev |
Input |
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
2.1.5 kd_mpi_ai_enable_chn#
Description:
Enable AI channel.
Syntax:
k_s32 kd_mpi_ai_enable_chn([k_audio_dev](#312-k_audio_dev) ai_dev, [k_ai_chn](#313-k_ai_chn) ai_chn);
Parameters:
Parameter |
Input/Output |
ai_dev |
Input |
ai_chn |
Audio channel number. |
Input |
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
2.1.6 kd_mpi_ai_disable_chn#
Description:
Disable AI channel.
Syntax:
k_s32 kd_mpi_ai_disable_chn([k_audio_dev](#312-k_audio_dev) ai_dev, [k_ai_chn](#313-k_ai_chn) ai_chn);
Parameters:
Parameter |
Input/Output |
ai_dev |
Input |
ai_chn |
Input |
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
2.1.7 kd_mpi_ai_get_frame#
Description:
Get audio frame.
Syntax:
k_s32 kd_mpi_ai_get_frame([k_audio_dev](#312-k_audio_dev) ai_dev, [k_ai_chn](#313-k_ai_chn) ai_chn, [k_audio_frame](#3114-k_audio_frame) *frame, k_u32 milli_sec);
Parameters:
Parameter |
Input/Output |
ai_dev |
Input |
ai_chn |
Input |
frame |
Audio frame data. |
Output |
milli_sec |
Timeout for getting data. -1 means blocking mode, waiting indefinitely if no data; 0 means non-blocking mode, returning an error if no data; >0 means blocking for milli_sec milliseconds, returning an error if timeout. |
Input |
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
Notes:
The value of milli_sec must be greater than or equal to -1. When it is -1, data is retrieved in blocking mode. When it is 0, data is retrieved in non-blocking mode. When it is greater than 0, it blocks for milli_sec milliseconds, and if there is no data, it returns a timeout error.
The corresponding AI channel must be enabled before retrieving audio frame data.
k_audio_frame audio_frame;
while(true) {
// get frame
if (K_SUCCESS != kd_mpi_ai_get_frame(dev_num, channel, &audio_frame, 1000)) {
continue;
// process frame
process_frame(&audio_frame);
// release frame
Description:
Release audio frame.
Syntax:
k_s32 kd_mpi_ai_release_frame([k_audio_dev](#312-k_audio_dev) ai_dev, [k_ai_chn](#313-k_ai_chn) ai_chn, const [k_audio_frame](#3114-k_audio_frame) *frame);
Parameters:
Parameter |
Input/Output |
ai_dev |
Input |
ai_chn |
Input |
frame |
Audio frame data. |
Input |
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
2.1.9 kd_mpi_ai_set_vqe_attr#
Description:
Set AI voice quality enhancement attributes.
Syntax:
k_s32 kd_mpi_ai_set_vqe_attr([k_audio_dev](#312-k_audio_dev) ai_dev, [k_ai_chn](#313-k_ai_chn) ai_chn, const [k_ai_vqe_enable](#3115-k_ai_vqe_enable) vqe_enable);
Parameters:
Parameter Name |
Input/Output |
ai_dev |
Input |
ai_chn |
Input |
vqe_enable |
Voice quality enhancement enable flag. |
Input |
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
Notes:
Audio 3A supports 16-bit sampling precision, and AGC only supports 8k/16k/32k/48k.
Description:
Get AI voice quality enhancement attributes.
Syntax:
k_s32 kd_mpi_ai_get_vqe_attr([k_audio_dev](#312-k_audio_dev) ai_dev, [k_ai_chn](#313-k_ai_chn) ai_chn, [k_ai_vqe_enable](#3115-k_ai_vqe_enable) vqe_enable);
Parameters:
Parameter Name |
Input/Output |
ai_dev |
Input |
ai_chn |
Input |
vqe_enable |
Pointer to voice quality enhancement enable flag. |
Output |
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
2.1.11 kd_mpi_ai_send_far_echo_frame#
Description:
Send far-end voice signal. This signal is collected by the far-end microphone (speaker’s voice) and is also equal to the voice played by the near-end speaker, also known as the reference voice.
Syntax:
k_s32 kd_mpi_ai_send_far_echo_frame([k_audio_dev](#312-k_audio_dev) ai_dev, [k_ai_chn](#313-k_ai_chn) ai_chn, const [k_audio_frame](#3114-k_audio_frame) *frame, k_s32 milli_sec);
Parameters:
Parameter Name |
Input/Output |
ai_dev |
Input |
ai_chn |
Input |
frame |
Reference voice data. |
Input |
milli_sec |
Timeout for sending data. -1 means blocking mode, waiting indefinitely if no data; 0 means non-blocking mode, returning an error if no data; >0 means blocking for milli_sec milliseconds, returning an error if timeout. |
Input |
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
2.2 Audio Output#
2.2.1 kd_mpi_ao_set_pub_attr#
Description:
Set AO device attributes.
Syntax:
k_s32 kd_mpi_ao_set_pub_attr([k_audio_dev](#312-k_audio_dev) ao_dev, const [k_aio_dev_attr](#3112-k_aio_dev_attr) *attr);
Parameters:
Parameter |
Input/Output |
ao_dev |
Input |
attr |
AO device attribute pointer. |
Input |
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
Header file: mpi_ao_api.h
Library file: libao.a
Notes:
k_aio_dev_attr ao_dev_attr;
memset(&ao_dev_attr, 0, sizeof(ao_dev_attr));
ao_dev_attr.kd_audio_attr.i2s_attr.point_num_per_frame = 48000 / 25;
if (K_SUCCESS != kd_mpi_ao_set_pub_attr(0, &ao_dev_attr)) {
return K_FAILED;
if (K_SUCCESS != kd_mpi_ao_enable(0)) {
printf("kd_mpi_ao_enable failed\n");
return K_FAILED;
if (K_SUCCESS != kd_mpi_ao_enable_chn(0, 1)) {
printf("kd_mpi_ao_enable_chn failed\n");
return K_FAILED;
2.2.2 kd_mpi_ao_get_pub_attr#
Description:
Get AO device attributes.
Syntax:
k_s32 kd_mpi_ao_get_pub_attr([k_audio_dev](#312-k_audio_dev) ao_dev, [k_aio_dev_attr](#3112-k_aio_dev_attr) *attr);
Parameters:
Parameter |
Input/Output |
ao_dev |
Input |
attr |
Output |
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
2.2.3 kd_mpi_ao_enable#
Description:
Enable AO device.
