K230 nncase Development Guide#
What is nncase#
nncase is a neural network compiler designed for AI accelerators. Currently supported targets include CPU/K210/K510/K230, etc.
Features provided by nncase:
  • Supports multi-input multi-output networks and multi-branch structures
  • Static memory allocation, no heap memory required
  • Operator fusion and optimization
  • Supports float and uint8/int8 quantized inference
  • Supports post-training quantization using floating-point models and quantization calibration sets
  • Flat model, supports zero-copy loading
Supported neural network model formats by nncase:
  • TFLite
  • ONNX
nncase Architecture#
nncase architecture
The nncase software stack includes two parts: compiler and runtime.
Compiler: Used to compile neural network models on a PC, ultimately generating kmodel files. It mainly includes modules such as importer, IR, Evaluator, Quantize, Transform optimization, Tiling, Partition, Schedule, and Codegen.
  • Importer: Imports models from other neural network frameworks into nncase
  • IR: Intermediate Representation, divided into Neutral IR (device-independent) imported by the importer and Target IR (device-specific) generated by lowering the Neutral IR
  • Evaluator: Provides interpretation execution capabilities for IR, often used in scenarios such as Constant Folding/PTQ Calibration
  • Transform: Used for IR transformation and graph traversal optimization
  • Quantize: Post-training quantization, adds quantization tags to the tensors to be quantized, collects tensor data ranges by calling the Evaluator for interpretation execution based on the input calibration set, inserts quantization/dequantization nodes, and finally optimizes to eliminate unnecessary quantization/dequantization nodes
  • Tiling: Due to the limited memory capacity of NPU, large computations need to be split. Additionally, choosing Tiling parameters when there is a large amount of data reuse in computations can impact latency and bandwidth
  • Partition: Splits the graph according to ModuleType, each subgraph corresponds to a RuntimeModule, and different types of RuntimeModules correspond to different Devices (CPU/K230)
  • Schedule: Generates the computation order and allocates buffers based on the data dependency relationships in the optimized graph
  • Codegen: Calls the codegen corresponding to each subgraph’s ModuleType to generate RuntimeModules
Runtime: Integrated into the user’s App, providing functions such as loading kmodel, setting input data, executing KPU, and retrieving output data.
Development Environment#
Operating System#
Supported operating systems include Ubuntu 18.04/Ubuntu 20.04
Software Environment#
No.
Software
Version
python
3.6/3.7/3.8/3.9/3.10
pip
>=20.3
3
numpy
1.19.5
4
onnx
1.9.0
5
onnx-simplifier
0.3.6
6
Onnxoptimizer
0.2.6
