K230 Audio API Reference
Contents
K230 Audio API Reference#
The audio module includes four sub-modules: audio input (ai), audio output (ao), audio encoding (aenc), and audio decoding (adec), as well as support for the built-in analog audio codec. The audio input module includes two types of audio interfaces, i2s and pdm, working with pdma for memory copying. It supports digital microphones (pdm/i2s) and analog audio codec (i2s) sound source input, with an internal analog audio codec that supports sound quality enhancement (VQE) processing: 3A (AEC echo cancellation, ANR noise reduction, AGC automatic gain control). The audio output module supports the i2s audio interface, working with pdma for memory copying, and can connect external data speakers or analog audio codecs for sound output. The audio encoding and decoding modules currently support G711 format audio encoding and decoding functions and support external codec registration.
The audio module is split into multiple sub-modules, with low-coupling data flow transmission between modules. This design meets the existing multimedia business requirements under MAIX3. The following diagram analyzes the usage scenario of the audio module in a voice intercom business. The audio data collected by the audio input module is encoded by the audio encoding module and then sent to the remote end through the network. The audio encoded data obtained from the remote end is decoded by the audio decoding module and then played through the audio output module.
Function Description#
Audio Input#
The audio input module (AI) mainly implements the configuration and activation of audio input devices and the acquisition of audio frame data.
The audio input module supports i2s and pdm protocol interfaces. i2s supports simultaneous collection of up to 2 dual-channel audio streams, and pdm supports simultaneous collection of up to 8 single-channel audio streams. Detailed i2s and pdm features are as follows:
  • i2s audio interface
    1. Data sampling rates support 8kHz/12kHz/16kHz/24kHz/32kHz/44.1kHz/48kHz/96kHz/192kHz, with sampling precision supporting 16/24/32bit.
    2. Supports 2 configurable IO groups for input/output of I2S audio data, supporting full-duplex mode.
  • pdm audio interface
    1. Supports PDM audio input, 1-bit width, sampling clock frequencies of 0.256MHz/0.384MHz/0.512MHz/0.768MHz/1.024MHz/1.4112MHz/1.536MHz/2.048MHz/2.8224MHz/3.072MHz/4.096MHz/5.6448MHz/6.144MHz/12.288MHz/24.576MHz, with the input PCM audio sampling rates of 8kHz/12kHz/16kHz/24kHz/32kHz/44.1kHz/48kHz/96kHz/192kHz. Sampling precision supports 16/24/32bit.
    2. Supports oversampling rates of 128, 64, and 32 times.
    3. Supports 1-4 IOs for inputting PDM audio data.
    4. Input supports configurable 1-8 PDM channels, supporting PDM left and right single-channel mode and dual-channel mode. Each IO channel mode is unified, and PDM dual-channel mode uses up to 4 IOs.
    5. Enabled channel numbers are continuous from small to large and do not support random enabling of channels.
Audio Output#
The audio output (AO) mainly implements the activation of audio output devices and the sending of audio frames to the output channel.
The audio output module supports the i2s protocol interface. i2s supports simultaneous output of up to 2 dual-channel audio streams.
    1. Data sampling rates support 8kHz/12kHz/16kHz/24kHz/32kHz/44.1kHz/48kHz/96kHz/192kHz, with sampling precision of 16/24/32bit.
Sound Quality Enhancement#
The audio module supports sound quality enhancement processing for audio data, realizing audio 3A functions. Currently supported sampling precision is 16bit, with a supported sampling rate of 16k.
API Reference#
Audio Input#
kd_mpi_ai_set_pub_attr#
Description:
Set AI device attributes.
Syntax:
k_s32 kd_mpi_ai_set_pub_attr([k_audio_dev](#k_audio_dev) ai_dev, const [k_aio_dev_attr](#k_aio_dev_attr) *attr);
Parameters:
Parameter
Input/Output
ai_dev
Audio device number.
Input
attr
AI device attribute pointer.
Input
Return Value:
Success
Non-zero
Failure, see error code
Requirements:
  • Header file: mpi_ai_api.h
  • Library file: libai.a
Notes:
k_aio_dev_attr aio_dev_attr;
memset(&aio_dev_attr, 0, sizeof(aio_dev_attr));
aio_dev_attr.kd_audio_attr.i2s_attr.bit_width = KD_AUDIO_BIT_WIDTH_16;
aio_dev_attr.kd_audio_attr.i2s_attr.point_num_per_frame = 44100 / 25;
if (K_SUCCESS != kd_mpi_ai_set_pub_attr(0, &aio_dev_attr)) {
    return K_FAILED;
if (K_SUCCESS != kd_mpi_ai_enable(0)) {
    return K_FAILED;
if (K_SUCCESS != kd_mpi_ai_enable_chn(0, 0)) {
    return K_FAILED;
kd_mpi_ai_get_pub_attr#
Description:
Get AI device attributes.
Syntax:
k_s32 kd_mpi_ai_get_pub_attr([k_audio_dev](#k_audio_dev) ai_dev, [k_aio_dev_attr](#k_aio_dev_attr) *attr);
Parameters:
Parameter
Input/Output
ai_dev
Input
attr
Output
Return Value:
Success
Non-zero
Requirements:
kd_mpi_ai_enable#
Description:
Enable AI device.
Syntax:
k_s32 kd_mpi_ai_enable([k_audio_dev](#k_audio_dev) ai_dev);
Parameters:
Parameter
Input/Output
ai_dev
Input
Return Value:
Success
Non-zero
Requirements:
kd_mpi_ai_disable#
Description:
Disable AI device.
Syntax:
k_s32 kd_mpi_ai_disable([k_audio_dev](#k_audio_dev) ai_dev);
Parameters:
Parameter
Input/Output
ai_dev
Input
Return Value:
Success
Non-zero
Requirements:
kd_mpi_ai_enable_chn#
Description:
Enable AI channel.
Syntax:
k_s32 kd_mpi_ai_enable_chn([k_audio_dev](#k_audio_dev) ai_dev, [k_ai_chn](#k_ai_chn) ai_chn);
Parameters:
Parameter
Input/Output
ai_dev
Input
ai_chn
Audio channel number.
Input
Return Value:
Success
Non-zero
Requirements:
kd_mpi_ai_disable_chn#
Description:
Disable AI channel.
Syntax:
k_s32 kd_mpi_ai_disable_chn([k_audio_dev](#k_audio_dev) ai_dev, [k_ai_chn](#k_ai_chn) ai_chn);
Parameters:
Parameter
Input/Output
ai_dev
Input
ai_chn
Input
Return Value:
Success
Non-zero
Requirements:
kd_mpi_ai_get_frame#
Description:
Get audio frame.
Syntax:
k_s32 kd_mpi_ai_get_frame([k_audio_dev](#k_audio_dev) ai_dev, [k_ai_chn](#k_ai_chn) ai_chn, [k_audio_frame](#k_audio_frame) *frame, k_u32 milli_sec);
Parameters:
Parameter
Input/Output
ai_dev
Input
ai_chn
Input
frame
Audio frame data.
