K230 Audio API reference
Contents
K230 Audio API reference#
Directory#
preface#
The AUDIO module includes four sub-modules of audio input, audio output, audio encoding, audio decoding, and control of the built-in audio codec.
Reader object#
  • Technical Support Engineer
Definition of acronyms#
abbreviation
illustrate
ai
Audio input module
ao
Audio output module
aenc
Audio coding module
adec
Audio decoding module
Revision history#
Document version number
Modify the description
Author
date
Initial edition
Sun Xiaopeng
2023/3/7
V1.1
1) Add support for I2S built-in codec 2) Add PDM single/dual channel support 3) Add AI and AO different sampling accuracy support (16/24/32) 4) The API interface remains unchanged, and parameter properties are added, and the documentation is improved.
Sun Xiaopeng
2023/3/27
V1.1.1
Add audio codec API interface Add sound quality enhancement APIinterface kd_mpi_ai_set_vqe_attr/kd_mpi_ai_get_vqe_attr, and description.
Sun Xiaopeng/Cui Yan
2023/4/12
V1.2
Modify the sound quality enhancement APIkd_mpi_ai_set_vqe_attrkd_mpi_ai_set_vqe_attr/kd_mpi_ai_get_vqe_attr Add audio codec mapi interface function
2023/4/27
V1.3
1) Add built-in Audio Codec API interface
Sun Xiaopeng
2023/5/10
v1.4
1)Support single and dual channel input and output, modifyk_audio_i2s_attrattributes, and add snd_Mode attribute. 2)Add built-in Audio Codec API interface: including volume acquisition and reset related interfaces:k_acodec_get_gain_micl/k_acodec_get_gain_micr/k_acodec_get_adcl_volume/k_acodec_get_adcr_volume/k_acodec_get_alc_gain_micl/k_acodec_get_alc_gain_micr/k_acodec_get_gain_hpoutl/k_acodec_get_gain_hpoutr/k_acodec_get_dacl_volumek_acodec_get_alc_gain_micrk_acodec_get_gain_hpoutlk_acodec_get_gain_hpoutr/k_acodec_get_dacr_volume/k_acodec_reset
Sun Xiaopeng
2023/6/15
The audio module includes four sub-modules of audio input AI, audio output AO, audio coding AENC, audio decoding ADCE, and support for built-in analog audio codec. The audio input module includes i2s and pdm two audio interfaces, with PDMA for memory copying, support digital microphone (PDM/I2S) and analog audio codec (i2S) sound source input, built-in analog audio codec, support sound quality enhancement (VQE) processing of audio data: 3A (AEC echo cancellation, ANR noise reduction, AGC automatic gain). The audio output module supports I2S audio interface, with PDMA to do memory copy, and can be connected to an external data speaker or analog audio codec as sound output. The audio encoding and decoding module temporarily supports audio codec functions for the G711 format and supports the registration of external codecs.
The audio module is divided into multiple sub-modules, and the data flow is transmitted to each other in a low-coupling manner, which is sufficient to meet the existing multimedia services under MAIX3. The following figure only analyzes the use of the audio module in the voice intercom service scenario. The collected audio data is encoded by the audio input module and sent to the remote end through the network, and the audio coding data obtained from the remote end is decoded by the audio decoding module and the remote sound can be played through the audio output module.
Function Description#
Audio input#
The audio input module (AI) mainly implements functions such as configuring and enabling audio input devices and obtaining audio frame data.
The audio input module supports I2s and PDM protocol interfaces. i2S supports simultaneous capture of up to 2 channels of two-channel audio, and PDM supports simultaneous capture of up to 8 channels of mono audio. The detailed I2S and PDM characteristics are as follows:
  • I2S audio interface
    1. The data sampling rate supports 8kHz/12kHz/16kHz/24kHz/32kHz/44.1kHz/48kHz/96kHz/192kHz, and the sampling accuracy supports 16/24/32bit.
    2. Support 2 sets of configurable IOs for input/output I2S audio data, support full-duplex mode.
  • PDM audio interface
    1. Support PDM audio input, 1bit wide, sample clock frequency of 0.256MHz/0.384MHz/0.512MHz/0.768MHz/1.024MHz/1.4112MHz/1.536MHz/2.048MHz/2.8224MHz/3.072MHz/4.096MHz/5.6448MHz/6.144MHz/12.288MHz/ 24.576MHz, the input PCM audio sampling rate is 8kHz/12kHz/16kHz/24kHz/32kHz/44.1kHz/48kHz/96kHz/192kHz. The sampling accuracy supports 16/24/32bit.
    2. Support oversampling rate 128, 64, 32 times oversampling.
    3. Supports 1-4 IOs for input PDM audio data.
    4. The input supports 1-8 PDM channels, supports PDM left and right mono mode and two-channel mode, each IO channel mode is unified, and PDM two-channel mode uses up to 4 IOs
    5. The sequence number of the enabled channels is small to large and continuous, and each channel is not supported to be enabled randomly
Audio output#
Audio output (AO) mainly implements the functions of enabling audio output devices and sending audio frames to output channels.
The audio output module supports an I2s protocol interface. i2S supports simultaneous output of up to 2 channels of two-channel audio.
    1. The data sampling rate supports 8kHz/12kHz/16kHz/24kHz/32kHz/44.1kHz/48kHz/96kHz/192kHz, and the sampling accuracy is 16/24/32bit.
Sound Quality Enhancement#
The audio module supports sound quality enhancement processing of audio data to realize audio 3A function. Currently, the supported sampling accuracy is 16bit, and the supported sampling rate is 16K.
API Reference#
Audio input#
kd_mpi_ai_set_pub_attr#
【Description】
Set AI device properties.
【Syntax】
【Parameters】
Parameter name
description
Input/output
ai_dev
Audio device number.
input
attr
AI device property pointer.
input
【Return value】
Return value
description
succeed
Non-0
Failed, see Error Code for value
【Requirement】
  • Header file: mpi_ai_api.h
  • Library file: libai.a
【Note】
none
【Example】
k_aio_dev_attr aio_dev_attr;
return K_FAILED;
return K_FAILED;
return K_FAILED;
kd_mpi_ai_get_pub_attr#
【Description】
Get AI device properties.
【Syntax】
【Parameters】
Parameter name
description
Input/output
ai_dev
input
attr
output
【Return value】
Return value
description
succeed
Non-0
【Requirement】
kd_mpi_ai_enable#
【Description】
Enable AI devices.