7
Onnxruntime
1.8.0
8
dotnet-runtime
7.0
Hardware Environment#
K230 evb
Model Compilation APIs (Python)#
nncase provides Python APIs for compiling neural network models on a PC
Supported Operators#
TFLite Operators#
Operator
Is Supported
ABS
Yes
ADD
Yes
ARG_MAX
Yes
ARG_MIN
Yes
AVERAGE_POOL_2D
Yes
BATCH_MATMUL
Yes
CAST
Yes
CEIL
Yes
CONCATENATION
Yes
CONV_2D
Yes
COS
Yes
CUSTOM
Yes
DEPTHWISE_CONV_2D
Yes
DIV
Yes
EQUAL
Yes
EXP
Yes
EXPAND_DIMS
Yes
FLOOR
Yes
FLOOR_DIV
Yes
FLOOR_MOD
Yes
FULLY_CONNECTED
Yes
GREATER
Yes
GREATER_EQUAL
Yes
L2_NORMALIZATION
Yes
LEAKY_RELU
Yes
LESS
Yes
LESS_EQUAL
Yes
LOG
Yes
LOGISTIC
Yes
MAX_POOL_2D
Yes
MAXIMUM
Yes
MEAN
Yes
MINIMUM
Yes
MUL
Yes
NEG
Yes
NOT_EQUAL
Yes
PAD
Yes
PADV2
Yes
MIRROR_PAD
Yes
PACK
Yes
POW
Yes
REDUCE_MAX
Yes
REDUCE_MIN
Yes
REDUCE_PROD
Yes
RELU
Yes
PRELU
Yes
RELU6
Yes
RESHAPE
Yes
RESIZE_BILINEAR
Yes
RESIZE_NEAREST_NEIGHBOR
Yes
ROUND
Yes
RSQRT
Yes
SHAPE
Yes
SIN
Yes
SLICE
Yes
SOFTMAX
Yes
SPACE_TO_BATCH_ND
Yes
SQUEEZE
Yes
BATCH_TO_SPACE_ND
Yes
STRIDED_SLICE
Yes
SQRT
Yes
SQUARE
Yes
SUB
Yes
SUM
Yes
TANH
Yes
TILE
Yes
TRANSPOSE
Yes
TRANSPOSE_CONV
Yes
QUANTIZE
Yes
FAKE_QUANT
Yes
DEQUANTIZE
Yes
GATHER
Yes
GATHER_ND
Yes
ONE_HOT
Yes
SQUARED_DIFFERENCE
Yes
LOG_SOFTMAX
Yes
SPLIT
Yes
HARD_SWISH
Yes
ONNX Operators#
Operator
Is Supported
Abs
Yes
Acos
Yes
Acosh
Yes
And
Yes
ArgMax
Yes
ArgMin
Yes
Asin
Yes
Asinh
Yes
Add
Yes
AveragePool
Yes
BatchNormalization
Yes
Cast
Yes
Ceil
Yes
Celu
Yes
Clip
Yes
Compress
Yes
Concat
Yes
Constant
Yes
ConstantOfShape
Yes
Conv
Yes
ConvTranspose
Yes
Cos
Yes
Cosh
Yes
CumSum
Yes
DepthToSpace
Yes
DequantizeLinear
Yes
Div
Yes
Dropout
Yes
Elu
Yes
Exp
Yes
Expand
Yes
Equal
Yes
Erf
Yes
Flatten
Yes
Floor
Yes
Gather
Yes
GatherElements
Yes
GatherND
Yes
Gemm
Yes
GlobalAveragePool
Yes
GlobalMaxPool
Yes
Greater
Yes
GreaterOrEqual
Yes
GRU
Yes
Hardmax
Yes
HardSigmoid
Yes
HardSwish
Yes
Identity
Yes
InstanceNormalization
Yes
LayerNormalization
Yes
LpNormalization
Yes
LeakyRelu
Yes
Less
Yes
LessOrEqual
Yes
Log
Yes
LogSoftmax
Yes
LRN
Yes
LSTM
Yes
MatMul
Yes
MaxPool
Yes
Max
Yes
Min
Yes
Mul
Yes
Neg
Yes
Not
Yes
OneHot
Yes
Pad
Yes
Pow
Yes
PRelu
Yes
QuantizeLinear
Yes
RandomNormal
Yes
RandomNormalLike
Yes
RandomUniform
Yes
RandomUniformLike
Yes
ReduceL1
Yes
ReduceL2
Yes
ReduceLogSum
Yes
ReduceLogSumExp
Yes
ReduceMax
Yes
ReduceMean
Yes
ReduceMin
Yes
ReduceProd
Yes
ReduceSum
Yes
ReduceSumSquare
Yes
Relu
Yes
Reshape
Yes
Resize
Yes
ReverseSequence
Yes
RoiAlign
Yes
Round
Yes
Rsqrt
Yes
Selu
Yes
Shape
Yes
Sign
Yes
Sin
Yes
Sinh
Yes
Sigmoid
Yes
Size
Yes
Slice
Yes
Softmax
Yes
Softplus
Yes
Softsign
Yes
SpaceToDepth
Yes
Split
Yes
Sqrt
Yes
Squeeze
Yes
Sub
Yes
Sum
Yes
Tanh
Yes
Tile
Yes
TopK
Yes
Transpose
Yes
Trilu
Yes
ThresholdedRelu
Yes
Upsample
Yes
Unsqueeze
Yes
Where
Yes
APIs#
Currently, the model compilation APIs support deep learning models in TFLite/ONNX formats.