Output
milli_sec
Timeout for getting data. -1 means blocking mode, waiting indefinitely if no data; 0 means non-blocking mode, returning an error if no data; >0 means blocking for milli_sec milliseconds, returning an error if timeout.
Input
Return Value:
Success
Non-zero
Requirements:
Notes:
  • The value of milli_sec must be greater than or equal to -1. When it is -1, data is retrieved in blocking mode. When it is 0, data is retrieved in non-blocking mode. When it is greater than 0, it blocks for milli_sec milliseconds, and if there is no data, it returns a timeout error.
  • The corresponding AI channel must be enabled before retrieving audio frame data.
k_audio_frame audio_frame;
while(true) {
    // get frame
    if (K_SUCCESS != kd_mpi_ai_get_frame(dev_num, channel, &audio_frame, 1000)) {
        continue;
    // process frame
    process_frame(&audio_frame);
    // release frame
kd_mpi_ai_release_frame#
Description:
Release audio frame.
Syntax:
k_s32 kd_mpi_ai_release_frame([k_audio_dev](#k_audio_dev) ai_dev, [k_ai_chn](#k_ai_chn) ai_chn, const [k_audio_frame](#k_audio_frame) *frame);
Parameters:
Parameter
Input/Output
ai_dev
Input
ai_chn
Input
frame
Audio frame data.
Input
Return Value:
Success
Non-zero
Requirements:
kd_mpi_ai_set_vqe_attr#
Description:
Set AI voice quality enhancement attributes.
Syntax:
k_s32 kd_mpi_ai_set_vqe_attr([k_audio_dev](#k_audio_dev) ai_dev, [k_ai_chn](#k_ai_chn) ai_chn, const [k_ai_vqe_enable](#k_ai_vqe_enable) vqe_enable);
Parameters:
Parameter Name
Input/Output
ai_dev
Input
ai_chn
Input
vqe_enable
Voice quality enhancement enable flag.
Input
Return Value:
Success
Non-zero
Requirements:
Notes:
Audio 3A supports 16-bit sampling precision, and AGC only supports 8k/16k/32k/48k.
kd_mpi_ai_get_vqe_attr#
Description:
Get AI voice quality enhancement attributes.
Syntax:
k_s32 kd_mpi_ai_get_vqe_attr([k_audio_dev](#k_audio_dev) ai_dev, [k_ai_chn](#k_ai_chn) ai_chn, [k_ai_vqe_enable](#k_ai_vqe_enable) vqe_enable);
Parameters:
Parameter Name
Input/Output
ai_dev
Input
ai_chn
Input
vqe_enable
Pointer to voice quality enhancement enable flag.
Output
Return Value:
Success
Non-zero
Requirements:
Description:
Send far-end voice signal. This signal is collected by the far-end microphone (speaker’s voice) and is also equal to the voice played by the near-end speaker, also known as the reference voice.
Syntax:
k_s32 kd_mpi_ai_send_far_echo_frame([k_audio_dev](#k_audio_dev) ai_dev, [k_ai_chn](#k_ai_chn) ai_chn, const [k_audio_frame](#k_audio_frame) *frame, k_s32 milli_sec);
Parameters:
Parameter Name
Input/Output
ai_dev
Input
ai_chn
Input
frame
Reference voice data.
Input
milli_sec
Timeout for sending data. -1 means blocking mode, waiting indefinitely if no data; 0 means non-blocking mode, returning an error if no data; >0 means blocking for milli_sec milliseconds, returning an error if timeout.
Input
Return Value:
Success
Non-zero
Requirements:
Audio Output#
kd_mpi_ao_set_pub_attr#
Description:
Set AO device attributes.
Syntax:
k_s32 kd_mpi_ao_set_pub_attr([k_audio_dev](#k_audio_dev) ao_dev, const [k_aio_dev_attr](#k_aio_dev_attr) *attr);
Parameters:
Parameter
Input/Output
ao_dev
Input
attr
AO device attribute pointer.
Input
Return Value:
Success
Non-zero
Requirements:
  • Header file: mpi_ao_api.h
  • Library file: libao.a
Notes:
k_aio_dev_attr ao_dev_attr;
memset(&ao_dev_attr, 0, sizeof(ao_dev_attr));
ao_dev_attr.kd_audio_attr.i2s_attr.point_num_per_frame = 48000 / 25;
if (K_SUCCESS != kd_mpi_ao_set_pub_attr(0, &ao_dev_attr)) {
    return K_FAILED;
if (K_SUCCESS != kd_mpi_ao_enable(0)) {
    printf("kd_mpi_ao_enable failed\n");
    return K_FAILED;
if (K_SUCCESS != kd_mpi_ao_enable_chn(0, 1)) {
    printf("kd_mpi_ao_enable_chn failed\n");
    return K_FAILED;
kd_mpi_ao_get_pub_attr#
Description:
Get AO device attributes.
Syntax:
k_s32 kd_mpi_ao_get_pub_attr([k_audio_dev](#k_audio_dev) ao_dev, [k_aio_dev_attr](#k_aio_dev_attr) *attr);
Parameters:
Parameter
Input/Output
ao_dev
Input
attr
Output
Return Value:
Success
Non-zero
Requirements:
kd_mpi_ao_enable#
Description:
Enable AO device.
Syntax:
k_s32 kd_mpi_ao_enable([k_audio_dev](#k_audio_dev) ao_dev);
Parameters:
Parameter
Input/Output
ao_dev
Input
Return Value:
Success
Non-zero
Requirements:
kd_mpi_ao_disable#
Description:
Disable AO device.
Syntax:
k_s32 kd_mpi_ao_disable([k_audio_dev](#k_audio_dev) ao_dev);
Parameters:
Parameter
Input/Output
ao_dev
Input
Return Value:
Success
Non-zero
Requirements:
kd_mpi_ao_enable_chn#
Description:
Enable AO channel.
Syntax:
k_s32 kd_mpi_ao_enable_chn([k_audio_dev](#k_audio_dev) ao_dev, [k_ao_chn](#k_ao_chn) ao_chn);
Parameters:
Parameter
Input/Output
ao_dev
Input
ao_chn
Input
Return Value:
Success
Non-zero
Requirements:
  • Library file: libao.a | Input |
Return Value:
Success
Non-zero
Requirements:
kd_mpi_ao_disable_chn#
Description:
Disable AO channel.
Syntax:
k_s32 kd_mpi_ao_disable_chn([k_audio_dev](#k_audio_dev) ao_dev, [k_ao_chn](#k_ao_chn) ao_chn);
Parameters:
Parameter
Input/Output
ao_dev
Input
ao_chn
Input
Return Value:
Success
Non-zero
Requirements:
kd_mpi_ao_send_frame#
Description:
Send AO frame data.