【Syntax】
【Parameters】
Parameter name
description
Input/output
ai_dev
input
【Return value】
Return value
description
succeed
Non-0
【Requirement】
kd_mpi_ai_disable#
【Description】
Disable the AI device.
【Syntax】
【Parameters】
Parameter name
description
Input/output
ai_dev
input
【Return value】
Return value
description
succeed
Non-0
【Requirement】
kd_mpi_ai_enable_chn#
【Description】
Enable the AI channel.
【Syntax】
k_s32 kd_mpi_ai_enable_chn(k_audio_dev ai_dev.k_ai_chnk_ai_chn ai_chn);
【Parameters】
Parameter name
description
Input/output
ai_dev
input
ai_chn
Audio channel number.
input
【Return value】
Return value
description
succeed
Non-0
【Requirement】
kd_mpi_ai_disable_chn#
【Description】
Disable the AI channel.
【Syntax】
k_s32 kd_mpi_ai_disable_chn(k_audio_dev ai_dev.k_ai_chnk_ai_chn ai_chn);
【Parameters】
Parameter name
description
Input/output
ai_dev
input
ai_chn
input
【Return value】
Return value
description
succeed
Non-0
【Requirement】
kd_mpi_ai_get_frame#
【Description】
Gets the audio frame.
【Syntax】
k_s32 kd_mpi_ai_get_frame(k_audio_dev ai_dev.k_ai_chnk_ai_chn ai_chn.k_audio_framek_audio_frame*frame, k_u32 milli_sec);
【Parameters】
Parameter name
description
Input/output
ai_dev
input
ai_chn
input
frame
Audio frame data.
output
milli_sec
The timeout period for getting data. -1 indicates blocking mode, waiting until there is no data; 0 indicates non-blocking mode, and returns an error when there is no data; >0 indicates blocking milli_sec milliseconds, and an error is returned if the timeout is returned.
input
【Return value】
Return value
description
succeed
Non-0
【Requirement】
【Note】
  • The value of the milli_sec must be greater than or equal to -1, the blocking mode is used to obtain data when it is equal to -1, and the data is obtained in blocking mode when it is equal to 0
When the blocking mode obtains data, if it is greater than 0, after blocking for milli_sec milliseconds, no data returns a timeout and an error is reported.
  • Before obtaining audio frame data, the corresponding AI channel must be enabled.
【Example】
k_audio_frame audio_frame;
while(true)
//get frame
continue ;
//process frame
process_frame(&audio_frame);
//release frame
kd_mpi_ai_release_frame#
【Description】
Release audio frames.
【Syntax】
k_s32 kd_mpi_ai_release_frame(k_audio_dev ai_dev,k_ai_chnk_ai_chn ai_chn,const k_audio_frame *frame);【参数】
Parameter name
description
Input/output
ai_dev
input
ai_chn
input
frame
Audio frame data.
input
【Return value】
Return value
description
succeed
Non-0
【Requirement】
kd_mpi_ai_set_vqe_attr#
【Description】
Set properties related to the AI’s sound quality enhancements.
【Syntax】
k_s32 kd_mpi_ai_set_vqe_attr(k_audio_dev ai_devk_ai_chn k_ai_chn ai_chn, const k_bool *vqe_enable);
【Parameters】
Parameter name
description
Input/output
ai_dev
input
ai_chn
input
vqe_enable
Sound quality enhancement enable flag bit. K_TRUE: Enable. K_FALSE: Not enabled.
input
【Return value】
Return value
description
succeed
Non-0
【Requirement】
【Note】
Currently, the supported sampling accuracy is 16bit, and the supported sampling rates are 8K and 16K.
kd_mpi_ai_get_vqe_attr#
【Description】
Get AI’s sound quality enhancement related attributes.
【Syntax】
k_s32 kd_mpi_ai_get_vqe_attr(k_audio_dev ai_dev, k_ai_chn ai_chn, k_bool *vqe_enable);
【Parameters】
Parameter name
description
Input/output
ai_dev
input
ai_chn
input
vqe_enable
Sound quality enhancement enable flag bit pointer. K_TRUE: Enable. K_FALSE: Not enabled.
output
【Return value】
Return value
description
succeed
Non-0
【Requirement】
Audio output#
kd_mpi_ao_set_pub_attr#
【Description】
Set the AO device properties.
【Syntax】
【Parameters】
Parameter name
description
Input/output
ao_dev
input
attr
AO device property pointer.
input
【Return value】
Return value
description
succeed
Non-0
【Requirement】
  • Header file: mpi_ao_api.h
  • Library file: libao.a
【Note】
none
【Example】
k_aio_dev_attr ao_dev_attr;
return K_FAILED;
return K_FAILED;
return K_FAILED;
kd_mpi_ao_get_pub_attr#
【Description】
Gets the AO device properties.
【Syntax】
【Parameters】
Parameter name
description
Input/output
ao_dev
input
attr
output
【Return value】
Return value
description
succeed
Non-0
【Requirement】
kd_mpi_ao_enable#
【Description】
Enable the AO device.
【Syntax】
【Parameters】
Parameter name
description
Input/output
ao_dev
input
【Return value】
Return value
description
succeed
Non-0
【Requirement】
kd_mpi_ao_disable#
【Description】
Disable the AO device.
【Syntax】
【Parameters】
Parameter name
description
Input/output
ao_dev
input
【Return value】
Return value
description
succeed
Non-0
【Requirement】
kd_mpi_ao_enable_chn#
【Description】
Enable the AO channel.
【Syntax】
k_s32 kd_mpi_ao_enable_chn(k_audio_dev ao_dev.k_ao_chnk_ao_chn ao_chn);
【Parameters】
Parameter name
description
Input/output
ao_dev
input
ao_chn
input
【Return value】
Return value
description
succeed
Non-0
【Requirement】
kd_mpi_ao_disable_chn#
【Description】
Disable the AO channel.
【Syntax】
k_s32 kd_mpi_ao_disable_chn(k_audio_dev ao_dev.k_ao_chnk_ao_chn ao_chn);
【Parameters】
Parameter name
description
Input/output
ao_dev
input
ao_chn
input
【Return value】
Return value
description
succeed
Non-0
【Requirement】
kd_mpi_ao_send_frame#
【Description】
Send AO frame data.