Syntax:
k_s32 kd_mpi_ao_enable([k_audio_dev](#312-k_audio_dev) ao_dev);
Parameters:
Parameter |
Input/Output |
ao_dev |
Input |
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
2.2.4 kd_mpi_ao_disable#
Description:
Disable AO device.
Syntax:
k_s32 kd_mpi_ao_disable([k_audio_dev](#312-k_audio_dev) ao_dev);
Parameters:
Parameter |
Input/Output |
ao_dev |
Input |
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
2.2.5 kd_mpi_ao_enable_chn#
Description:
Enable AO channel.
Syntax:
k_s32 kd_mpi_ao_enable_chn([k_audio_dev](#312-k_audio_dev) ao_dev, [k_ao_chn](#314-k_ao_chn) ao_chn);
Parameters:
Parameter |
Input/Output |
ao_dev |
Input |
ao_chn |
Input |
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
Library file: libao.a | Input |
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
2.2.6 kd_mpi_ao_disable_chn#
Description:
Disable AO channel.
Syntax:
k_s32 kd_mpi_ao_disable_chn([k_audio_dev](#312-k_audio_dev) ao_dev, [k_ao_chn](#314-k_ao_chn) ao_chn);
Parameters:
Parameter |
Input/Output |
ao_dev |
Input |
ao_chn |
Input |
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
2.2.7 kd_mpi_ao_send_frame#
Description:
Send AO frame data.
Syntax:
k_s32 kd_mpi_ao_send_frame([k_audio_dev](#312-k_audio_dev) ao_dev, [k_ao_chn](#314-k_ao_chn) ao_chn, const [k_audio_frame](#3114-k_audio_frame) *frame, k_s32 milli_sec);
Parameters:
Parameter |
Input/Output |
ao_dev |
Input |
ao_chn |
Input |
frame |
Pointer to audio frame data. |
Input |
milli_sec |
Input |
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
Notes:
The value of milli_sec must be greater than or equal to -1. When it is -1, data is sent in blocking mode. When it is 0, data is sent in non-blocking mode. When it is greater than 0, it blocks for milli_sec milliseconds, and if there is no data, it returns a timeout error.
The corresponding AO channel must be enabled before sending audio frame data.
k_s32 ret = 0;
while (true) {
// get ai frame
if (K_SUCCESS != ret) {
continue;
// send ai frame to ao
// release ai frame
2.3 Audio Encoding#
Audio encoding primarily implements creating encoding channels, sending audio frames for encoding, and retrieving encoded streams.
The audio encoding section provides G711a/u encoding, currently only supporting 16-bit sampling precision.
kd_mpi_aenc_register_encoder: Register encoder.
kd_mpi_aenc_unregister_encoder: Unregister encoder.
kd_mpi_aenc_create_chn: Create encoding channel.
kd_mpi_aenc_destroy_chn: Destroy encoding channel.
kd_mpi_aenc_send_frame: Send audio frame for encoding.
kd_mpi_aenc_get_stream: Get encoded audio stream.
kd_mpi_aenc_release_stream: Release encoded audio stream.
Description:
Register encoder.
Syntax:
k_s32 kd_mpi_aenc_register_encoder(k_s32 *handle, const [k_aenc_encoder](#322-k_aenc_encoder) *encoder);
Parameters:
Parameter |
Input/Output |
handle |
Registration handle. |
Output |
encoder |
Encoder attribute structure. |
Input |
Notes:
Users register an encoder by passing in the encoder attribute structure to the AENC module and receive a registration handle, which can be used later to unregister the encoder.
The AENC module can register up to 20 encoders, and it already registers G711.a and G711.u encoders.
The same encoding protocol cannot register multiple encoders. For example, if a G711 encoder is already registered, another G711 encoder cannot be registered.
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
Header file: mpi_aenc_api.h
Library file: libaenc.a
Description:
Unregister encoder.
Syntax:
Parameters:
Parameter |
Input/Output |
handle |
Unregistration handle. |
Input |
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
2.3.3 kd_mpi_aenc_create_chn#
Description:
Create audio encoding channel.
Syntax:
k_s32 kd_mpi_aenc_create_chn([k_aenc_chn](#326-k_aenc_chn) aenc_chn, const [k_aenc_chn_attr](#323-k_aenc_chn_attr) *attr);
Parameters:
Parameter |
Input/Output |
aenc_chn |
Channel number. Range: [0, AENC_MAX_CHN_NUM). |
Input |
attr |
Pointer to audio encoding channel attributes. |
Input |
Notes:
Buffer size is in frames, ranging from [2, K_MAX_AUDIO_FRAME_NUM], recommended to be configured above 10. Small buffer configurations may result in frame loss and other anomalies. Each encoding channel configures queue size based on buffer size to cache encoded frame data.
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
Description:
Destroy audio encoding channel.
Syntax:
k_s32 kd_mpi_aenc_destroy_chn([k_aenc_chn](#326-k_aenc_chn) aenc_chn);
Parameters:
Parameter |
Input/Output |
aenc_chn |
Input |
Notes:
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
2.3.5 kd_mpi_aenc_send_frame#
Description:
Syntax:
k_s32 kd_mpi_aenc_send_frame([k_aenc_chn](#326-k_aenc_chn) aenc_chn, const [k_audio_frame](#3114-k_audio_frame) *frame);
Parameters:
Parameter |
Input/Output |
aenc_chn |
Input |
frame |
Pointer to audio frame structure. |
Input |
Notes:
Sending encoded audio frames is a non-blocking interface. If the audio stream buffer is full, it returns failure. This interface is used for users to actively send audio frames for encoding. If the AENC channel is already bound to AI through the system binding interface, it is not necessary and not recommended to call this interface. When calling this interface to send audio frames, the corresponding encoding channel must be created first.
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
2.3.6 kd_mpi_aenc_get_stream#
Description:
Syntax:
k_s32 kd_mpi_aenc_get_stream([k_aenc_chn](#326-k_aenc_chn) aenc_chn, [k_audio_stream](#327-k_audio_stream) *stream, k_s32 milli_sec);
Parameters:
Parameter |
Input/Output |
aenc_chn |
Input |
stream |
Pointer to the retrieved audio stream. |
Output |
milli_sec |
Input |
Notes:
The channel must be created before retrieving streams, otherwise it directly returns failure. If the channel is destroyed during the process of retrieving streams, it immediately returns failure.