Syntax:
k_s32 kd_mpi_ao_send_frame([k_audio_dev](#k_audio_dev) ao_dev, [k_ao_chn](#k_ao_chn) ao_chn, const [k_audio_frame](#k_audio_frame) *frame, k_s32 milli_sec);
Parameters:
Parameter
Input/Output
ao_dev
Input
ao_chn
Input
frame
Pointer to audio frame data.
Input
milli_sec
Input
Return Value:
Success
Non-zero
Requirements:
Notes:
  • The value of milli_sec must be greater than or equal to -1. When it is -1, data is sent in blocking mode. When it is 0, data is sent in non-blocking mode. When it is greater than 0, it blocks for milli_sec milliseconds, and if there is no data, it returns a timeout error.
  • The corresponding AO channel must be enabled before sending audio frame data.
k_s32 ret = 0;
while (true) {
    // get ai frame
    if (K_SUCCESS != ret) {
        continue;
    // send ai frame to ao
    // release ai frame
Audio Encoding#
Audio encoding primarily implements creating encoding channels, sending audio frames for encoding, and retrieving encoded streams.
The audio encoding section provides G711a/u encoding, currently only supporting 16-bit sampling precision.
kd_mpi_aenc_register_encoder#
Description:
Register encoder.
Syntax:
k_s32 kd_mpi_aenc_register_encoder(k_s32 *handle, const [k_aenc_encoder](#k_aenc_encoder) *encoder);
Parameters:
Parameter
Input/Output
handle
Registration handle.
Output
encoder
Encoder attribute structure.
Input
Notes:
Users register an encoder by passing in the encoder attribute structure to the AENC module and receive a registration handle, which can be used later to unregister the encoder.
The AENC module can register up to 20 encoders, and it already registers G711.a and G711.u encoders.
The same encoding protocol cannot register multiple encoders. For example, if a G711 encoder is already registered, another G711 encoder cannot be registered.
Return Value:
Success
Non-zero
Requirements:
  • Header file: mpi_aenc_api.h
  • Library file: libaenc.a
Description:
Unregister encoder.
Syntax:
Parameters:
Parameter
Input/Output
handle
Unregistration handle.
Input
Return Value:
Success
Non-zero
Requirements:
kd_mpi_aenc_create_chn#
Description:
Create audio encoding channel.
Syntax:
k_s32 kd_mpi_aenc_create_chn([k_aenc_chn](#k_aenc_chn) aenc_chn, const [k_aenc_chn_attr](#k_aenc_chn_attr) *attr);
Parameters:
Parameter
Input/Output
aenc_chn
Channel number. Range: [0, AENC_MAX_CHN_NUM).
Input
attr
Pointer to audio encoding channel attributes.
Input
Notes:
Buffer size is in frames, ranging from [2, K_MAX_AUDIO_FRAME_NUM], recommended to be configured above 10. Small buffer configurations may result in frame loss and other anomalies. Each encoding channel configures queue size based on buffer size to cache encoded frame data.
Return Value:
Success
Non-zero
Requirements:
kd_mpi_aenc_destroy_chn#
Description:
Destroy audio encoding channel.
Syntax:
k_s32 kd_mpi_aenc_destroy_chn([k_aenc_chn](#k_aenc_chn) aenc_chn);
Parameters:
Parameter
Input/Output
aenc_chn
Input
Notes:
Return Value:
Success
Non-zero
Requirements:
kd_mpi_aenc_send_frame#
Description:
Send audio frame for encoding.
Syntax:
k_s32 kd_mpi_aenc_send_frame([k_aenc_chn](#k_aenc_chn) aenc_chn, const [k_audio_frame](#k_audio_frame) *frame);
Parameters:
Parameter
Input/Output
aenc_chn
Input
frame
Pointer to audio frame structure.
Input
Notes:
Sending encoded audio frames is a non-blocking interface. If the audio stream buffer is full, it returns failure. This interface is used for users to actively send audio frames for encoding. If the AENC channel is already bound to AI through the system binding interface, it is not necessary and not recommended to call this interface. When calling this interface to send audio frames, the corresponding encoding channel must be created first.
Return Value:
Success
Non-zero
Requirements:
kd_mpi_aenc_get_stream#
Description:
Get encoded audio stream.
Syntax:
k_s32 kd_mpi_aenc_get_stream([k_aenc_chn](#k_aenc_chn) aenc_chn, [k_audio_stream](#k_audio_stream) *stream, k_s32 milli_sec);
Parameters:
Parameter
Input/Output
aenc_chn
Input
stream
Pointer to the retrieved audio stream.
Output
milli_sec
Input
Notes:
The channel must be created before retrieving streams, otherwise it directly returns failure. If the channel is destroyed during the process of retrieving streams, it immediately returns failure.
Return Value:
Success
Non-zero
Requirements:
kd_mpi_aenc_release_stream#
Description:
Release encoded audio stream.
Syntax:
k_s32 kd_mpi_aenc_release_stream([k_aenc_chn](#k_aenc_chn) aenc_chn, const [k_audio_stream](#k_audio_stream) *stream);
Parameters:
Parameter
Input/Output
aenc_chn
Input
stream
Output
Notes:
Return Value:
Success
Non-zero
Requirements:
Audio Decoding#
Audio decoding primarily implements creating decoding channels, sending audio streams for decoding, and retrieving decoded audio frames.
The audio encoding and decoding section provides G711a/u decoding, currently supporting 16-bit sampling precision.
kd_mpi_adec_register_decoder#
Description:
Register decoder.
Syntax:
k_s32 kd_mpi_adec_register_decoder(k_s32 *handle, const [k_adec_decoder](#k_adec_decoder) *decoder);
Parameters:
Parameter
Input/Output
handle
Output
decoder
Decoder attribute struct.
Input
Notes:
Users register a decoder to the ADEC module by passing in the decoder attribute structure and receive a registration handle, which can be used later to unregister the decoder. The ADEC module can register up to 20 decoders, and it already registers G711a and G711u decoders. The same decoding protocol cannot register multiple decoders. For example, if a G711 decoder is already registered, another G711 decoder cannot be registered.
Return Value:
Success
Non-zero
Requirements:
  • Header file: mpi_adec_api.h
  • Library file: libadec.a
Description:
Unregister decoder.
Syntax:
Parameters:
Parameter
Input/Output
handle
Input
Return Value:
Success
Non-zero
Requirements:
kd_mpi_adec_create_chn#
Description:
Create audio decoding channel.
Syntax:
k_s32 kd_mpi_adec_create_chn([k_adec_chn](#k_adec_chn) adec_chn, const [k_adec_chn_attr](#k_adec_chn_attr) *attr);
Parameters:
Parameter
Input/Output
adec_chn
Channel number. Range: [0, ADEC_MAX_CHN_NUM).
Input
attr
Pointer to channel attributes.