【Syntax】
k_s32 kd_mpi_ao_send_frame
(k_audio_dev ao_dev,k_ao_chnk_ao_chn ao_chn,const k_audio_frame*frame,k_s32 milli_sec);
【Parameters】
Parameter name
description
Input/output
ao_dev
input
ao_chn
input
frame
Audio frame data pointer.
input
milli_sec
The timeout period for sending data. -1 indicates blocking mode, waiting until there is no data; 0 indicates non-blocking mode, and returns an error when there is no data; >0 indicates blocking milli_sec milliseconds, and an error is returned if the timeout is returned.
input
【Return value】
Return value
description
succeed
Non-0
【Requirement】
【Note】
  • Before sending audio frame data, the corresponding AO channel must be enabled.
【Example】
k_s32 ret = 0;
while (true)
//get ai frame
if (K_SUCCESS != ret)
continue ;
//send ai frame to ao
//release ai frame
Audio Coding#
Audio coding mainly implements the functions of creating encoding channels, sending audio frame encoding, and obtaining encoding code streams. For the audio coding part, G711A/U encoding is provided, and only supports 16-bit sampling accuracy.
kd_mpi_aenc_register_encoder#
  • 【Description】
Register the encoder.
  • 【Syntax】
  • 【Parameters】
Parameter name
Input/output
handle
Register the handle.
output
encoder
Encoder property structure.
input
  • 【Description】
The user registers an encoder with the AENC module by passing in the encoder attribute struct and returns a registration sentence
handle, the user can finally register the encoder by registering the handle.
The AENC module can register up to 20 encoders and has itself registered G711.a, G711.u
Two encoders.
The same encoding protocol does not allow duplicate encoder registrations, for example, if the G711 encoder is already registered, another encoder is not allowed
Register another G711 encoder
  • 【Return value】
Return value
description
succeed
Non-0
【Requirement】
  • Header file: mpi_aenc_api.h
  • Library file: libaenc.a
  • 【Description】
Unregister the encoder.
  • 【Syntax】
  • 【Parameters】
Parameter name
Input/output
handle
Logoff handle.
input
  • 【Return value】
Return value
description
succeed
Non-0
【Requirement】
kd_mpi_aenc_create_chn#
  • 【Description】
Create an audio encoding channel.
  • 【Syntax】
Parameter name
Input/output
aenc_chn
Tōdō-go. value range: [0, AENC_MAX_CHN_NUM)。
input
attr
Audio encoding channel property pointer.
input
  • 【Description】
The buffer size is measured in frames, the value range is 2,[K_MAX_AUDIO_FRAME_NUM]the recommended configuration is 10 or above, too small buffer configuration may cause abnormalities such as frame drops. Each encoding channel configures the queue size based on the buffer size to cache the encoded frame data.
  • 【Return value】
Return value
description
succeed
Non-0
【Requirement】
kd_mpi_aenc_destroy_chn#
  • 【Description】
Destroy the audio encoding channel.
  • 【Syntax】
Parameter name
Input/output
aenc_chn
Tōdō-go. Value range: [0, AENC_MAX_CHN_NUM)。
input
  • 【Description】
none
  • 【Return value】
Return value
description
succeed
Non-0
【Requirement】
kd_mpi_aenc_send_frame#
  • 【Description】
Send audio encoded frames.
  • 【Syntax】
  • 【Parameters】
Parameter name
Input/output
aenc_chn
Channel number. Value range: [0, AENC_MAX_CHN_NUM]. input
input
frame
Audio frame structure pointer.
input
  • 【Description】
The audio encoding sending stream is a non-blocking interface, and if the audio stream cache is full, it will directly return the failure. This interface is used for users to actively send audio frames for encoding, and if the AENC channel is already bound to AI through the system binding interface, this interface is not required or recommended. When you call this operation to send audio encoded audio frames, you must first create a corresponding encoding channel.
  • 【Return value】
Return value
description
succeed
Non-0
【Requirement】
kd_mpi_aenc_get_stream#
  • 【Description】
Gets the audio encoding stream.
  • 【Syntax】
  • 【Parameters】
Parameter name
Input/output
aenc_chn
input
stream
The obtained audio stream.
output
milli_sec
The timeout period for obtaining data -1 indicates blocking mode, waiting until there is no data; 0 indicates non-blocking mode, and an error is returned when there is no data; >0 indicates blocking s32MilliSec milliseconds, and an error is returned if the timeout is returned.
input
  • 【Description】
The channel must be created before it is possible to obtain the bitstream, otherwise it will fail directly if it is pinned in the process of obtaining the bitstream
Destroying the channel will immediately return failure.
The value of s32MilliSec must be greater than or equal to -1, and data must be obtained in blocking mode when equal to -1, and 0 when it is equal
Data is obtained in non-blocking mode, and when greater than 0, no data is returned after blocking s32MilliSec milliseconds
and report an error.
  • 【Return value】
Return value
description
succeed
Non-0
【Requirement】
kd_mpi_aenc_release_stream#
  • 【Description】
Release the audio encoding stream.
  • 【Syntax】
  • 【Parameters】
Parameter name
Input/output
aenc_chn
input
stream
output
  • 【Description】
none
  • 【Return value】
Return value
description
succeed
Non-0
【Requirement】
Audio Decoding#
Audio decoding mainly realizes the functions of decoding channels, sending audio code stream decoding, and obtaining decoded audio frames.
The audio codec part provides G711A/U decoding, which temporarily supports 16-bit sampling accuracy.
kd_mpi_adec_register_decoder#
  • 【Description】
Register the decoder.
  • 【Syntax】
  • 【Parameters】
Parameter name
Input/output
handle
output
decoder
The decoder property structure.
input
  • 【Description】
The user registers a decoder with the ADEC module by passing in the decoder attribute structure and returns a registration handle, which the user can finally unregister by registering the handle. The ADEC module can register up to 20 decoders, and it has registered two decoders, G711a and G711u. The same decoding protocol does not allow duplicate registration of decoders, for example, if a G711 decoder is already registered, another G711 decoder is not allowed.
  • 【Return value】
Return value
description
succeed
Non-0
【Requirement】
Header file: mpi_adec_api.h
Library file: libadec.a
  • 【Description】
Log out of the decoder.
  • 【Syntax】
  • 【Parameters】
Parameter name
Input/output
handle
Logoff handle.
input
  • 【Return value】
Return value
description
succeed
Non-0
  • 【Requirement】
  • Header file: mpi_adec_api.h
  • Library file: libadec.a
kd_mpi_adec_create_chn#
  • 【Description】
Create an audio decoding channel.