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
Description:
Syntax:
k_s32 kd_mpi_aenc_release_stream([k_aenc_chn](#326-k_aenc_chn) aenc_chn, const [k_audio_stream](#327-k_audio_stream) *stream);
Parameters:
Parameter |
Input/Output |
aenc_chn |
Input |
stream |
Output |
Notes:
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
2.4 Audio Decoding#
Audio decoding primarily implements creating decoding channels, sending audio streams for decoding, and retrieving decoded audio frames.
The audio encoding and decoding section provides G711a/u decoding, currently supporting 16-bit sampling precision.
kd_mpi_adec_register_decoder: Register decoder.
kd_mpi_adec_unregister_decoder: Unregister decoder.
kd_mpi_adec_create_chn: Create audio decoding channel.
kd_mpi_adec_destroy_chn: Destroy audio decoding channel.
kd_mpi_adec_send_stream: Send audio stream to audio decoding channel.
kd_mpi_adec_clr_chn_buf: Clear current audio data buffer in ADEC channel.
kd_mpi_adec_get_frame: Retrieve decoded audio frame.
kd_mpi_adec_release_frame: Release decoded audio frame.
Description:
Register decoder.
Syntax:
k_s32 kd_mpi_adec_register_decoder(k_s32 *handle, const [k_adec_decoder](#329-k_adec_decoder) *decoder);
Parameters:
Parameter |
Input/Output |
handle |
Output |
decoder |
Decoder attribute struct. |
Input |
Notes:
Users register a decoder to the ADEC module by passing in the decoder attribute structure and receive a registration handle, which can be used later to unregister the decoder. The ADEC module can register up to 20 decoders, and it already registers G711a and G711u decoders. The same decoding protocol cannot register multiple decoders. For example, if a G711 decoder is already registered, another G711 decoder cannot be registered.
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
Header file: mpi_adec_api.h
Library file: libadec.a
Description:
Unregister decoder.
Syntax:
Parameters:
Parameter |
Input/Output |
handle |
Input |
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
2.4.3 kd_mpi_adec_create_chn#
Description:
Syntax:
k_s32 kd_mpi_adec_create_chn([k_adec_chn](#3212-k_adec_chn) adec_chn, const [k_adec_chn_attr](#328-k_adec_chn_attr) *attr);
Parameters:
Parameter |
Input/Output |
adec_chn |
Channel number. Range: [0, ADEC_MAX_CHN_NUM). |
Input |
attr |
Pointer to channel attributes. |
Input |
Notes:
The protocol type specifies the decoding protocol for the channel, currently supporting G711. Some attributes of audio decoding need to match the output device attributes, such as sampling rate, frame length (number of samples per frame), etc. Buffer size is in frames, ranging from [2, K_MAX_AUDIO_FRAME_NUM], recommended to be configured above 10. Small buffer configurations may result in frame loss and other anomalies. This interface can only be used before the channel is created (or after it is destroyed). If the channel has already been created, it returns that the channel is already created.
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
Description:
Syntax:
k_s32 kd_mpi_adec_destroy_chn([k_adec_chn](#3212-k_adec_chn) adec_chn);
Parameters:
Parameter |
Input/Output |
adec_chn |
Input |
Notes:
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
Description:
Syntax:
k_s32 kd_mpi_adec_send_stream(k_adec_chn adec_chn, const k_audio_stream *stream, k_bool block);
Parameters:
Parameter |
Description: |
Input/Output |
adec_chn |
Input |
stream |
Audio stream. |
Input |
block |
Blocking flag. HI_TRUE: Blocking. HI_FALSE: Non-blocking. |
Input |
Notes:
When sending data, the channel must already be created; otherwise, it directly returns failure. If the channel is destroyed during the data sending process, it immediately returns failure. Supports sending streams in blocking or non-blocking mode. When sending streams in blocking mode, if the buffer used to cache the decoded audio frames is full, this interface call will be blocked until the decoded audio frame data is taken away or the ADEC channel is destroyed.
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
Description:
Syntax:
k_s32 kd_mpi_adec_clr_chn_buf([k_adec_chn](#3212-k_adec_chn) adec_chn);
Parameters:
Parameter |
Input/Output |
adec_chn |
Input |
Notes:
The decoding channel must be created; otherwise, it returns a channel does not exist error code.
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
2.4.7 kd_mpi_adec_get_frame#
Description:
Syntax:
k_s32 kd_mpi_adec_get_frame([k_adec_chn](#3212-k_adec_chn) adec_chn, [k_audio_frame](#3114-k_audio_frame) *frame, k_s32 milli_sec);
Parameters:
Parameter |
Input/Output |
adec_chn |
Audio decoding channel. |
Input |
frame_info |
Audio frame data structure. |
Output |
block |
Blocking flag for retrieval. |
Input |
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
Description:
Release the retrieved audio decoding frame data.
Syntax:
k_s32 kd_mpi_adec_release_frame([k_adec_chn](#326-k_aenc_chn) adec_chn, const [k_audio_frame](#3114-k_audio_frame) *frame);
Parameters:
Parameter |
Input/Output |
adec_chn |
Input |
frame_info |
Input |
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
2.5 Built-in Audio Codec#
The built-in Audio Codec primarily provides operations on hardware devices through ioctl. Among the provided ioctl commands, some commands can be used with the default values set during module loading. The ioctl call implements reading and writing to the built-in Audio Codec registers.
The current version of audio codec control operations mainly includes: ADC digital and analog volume, DAC digital/analog volume, ADC/DAC mute control. Sampling rate, sampling precision, and I2S alignment mode control operations are automatically completed by the kernel through the AI and AO API interfaces (the kernel code automatically implements the operation of the codec hardware device), and ioctl interfaces are no longer provided for control.