Input
Notes:
The protocol type specifies the decoding protocol for the channel, currently supporting G711. Some attributes of audio decoding need to match the output device attributes, such as sampling rate, frame length (number of samples per frame), etc. Buffer size is in frames, ranging from [2, K_MAX_AUDIO_FRAME_NUM], recommended to be configured above 10. Small buffer configurations may result in frame loss and other anomalies. This interface can only be used before the channel is created (or after it is destroyed). If the channel has already been created, it returns that the channel is already created.
Return Value:
Success
Non-zero
Requirements:
kd_mpi_adec_destroy_chn#
Description:
Destroy audio decoding channel.
Syntax:
k_s32 kd_mpi_adec_destroy_chn([k_adec_chn](#k_adec_chn) adec_chn);
Parameters:
Parameter
Input/Output
adec_chn
Input
Notes:
Return Value:
Success
Non-zero
Requirements:
kd_mpi_adec_send_stream#
Description:
Send audio stream to audio decoding channel.
Syntax:
k_s32 kd_mpi_adec_send_stream(k_adec_chn adec_chn, const k_audio_stream *stream, k_bool block);
Parameters:
Parameter
Description:
Input/Output
adec_chn
Input
stream
Audio stream.
Input
block
Blocking flag. HI_TRUE: Blocking. HI_FALSE: Non-blocking.
Input
Notes:
When sending data, the channel must already be created; otherwise, it directly returns failure. If the channel is destroyed during the data sending process, it immediately returns failure. Supports sending streams in blocking or non-blocking mode. When sending streams in blocking mode, if the buffer used to cache the decoded audio frames is full, this interface call will be blocked until the decoded audio frame data is taken away or the ADEC channel is destroyed.
Return Value:
Success
Non-zero
Requirements:
kd_mpi_adec_clr_chn_buf#
Description:
Clear current audio data buffer in ADEC channel.
Syntax:
k_s32 kd_mpi_adec_clr_chn_buf([k_adec_chn](#k_adec_chn) adec_chn);
Parameters:
Parameter
Input/Output
adec_chn
Input
Notes:
The decoding channel must be created; otherwise, it returns a channel does not exist error code.
Return Value:
Success
Non-zero
Requirements:
kd_mpi_adec_get_frame#
Description:
Retrieve decoded audio frame.
Syntax:
k_s32 kd_mpi_adec_get_frame([k_adec_chn](#k_adec_chn) adec_chn, [k_audio_frame](#k_audio_frame) *frame, k_s32 milli_sec);
Parameters:
Parameter
Input/Output
adec_chn
Audio decoding channel.
Input
frame_info
Audio frame data structure.
Output
block
Blocking flag for retrieval.
Input
Return Value:
Success
Non-zero
Requirements:
kd_mpi_adec_release_frame#
Description:
Release the retrieved audio decoding frame data.
Syntax:
k_s32 kd_mpi_adec_release_frame([k_adec_chn](#k_aenc_chn) adec_chn, const [k_audio_frame](#k_audio_frame) *frame);
Parameters:
Parameter
Input/Output
adec_chn
Input
frame_info
Input
Return Value:
Success
Non-zero
Requirements:
Built-in Audio Codec#
The built-in Audio Codec primarily provides operations on hardware devices through ioctl. Among the provided ioctl commands, some commands can be used with the default values set during module loading. The ioctl call implements reading and writing to the built-in Audio Codec registers.
The current version of audio codec control operations mainly includes: ADC digital and analog volume, DAC digital/analog volume, ADC/DAC mute control. Sampling rate, sampling precision, and I2S alignment mode control operations are automatically completed by the kernel through the AI and AO API interfaces (the kernel code automatically implements the operation of the codec hardware device), and ioctl interfaces are no longer provided for control.
Standard function commands for the built-in Audio Codec:
k_acodec_set_gain_micl#
Description:
Left channel input analog gain control
Syntax:
Parameters:
Parameter
Input/Output
fd
Audio Codec device file descriptor
Input
ioctl number
Input
arg
Unsigned integer pointer
Input
Return Value:
Success
Non-zero
Requirements:
  • Header file: k_acodec_comm.h
  • Library file: libacodec.a
Notes:
The analog gain range is 0db, 6db, 20db, 30db.
k_acodec_set_gain_micr#
  • Description:
Right channel input analog gain control
  • Syntax:
  • Parameters:
Parameter Name
Input/Output
fd
Input
ioctl number
Input
arg
Input
  • Return Value:
Success
Non-zero
  • Requirements:
  • Notes:
k_acodec_set_adcl_volume#
  • Description:
Left channel input digital gain control.
  • Syntax:
  • Parameters:
Parameter Name
Input/Output
fd
Input
ioctl number
Input
arg
Signed float pointer
Input
  • Return Value:
Success
Non-zero
  • Requirements:
  • Notes:
The digital gain range is [-97, 30], the larger the value, the higher the volume, incremented by 0.5db.
k_acodec_set_adcr_volume#
  • Description:
Right channel input digital gain control.
  • Syntax:
  • Parameters:
Parameter Name
Input/Output
fd
Input
ioctl number
Input
arg
Input
  • Return Value:
Success
Non-zero
  • Requirements:
  • Notes:
k_acodec_set_alc_gain_micl#
  • Description:
Left channel ALC input analog gain control.
  • Syntax:
  • Parameters:
Parameter Name
Input/Output
fd
Input
ioctl number
Input
arg
Input
  • Return Value:
Success
Non-zero
  • Requirements:
  • Notes:
The analog gain range is [-18, 28.5], the larger the value, the higher the volume, incremented by 1.5db.
k_acodec_set_alc_gain_micr#
  • Description:
Right channel ALC input analog gain control.
  • Syntax:
  • Parameters:
Parameter Name
Input/Output
fd
Input
ioctl number
Input
arg
Input
  • Return Value:
Success
Non-zero
  • Requirements:
  • Notes:
k_acodec_set_gain_hpoutl#
  • Description:
Left channel output analog gain control.
  • Syntax:
  • Parameters:
Parameter Name
Input/Output
fd
Input
ioctl number
Input
arg
Input
  • Return Value:
Success
Non-zero
  • Requirements:
  • Notes:
The analog gain range is [-39, 6], the larger the value, the higher the volume, incremented by 1.5db.
k_acodec_set_gain_hpoutr#
  • Description:
Right channel output analog gain control.
  • Syntax:
  • Parameters:
Parameter Name
Input/Output
fd
Input
ioctl number
Input
arg
Input
  • Return Value:
Success
Non-zero
  • Requirements:
  • Notes:
k_acodec_set_dacl_volume#
  • Description:
Left channel output digital gain control.
  • Syntax:
  • Parameters:
Parameter Name
Input/Output
fd
Input
ioctl number
Input
arg
Input
  • Return Value:
Success
Non-zero
  • Requirements:
  • Notes:
The digital gain range is [-120, 7], the larger the value, the higher the volume, incremented by 0.5db.
k_acodec_set_dacr_volume#
  • Description:
Right channel output digital gain control.