  • 【Syntax】
  • 【Parameters】
Parameter name
Input/output
adec_chn
Tōdō-go. value range:[0, ADEC_MAX_CHN_NUM).
input
attr
Channel property pointer.
input
  • 【Description】
The protocol type specifies the decoding protocol for that channel and currently supports G711. Some properties of audio decoding need to match the output device properties, such as sample rate, frame length (number of samples per frame), and so on. The buffer size is measured in frames, the value range is 2, K_MAX_AUDIO_FRAME_NUMit is recommended to configure it to be above 10, too small buffer configuration may cause exceptions such as frame drops. This interface can only be used before (or after the channel has been created) and returned if the channel has already been created.
  • 【Return value】
Return value
description
succeed
Non-0
【Requirement】
kd_mpi_adec_destroy_chn#
  • 【Description】
Destroy the audio decoding channel.
  • 【Syntax】
  • 【Parameters】
Parameter name
Input/output
adec_chn
Tōdō-go. value range: [0, ADEC_MAX_CHN_NUM)。
input
  • 【Description】
none
  • 【Return value】
Return value
description
succeed
Non-0
  • 【Requirement】
kd_mpi_adec_send_stream#
  • 【Description】
Send an audio stream to the audio decoding channel.
  • 【Syntax】
  • 【Parameters】
Parameter name
Input/output
adec_chn
input
stream
Audio bitstream.
input
block
Blocking identification. HI_TRUE: Blocking. HI_FALSE: Non-blocking.
input
  • 【Description】
When sending data, you must ensure that the channel has been created, otherwise the direct return fails, and if the channel is destroyed during the data delivery process, the failure will be returned immediately. Supports blocking or non-blocking stream sending. When sending a stream in blocking mode, if the buffer used to cache the decoded audio frame is full, this interface call will be blocked until the decoded audio frame data is removed or the ADEC channel is destroyed.
  • 【Return value】
Return value
description
succeed
Non-0
  • 【Requirement】
kd_mpi_adec_clr_chn_buf#
  • 【Description】
Clears the current audio data cache in the ADEC channel.
  • 【Syntax】
  • 【Parameters】
Parameter name
Input/output
adec_chn
input
  • 【Description】
It is required that the decoding channel has already been created, and if the channel has not been created, the error code of the channel is returned.
  • 【Return value】
Return value
description
succeed
Non-0
  • 【Requirement】
kd_mpi_adec_get_frame#
  • 【Description】
Gets the audio decoded frame data.
  • 【Syntax】
  • 【Parameters】
Parameter name
Input/output
adec_chn
Audio decoding channel.
input
frame_info
Audio frame data structure output
output
block
Whether to get in blocking mode
input
  • 【Return value】
Return value
description
succeed
Non-0
  • 【Requirement】
kd_mpi_adec_release_frame#
  • 【Description】
Release the obtained audio decoded frame data.
  • 【Syntax】
  • 【Parameters】
Parameter name
Input/output
adec_chn
input
frame_info
input
  • 【Return value】
Return value
description
succeed
Non-0
  • 【Requirement】
built-in Audio Codec#
The built-in Audio Codec mainly provides operation of hardware devices through ioctl. Among the CMDs of the IOCTL offered, there are some
cmd users do not need to call it, and can directly use the default value when the module is loaded. The ioctl call implements the reading and writing of the built-in Audio Codec registers.
The control operation of the current version of the audio codec mainly includes: ADC digital and analog volume, DAC digital/analog volume, ADC/DAC mute control. Among them, the sampling rate, sampling accuracy, and I2S alignment mode are automatically completed by the user by calling the API interface kernel of AI and AO (the kernel code automatically implements the operation on the codec hardware device), and no longer provides an IOCTL interface to control.
Built-in Audio Codec standard function cmd:
k_acodec_set_gain_micl#
  • 【Description】
Left channel input analog gain control
  • 【Syntax】
  • 【Parameters】
Parameter name
Input/output
fd
Audio Codec device file descriptor
input
IOCTL number
input
Arg
Unsigned integer pointer
input
  • 【Return value】
Return value
description
succeed
Non-0
  • 【Requirement】
Header file: k_acodec_comm.h
Library file: libacodec.a
  • 【Note】
The analog gain ranges are 0db, 6db, 20db, 30db.
k_acodec_set_gain_micr#
  • 【Description】
Right channel input analog gain control
  • 【Syntax】
  • 【Parameters】
Parameter name
Input/output
fd
input
IOCTL number
input
Arg
input
  • 【Return value】
Return value
description
succeed
Non-0
  • 【Requirement】
  • 【Note】
k_acodec_set_adcl_volume#
  • 【Description】
Left channel input digital gain control.
  • 【Syntax】
  • 【Parameters】
Parameter name
Input/output
fd
input
IOCTL number
input
Arg
Signed floating-point pointer
input
  • 【Return value】
Return value
description
succeed
Non-0
  • 【Requirement】
  • 【Note】
Analog gain range, the [-97,30]larger the assignment, the louder the volume, in 0.5dB increments.
k_acodec_set_adcr_volume#
  • 【Description】
Right channel input digital gain control.
  • 【Syntax】
  • 【Parameters】
Parameter name
Input/output
fd
input
IOCTL number
input
Arg
input
  • 【Return value】
Return value
description
succeed
Non-0
  • 【Requirement】
  • 【Note】
k_acodec_set_alc_gain_micl#
  • 【Description】
Left channel ALC input analog gain control.
  • 【Syntax】
  • 【Parameters】
Parameter name
Input/output
fd
input
IOCTL number
input
Arg
input
  • 【Return value】
Return value
description
succeed
Non-0
  • 【Requirement】
  • 【Note】
Analog gain range, the larger the assignment, the [-18,28.5]louder the volume, in 1.5dB increments.
k_acodec_set_alc_gain_micr#
  • 【Description】
Right-channel ALC input analog gain control.
  • 【Syntax】
  • 【Parameters】
Parameter name
Input/output
fd
input
IOCTL number
input
Arg
input
  • 【Return value】
Return value
description
succeed
Non-0
  • 【Requirement】
  • 【Note】
k_acodec_set_gain_hpoutl#
  • 【Description】
Left channel output analog gain control.