CompileOptions#
Description:
The CompileOptions class is used to configure nncase compilation options. The descriptions of each attribute are as follows:
Attribute Name
Type
Required
target
string
Yes
Specifies the compilation target, such as ‘cpu’ or ‘k230’
dump_ir
bool
No
Specifies whether to dump IR, defaults to False
dump_asm
bool
No
Specifies whether to dump asm assembly files, defaults to False
dump_dir
string
No
Specifies the directory to dump files when dump_ir or other dump options are enabled, defaults to “”
input_file
string
No
Specifies the parameter file path when the ONNX model exceeds 2GB, defaults to “”
preprocess
bool
No
Specifies whether to enable preprocessing, defaults to False. The following parameters are effective only when preprocess=True
input_type
string
No
Specifies the input data type when preprocessing is enabled, defaults to “float”. When preprocess is True, must be “uint8” or “float32”
input_shape
list[int]
No
Specifies the shape of the input data when preprocessing is enabled, defaults to []. When preprocess is True, must be specified
input_range
list[float]
No
Specifies the floating-point range of the input data after dequantization when preprocessing is enabled, defaults to []. When preprocess is True and input_type is uint8, must be specified
input_layout
string
No
Specifies the layout of the input data, defaults to “”
swapRB
bool
No
Specifies whether to reverse the data in the channel dimension, defaults to False
mean
list[float]
No
Mean value for preprocessing normalization, defaults to [0,0,0]
std
list[float]
No
Standard deviation for preprocessing normalization, defaults to [1,1,1]
letterbox_value
float
No
Specifies the fill value for letterbox preprocessing, defaults to 0
output_layout
string
No
Specifies the layout of the output data, defaults to “”
shape_bucket_enable
bool
Yes
Specifies whether to enable ShapeBucket functionality, defaults to False. Effective when dump_ir=True
shape_bucket_range_info
Dict[str, [int, int]]
Yes
Specifies the range of variables in each dimension of the input shape, minimum value must be greater than or equal to 1
shape_bucket_segments_count
int
Yes
Specifies the number of segments to divide the input variable’s range
shape_bucket_fix_var_map
Dict[str, int]
No
Specifies fixed values for variables in the shape dimension information
Preprocessing Workflow#
Currently, custom preprocessing order is not supported. You can configure the required preprocessing parameters based on the following workflow diagram.
graph TD; NewInput("NewInput
(shape = input_shape
Parameter explanations:
  1. input_range specifies the floating-point range after dequantization when the input data type is fixed-point.
    a. If the input data type is uint8 and the range is [0,255], setting input_range to [0,255] means dequantization only converts the data type from uint8 to float32. The mean and std parameters should still be specified based on data in the range [0,255].
    b. If the input data type is uint8 and the range is [0,255], setting input_range to [0,1] means dequantization will convert fixed-point data to floating-point data in the range [0,1]. The mean and std parameters should be specified based on data in the range [0,1].
    graph TD; NewInput_uint8("NewInput_uint8
    [input_type:uint8]") --input_range:0,1 -->dequantize_1["Dequantize"]--float range:0,1--> OldInput_float32
  2. input_shape specifies the shape of the input data, and input_layout specifies its layout. It currently supports both string (e.g., "NHWC", "NCHW") and index formats. Non-4D data processing is also supported. When configured as a string, input_layout specifies the layout of the input data. When configured as an index, input_layout specifies the permutation parameter for a Transpose operation.
graph TD; subgraph B NewInput1("NewInput: 1,4,10") --"input_layout:"0,2,1""-->Transpose2("Transpose perm: 0,2,1") --> OldInput2("OldInput: 1,10,4"); end subgraph A NewInput --"input_layout:"NHWC""--> Transpose0("Transpose: NHWC2NCHW") --> OldInput; NewInput("NewInput: 1,224,224,3 (NHWC)") --"input_layout:"0,3,1,2""--> Transpose1("Transpose perm: 0,3,1,2") --> OldInput("OldInput: 1,3,224,224 (NCHW)"); end
Similarly, output_layout can be configured as shown below.
graph TD; subgraph B OldOutput1("OldOutput: 1,10,4,5,2") --"output_layout: "0,2,3,1,4""--> Transpose5("Transpose perm: 0,2,3,1,4") --> NewOutput1("NewOutput: 1,4,5,10,2"); end subgraph A OldOutput --"output_layout: "NHWC""--> Transpose3("Transpose: NCHW2NHWC") --> NewOutput("NewOutput
NHWC"); end
Dynamic Shape Parameters#
ShapeBucket is a solution for dynamic shapes that optimizes based on the range of input lengths and the specified number of segments. This feature is disabled by default and needs to be enabled through the corresponding option. Apart from specifying the relevant field information, the rest of the compilation process is the same as compiling a static model.
  • ONNX
In the shape information of a model, some dimensions may be variable names. For example, consider an ONNX model with the following inputs:
tokens: int64[batch_size, tgt_seq_len] step: float32[seq_len, batch_size]
The shape information contains three variables: seq_len, tgt_seq_len, and batch_size. Although batch_size is a variable, it is fixed to 3 in actual use. Therefore, add batch_size = 3 to fix_var_map to fix this dimension to 3 during runtime. The variables seq_len and tgt_seq_len are dynamic and need to be configured with their actual ranges in range_info. segments_count specifies the number of segments to divide the range into, which will proportionally increase the compilation time.