  • Syntax:
  • Parameters:
Parameter Name
Input/Output
fd
Input
ioctl number
Input
arg
Input
  • Return Value:
Success
Non-zero
  • Requirements:
  • Notes:
k_acodec_set_micl_mute#
  • Description:
Left channel input mute control.
  • Syntax:
  • Parameters:
Parameter Name
Input/Output
fd
Input
ioctl number
Input
arg
Bool pointer
Input
  • Return Value:
Success
Non-zero
  • Requirements:
  • Notes:
Value range: K_TRUE for mute, K_FALSE to unmute.
k_acodec_set_micr_mute#
  • Description:
Right channel input mute control.
  • Syntax:
  • Parameters:
Parameter Name
Input/Output
fd
Input
ioctl number
Input
arg
Bool pointer
Input
  • Return Value:
Success
Non-zero
  • Requirements:
  • Notes:
k_acodec_set_dacl_mute#
  • Description:
Left channel output mute control.
  • Syntax:
  • Parameters:
Parameter Name
Input/Output
fd
Input
ioctl number
Input
arg
Bool pointer
Input
  • Return Value:
Success
Non-zero
  • Requirements:
  • Notes:
k_acodec_set_dacr_mute#
  • Description:
Right channel output mute control.
  • Syntax:
  • Parameters:
Parameter Name
Input/Output
fd
Input
ioctl number
Input
arg
Bool pointer
Input
  • Return Value:
Success
Non-zero
  • Requirements:
  • Notes:
k_acodec_get_gain_micl#
  • Description:
Get left channel input analog gain value.
  • Syntax:
  • Parameters:
Parameter Name
Input/Output
fd
Input
ioctl number
Input
arg
Output
  • Return Value:
Success
Non-zero
  • Requirements:
  • Notes:
The analog gain range obtained is 0db, 6db, 20db, 30db.
k_acodec_get_gain_micr#
  • Description:
Get right channel input analog gain value.
Syntax:
Parameters:
Parameter Name
Input/Output
fd
Input
ioctl number
Input
arg
Output
Return Value:
Success
Non-zero
Requirements:
Notes:
k_acodec_get_adcl_volume#
Description:
Get left channel input digital volume value.
Syntax:
Parameters:
Parameter Name
Input/Output
fd
Input
ioctl number
Input
arg
Output
Return Value:
Success
Non-zero
Requirements:
Notes:
k_acodec_get_adcr_volume#
Description:
Get right channel input digital gain control value.
Syntax:
Parameters:
Parameter Name
Input/Output
fd
Input
ioctl number
Input
arg
Output
Return Value:
Success
Non-zero
Requirements:
Notes:
k_acodec_get_alc_gain_micl#
Description:
Get left channel ALC input analog gain value.
Syntax:
int ioctl (int fd, k_acodec_get_alc_gain_micl, float *arg);
Parameters:
Parameter Name
Input/Output
fd
Input
ioctl number
Input
arg
Output
Return Value:
Success
Non-zero
Requirements:
Notes:
k_acodec_get_alc_gain_micr#
Description:
Get right channel ALC input analog gain value.
Syntax:
Parameters:
Parameter Name
Input/Output
fd
Input
ioctl number
Input
arg
Output
Return Value:
Success
Non-zero
Requirements:
Notes:
k_acodec_get_gain_hpoutl#
Description:
Get left channel output analog gain value.
Syntax:
Parameters:
Parameter Name
Input/Output
fd
Input
ioctl number
Input
arg
Output
Return Value:
Success
Non-zero
Requirements:
Notes:
k_acodec_get_gain_hpoutr#
Description:
Get right channel output analog gain control.
Syntax:
Parameters:
Parameter Name
Input/Output
fd
Input
ioctl number
Input
arg
Output
Return Value:
Success
Non-zero
Requirements:
Notes:
k_acodec_get_dacl_volume#
Description:
Get left channel output digital gain value.
Syntax:
Parameters:
Parameter Name
Input/Output
fd
Input
ioctl number
Input
arg
Output
Return Value:
Success
Non-zero
Requirements:
Notes:
k_acodec_get_dacr_volume#
Description:
Get right channel output digital gain value.
Syntax:
Parameters:
Parameter Name
Input/Output
fd
Input
ioctl number
Input
arg
Output
Return Value:
Success
Non-zero
Requirements:
Notes:
k_acodec_reset#
Description:
Volume reset: including ADC, DAC, ALC digital and analog gain.
Syntax:
int ioctl (int fd, k_acodec_reset, ...);
Parameters:
Parameter Name
Input/Output
fd
Input
k_acodec_reset
ioctl number
Input
Return Value:
Success
Non-zero
Requirements:
Notes:
Audio Encoding MAPI#
The audio encoding function module provides the following MAPI:
kd_mapi_aenc_init#
Description:
Initialize encoding channel.
Syntax:
kd_mapi_aenc_init([k_handle](#k_handle) aenc_hdl, const [k_aenc_chn_attr](#k_aenc_chn_attr) *attr);
kd_mapi_aenc_deinit#
Description:
Deinitialize encoding channel.
Parameters:
kd_mapi_aenc_deinit([k_handle](#k_handle) aenc_hdl);
kd_mapi_aenc_start#
Description:
Start encoding channel.
Syntax:
kd_mapi_aenc_start([k_handle](#k_handle) aenc_hdl);
kd_mapi_aenc_stop#
Description:
Stop encoding channel.
Syntax:
kd_mapi_aenc_stop([k_handle](#k_handle) aenc_hdl);
Description:
Register encoding callback function.
Syntax:
k_s32 kd_mapi_aenc_registercallback([k_handle](#k_handle) aenc_hdl, k_aenc_callback_s *aenc_cb);
Description:
Unregister encoding callback function.
Syntax:
k_s32 kd_mapi_aenc_unregistercallback([k_handle](#k_handle) aenc_hdl);
kd_mapi_aenc_bind_ai#
Description:
Bind AI.
Syntax:
k_s32 kd_mapi_aenc_bind_ai([k_handle](#k_handle) ai_hdl, [k_handle](#k_handle) aenc_hdl);
kd_mapi_aenc_unbind_ai#
Description:
Unbind AI.
Syntax:
k_s32 kd_mapi_aenc_unbind_ai([k_handle](#k_handle) ai_hdl, [k_handle](#k_handle) aenc_hdl);
Description:
Register external audio encoder.
Syntax:
k_s32 kd_mapi_register_ext_audio_encoder(const [k_aenc_encoder](#k_aenc_encoder) *encoder, [k_handle](#k_handle) * aencoder_hdl);
Description:
Unregister external audio encoder.
Syntax:
k_s32 kd_mapi_unregister_ext_audio_encoder([k_handle](#k_handle) aencoder_hdl);
kd_mapi_aenc_send_frame#
Description:
Send audio encoding frame.