Standard function commands for the built-in Audio Codec:
k_acodec_set_gain_micl: Left channel input analog gain control
k_acodec_set_gain_micr: Right channel input analog gain control
k_acodec_set_adcl_volume: Left channel input digital volume control
k_acodec_set_adcr_volume: Right channel input digital volume control
k_acodec_set_alc_gain_micl: ALC left channel input analog gain control
k_acodec_set_alc_gain_micr: ALC right channel input analog gain control
k_acodec_set_gain_hpoutl: Left channel output analog volume control
k_acodec_set_gain_hpoutr: Right channel output analog volume control
k_acodec_set_dacl_volume: Left channel output digital volume control
k_acodec_set_dacr_volume: Right channel output digital volume control
k_acodec_set_micl_mute: Left channel input mute control
k_acodec_set_micr_mute: Right channel input mute control
k_acodec_set_dacl_mute: Left channel output mute control
k_acodec_set_dacr_mute: Right channel output mute control
k_acodec_get_gain_micl: Get left channel input analog gain value
k_acodec_get_gain_micr: Get right channel input analog gain value
k_acodec_get_adcl_volume: Get left channel input digital volume value
k_acodec_get_adcr_volume: Get right channel input digital volume value
k_acodec_get_alc_gain_micl: Get ALC left channel input analog gain value
k_acodec_get_alc_gain_micr: Get ALC right channel input analog gain value
k_acodec_get_gain_hpoutl: Get left channel output analog volume value
k_acodec_get_gain_hpoutr: Get right channel output analog volume value
k_acodec_get_dacl_volume: Get left channel output digital volume value
k_acodec_get_dacr_volume: Get right channel output digital volume value
k_acodec_reset: Volume reset
2.5.1 k_acodec_set_gain_micl#
Description:
Syntax:
Parameters:
Parameter |
Input/Output |
fd |
Audio Codec device file descriptor |
Input |
k_acodec_set_gain_micl |
ioctl number |
Input |
arg |
Unsigned integer pointer |
Input |
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
Header file: k_acodec_comm.h
Library file: libacodec.a
Notes:
The analog gain range is 0db, 6db, 20db, 30db.
2.5.2 k_acodec_set_gain_micr#
Description:
Syntax:
Parameters:
Parameter Name |
Input/Output |
fd |
Input |
k_acodec_set_gain_micr |
ioctl number |
Input |
arg |
Input |
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
Notes:
Description:
Left channel input digital gain control.
Syntax:
Parameters:
Parameter Name |
Input/Output |
fd |
Input |
k_acodec_set_adcl_volume |
ioctl number |
Input |
arg |
Signed float pointer |
Input |
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
Notes:
The digital gain range is [-97, 30], the larger the value, the higher the volume, incremented by 0.5db.
Description:
Right channel input digital gain control.
Syntax:
Parameters:
Parameter Name |
Input/Output |
fd |
Input |
k_acodec_set_adcr_volume |
ioctl number |
Input |
arg |
Input |
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
Notes:
Description:
Left channel ALC input analog gain control.
Syntax:
Parameters:
Parameter Name |
Input/Output |
fd |
Input |
k_acodec_set_alc_gain_micl |
ioctl number |
Input |
arg |
Input |
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
Notes:
The analog gain range is [-18, 28.5], the larger the value, the higher the volume, incremented by 1.5db.
Description:
Right channel ALC input analog gain control.
Syntax:
Parameters:
Parameter Name |
Input/Output |
fd |
Input |
k_acodec_set_alc_gain_micr |
ioctl number |
Input |
arg |
Input |
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
Notes:
Description:
Left channel output analog gain control.
Syntax:
Parameters:
Parameter Name |
Input/Output |
fd |
Input |
k_acodec_set_gain_hpoutl |
ioctl number |
Input |
arg |
Input |
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
Notes:
The analog gain range is [-39, 6], the larger the value, the higher the volume, incremented by 1.5db.
Description:
Right channel output analog gain control.
Syntax:
Parameters:
Parameter Name |
Input/Output |
fd |
Input |
k_acodec_set_gain_hpoutr |
ioctl number |
Input |
arg |
Input |
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
Notes:
Description:
Left channel output digital gain control.
Syntax:
Parameters:
Parameter Name |
Input/Output |
fd |
Input |
k_acodec_set_dacl_volume |
ioctl number |
Input |
arg |
Input |
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
Notes:
The digital gain range is [-120, 7], the larger the value, the higher the volume, incremented by 0.5db.
Description:
Right channel output digital gain control.
Syntax:
Parameters:
Parameter Name |
Input/Output |
fd |
Input |
k_acodec_set_dacr_volume |
ioctl number |
Input |
arg |
Input |
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
Notes:
Description:
Left channel input mute control.
Syntax:
Parameters:
Parameter Name |
Input/Output |
fd |
Input |
k_acodec_set_micl_mute |
ioctl number |
Input |
arg |
Bool pointer |
Input |
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
Notes:
Value range: K_TRUE for mute, K_FALSE to unmute.
Description:
Right channel input mute control.
Syntax:
Parameters:
Parameter Name |
Input/Output |
fd |
Input |
k_acodec_set_micr_mute |
ioctl number |
Input |
arg |
Bool pointer |
Input |
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
Notes:
Description:
Left channel output mute control.
Syntax:
Parameters:
Parameter Name |
Input/Output |
fd |
Input |
k_acodec_set_dacl_mute |
ioctl number |
Input |
arg |
Bool pointer |
Input |
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
Notes:
Description:
Right channel output mute control.
Syntax:
Parameters:
Parameter Name |
Input/Output |
fd |
Input |
k_acodec_set_dacr_mute |
ioctl number |
Input |
arg |
Bool pointer |
Input |
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
Notes:
Description:
Get left channel input analog gain value.
Syntax:
Parameters:
Parameter Name |
Input/Output |
fd |
Input |
k_acodec_get_gain_micl |
ioctl number |
Input |
arg |
Output |
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
Notes:
The analog gain range obtained is 0db, 6db, 20db, 30db.
Description:
Get right channel input analog gain value.
Syntax:
Parameters:
Parameter Name |
Input/Output |
fd |
Input |
k_acodec_get_gain_micr |
ioctl number |
Input |
arg |
Output |
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
Notes:
Description:
Get left channel input digital volume value.
Syntax:
Parameters:
Parameter Name |
Input/Output |
fd |
Input |
k_acodec_get_adcl_volume |
ioctl number |
Input |
arg |
Output |
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
Notes:
Description:
Get right channel input digital gain control value.
Syntax:
Parameters:
Parameter Name |
Input/Output |
fd |
Input |
k_acodec_get_adcr_volume |
ioctl number |
Input |
arg |
Output |
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
Notes:
Description:
Get left channel ALC input analog gain value.
Syntax:
int ioctl (int fd, k_acodec_get_alc_gain_micl, float *arg);
Parameters:
Parameter Name |
Input/Output |
fd |
Input |
k_acodec_get_alc_gain_micl |
ioctl number |
Input |
arg |
Output |
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
Notes:
Description:
Get right channel ALC input analog gain value.
Syntax:
Parameters:
Parameter Name |
Input/Output |
fd |
Input |
k_acodec_get_alc_gain_micr |
ioctl number |
Input |
arg |
Output |
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
Notes:
Description:
Get left channel output analog gain value.