Here is an example of the corresponding compilation parameters:
  • TFLite
Unlike ONNX models, TFLite models do not currently label dimension names in the shape. Currently, only one dimension in the input can be dynamic, and it is uniformly named as -1. The configuration is as follows:
After configuring these options, the entire compilation process is the same as for a static shape model.
Parameter Configuration Example#
Instantiate CompileOptions and configure the attribute values.
compile_options.target = "cpu"  # "k230"
# preprocess args
    compile_options.input_type = "uint8"  # "uint8" "float32"
    compile_options.input_layout = "NHWC"  # "NHWC" "NCHW"
    compile_options.std = [1,1,1]
    compile_options.output_layout = "NHWC"  # "NHWC" "NCHW"
# Dynamic shape args
ImportOptions#
Description:
The ImportOptions class is used to configure nncase import options.
Definition:
class ImportOptions:
    def __init__(self) -> None:
        pass
Instantiate ImportOptions and configure attribute values.
#import_options
PTQTensorOptions#
Description:
The PTQTensorOptions class is used to configure nncase PTQ options.
Name
Type
Required
samples_count
int
No
Specifies the number of samples used for the quantization calibration set
calibrate_method
string
No
Specifies the quantization method, options are ‘NoClip’ and ‘Kld’, default is ‘Kld’
finetune_weights_method
string
No
Specifies whether to fine-tune weights, options are ‘NoFineTuneWeights’ and ‘UseSquant’, default is ‘NoFineTuneWeights’
quant_type
string
No
Specifies the data quantization type, options are ‘uint8’, ‘int8’, ‘int16’
w_quant_type
string
No
Specifies the weight quantization type, options are ‘uint8’, ‘int8’, ‘int16’
No
The above two types cannot both be ‘int16’
quant_scheme
string
No
Path to the quantization parameter configuration file
quant_scheme_strict_mode
bool
No
Whether to strictly follow quant_scheme for quantization
export_quant_scheme
bool
No
Whether to export the quantization parameter configuration file
bool
No
Whether to export weights quantization parameters in bychannel form, it is recommended to set this parameter to True
For detailed usage of mixed quantization, see MixQuant Guide
# ptq_options
ptq_options.samples_count = 6
ptq_options.quant_scheme = ""
compiler.use_ptq(ptq_options)
set_tensor_data#
Description:
Sets tensor data.
Definition:
[Parameters]
Name
Type
List[List[np.ndarray]]
Calibration data
[Return Value]
# ptq_options
Compiler#
Description:
The Compiler class is used to compile neural network models.
Definition:
class Compiler:
    _target: _nncase.Target
    _compiler: _nncase.Compiler
    _module: IRModule
import_tflite#
Description:
Imports a TFLite model.
Definition:
[Parameters]
Name
Type
model_content
byte[]
The content of the model
import_options
ImportOptions
Import options
[Return Value]
import_onnx#
Description:
Imports an ONNX model.
Definition:
[Parameters]
Name
Type
model_content
byte[]
import_options
ImportOptions
Import options
[Return Value]
use_ptq#
Description:
Sets PTQ configuration options.
  • Quantization is mandatory for K230 by default.
Definition:
[Parameters]
Name
Type
ptq_options
PTQTensorOptions
[Return Value]
compile#
Description:
Compiles the neural network model.
Definition:
compile()
[Parameters]
[Return Value]
compiler.compile()
gencode_tobytes#
Description:
Generates kmodel byte stream.
Definition:
gencode_tobytes()
[Parameters]
[Return Value]
bytes[]
    f.write(kmodel)
Examples#
The following examples use models and Python compilation scripts.
  • The original model files are located in /path/to/k230_sdk/src/big/nncase/examples/models
  • The Python compilation scripts are located in /path/to/k230_sdk/src/big/nncase/examples/scripts
Compiling a TFLite Model#
The mbv2_tflite.py script is as follows:
import argparse
import numpy as np
from PIL import Image
import nncase
        model_content = f.read()
    return model_content
    data = []
    for i in range(batch):
    return data
def main():
    args = parser.parse_args()
    dump_dir = 'tmp/mbv2_tflite'
    # compile_options
    # compiler
    # import
    # ptq_options
    # compile
    compiler.compile()
    # kmodel
        f.write(kmodel)
if __name__ == '__main__':
    main()
Run the following command to compile the mobilenetv2 TFLite model with the target set to k230:
Compiling an ONNX Model#
For ONNX models, it is recommended to use the ONNX Simplifier to simplify the model before using nncase to compile it.