Syntax:
k_s32 kd_mapi_aenc_send_frame([k_handle](#k_handle) ai_hdl, const [k_audio_frame](#k_audio_frame) *frame);
Audio Decoding MAPI#
The audio decoding function module provides the following MAPI:
kd_mapi_adec_init#
  • Description:
Initialize decoding channel.
  • Syntax:
kd_mapi_adec_init([k_handle](#k_handle) adec_hdl, const [k_adec_chn_attr](#k_adec_chn_attr) *attr);
kd_mapi_adec_deinit#
  • Description:
Deinitialize decoding channel.
  • Syntax:
kd_mapi_adec_deinit([k_handle](#k_handle) adec_hdl);
kd_mapi_adec_start#
  • Description:
Start decoding channel.
  • Syntax:
kd_mapi_adec_start([k_handle](#k_handle) adec_hdl);
kd_mapi_adec_stop#
  • Description:
Stop decoding channel.
  • Syntax:
kd_mapi_adec_stop([k_handle](#k_handle) adec_hdl);
  • Description:
Register decoding callback function.
  • Syntax:
k_s32 kd_mapi_adec_registercallback([k_handle](#k_handle) adec_hdl, k_adec_callback_s *adec_cb);
  • Description:
Unregister decoding callback function.
  • Syntax:
k_s32 kd_mapi_adec_unregistercallback([k_handle](#k_handle) adec_hdl);
kd_mapi_adec_bind_ao#
  • Description:
Bind AO.
  • Syntax:
k_s32 kd_mapi_adec_bind_ao([k_handle](#k_handle) ao_hdl, [k_handle](#k_handle) adec_hdl);
kd_mapi_adec_unbind_ao#
  • Description:
Unbind AO.
  • Syntax:
k_s32 kd_mapi_adec_unbind_ao([k_handle](#k_handle) ao_hdl, [k_handle](#k_handle) adec_hdl);
  • Description:
Register external audio decoder.
  • Syntax:
k_s32 kd_mapi_register_ext_audio_decoder(const [k_adec_decoder](#k_adec_decoder) *decoder, [k_handle](#k_handle) *adecoder_hdl);
  • Description:
Unregister external audio decoder.
  • Syntax:
k_s32 kd_mapi_unregister_ext_audio_decoder([k_handle](#k_handle) adecoder_hdl);
kd_mapi_adec_send_stream#
  • Description:
Send audio decoding frame.
  • Syntax:
k_s32 kd_mapi_adec_send_stream([k_handle](#k_handle) ai_hdl, const [k_audio_stream](#k_audio_stream) *stream);
Data Types#
Audio Input/Output#
The data types and structures related to audio input/output are defined as follows:
k_audio_type#
  • Description:
Defines audio input/output types.
  • Definition:
    KD_AUDIO_INPUT_TYPE_I2S = 0, // I2S input
    KD_AUDIO_INPUT_TYPE_PDM = 1, // PDM input
    KD_AUDIO_OUTPUT_TYPE_I2S = 2, // I2S output
} k_audio_type;
  • Notes:
Audio input includes I2S and PDM, while audio output only includes I2S.
  • Related Data Types and Interfaces:
k_audio_dev#
  • Description:
Defines audio devices.
  • Definition:
typedef k_u32 k_audio_dev;
  • Notes:
For the AI module, k_audio_dev can be 0 or 1, where 0 is for I2S audio input and 1 is for PDM audio input.
For the AO module, k_audio_dev is fixed at 0, which means I2S audio output.
k_ai_chn#
  • Description:
Defines AI audio channels.
  • Definition:
typedef k_u32 k_ai_chn;
  • Notes:
I2S audio input has 2 channels, with values ranging from [0, 1].
PDM audio input has 4 channels, with values ranging from [0, 3].
k_ao_chn#
  • Description:
Defines AO audio channels.
  • Definition:
typedef k_u32 k_ao_chn;
  • Notes:
I2S audio output has 2 channels, with values ranging from [0, 1].
K_MAX_AUDIO_FRAME_NUM#
  • Description:
Defines the maximum number of audio decoding buffer frames.
  • Definition:
k_audio_bit_width#
  • Description:
Defines audio sampling precision.
  • Definition:
    KD_AUDIO_BIT_WIDTH_16 = 0, /* 16-bit width */
    KD_AUDIO_BIT_WIDTH_24 = 1, /* 24-bit width */
    KD_AUDIO_BIT_WIDTH_32 = 2, /* 32-bit width */
} k_audio_bit_width;
  • Notes:
k_audio_snd_mode#
  • Description:
Defines audio channel modes.
  • Definition:
    KD_AUDIO_SOUND_MODE_MONO = 0, /* Mono */
    KD_AUDIO_SOUND_MODE_STEREO = 1, /* Stereo */
} k_audio_snd_mode;
k_audio_pdm_oversample#
  • Description:
Defines PDM oversampling.
  • Definition:
    KD_AUDIO_PDM_INPUT_OVERSAMPLE_64,
    KD_AUDIO_PDM_INPUT_OVERSAMPLE_128,
} k_audio_pdm_oversample;
k_audio_pdm_attr#
  • Description:
Defines PDM audio input attributes.
  • Definition:
    k_u32 chn_cnt; /* Channel number on FS, I2S valid value: 1/2, PDM valid value: 1/2/3/4 */
    k_audio_sample_rate rate;
    k_audio_bit_width width;
    k_audio_snd_mode mode;
    k_u32 frame_num; /* Frame number in buffer [2, K_MAX_AUDIO_FRAME_NUM] */
    k_u32 point_num_per_frame;
} k_audio_pdm_attr;
  • Members:
Member Name
chn_cnt
Supported channel count. Supports 1-4 channels, channels must be consecutive.
sample_rate
Sampling rate: supports 8k~192k
bit_width
Sampling precision: supports 16/24/32
snd_mode
Audio channel mode. Supports mono and stereo.
pdm_oversample
Oversampling: supports 32, 64, 128 times oversampling.
frame_num
Buffer frame number [2, K_MAX_AUDIO_FRAME_NUM].
point_num_per_frame
Number of sampling points per frame.
  • Notes:
k_audio_i2s_attr#
  • Description:
Defines I2S audio input attributes.
  • Definition:
    k_u32 sample_rate; /* Sample rate 8k ~192k */
    k_audio_bit_width bit_width;
    k_audio_snd_mode snd_mode; /* Mono or stereo */
    k_i2s_in_mono_channel mono_channel; /* Use mic input or headphone input */
    k_i2s_work_mode i2s_mode;  /* I2S work mode */
    k_aio_i2s_type type;
} k_audio_i2s_attr;
  • Members:
Member Name
chn_cnt
Supported channel count. Supports 1-2 channels.
sample_rate
bit_width
snd_mode
mono_channel
Mono channel source selection. 0: mic input, 1: headphone input
i2s_mode
I2S working mode: supports Philips mode, left-justified mode, right-justified mode.
frame_num
point_num_per_frame
Number of sampling points per frame [sample_rate/100, sample_rate].
i2s_type
I2S interfacing device type: internal codec or external device.