Syntax:
Parameters:
Parameter Name |
Input/Output |
fd |
Input |
k_acodec_get_gain_hpoutl |
ioctl number |
Input |
arg |
Output |
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
Notes:
Description:
Get right channel output analog gain control.
Syntax:
Parameters:
Parameter Name |
Input/Output |
fd |
Input |
k_acodec_get_gain_hpoutr |
ioctl number |
Input |
arg |
Output |
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
Notes:
Description:
Get left channel output digital gain value.
Syntax:
Parameters:
Parameter Name |
Input/Output |
fd |
Input |
k_acodec_get_dacl_volume |
ioctl number |
Input |
arg |
Output |
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
Notes:
Description:
Get right channel output digital gain value.
Syntax:
Parameters:
Parameter Name |
Input/Output |
fd |
Input |
k_acodec_get_dacr_volume |
ioctl number |
Input |
arg |
Output |
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
Notes:
2.5.10 k_acodec_reset#
Description:
Volume reset: including ADC, DAC, ALC digital and analog gain.
Syntax:
int ioctl (int fd, k_acodec_reset, ...);
Parameters:
Parameter Name |
Input/Output |
fd |
Input |
k_acodec_reset |
ioctl number |
Input |
Return Value:
Return Value |
Success |
Non-zero |
Requirements:
Notes:
2.6 Audio Encoding MAPI#
The audio encoding function module provides the following MAPI:
kd_mapi_aenc_init: Initialize encoding channel
kd_mapi_aenc_deinit: Deinitialize encoding channel
kd_mapi_aenc_start: Start encoding channel
kd_mapi_aenc_stop: Stop encoding channel
kd_mapi_aenc_registercallback: Register encoding callback function
kd_mapi_aenc_unregistercallback: Unregister encoding callback function
kd_mapi_aenc_bind_ai: Bind AI
kd_mapi_aenc_unbind_ai: Unbind AI
kd_mapi_register_ext_audio_encoder: Register external audio encoder
kd_mapi_unregister_ext_audio_encoder: Unregister external audio encoder
kd_mapi_aenc_send_frame: Send audio encoding frame
2.6.1 kd_mapi_aenc_init#
Description:
Initialize encoding channel.
Syntax:
kd_mapi_aenc_init([k_handle](#331-k_handle) aenc_hdl, const [k_aenc_chn_attr](#323-k_aenc_chn_attr) *attr);
2.6.2 kd_mapi_aenc_deinit#
Description:
Deinitialize encoding channel.
Parameters:
kd_mapi_aenc_deinit([k_handle](#331-k_handle) aenc_hdl);
2.6.3 kd_mapi_aenc_start#
Description:
Start encoding channel.
Syntax:
kd_mapi_aenc_start([k_handle](#331-k_handle) aenc_hdl);
2.6.4 kd_mapi_aenc_stop#
Description:
Stop encoding channel.
Syntax:
kd_mapi_aenc_stop([k_handle](#331-k_handle) aenc_hdl);
Description:
Register encoding callback function.
Syntax:
k_s32 kd_mapi_aenc_registercallback([k_handle](#331-k_handle) aenc_hdl, k_aenc_callback_s *aenc_cb);
Description:
Unregister encoding callback function.
Syntax:
k_s32 kd_mapi_aenc_unregistercallback([k_handle](#331-k_handle) aenc_hdl);
2.6.7 kd_mapi_aenc_bind_ai#
Description:
Bind AI.
Syntax:
k_s32 kd_mapi_aenc_bind_ai([k_handle](#331-k_handle) ai_hdl, [k_handle](#331-k_handle) aenc_hdl);
2.6.8 kd_mapi_aenc_unbind_ai#
Description:
Unbind AI.
Syntax:
k_s32 kd_mapi_aenc_unbind_ai([k_handle](#331-k_handle) ai_hdl, [k_handle](#331-k_handle) aenc_hdl);
Description:
Register external audio encoder.
Syntax:
k_s32 kd_mapi_register_ext_audio_encoder(const [k_aenc_encoder](#322-k_aenc_encoder) *encoder, [k_handle](#331-k_handle) * aencoder_hdl);
Description:
Unregister external audio encoder.
Syntax:
k_s32 kd_mapi_unregister_ext_audio_encoder([k_handle](#331-k_handle) aencoder_hdl);
Description:
Send audio encoding frame.
Syntax:
k_s32 kd_mapi_aenc_send_frame([k_handle](#331-k_handle) ai_hdl, const [k_audio_frame](#3114-k_audio_frame) *frame);
2.7 Audio Decoding MAPI#
The audio decoding function module provides the following MAPI:
kd_mapi_adec_init: Initialize decoding channel
kd_mapi_adec_deinit: Deinitialize decoding channel
kd_mapi_adec_start: Start decoding channel.
kd_mapi_adec_stop: Stop decoding channel.
kd_mapi_adec_registercallback: Register decoding callback function.
kd_mapi_adec_unregistercallback: Unregister decoding callback function.
kd_mapi_adec_bind_ao: Bind AO.
kd_mapi_adec_unbind_ao: Unbind AO.
kd_mapi_register_ext_audio_decoder: Register external audio decoder.
kd_mapi_unregister_ext_audio_decoder: Unregister external audio decoder.
kd_mapi_adec_send_stream: Send audio decoding frame.
2.7.1 kd_mapi_adec_init#
Description:
Initialize decoding channel.
Syntax:
kd_mapi_adec_init([k_handle](#331-k_handle) adec_hdl, const [k_adec_chn_attr](#323-k_adec_chn_attr) *attr);
2.7.2 kd_mapi_adec_deinit#
Description:
Deinitialize decoding channel.
Syntax:
kd_mapi_adec_deinit([k_handle](#331-k_handle) adec_hdl);
2.7.3 kd_mapi_adec_start#
Description:
Syntax:
kd_mapi_adec_start([k_handle](#331-k_handle) adec_hdl);
2.7.4 kd_mapi_adec_stop#
Description:
Syntax:
kd_mapi_adec_stop([k_handle](#331-k_handle) adec_hdl);
Description:
Syntax:
k_s32 kd_mapi_adec_registercallback([k_handle](#331-k_handle) adec_hdl, k_adec_callback_s *adec_cb);
Description:
Syntax:
k_s32 kd_mapi_adec_unregistercallback([k_handle](#331-k_handle) adec_hdl);
2.7.7 kd_mapi_adec_bind_ao#
Description:
Bind AO.