The yolov5s_onnx.py script is as follows:
import argparse
import numpy as np
import onnxsim
import onnx
import nncase
    input_tensors = [
    # input
    inputs = []
        input_dict = {}
        input_dict['name'] = e.name
        inputs.append(input_dict)
    return onnx_model, inputs
    input_shapes = {}
    for input in inputs:
    return model_file
    data = []
    return data
    data = []
    return data
def main():
    dump_dir = 'tmp/yolov5s_onnx'
        os.makedirs(dump_dir)
    # onnx simplify
    # compile_options
    # compiler
    # import
    # ptq_options
    # compile
    compiler.compile()
    # kmodel
        f.write(kmodel)
    main()
Run the following command to compile the ONNX model with the target set to k230:
root@c285a41a7243:/mnt/src/big/nncase/examples# python3 ./scripts/yolov5s_onnx.py --target k230 --model models/yolov5s.onnx --dataset calibration_dataset
Simulator APIs (Python)#
In addition to model compilation APIs, nncase also provides inference APIs that allow you to run compiled kmodel on a PC to verify if the nncase inference results are consistent with the runtime results of the corresponding deep learning framework.
APIs#
MemoryRange#
Description:
The MemoryRange class is used to represent a memory range.
Definition:
    .def_property(
[Attributes]
Name
Type
location
int
Memory location: 0 for input, 1 for output, 2 for rdata, 3 for data, 4 for shared_data
dtype
Python data type
Data type
start
int
Memory start address
size
int
Memory size
mr = nncase.MemoryRange()
RuntimeTensor#
Description:
The RuntimeTensor class is used to represent a runtime tensor.
Definition:
            datatype,
                          .unwrap_or_throw();
        arr.inc_ref();
        return tensor;
        return py::array(
            to_dtype(tensor.datatype()),
            tensor.shape(),
            src_buffer.data());
[Attributes]
Name
Type
dtype
Python data type
Data type of the tensor
shape
list
Shape of the tensor
from_numpy#
Description:
Constructs a RuntimeTensor object from a numpy.ndarray.
Definition:
from_numpy(py::array arr)
[Parameters]
Name
Type
arr
numpy.ndarray
numpy.ndarray object
[Return Value]
RuntimeTensor
copy_to#
Description:
Copies a RuntimeTensor.
Definition:
copy_to(RuntimeTensor to)
[Parameters]
Name
Type
to
RuntimeTensor
[Return Value]
to_numpy#
Description:
Converts a RuntimeTensor to a numpy.ndarray object.
Definition:
to_numpy()
[Parameters]
[Return Value]
Simulator#
Description:
The Simulator class is used to run kmodel inference on a PC.
Definition:
    .def(py::init())
[Attributes]
Name
Type
inputs_size
int
Number of inputs
outputs_size
int
Number of outputs
sim = nncase.Simulator()
load_model#
Description:
Loads a kmodel.
Definition:
load_model(model_content)
[Parameters]
Name
Type
model_content
byte[]
kmodel byte stream
[Return Value]
sim.load_model(kmodel)
get_input_desc#
Description:
Gets the description of the input at the specified index.
Definition:
get_input_desc(index)
[Parameters]
Name
Type
index
int
Index of the input
[Return Value]
MemoryRange
get_output_desc#
Description:
Gets the description of the output at the specified index.
Definition:
get_output_desc(index)
[Parameters]
Name
Type
index
int
Index of the output
[Return Value]
MemoryRange
get_input_tensor#
Description:
Gets the RuntimeTensor of the input at the specified index.
Definition:
get_input_tensor(index)
[Parameters]
Name
Type
index
int
Index of the input tensor
[Return Value]
RuntimeTensor
set_input_tensor#
Description:
Sets the RuntimeTensor of the input at the specified index.
Definition:
[Parameters]
Name
Type
index
int
tensor
RuntimeTensor
Input tensor
[Return Value]
get_output_tensor#
Description:
Gets the RuntimeTensor of the output at the specified index.
Definition:
get_output_tensor(index)
[Parameters]
Name
Type
index
int
Index of the output tensor
[Return Value]
RuntimeTensor
set_output_tensor#
Description:
Sets the RuntimeTensor of the output at the specified index.
Definition:
[Parameters]
Name
Type
index
int
tensor
RuntimeTensor
Output tensor
[Return Value]
run#
Description:
Runs kmodel inference.