  • Notes:
The value of point_num_per_frame and sample_rate determines the interrupt frequency generated by the hardware. A high frequency can affect system performance and other tasks. It is recommended that these parameters satisfy the equation: (point_num_per_frame * 1000) / sample_rate >= 10 (100 interrupts). For example, at a sampling rate of 16000Hz, it is recommended to set the number of sampling points to be greater than or equal to 160.
k_i2s_work_mode#
  • Description:
Defines I2S working modes.
  • Definition:
    K_STANDARD_MODE = 1,
    K_RIGHT_JUSTIFYING_MODE = 2,
    K_LEFT_JUSTIFYING_MODE = 4,
} k_i2s_work_mode;
  • Notes:
k_aio_dev_attr#
  • Description:
Defines the attribute structure of audio input/output devices.
  • Definition:
    k_audio_type type;
    union {
        k_audio_pdm_attr pdm_attr;
        k_audio_i2s_attr i2s_attr;
    } kd_audio_attr;
} k_aio_dev_attr;
  • Members:
Member Name
audio_type
Audio type.
kd_audio_attr
Audio attribute settings.
  • Notes:
k_aio_i2s_type#
  • Description:
Defines I2S interfacing device types.
  • Definition:
    K_AIO_I2STYPE_EXTERN, /* AIO I2S connect external hardware */
} k_aio_i2s_type;
  • Notes:
The built-in audio codec uses I2S channel 0, while I2S channel 1 is used for external codecs.
k_audio_frame#
  • Description:
Defines audio frame structures.
  • Definition:
    void* virt_addr;
    k_u64 phys_addr;
    k_u32 len; /* data length per channel in frame */
    k_u32 pool_id;
} k_audio_frame;
  • Members:
Member Name
bit_width
Sampling precision.
snd_mode
Audio channel mode.
virt_addr
Virtual address of the audio frame data.
phys_addr
Physical address of the audio frame data.
time_stamp
Audio frame timestamp, in μs.
seq
Audio frame sequence number.
len
Audio frame length, in bytes.
pool_id
Audio frame buffer pool ID.
  • Notes:
k_ai_vqe_enable#
Description:
Defines the configuration structure for audio input voice quality enhancement.
Definition:
    k_bool aec_enable;
    k_u32  aec_echo_delay_ms; // Time difference from speaker output to mic input (100-500ms)
    k_bool agc_enable;
    k_bool ans_enable;
} k_ai_vqe_enable;
Members:
Member Name
aec_enable
Echo cancellation enable.
aec_echo_delay_ms
Echo cancellation filter length, recommended to be 100-500ms. This is the time difference from speaker output to mic input. The specific value needs fine-tuning, as improper adjustment can directly affect the echo cancellation effect.
agc_enable
Automatic gain control enable.
ans_enable
Audio noise suppression enable.
Notes:
k_i2s_in_mono_channel#
  • Description:
Defines mono channel source.
  • Definition:
    KD_I2S_IN_MONO_RIGHT_CHANNEL = 0,  // mic input
    KD_I2S_IN_MONO_LEFT_CHANNEL = 1,   // hp input
} k_i2s_in_mono_channel;
Audio Encoding/Decoding#
The data types and structures related to audio encoding/decoding are defined as follows:
k_payload_type#
  • Description:
Defines the enumeration of audio and video payload types.
  • Definition:
    K_PT_PCMU = 0,
    K_PT_1016 = 1,
    K_PT_G721 = 2,
    K_PT_GSM = 3,
    K_PT_G723 = 4,
    K_PT_DVI4_8K = 5,
    K_PT_DVI4_16K = 6,
    K_PT_LPC = 7,
    K_PT_PCMA = 8,
    K_PT_G722 = 9,
    K_PT_S16BE_STEREO = 10,
    K_PT_S16BE_MONO = 11,
    K_PT_QCELP = 12,
    K_PT_CN = 13,
    K_PT_MPEGAUDIO = 14,
    K_PT_G728 = 15,
    K_PT_DVI4_3 = 16,
    K_PT_DVI4_4 = 17,
    K_PT_G729 = 18,
    K_PT_G711A = 19,
    K_PT_G711U = 20,
    K_PT_G726 = 21,
    K_PT_G729A = 22,
    K_PT_LPCM = 23,
    K_PT_CelB = 25,
    K_PT_JPEG = 26,
    K_PT_CUSM = 27,
    K_PT_NV = 28,
    K_PT_PICW = 29,
    K_PT_CPV = 30,
    K_PT_H261 = 31,
    K_PT_MPEGVIDEO = 32,
    K_PT_MPEG2TS = 33,
    K_PT_H263 = 34,
    K_PT_SPEG = 35,
    K_PT_MPEG2VIDEO = 36,
    K_PT_AAC = 37,
    K_PT_WMA9STD = 38,
    K_PT_HEAAC = 39,
    K_PT_PCM_VOICE = 40,
    K_PT_PCM_AUDIO = 41,
    K_PT_MP3 = 43,
    K_PT_ADPCMA = 49,
    K_PT_AEC = 50,
    K_PT_X_LD = 95,
    K_PT_H264 = 96,
    K_PT_D_GSM_HR = 200,
    K_PT_D_GSM_EFR = 201,
    K_PT_D_L8 = 202,
    K_PT_D_RED = 203,
    K_PT_D_VDVI = 204,
    K_PT_D_BT656 = 220,
    K_PT_D_H263_1998 = 221,
    K_PT_D_MP1S = 222,
    K_PT_D_MP2P = 223,
    K_PT_D_BMPEG = 224,
    K_PT_MP4VIDEO = 230,
    K_PT_MP4AUDIO = 237,
    K_PT_VC1 = 238,
    K_PT_JVC_ASF = 255,
    K_PT_D_AVI = 256,
    K_PT_DIVX3 = 257,
    K_PT_AVS = 258,
    K_PT_REAL8 = 259,
    K_PT_REAL9 = 260,
    K_PT_VP6 = 261,
    K_PT_VP6F = 262,
    K_PT_VP6A = 263,
    K_PT_SORENSON = 264,
    K_PT_H265 = 265,
    K_PT_VP8 = 266,
    K_PT_MVC = 267,
    K_PT_PNG = 268,
    K_PT_AMR = 1001,
    K_PT_MJPEG = 1002,
    K_PT_AMRWB = 1003,
    K_PT_PRORES = 1006,
    K_PT_OPUS = 1007,
    K_PT_BUTT
} k_payload_type;
  • Notes:
k_aenc_encoder#
  • Description:
Defines the encoder attribute structure.