Syntax:
k_s32 kd_mapi_adec_bind_ao([k_handle](#331-k_handle) ao_hdl, [k_handle](#331-k_handle) adec_hdl);
2.7.8 kd_mapi_adec_unbind_ao#
Description:
Unbind AO.
Syntax:
k_s32 kd_mapi_adec_unbind_ao([k_handle](#331-k_handle) ao_hdl, [k_handle](#331-k_handle) adec_hdl);
Description:
Syntax:
k_s32 kd_mapi_register_ext_audio_decoder(const [k_adec_decoder](#329-k_adec_decoder) *decoder, [k_handle](#331-k_handle) *adecoder_hdl);
Description:
Syntax:
k_s32 kd_mapi_unregister_ext_audio_decoder([k_handle](#331-k_handle) adecoder_hdl);
Description:
Syntax:
k_s32 kd_mapi_adec_send_stream([k_handle](#331-k_handle) ai_hdl, const [k_audio_stream](#327-k_audio_stream) *stream);
3. Data Types#
3.1 Audio Input/Output#
The data types and structures related to audio input/output are defined as follows:
k_audio_type: Defines audio input/output types.
k_audio_dev: Defines audio devices.
k_ai_chn: Defines AI channels.
k_ao_chn: Defines AO channels.
K_MAX_AUDIO_FRAME_NUM: Defines the maximum number of audio decoding buffer frames.
k_audio_bit_width: Defines audio sampling precision.
k_audio_snd_mode: Defines audio channel modes.
k_audio_pdm_oversample: Defines PDM oversampling.
k_aio_dev_attr: Defines the attribute structure of audio input/output devices.
k_audio_pdm_attr: Defines PDM audio input attributes.
k_i2s_work_mode: Defines I2S working modes.
k_audio_i2s_attr: Defines I2S audio input attributes.
k_aio_i2s_type: Defines I2S interfacing device types.
k_audio_frame: Defines audio frame structures.
k_ai_vqe_enable: Defines the configuration structure for audio input voice quality enhancement.
3.1.1 k_audio_type#
Description:
Definition:
KD_AUDIO_INPUT_TYPE_I2S = 0, // I2S input
KD_AUDIO_INPUT_TYPE_PDM = 1, // PDM input
KD_AUDIO_OUTPUT_TYPE_I2S = 2, // I2S output
} k_audio_type;
Notes:
Audio input includes I2S and PDM, while audio output only includes I2S.
3.1.2 k_audio_dev#
Description:
Definition:
typedef k_u32 k_audio_dev;
Notes:
For the AI module, k_audio_dev can be 0 or 1, where 0 is for I2S audio input and 1 is for PDM audio input.
For the AO module, k_audio_dev is fixed at 0, which means I2S audio output.
3.1.3 k_ai_chn#
Description:
Defines AI audio channels.
Definition:
typedef k_u32 k_ai_chn;
Notes:
I2S audio input has 2 channels, with values ranging from [0, 1].
PDM audio input has 4 channels, with values ranging from [0, 3].
3.1.4 k_ao_chn#
Description:
Defines AO audio channels.
Definition:
typedef k_u32 k_ao_chn;
Notes:
I2S audio output has 2 channels, with values ranging from [0, 1].
3.1.5 K_MAX_AUDIO_FRAME_NUM#
Description:
Definition:
3.1.6 k_audio_bit_width#
Description:
Definition:
KD_AUDIO_BIT_WIDTH_16 = 0, /* 16-bit width */
KD_AUDIO_BIT_WIDTH_24 = 1, /* 24-bit width */
KD_AUDIO_BIT_WIDTH_32 = 2, /* 32-bit width */
} k_audio_bit_width;
Notes:
3.1.7 k_audio_snd_mode#
Description:
Definition:
KD_AUDIO_SOUND_MODE_MONO = 0, /* Mono */
KD_AUDIO_SOUND_MODE_STEREO = 1, /* Stereo */
} k_audio_snd_mode;
3.1.8 k_audio_pdm_oversample#
Description:
Definition:
KD_AUDIO_PDM_INPUT_OVERSAMPLE_64,
KD_AUDIO_PDM_INPUT_OVERSAMPLE_128,
} k_audio_pdm_oversample;
3.1.9 k_audio_pdm_attr#
Description:
Definition:
k_u32 chn_cnt; /* Channel number on FS, I2S valid value: 1/2, PDM valid value: 1/2/3/4 */
k_audio_sample_rate rate;
k_audio_bit_width width;
k_audio_snd_mode mode;
k_u32 frame_num; /* Frame number in buffer [2, K_MAX_AUDIO_FRAME_NUM] */
k_u32 point_num_per_frame;
} k_audio_pdm_attr;
Members:
Member Name |
chn_cnt |
Supported channel count. Supports 1-4 channels, channels must be consecutive. |
sample_rate |
Sampling rate: supports 8k~192k |
bit_width |
Sampling precision: supports 16/24/32 |
snd_mode |
Audio channel mode. Supports mono and stereo. |
pdm_oversample |
Oversampling: supports 32, 64, 128 times oversampling. |
frame_num |
Buffer frame number |
point_num_per_frame |
Number of sampling points per frame. |
Notes:
3.1.10 k_audio_i2s_attr#
Description:
Definition:
k_u32 sample_rate; /* Sample rate 8k ~192k */
k_audio_bit_width bit_width;
k_audio_snd_mode snd_mode; /* Mono or stereo */
k_i2s_in_mono_channel mono_channel; /* Use mic input or headphone input */
k_i2s_work_mode i2s_mode; /* I2S work mode */
k_aio_i2s_type type;
} k_audio_i2s_attr;
Members:
Member Name |
chn_cnt |
Supported channel count. Supports 1-2 channels. |
sample_rate |
bit_width |
snd_mode |
mono_channel |
Mono channel source selection. 0: mic input, 1: headphone input |
i2s_mode |
I2S working mode: supports Philips mode, left-justified mode, right-justified mode. |
frame_num |
Number of sampling points per frame |
i2s_type |
I2S interfacing device type: internal codec or external device. |
Notes:
The value of point_num_per_frame and sample_rate determines the interrupt frequency generated by the hardware. A high frequency can affect system performance and other tasks. It is recommended that these parameters satisfy the equation: (point_num_per_frame * 1000) / sample_rate >= 10 (100 interrupts). For example, at a sampling rate of 16000Hz, it is recommended to set the number of sampling points to be greater than or equal to 160.