Definition:
run()
[Parameters]
[Return Value]
sim.run()
Examples#
Precondition: The yolov5s_onnx.py script has already compiled the yolov5s.onnx model.
The yolov5s_onnx_simu.py script is located in the /path/to/k230_sdk/src/big/nncase/examples/scripts subdirectory and contains the following content:
import copy
import argparse
import numpy as np
import onnx
import onnxruntime as ort
import nncase
def cosine(gt, pred):
def main():
    # cpu inference
    output_names = []
    model_input_type = np.float32
    cpu_results = []
    # create simulator
    # read kmodel
    # load kmodel
    # read input.bin
    # set input for simulator
    # simulator inference
    nncase_results = []
    sim.run()
    # compare
    main()
Run the inference script:
Comparison of nncase simulator and CPU inference results:
KPU Runtime APIs (C++)#
Introduction#
KPU Runtime APIs are used to load kmodel on AI devices, set input data, execute KPU/CPU computation, and get output data, etc.
Currently, only C++ APIs are provided. The relevant header files and static libraries are located in the /path/to/k230_sdk/src/big/nncase/riscv64 directory.
$ tree -L 3 riscv64/
riscv64/
├── gsl
│   └── gsl-lite.hpp
├── nncase
│   ├── include
│   │   └── nncase
│   └── lib
│       ├── cmake
│       ├── libfunctional_k230.a
│       ├── libnncase.rt_modules.k230.a
│       └── libNncase.Runtime.Native.a
└── rvvlib
    ├── include
    │   ├── k230_math.h
    │   ├── nms.h
    │   └── rvv_math.h
    └── librvv.a
8 directories, 8 files
APIs#
hrt::create#
Description:
Creates a runtime_tensor.
Definition:
(3) NNCASE_API result<runtime_tensor> create(typecode_t datatype, dims_t shape, strides_t strides, gsl::span<gsl::byte> data, bool copy, memory_pool_t pool = pool_shared_first, uintptr_t physical_address = 0) noexcept;
[Parameters]
Name
Type
datatype
typecode_t
Data type, e.g., dt_float32, dt_uint8
shape
dims_t
Shape of the tensor
User data buffer
copy
bool
Whether to copy
pool
memory_pool_t
Memory pool type, default is pool_shared_first
physical_address
uintptr_t
Physical address specified by the user
[Return Value]
// create input tensor
hrt::sync#
Description:
Synchronizes the cache of the tensor.
  • For user input data, this interface’s sync_write_back should be called to ensure the data is flushed to DDR.
  • For GNNE/AI2D computation output data, the GNNE/AI2D runtime has already performed sync_invalidate by default.
Definition:
Parameters:
Name
Type
tensor
runtime_tensor
The tensor to operate on
op
sync_op_t
sync_invalidate (invalidate the tensor cache) or sync_write_back (write the tensor cache to DDR)
force
bool
Whether to force execution
Return Value:
result<void>
interpreter::load_model#
Description:
Loads a kmodel.
Definition:
Parameters:
Name
Type
buffer
gsl::span <const gsl::byte>
kmodel buffer
Return Value:
result<void>
interpreter interp;
interpreter::inputs_size#
Description:
Gets the number of model inputs.
Definition:
Parameters:
Return Value:
size_t
interpreter::outputs_size#
Description:
Gets the number of model outputs.
Definition:
Parameters:
Return Value:
size_t
interpreter::input_shape#
Description:
Gets the shape of the specified input.
Definition:
Parameters:
Name
Type
index
size_t
Index of the input
Return Value:
runtime_shape_t
interpreter::output_shape#
Description:
Gets the shape of the specified output.
Definition:
Parameters:
Name
Type
index
size_t
Index of the output
Return Value:
runtime_shape_t
interpreter::input_tensor#
Description:
Gets/Sets the input tensor at the specified index.
Definition:
Parameters:
Name
Type
index
size_t
Index of the input
tensor
runtime_tensor
The runtime tensor for input
Return Value:
(1) result<runtime_tensor>
(2) result<void>
// set input
interpreter::output_tensor#
Description:
Gets/Sets the output tensor at the specified index.
Definition:
Parameters:
Name
Type
index
size_t
Index of the output
tensor
runtime_tensor
The runtime tensor for output
Return Value:
(2) result<void>
// get output
interpreter::run#
Description:
Executes KPU computation.