  • 【Syntax】
  • 【Parameters】
Parameter name
Input/output
fd
input
IOCTL number
input
Arg
input
  • 【Return value】
Return value
description
succeed
Non-0
  • 【Requirement】
  • 【Note】
Analog gain range, the larger the assignment, the [-39,6]louder the volume, in 1.5dB increments.
k_acodec_set_gain_hpoutr#
  • 【Description】
The right channel outputs analog gain control.
  • 【Syntax】
  • 【Parameters】
Parameter name
Input/output
fd
input
IOCTL number
input
Arg
input
  • 【Return value】
Return value
description
succeed
Non-0
  • 【Requirement】
  • 【Note】
k_acodec_set_dacl_volume#
  • 【Description】
Left channel output digital gain control.
  • 【Syntax】
  • 【Parameters】
Parameter name
Input/output
fd
input
IOCTL number
input
Arg
input
  • 【Return value】
Return value
description
succeed
Non-0
  • 【Requirement】
  • 【Note】
Analog gain range, the [-120,7]larger the assignment, the louder the volume, in 0.5dB increments.
k_acodec_set_dacr_volume#
  • 【Description】
The right channel outputs digital gain control.
  • 【Syntax】
  • 【Parameters】
Parameter name
Input/output
fd
input
IOCTL number
input
Arg
input
  • 【Return value】
Return value
description
succeed
Non-0
  • 【Requirement】
  • 【Note】
k_acodec_set_micl_mute#
  • 【Description】
Left channel input mute control.
  • 【Syntax】
  • 【Parameters】
Parameter name
Input/output
fd
input
IOCTL number
input
Arg
Bool-type pointers
input
  • 【Return value】
Return value
description
succeed
Non-0
  • 【Requirement】
  • 【Note】
Value range: K_TRUE mute, K_FALSE unmute.
k_acodec_set_micr_mute#
  • 【Description】
Right channel input mute control.
  • 【Syntax】
  • 【Parameters】
Parameter name
Input/output
fd
input
IOCTL number
input
Arg
Bool-type pointers
input
  • 【Return value】
Return value
description
succeed
Non-0
  • 【Requirement】
  • 【Note】
k_acodec_set_dacl_mute#
  • 【Description】
Left channel output mute control.
  • 【Syntax】
  • 【Parameters】
Parameter name
Input/output
fd
input
IOCTL number
input
Arg
Bool-type pointers
input
  • 【Return value】
Return value
description
succeed
Non-0
  • 【Requirement】
  • 【Note】
k_acodec_set_dacr_mute#
  • 【Description】
Right channel output mute control.
  • 【Syntax】
  • 【Parameters】
Parameter name
Input/output
fd
input
IOCTL number
input
Arg
Bool-type pointers
input
  • 【Return value】
Return value
description
succeed
Non-0
  • 【Requirement】
  • 【Note】
k_acodec_get_gain_micl#
  • 【Description】
Gets the analog gain value for the left channel input.
  • 【Syntax】
  • 【Parameters】
Parameter name
Input/output
fd
input
IOCTL number
input
Arg
output
  • 【Return value】
Return value
description
succeed
Non-0
  • 【Requirement】
  • 【Note】
The obtained analog gain ranges are 0dB, 6dB, 20dB, 30dB.
k_acodec_get_gain_micr#
  • 【Description】
Gets the right channel input analog gain value.
  • 【Syntax】
  • 【Parameters】
Parameter name
Input/output
fd
input
IOCTL number
input
Arg
output
  • 【Return value】
Return value
description
succeed
Non-0
  • 【Requirement】
  • 【Note】
k_acodec_get_adcl_volume#
  • 【Description】
Gets the left channel input digital volume value
  • 【Syntax】
  • 【Parameters】
Parameter name
Input/output
fd
input
IOCTL number
input
Arg
output
  • 【Return value】
Return value
description
succeed
Non-0
  • 【Requirement】
  • 【Note】
k_acodec_get_adcr_volume#
  • 【Description】
Gets the right channel input digital gain control value.
  • 【Syntax】
  • 【Parameters】
Parameter name
Input/output
fd
input
IOCTL number
input
Arg
output
  • 【Return value】
Return value
description
succeed
Non-0
  • 【Requirement】
  • 【Note】
k_acodec_get_alc_gain_micl#
  • 【Description】
Obtain the analog gain value for the left channel ALC input.
  • 【Syntax】
  • 【Parameters】
Parameter name
Input/output
fd
input
IOCTL number
input
Arg
output
  • 【Return value】
Return value
description
succeed
Non-0
  • 【Requirement】
  • 【Note】
k_acodec_get_alc_gain_micr#
  • 【Description】
Obtain the analog gain value of the right channel ALC input.
  • 【Syntax】
  • 【Parameters】
Parameter name
Input/output
fd
input
IOCTL number
input
Arg
output
  • 【Return value】
Return value
description
succeed
Non-0
  • 【Requirement】
  • 【Note】
k_acodec_get_gain_hpoutl#
  • 【Description】
Gets the analog gain value of the left channel output.
  • 【Syntax】
  • 【Parameters】
Parameter name
Input/output
fd
input
IOCTL number
input
Arg
output
  • 【Return value】
Return value
description
succeed
Non-0
  • 【Requirement】
  • 【Note】
k_acodec_get_gain_hpoutr#
  • 【Description】
Get right channel output analog gain control.
  • 【Syntax】
  • 【Parameters】
Parameter name
Input/output
fd
input
IOCTL number
input
Arg
output
  • 【Return value】
Return value
description
succeed
Non-0
  • 【Requirement】
  • 【Note】
k_acodec_get_dacl_volume#
  • 【Description】
Gets the digital gain value of the left channel output.
  • 【Syntax】
  • 【Parameters】
Parameter name
Input/output
fd
input
IOCTL number
input
Arg
output
  • 【Return value】
Return value
description
succeed
Non-0
  • 【Requirement】
  • 【Note】
k_acodec_get_dacr_volume#
  • 【Description】
Gets the digital gain value of the right channel output.
  • 【Syntax】
  • 【Parameters】
Parameter name
Input/output
fd
input
IOCTL number
input
Arg
output
  • 【Return value】
Return value
description
succeed
Non-0
  • 【Requirement】
  • 【Note】
k_acodec_reset#
  • 【Description】
Volume reset: Includes ADC, DAC, ALC digital and analog gain.