3.1.11 k_i2s_work_mode#
Description:
Definition:
K_STANDARD_MODE = 1,
K_RIGHT_JUSTIFYING_MODE = 2,
K_LEFT_JUSTIFYING_MODE = 4,
} k_i2s_work_mode;
Notes:
3.1.12 k_aio_dev_attr#
Description:
Definition:
k_audio_type type;
union {
k_audio_pdm_attr pdm_attr;
k_audio_i2s_attr i2s_attr;
} kd_audio_attr;
} k_aio_dev_attr;
Members:
Member Name |
audio_type |
Audio type. |
kd_audio_attr |
Audio attribute settings. |
Notes:
3.1.13 k_aio_i2s_type#
Description:
Definition:
K_AIO_I2STYPE_EXTERN, /* AIO I2S connect external hardware */
} k_aio_i2s_type;
Notes:
The built-in audio codec uses I2S channel 0, while I2S channel 1 is used for external codecs.
3.1.14 k_audio_frame#
Description:
Definition:
void* virt_addr;
k_u64 phys_addr;
k_u32 len; /* data length per channel in frame */
k_u32 pool_id;
} k_audio_frame;
Members:
Member Name |
bit_width |
Sampling precision. |
snd_mode |
Audio channel mode. |
virt_addr |
Virtual address of the audio frame data. |
phys_addr |
Physical address of the audio frame data. |
time_stamp |
Audio frame timestamp, in μs. |
seq |
Audio frame sequence number. |
len |
Audio frame length, in bytes. |
pool_id |
Audio frame buffer pool ID. |
Notes:
3.1.15 k_ai_vqe_enable#
Description:
Definition:
k_bool aec_enable;
k_u32 aec_echo_delay_ms; // Time difference from speaker output to mic input (100-500ms)
k_bool agc_enable;
k_bool ans_enable;
} k_ai_vqe_enable;
Members:
Member Name |
aec_enable |
Echo cancellation enable. |
aec_echo_delay_ms |
Echo cancellation filter length, recommended to be 100-500ms. This is the time difference from speaker output to mic input. The specific value needs fine-tuning, as improper adjustment can directly affect the echo cancellation effect. |
agc_enable |
Automatic gain control enable. |
ans_enable |
Audio noise suppression enable. |
Notes:
3.1.16 k_i2s_in_mono_channel#
Description:
Defines mono channel source.
Definition:
KD_I2S_IN_MONO_RIGHT_CHANNEL = 0, // mic input
KD_I2S_IN_MONO_LEFT_CHANNEL = 1, // hp input
} k_i2s_in_mono_channel;
3.2 Audio Encoding/Decoding#
The data types and structures related to audio encoding/decoding are defined as follows:
3.2.1 k_payload_type#
Description:
Defines the enumeration of audio and video payload types.
Definition:
K_PT_PCMU = 0,
K_PT_1016 = 1,
K_PT_G721 = 2,
K_PT_GSM = 3,
K_PT_G723 = 4,
K_PT_DVI4_8K = 5,
K_PT_DVI4_16K = 6,
K_PT_LPC = 7,
K_PT_PCMA = 8,
K_PT_G722 = 9,
K_PT_S16BE_STEREO = 10,
K_PT_S16BE_MONO = 11,
K_PT_QCELP = 12,
K_PT_CN = 13,
K_PT_MPEGAUDIO = 14,
K_PT_G728 = 15,
K_PT_DVI4_3 = 16,
K_PT_DVI4_4 = 17,
K_PT_G729 = 18,
K_PT_G711A = 19,
K_PT_G711U = 20,
K_PT_G726 = 21,
K_PT_G729A = 22,
K_PT_LPCM = 23,
K_PT_CelB = 25,
K_PT_JPEG = 26,
K_PT_CUSM = 27,
K_PT_NV = 28,
K_PT_PICW = 29,
K_PT_CPV = 30,
K_PT_H261 = 31,
K_PT_MPEGVIDEO = 32,
K_PT_MPEG2TS = 33,
K_PT_H263 = 34,
K_PT_SPEG = 35,
K_PT_MPEG2VIDEO = 36,
K_PT_AAC = 37,
K_PT_WMA9STD = 38,
K_PT_HEAAC = 39,
K_PT_PCM_VOICE = 40,
K_PT_PCM_AUDIO = 41,
K_PT_MP3 = 43,
K_PT_ADPCMA = 49,
K_PT_AEC = 50,
K_PT_X_LD = 95,
K_PT_H264 = 96,
K_PT_D_GSM_HR = 200,
K_PT_D_GSM_EFR = 201,
K_PT_D_L8 = 202,
K_PT_D_RED = 203,
K_PT_D_VDVI = 204,
K_PT_D_BT656 = 220,
K_PT_D_H263_1998 = 221,
K_PT_D_MP1S = 222,
K_PT_D_MP2P = 223,
K_PT_D_BMPEG = 224,
K_PT_MP4VIDEO = 230,
K_PT_MP4AUDIO = 237,
K_PT_VC1 = 238,
K_PT_JVC_ASF = 255,
K_PT_D_AVI = 256,
K_PT_DIVX3 = 257,
K_PT_AVS = 258,
K_PT_REAL8 = 259,
K_PT_REAL9 = 260,
K_PT_VP6 = 261,
K_PT_VP6F = 262,
K_PT_VP6A = 263,
K_PT_SORENSON = 264,
K_PT_H265 = 265,
K_PT_VP8 = 266,
K_PT_MVC = 267,
K_PT_PNG = 268,
K_PT_AMR = 1001,
K_PT_MJPEG = 1002,
K_PT_AMRWB = 1003,
K_PT_PRORES = 1006,
K_PT_OPUS = 1007,
K_PT_BUTT
} k_payload_type;
Notes:
3.2.2 k_aenc_encoder#
Description:
Defines the encoder attribute structure.
Definition:
k_payload_type type;
k_u32 max_frame_len;
k_s32 (*func_open_encoder)(void *encoder_attr, void **encoder);
k_s32 (*func_enc_frame)(void *encoder, const k_audio_frame *data, k_u8 *outbuf, k_u32 *out_len);
} k_aenc_encoder;
Members:
Member Name |
type |
Encoding protocol type. |
max_frame_len |
Maximum stream length. |
name |
Encoder name. |
func_open_encoder |
Function pointer to open encoder. |
func_enc_frame |
Function pointer to encode frame. |
func_close_encoder |
Function pointer to close encoder. |
Notes:
3.2.3 k_aenc_chn_attr#
Description:
Defines the encoder channel attribute structure.