Definition:
result<void> run() noexcept;
Parameters:
Return Value:
result<void>
// run
Example#
#include <chrono>
#include <fstream>
#include <iostream>
#define USE_OPENCV 1
#define preprocess 1
#if USE_OPENCV
#endif
using namespace nncase;
#define INPUT_HEIGHT 224
#define INPUT_WIDTH 224
#define INPUT_CHANNELS 3
template <class T>
    ifs.seekg(0, ifs.end);
    size_t len = ifs.tellg();
    ifs.seekg(0, ifs.beg);
    ifs.close();
    return vec;
    ifs.read(buffer, len);
    ifs.close();
    std::vector<std::string> vec;
    vec.reserve(1024);
    std::ifstream fp(file_name);
    std::string label;
    while (getline(fp, label))
        vec.push_back(label);
    return vec;
template<typename T>
    T denominator{ 0 };
        denominator += dst[i];
        dst[i] /= denominator;
#if USE_OPENCV
    std::vector<uint8_t> vec;
    cv::split(img, rgbChannels);
    return vec;
#endif
    // load kmodel
    interpreter interp;
    // Load kmodel from memory
    // Load kmodel from file stream
    // create output tensor
    // set input data
#if USE_OPENCV
    cv::resize(img, img, cv::Size(INPUT_WIDTH, INPUT_HEIGHT), cv::INTER_NEAREST);
#else
#endif
    // run
    size_t counter = 1;
    // get output data
    // postprocess softmax by cpu
    size_t idx = it - buf;
    // load label
    if (argc != 4)
        return -1;
    if (ret)
        return -2;
AI2D Runtime APIs (C++)#
Introduction#
AI2D Runtime APIs are used to configure AI2D parameters on AI devices, generate related register configurations, execute AI2D computations, etc. Please read the last section Precautions before use.
Supported Format Conversions#
Input Format
Output Format
Remarks
YUV420_NV12
RGB_planar/YUV420_NV12
YUV420_NV21
RGB_planar/YUV420_NV21
YUV420_I420
RGB_planar/YUV420_I420
YUV400
YUV400
NCHW(RGB_planar)
NCHW(RGB_planar)
RGB_packed
RGB_planar/RGB_packed
RAW16
RAW16/8
Depth map, performs shift operation
Function Descriptions#
Function
Remarks
Affine Transformation
Supports input formats YUV420, YUV400, RGB (planar/packed); supports depth map RAW16 format; supports output formats YUV400, RGB, depth map
Crop/Resize/Padding
Supports input YUV420, YUV400, RGB; supports depth map RAW16 format; Resize supports intermediate NCHW arrangement format; supports output formats YUV420, YUV400, RGB
Only supports constant padding
Shift
Supports input format Raw16; supports output format Raw8
Sign Bit
Supports signed and unsigned input
APIs#
ai2d_format#
Description:
ai2d_format is used to configure the optional data formats for input and output.
Definition:
enum class ai2d_format
    YUV420_NV12 = 0,
    YUV420_NV21 = 1,
    YUV420_I420 = 2,
    NCHW_FMT = 3,
    RGB_packed = 4,
    RAW16 = 5,
ai2d_interp_method#
Description:
ai2d_interp_method is used to configure the optional interpolation methods.
Definition:
enum class ai2d_interp_method
    tf_nearest = 0,
    tf_bilinear = 1,
    cv2_nearest = 2,
    cv2_bilinear = 3,
ai2d_interp_mode#
Description:
ai2d_interp_mode is used to configure the optional interpolation modes.
Definition:
enum class ai2d_interp_mode
    none = 0,
    align_corner = 1,
    half_pixel = 2,
ai2d_pad_mode#
Description:
ai2d_pad_mode is used to configure the optional padding modes. Currently, only constant padding is supported.
Definition:
enum class ai2d_pad_mode
    constant = 0,
    copy = 1,
    mirror = 2,
ai2d_datatype_t#
Description:
ai2d_datatype_t is used to set the data types during the AI2D computation process.
Definition:
struct ai2d_datatype_t
    ai2d_format src_format;
    ai2d_format dst_format;
    datatype_t src_type;
    datatype_t dst_type;
Parameters:
Name
Type
src_format
ai2d_format
Input data format
dst_format
ai2d_format
Output data format
src_type
datatype_t
Input data type
dst_type
datatype_t
Output data type
src_loc
ai2d_data_loc
Input data location, default is DDR
dst_loc
ai2d_data_loc
Output data location, default is DDR
ai2d_crop_param_t#
Description:
ai2d_crop_param_t is used to configure parameters related to cropping.