  • 【Syntax】
  • 【Parameters】
Parameter name
Input/output
fd
input
k_acodec_reset
IOCTL number
input
  • 【Return value】
Return value
description
succeed
Non-0
  • 【Requirement】
  • 【Note】
none
Audio coding MAPI#
The Audio Coding feature module provides the following MAPIs:
kd_mapi_aenc_init#
  • 【Description】
Initialize the encoding channel.
  • 【Syntax】
kd_mapi_aenc_deinit#
  • 【Description】
Go to initialize the encoding channel.
  • 【Syntax】
kd_mapi_aenc_start#
  • 【Description】
Start the encoding channel.
  • 【Syntax】
kd_mapi_aenc_stop#
  • 【Description】
Stop encoding the channel.
  • 【Syntax】
  • 【Description】
Registers the encoding callback function.
  • 【Syntax】
k_s32 kd_mapi_aenc_registercallback(k_handle aenc_hdl.k_aenc_callback_s *aenc_cb);
  • 【Description】
  • 【Syntax】
kd_mapi_aenc_bind_ai#
  • 【Description】
Bind AI.
  • 【Syntax】
k_s32 kd_mapi_aenc_bind_ai(k_handle ai_hdl.k_handlek_handle aenc_hdl);
kd_mapi_aenc_unbind_ai#
  • 【Description】
Unbind AI.
  • 【Syntax】
k_s32 kd_mapi_aenc_unbind_ai(k_handle ai_hdl.k_handlek_handle aenc_hdl);
  • 【Description】
Register an external encoder.
  • 【Syntax】
k_s32 kd_mapi_register_ext_audio_encoder(const k_aenc_encoder *encoder,k_handlek_handle * aencoder_hdl);
  • 【Description】
Unregister the external audio encoder.
  • 【Syntax】
kd_mapi_aenc_send_frame#
  • 【Description】
Send audio encoded audio frames
  • 【Syntax】
Audio Decoding MAPI#
The Audio Decoding feature module provides the following MAPIs:
kd_mapi_adec_init#
  • 【Description】
Initialize the decoding channel.
  • 【Syntax】
kd_mapi_adec_deinit#
  • 【Description】
Deinitialize the decoding channel.
  • 【Syntax】
kd_mapi_adec_start#
  • 【Description】
Start the decoding channel.
  • 【Syntax】
kd_mapi_adec_stop#
  • 【Description】
Stop the decoding channel.
  • 【Syntax】
  • 【Description】
Register the decode callback function.
  • 【Syntax】
k_s32 kd_mapi_adec_registercallback(k_handle adec_hdl.k_adec_callback_s *adec_cb);
  • 【Description】
  • 【Syntax】
kd_mapi_adec_bind_ao#
  • 【Description】
Bind ao.
  • 【Syntax】
k_s32 kd_mapi_adec_bind_ao(k_handle ao_hdl.k_handlek_handle adec_hdl);
kd_mapi_adec_unbind_ao#
  • 【Description】
Unbind ao.
  • 【Syntax】
k_s32 kd_mapi_adec_unbind_ao(k_handle ao_hdl.k_handlek_handle adec_hdl);
  • 【Description】
Register the external decoder.
  • 【Syntax】
k_s32 kd_mapi_register_ext_audio_decoder(const k_adec_decoder *decoder,k_handlek_handle * adecoder_hdl);
  • 【Description】
Unregister the external audio decoder.
  • 【Syntax】
kd_mapi_adec_send_stream#
  • 【Description】
Send audio to decode audio frames.
  • 【Syntax】
Data Type#
Audio input and output#
The data types and data structures related to audio input and output are defined as follows:
k_audio_type#
【Description】
Define audio input and output types.
【Definition】
} k_audio_type;
【Note】
The audio input includes I2S and PDM, and the audio output is only I2S.
【See Also】
none
k_audio_dev#
【Description】
Define an audio device.
【Definition】
typedef k_u32 k_audio_dev;
【Note】
AI module, k_audio_dev values are 0 and 1, where 0 is the I2S audio input and 1 is the PDM audio input.
AO module, the k_audio_dev value is fixed to 0, that is, the I2S audio output.
k_ai_chn#
【Description】
Define AI audio channels.
【Definition】
typedef k_u32 k_ai_chn;
【Note】
I2S audio input, there are 2 groups, the value range is .[0,1]
PDM audio input, there are 4 groups, the value range is .[0,3]
k_ao_chn#
【Description】
Define the AO audio channel.
【Definition】
typedef k_u32 k_ao_chn;
【Note】
I2S audio output, there are 2 groups, the value range is .[0,1]
K_MAX_AUDIO_FRAME_NUM#
【Description】
Defines the maximum number of audio decoding cache frames.
【Definition】
k_audio_bit_width#
【Description】
  • Define the audio sampling accuracy.
【Definition】
} k_audio_bit_width;
【Note】
none
【See Also】
none
k_audio_snd_mode#
【Description】
  • Define the channel mode.
【Definition】
} k_audio_snd_mode;
k_audio_pdm_oversample#
【Description】
Define PDM oversampling.
【Definition】
} k_audio_pdm_oversample;
k_audio_pdm_attr#
【Description】
Define PDM audio input properties.
【Definition】
k_audio_sample_rate rate;
k_audio_bit_width width;
k_audio_snd_mode mode;
k_u32 point_num_per_frame;
} k_audio_pdm_attr;
【Members】
Member name
description
chn_cnt
The number of channels supported. Supports 1-4 channels, and channel enablement needs to be continuous.
sample_rate
Sample rate: support 8K~192K
bit_width
Sampling accuracy: support 16/24/32
snd_mode
Audio channel mode. Supports mono and dual channels.
pdm_oversample
Oversampling: Supports 32, 64, and 128 times oversampling.
frame_num
The number of cached frames[2,K_MAX_AUDIO_FRAME_NUM].
point_num_per_frame
The number of sample points per frame.
【Note】
none
【See Also】
none
k_audio_i2s_attr#
【Description】
Define I2S audio input properties.
【Definition】
k_audio_bit_width bit_width;
k_aio_i2s_type type;
} k_audio_i2s_attr;
【Members】
Member name
description
chn_cnt
The number of channels supported. Support 1-2 channels.
sample_rate
bit_width
snd_mode
I2s_mode
I2S working mode: support Philips mode, left alignment mode, right alignment mode.
frame_num
point_num_per_frame
The number of sample points per frame[sample_rate/100,sample_rate].
i2s_type
I2S docking device type: built-in codec or external device.