Definition:
k_u32 buf_size; // buffer size [2, K_MAX_AUDIO_FRAME_NUM]
} k_aenc_chn_attr;
Members:
Member Name |
type |
Audio encoding protocol type. |
Frame length corresponding to the audio encoding protocol (encoding can be performed if the received audio frame length is less than or equal to this frame length). |
buf_size |
Audio encoding buffer size. Range: |
Notes:
3.2.4 AENC_MAX_CHN_NUMS#
Description:
Defines the maximum number of encoding channels.
Definition:
#define AENC_MAX_CHN_NUMS 4
Notes:
3.2.5 K_MAX_ENCODER_NAME_LEN#
Description:
Defines the maximum length of the audio encoder name.
Definition:
Notes:
3.2.6 k_aenc_chn#
Description:
Defines the encoding channel type.
Definition:
typedef k_u32 k_aenc_chn;
Notes:
3.2.7 k_audio_stream#
Description:
Defines the stream structure.
Definition:
k_u64 phys_addr; /* the physical address of stream */
k_u32 len; /* stream length, in bytes */
k_u64 time_stamp; /* frame timestamp */
k_u32 seq; /* frame sequence number, if stream is not a valid frame, seq is 0 */
} k_audio_stream;
Members:
Member Name |
stream |
Pointer to the audio stream data. |
phys_addr |
Physical address of the audio stream. |
len |
Length of the audio stream, in bytes. |
time_stamp |
Timestamp of the audio stream. |
seq |
Sequence number of the audio stream. |
Notes:
3.2.8 k_adec_chn_attr#
Description:
Defines the decoder channel attribute structure.
Definition:
k_payload_type payload_type;
k_u32 buf_size; /* buffer size [2~K_MAX_AUDIO_FRAME_NUM] */
} k_adec_chn_attr;
Members:
Member Name |
payload_type |
Audio decoding protocol type. |
Frame length corresponding to the audio decoding protocol. |
buf_size |
Audio decoding buffer size. Range: |
Notes:
Some attributes of audio decoding need to match the attributes of the output device, such as sampling rate, frame length (number of sampling points per frame), etc.
3.2.9 k_adec_decoder#
Description:
Defines the decoder attribute structure.
Definition:
k_s32 (*func_open_decoder)(void *decoder_attr, void **decoder);
k_s32 (*func_dec_frame)(void *decoder, k_u8 **inbuf, k_s32 *left_byte, k_u16 *outbuf, k_u32 *out_len, k_u32 *chns);
} k_adec_decoder;
Members:
Member Name |
payload_type |
Decoding protocol type. |
name |
Decoder name. |
func_open_decoder |
Function pointer to open decoder. |
func_dec_frame |
Function pointer to decode frame. |
func_get_frame_info |
Function pointer to get audio frame information. |
func_close_decoder |
Function pointer to close decoder. |
func_reset_decoder |
Function pointer to reset decoder. |
Notes:
Description:
Defines the maximum length of the audio decoder name.
Definition:
Notes:
3.2.11 ADEC_MAX_CHN_NUMS#
Description:
Defines the maximum number of decoding channels.
Definition:
#define ADEC_MAX_CHN_NUMS 4
Notes:
3.2.12 k_adec_chn#
Description:
Defines the decoding channel type.
Definition:
typedef k_u32 k_adec_chn;
Notes:
3.3 MAPI#
The data types and structures related to audio MAPI are defined as follows:
3.3.1 k_handle#
Description:
Defines the operation handle.
Definition:
typedef k_u32 k_handle;
4.1 Audio Input API Error Codes#
Error Code |
Macro Definition |
0xA0158001 |
K_ERR_AI_INVALID_DEVID |
Invalid audio input device number |
0xA0158002 |
K_ERR_AI_INVALID_CHNID |
Invalid audio input channel number |
0xA0158003 |
K_ERR_AI_ILLEGAL_PARAM |
Invalid audio input parameter setting |
0xA0158004 |
K_ERR_AI_NOT_ENABLED |
Audio input device or channel not enabled |
0xA0158005 |
K_ERR_AI_NULL_PTR |
Null pointer error in input parameters |
0xA0158006 |
K_ERR_AI_NOT_CFG |
Audio input device attributes not set |
0xA0158007 |
K_ERR_AI_NOT_SUPPORT |
Operation not supported |
0xA0158008 |
K_ERR_AI_NOT_PERM |
Operation not permitted |
0xA0158009 |
K_ERR_AI_NO_MEM |
Failed to allocate memory |
0xA015800A |
K_ERR_AI_NO_BUF |
Insufficient audio input buffer |
0xA015800B |
K_ERR_AI_BUF_EMPTY |
Audio input buffer is empty |
0xA015800C |
K_ERR_AI_BUF_FULL |
Audio input buffer is full |
0xA015800D |
K_ERR_AI_NOT_READY |
Audio input system not initialized |
0xA015800E |
K_ERR_AI_BUSY |
Audio input system is busy |
4.2 Audio Output API Error Codes#
Error Code |
Macro Definition |
0xA0159001 |
K_ERR_AO_INVALID_DEV_ID |
Invalid audio output device number |
0xA0159002 |
K_ERR_AO_INVALID_CHN_ID |
Invalid audio output channel number |
0xA0159003 |
K_ERR_AO_ILLEGAL_PARAM |
Invalid audio output parameter setting |
0xA0159004 |
K_ERR_AO_NOT_ENABLED |
Audio output device or channel not enabled |
0xA0159005 |
K_ERR_AO_NULL_PTR |
Null pointer error in output |
0xA0159006 |
K_ERR_AO_NOT_CFG |
Audio output device attributes not set |
0xA0159007 |
K_ERR_AO_NOT_SUPPORT |
0xA0159008 |
K_ERR_AO_NOT_PERM |
0xA0159009 |
K_ERR_AO_NO_MEM |
Insufficient system memory |
0xA015900A |
K_ERR_AO_NO_BUF |
Insufficient audio output buffer |
0xA015900B |
K_ERR_AO_BUF_EMPTY |
Audio output buffer is empty |
0xA015900C |
K_ERR_AO_BUF_FULL |
Audio output buffer is full |
0xA015900D |
K_ERR_AO_NOT_READY |
Audio output system not initialized |
0xA015900E |
K_ERR_AO_BUSY |
Audio output system is busy |