Definition:
struct ai2d_crop_param_t
    bool crop_flag = false;
    int32_t start_x = 0;
    int32_t start_y = 0;
    int32_t width = 0;
    int32_t height = 0;
Parameters:
Name
Type
crop_flag
bool
Whether to enable cropping
start_x
int
Starting pixel in the width direction
start_y
int
Starting pixel in the height direction
int
Crop length in the width direction
int
Crop length in the height direction
ai2d_shift_param_t#
Description:
ai2d_shift_param_t is used to configure parameters related to shifting.
Definition:
struct ai2d_shift_param_t
    bool shift_flag = false;
    int32_t shift_val = 0;
Parameters:
Name
Type
shift_flag
bool
Whether to enable shifting
shift_val
int
Number of bits to shift right
ai2d_pad_param_t#
Description:
ai2d_pad_param_t is used to configure parameters related to padding.
Definition:
struct ai2d_pad_param_t
    bool pad_flag = false;
    runtime_paddings_t paddings;
Parameters:
Name
Type
pad_flag
bool
Whether to enable padding
paddings
runtime_paddings_t
Padding for each dimension, shape=[4, 2], representing the padding count for the front and back of dim0 to dim4, with dim0/dim1 fixed at {0, 0}
pad_mode
ai2d_pad_mode
Padding mode, only constant padding is supported
pad_val
std::vector<int32_t>
Padding value for each channel
ai2d_resize_param_t#
Description:
ai2d_resize_param_t is used to configure parameters related to resizing.
Definition:
struct ai2d_resize_param_t
    bool resize_flag = false;
Parameters:
Name
Type
resize_flag
bool
Whether to enable resizing
interp_method
ai2d_interp_method
Interpolation method for resizing
interp_mode
ai2d_interp_mode
Resize mode
ai2d_affine_param_t#
Description:
ai2d_affine_param_t is used to configure parameters related to affine transformations.
Definition:
struct ai2d_affine_param_t
    bool affine_flag = false;
    uint32_t cord_round = 0;
    uint32_t bound_ind = 0;
    int32_t bound_val = 0;
    uint32_t bound_smooth = 0;
    std::vector<float> M;
Parameters:
Name
Type
affine_flag
bool
Whether to enable affine transformations
interp_method
ai2d_interp_method
Interpolation method used for affine transformations
cord_round
uint32_t
Integer boundary, 0 or 1
bound_ind
uint32_t
Boundary pixel mode, 0 or 1
bound_val
uint32_t
Boundary fill value
bound_smooth
uint32_t
Boundary smoothing, 0 or 1
M
std::vector<float>
Vector corresponding to the affine transformation matrix. For affine transformation \(Y=\[a_0, a_1; a_2, a_3\] \cdot X + \[b_0, b_1\]\), \(M=\{a_0,a_1,b_0,a_2,a_3,b_1\}\)
ai2d_builder::ai2d_builder#
Description:
Constructor for ai2d_builder.
Definition:
Parameters:
Name
Type
input_shape
dims_t
Input shape
output_shape
dims_t
Output shape
ai2d_dtype
ai2d_datatype_t
AI2D data type
crop_param
ai2d_crop_param_t
Crop parameters
shift_param
ai2d_shift_param_t
Shift parameters
pad_param
ai2d_pad_param_t
Pad parameters
resize_param
ai2d_resize_param_t
Resize parameters
affine_param
ai2d_affine_param_t
Affine parameters
Return Value:
ai2d_builder::build_schedule#
Description:
Generates the parameters required for AI2D computation.
Definition:
Parameters:
Return Value:
result<void>
ai2d_builder::invoke#
Description:
Configures the registers and starts the AI2D computation.
Definition:
Parameters:
Name
Type
input
runtime_tensor
Input tensor
output
runtime_tensor
Output tensor
Return Value:
result<void>
// run ai2d
Example#
    // input tensor
    // output tensor
    // config ai2d
    // run
    // compare
    if (!ret)
    else
Notes#
  1. Affine and Resize functions are mutually exclusive and cannot be enabled simultaneously.
  2. The input format for the Shift function can only be Raw16.
  3. The pad value is configured per channel, and the number of elements in the list should be equal to the number of channels.
  4. In the current version, when only one AI2D function is needed, other parameters also need to be configured, with the flag set to false, and other fields do not need to be configured.
  5. When configuring multiple functions, the execution order is Crop->Shift->Resize/Affine->Pad. Ensure the parameters match accordingly.