【Note】
The number of sample points per frame point_num_per_frame and the value of the sample rate sample_rate determine the hardware generation
The frequency of interruptions, too high a frequency will affect the performance of the system, and other services will also affect each other, it is recommended that these two parameters be involved
The value of the number satisfies the formula: (point_num_per_frame * 1000) / sample_rate > = 10 (interrupt 100 times), such as sampling
When the rate is 16000Hz, it is recommended that the number of sampling points be greater than or equal to 160.
【See Also】
none
k_i2s_work_mode#
【Description】
Define the I2S operating mode.
【Definition】
K_STANDARD_MODE = 1,
K_RIGHT_JUSTIFYING_MODE = 2,
K_LEFT_JUSTIFYING_MODE = 4
} k_i2s_work_mode;
【Note】
none
【See Also】
none
k_aio_dev_attr#
【Description】
Defines the audio input/output device property structure.
【Definition】
k_audio_type type;
union
k_audio_pdm_attr pdm_attr;
k_audio_i2s_attr i2s_attr;
} kd_audio_attr;
} k_aio_dev_attr;
【Members】
Member name
description
audio_type
Audio type.
kd_audio_attr
Audio property settings
【Note】
none
【See Also】
none
k_aio_i2s_type#
【Description】
Define the I2S docking device type.
【Definition】
} k_aio_i2s_type;
【Note】
The built-in audio codec uses the group 0 I2S path, and the group 1 I2S path still uses an external codec.
【See Also】
none
k_audio_frame#
【Description】
Defines the audio frame structure.
【Definition】
k_audio_snd_mode snd_mode;
void* virt_addr;
k_u64 phys_addr;
k_u32 pool_id;
} k_audio_frame;
【Members】
Member name
description
bit_width
Sampling accuracy.
snd_mode
Audio channel mode.
virt_addr
Audio frame data virtual address.
phys_addr
The physical address of the audio frame data.
time_stamp
Audio frame timestamp, in μs.
seq
Audio frame sequence number.
only
Audio frame length, in bytes.
pool_id
Audio framebuffer pool ID.
【Note】
none
【See Also】
none
k_audio_anr_cfg#
【Description】
Define the audio voice noise reduction feature configuration information structure.
【Definition】
k_bool anr_switch;
} k_audio_anr_cfg;
【Members】
Member name
description
anr_switch
Audio voice noise reduction function enabled.
【Note】
none
【See Also】
none
k_audio_agc_cfg#
【Description】
Define the audio auto-gain function configuration information structure.
【Definition】
k_bool agc_switch;
} k_audio_agc_cfg;
【Members】
Member name
description
agc_switch
Audio auto-gain is enabled.
【Note】
none
【See Also】
none
k_ai_vqe_cfg#
【Description】
Define the audio input sound quality enhancement configuration information structure.
【Definition】
typedef struct { k_audio_anr_cfg anr_cfg; k_audio_agc_cfg agc_cfg; } k_ai_vqe_cfg;
【Members】
Member name
description
anr_cfg
Audio voice noise reduction function configuration parameters.
agc_cfg
Audio automatic gain control configuration parameters.
【Note】
none
【See Also】
none
Audio codec#
The relevant data types and data structures of audio codecs are defined as follows:
k_payload_type
k_aenc_encoder
k_aenc_chn_attr
AENC_MAX_CHN_NUMS
K_MAX_ENCODER_NAME_LEN
k_aenc_chn
k_audio_stream
k_adec_chn_attr
k_adec_decoder
K_MAX_DECODER_NAME_LEN
ADEC_MAX_CHN_NUMS
k_payload_type#
【Description】
Define an audio and video payload type enumeration.
【Definition】
K_PT_PCMU = 0,
K_PT_1016 = 1,
K_PT_G721 = 2,
K_PT_GSM = 3,
K_PT_G723 = 4,
K_PT_DVI4_8K = 5,
K_PT_DVI4_16K = 6,
K_PT_LPC = 7,
K_PT_PCMA = 8,
K_PT_G722 = 9,
K_PT_S16BE_STEREO = 10,
K_PT_S16BE_MONO = 11,
K_PT_QCELP = 12,
K_PT_CN = 13,
K_PT_MPEGAUDIO = 14,
K_PT_G728 = 15,
K_PT_DVI4_3 = 16,
K_PT_DVI4_4 = 17,
K_PT_G729 = 18,
K_PT_G711A = 19,
K_PT_G711U = 20,
K_PT_G726 = 21,
K_PT_G729A = 22,
K_PT_LPCM = 23,
K_PT_CelB = 25,
K_PT_JPEG = 26,
K_PT_CUSM = 27,
K_PT_NV = 28,
K_PT_PICW = 29,
K_PT_CPV = 30,
K_PT_H261 = 31,
K_PT_MPEGVIDEO = 32,
K_PT_MPEG2TS = 33,
K_PT_H263 = 34,
K_PT_SPEG = 35,
K_PT_MPEG2VIDEO = 36,
K_PT_AAC = 37,
K_PT_WMA9STD = 38,
K_PT_HEAAC = 39,
K_PT_PCM_VOICE = 40,
K_PT_PCM_AUDIO = 41,
K_PT_MP3 = 43,
K_PT_ADPCMA = 49,
K_PT_AEC = 50,
K_PT_X_LD = 95,
K_PT_H264 = 96,
K_PT_D_GSM_HR = 200,
K_PT_D_GSM_EFR = 201,
K_PT_D_L8 = 202,
K_PT_D_RED = 203,
K_PT_D_VDVI = 204,
K_PT_D_BT656 = 220,
K_PT_D_H263_1998 = 221,
K_PT_D_MP1S = 222,
K_PT_D_MP2P = 223,
K_PT_D_BMPEG = 224,
K_PT_MP4VIDEO = 230,
K_PT_MP4AUDIO = 237,
K_PT_VC1 = 238,
K_PT_JVC_ASF = 255,
K_PT_D_AVI = 256,
K_PT_DIVX3 = 257,
K_PT_AVS = 258,
K_PT_REAL8 = 259,
K_PT_REAL9 = 260,
K_PT_VP6 = 261,
K_PT_VP6F = 262,
K_PT_VP6A = 263,
K_PT_SORENSON = 264,
K_PT_H265 = 265,
K_PT_VP8 = 266,
K_PT_MVC = 267,
K_PT_PNG = 268,
K_PT_AMR = 1001,
K_PT_MJPEG = 1002,
K_PT_AMRWB = 1003,
K_PT_PRORES = 1006,
K_PT_OPUS = 1007,
K_PT_BUTT
} k_payload_type;
【Note】
none
【See Also】
none
k_aenc_encoder#
【Description】
Define the encoder property structure.