  • Definition:
    k_payload_type type;
    k_u32 max_frame_len;
    k_s32 (*func_open_encoder)(void *encoder_attr, void **encoder);
    k_s32 (*func_enc_frame)(void *encoder, const k_audio_frame *data, k_u8 *outbuf, k_u32 *out_len);
} k_aenc_encoder;
  • Members:
Member Name
Encoding protocol type.
max_frame_len
Maximum stream length.
name
Encoder name.
func_open_encoder
Function pointer to open encoder.
func_enc_frame
Function pointer to encode frame.
func_close_encoder
Function pointer to close encoder.
  • Notes:
k_aenc_chn_attr#
  • Description:
Defines the encoder channel attribute structure.
  • Definition:
    k_u32 buf_size; // buffer size [2, K_MAX_AUDIO_FRAME_NUM]
} k_aenc_chn_attr;
  • Members:
Member Name
Audio encoding protocol type.
point_num_per_frame
Frame length corresponding to the audio encoding protocol (encoding can be performed if the received audio frame length is less than or equal to this frame length).
buf_size
Audio encoding buffer size. Range: [2, K_MAX_AUDIO_FRAME_NUM], in frames.
  • Notes:
AENC_MAX_CHN_NUMS#
  • Description:
Defines the maximum number of encoding channels.
  • Definition:
#define AENC_MAX_CHN_NUMS 4
  • Notes:
K_MAX_ENCODER_NAME_LEN#
  • Description:
Defines the maximum length of the audio encoder name.
  • Definition:
  • Notes:
k_aenc_chn#
  • Description:
Defines the encoding channel type.
  • Definition:
typedef k_u32 k_aenc_chn;
  • Notes:
k_audio_stream#
  • Description:
Defines the stream structure.
  • Definition:
    k_u64 phys_addr; /* the physical address of stream */
    k_u32 len; /* stream length, in bytes */
    k_u64 time_stamp; /* frame timestamp */
    k_u32 seq; /* frame sequence number, if stream is not a valid frame, seq is 0 */
} k_audio_stream;
  • Members:
Member Name
stream
Pointer to the audio stream data.
phys_addr
Physical address of the audio stream.
len
Length of the audio stream, in bytes.
time_stamp
Timestamp of the audio stream.
seq
Sequence number of the audio stream.
  • Notes:
k_adec_chn_attr#
  • Description:
Defines the decoder channel attribute structure.
  • Definition:
    k_payload_type payload_type;
    k_u32 buf_size; /* buffer size [2~K_MAX_AUDIO_FRAME_NUM] */
} k_adec_chn_attr;
  • Members:
Member Name
payload_type
Audio decoding protocol type.
point_num_per_frame
Frame length corresponding to the audio decoding protocol.
buf_size
Audio decoding buffer size. Range: [2, K_MAX_AUDIO_FRAME_NUM], in frames.
  • Notes:
Some attributes of audio decoding need to match the attributes of the output device, such as sampling rate, frame length (number of sampling points per frame), etc.
k_adec_decoder#
  • Description:
Defines the decoder attribute structure.
  • Definition:
    k_s32 (*func_open_decoder)(void *decoder_attr, void **decoder);
    k_s32 (*func_dec_frame)(void *decoder, k_u8 **inbuf, k_s32 *left_byte, k_u16 *outbuf, k_u32 *out_len, k_u32 *chns);
} k_adec_decoder;
  • Members:
Member Name
payload_type
Decoding protocol type.
name
Decoder name.
func_open_decoder
Function pointer to open decoder.
func_dec_frame
Function pointer to decode frame.
func_get_frame_info
Function pointer to get audio frame information.
func_close_decoder
Function pointer to close decoder.
func_reset_decoder
Function pointer to reset decoder.
  • Notes:
K_MAX_DECODER_NAME_LEN#
  • Description:
Defines the maximum length of the audio decoder name.
  • Definition:
  • Notes:
ADEC_MAX_CHN_NUMS#
  • Description:
Defines the maximum number of decoding channels.
  • Definition:
#define ADEC_MAX_CHN_NUMS 4
  • Notes:
k_adec_chn#
  • Description:
Defines the decoding channel type.
  • Definition:
typedef k_u32 k_adec_chn;
  • Notes:
MAPI#
The data types and structures related to audio MAPI are defined as follows:
k_handle#
  • Description:
Defines the operation handle.
  • Definition:
typedef k_u32 k_handle;
Audio Input API Error Codes#
Error Code
Macro Definition
0xA0158001
K_ERR_AI_INVALID_DEVID
Invalid audio input device number
0xA0158002
K_ERR_AI_INVALID_CHNID
Invalid audio input channel number
0xA0158003
K_ERR_AI_ILLEGAL_PARAM
Invalid audio input parameter setting
0xA0158004
K_ERR_AI_NOT_ENABLED
Audio input device or channel not enabled
0xA0158005
K_ERR_AI_NULL_PTR
Null pointer error in input parameters
0xA0158006
K_ERR_AI_NOT_CFG
Audio input device attributes not set
0xA0158007
K_ERR_AI_NOT_SUPPORT
Operation not supported
0xA0158008
K_ERR_AI_NOT_PERM
Operation not permitted
0xA0158009
K_ERR_AI_NO_MEM
Failed to allocate memory
0xA015800A
K_ERR_AI_NO_BUF
Insufficient audio input buffer
0xA015800B
K_ERR_AI_BUF_EMPTY
Audio input buffer is empty
0xA015800C
K_ERR_AI_BUF_FULL
Audio input buffer is full
0xA015800D
K_ERR_AI_NOT_READY
Audio input system not initialized
0xA015800E
K_ERR_AI_BUSY
Audio input system is busy
Audio Output API Error Codes#
Error Code
Macro Definition
0xA0159001
K_ERR_AO_INVALID_DEV_ID
Invalid audio output device number
0xA0159002
K_ERR_AO_INVALID_CHN_ID
Invalid audio output channel number
0xA0159003
K_ERR_AO_ILLEGAL_PARAM
Invalid audio output parameter setting
0xA0159004
K_ERR_AO_NOT_ENABLED
Audio output device or channel not enabled
0xA0159005
K_ERR_AO_NULL_PTR
Null pointer error in output
0xA0159006
K_ERR_AO_NOT_CFG
Audio output device attributes not set
0xA0159007
K_ERR_AO_NOT_SUPPORT
0xA0159008
K_ERR_AO_NOT_PERM
0xA0159009
K_ERR_AO_NO_MEM
Insufficient system memory
0xA015900A
K_ERR_AO_NO_BUF
Insufficient audio output buffer
0xA015900B
K_ERR_AO_BUF_EMPTY
Audio output buffer is empty
0xA015900C
K_ERR_AO_BUF_FULL
Audio output buffer is full
0xA015900D
K_ERR_AO_NOT_READY
Audio output system not initialized
0xA015900E
K_ERR_AO_BUSY
Audio output system is busy