【Definition】
} k_aenc_encoder;
【Members】
Member name
description
Encoded protocol type.
max_frame_len
Maximum bitstream length.
name
Encoder name.
func_open_encoder
Open the function pointer for the encoder.
func_enc_frame
The function pointer to be encoded.
func_close_encoder
Turn off the encoder’s function pointer.
【Note】
none
【See Also】
none
k_aenc_chn_attr#
【Description】
Defines the encoder channel property structure.
【Definition】
k_payload_type type;
} k_aenc_chn_attr;
【Members】
Member name
description
Audio encoding protocol type.
point_num_per_frame
The corresponding frame length of the audio coding protocol (the audio frame length received when encoding is less than or equal to that frame length can be encoded).
buf_size
Audio encoding cache size. Value range:[2, K_MAX_AUDIO_FRAME_NUM] in frames.
【Note】
none
【See Also】
none
AENC_MAX_CHN_NUMS#
【Description】
Defines the maximum number of encoded channels.
【Definition】
#define AENC_MAX_CHN_NUMS 4
【Note】
none
【See Also】
none
K_MAX_ENCODER_NAME_LEN#
【Description】
Defines the audio encoder name maximum length.
【Definition】
【Note】
none
【See Also】
none
k_aenc_chn#
【Description】
Defines the encoding channel type.
【Definition】
typedef k_u32 k_aenc_chn;
【Note】
none
【See Also】
none
k_audio_stream#
【Description】
Define the bitstream structure.
【Definition】
} k_audio_stream;
【Members】
Member name
description
stream
Audio stream data pointer
phys_addr
The physical address of the audio stream.
only
Audio stream length. Units in byte.
time_stamp
Audio stream timestamp.
seq
Audio stream sequence number.
【Note】
none
【See Also】
none
k_adec_chn_attr#
【Description】
Defines the decoder channel property structure.
【Definition】
k_payload_type payload_type;
} k_adec_chn_attr;
【Members】
Member name
description
Audio decoding protocol type.
point_num_per_frame
The frame length corresponding to the audio decoding protocol
buf_size
【Note】
Some properties of audio decoding need to match output device properties, such as sample rate, frame length (samples per frame
Number of points), etc.
【See Also】
none
k_adec_decoder#
【Description】
Defines the decoder property structure.
【Definition】
} k_adec_decoder;
【Members】
Member name
description
Decodes the protocol type.
name
Decoder name.
func_open_decoder
Open the function pointer for the decoder.
func_get_frame_info
A function pointer that gets audio frame information.
func_close_decoder
Turns off the function pointer for the decoder.
func_reset_decoder
Empty the buffer buffer, reset the decoder’s function pointer.
【Note】
none
【See Also】
none
K_MAX_DECODER_NAME_LEN#
【Description】
Defines the maximum length of the audio decoder name.
【Definition】
【Note】
none
【See Also】
none
ADEC_MAX_CHN_NUMS#
【Description】
Defines the maximum number of decoding channels.
【Definition】
#define ADEC_MAX_CHN_NUMS 4
【Note】
none
【See Also】
none
k_adec_chn#
【Description】
Defines the decoding channel type.
【Definition】
typedef k_u32 k_adec_chn;
【Note】
none
【See Also】
none
MAPI#
The data types and data structures related to audio MAPI are defined as follows
k_handle
k_handle#
【Description】
Define the operation handle.
【Definition】
typedef k_u32 k_handle;
【See Also】
none
Error codes#
Audio Input API Error Code#
Error code
Macro definitions
description
0xA0158001
K_ERR_AI_INVALID_DEVID
The audio input device number is invalid
0xA0158002
K_ERR_AI_INVALID_CHNID
The audio input channel number is invalid
0xA0158003
K_ERR_AI_ILLEGAL_PARAM
The audio input parameter setting is invalid
0xA0158004
K_ERR_AI_NOT_ENABLED
The audio input device or channel is not enabled
0xA0158005
K_ERR_AI_NULL_PTR
The input parameter null pointer is incorrect
0xA0158006
K_ERR_AI_NOT_CFG
Audio input device properties are not set
0xA0158007
K_ERR_AI_NOT_SUPPORT
Operation is not supported
0xA0158008
K_ERR_AI_NOT_PERM
Operation is not allowed
0xA0158009
K_ERR_AI_NO_MEM
Failed to allocate memory
0xA015800A
K_ERR_AI_NO_BUF
Insufficient audio input cache
0xA015800B
K_ERR_AI_BUF_EMPTY
The audio input cache is empty
0xA015800C
K_ERR_AI_BUF_FULL
The audio input cache is full
0xA015800D
K_ERR_AI_NOT_READY
The audio input system is not initialized
0xA015800E
K_ERR_AI_BUSY
The audio input system is busy
Audio Output API error codes#
Error code
Macro definitions
description
0xA0159001
K_ERR_AO_INVALID_DEV_ID
The audio output device number is invalid
0xA0159002
K_ERR_AO_INVALID_CHN_ID
The audio output channel number is invalid
0xA0159003
K_ERR_AO_ILLEGAL_PARAM
The audio output parameter setting is invalid
0xA0159004
K_ERR_AO_NOT_ENABLED
The audio output device or channel is not enabled
0xA0159005
K_ERR_AO_NULL_PTR
Output null pointer error
0xA0159006
K_ERR_AO_NOT_CFG
The audio output device property is not set
0xA0159007
K_ERR_AO_NOT_SUPPORT
The operation is not supported
0xA0159008
K_ERR_AO_NOT_PERM
0xA0159009
K_ERR_AO_NO_MEM
The system is low on memory
0xA015900A
K_ERR_AO_NO_BUF
Insufficient audio output cache
0xA015900B
K_ERR_AO_BUF_EMPTY
The audio output cache is empty
0xA015900C
K_ERR_AO_BUF_FULL
The audio output cache is full
0xA015900D
K_ERR_AO_NOT_READY
The audio output system is not initialized
0xA015900E
K_ERR_AO_BUSY
The audio output system is busy
