1. 功能介绍#
2. 模块依赖#
2.1 操作系统#
2.2 硬件环境#
表 2-1 飞线关系
Link1
Link2
Link3
Link4
Link5
K230排针
J5 PIN16 (5V)
J8 PIN9 (GPIO34)
WiFi排针
J6 PIN1 (5V)
J2 PIN3 (SDIO_INT_OUT)
J2 PIN4 (TX)
J2 PIN5 (RX)
J2 PIN6 (GND)
TTL-USB
RX
TX
GND
3. 模块配置#
3.1 设备树修改#
3.1.1 配置引脚function#
&iomux {
pinctrl-names = "default";
pinctrl-0 = <&pins>;
pins: iomux_pins {
pinctrl-single,pins = <
3.1.2 配置GPIO控制器#
gpio52: gpio52@9140c000 {
#address-cells = <1>;
#size-cells = <0>;
interrupt-controller;
interrupt-parent = <&intc>;
#interrupt-cells = <2>;
port52: gpio-controller@0 {
gpio-controller;
#gpio-cells = <2>;
nr-gpios = <1>;
reg-bank = <0>;
id = <52>;
3.1.3 配置SDHCI1参数#
sdcard: sdhci1@91581000 {
interrupts = <144>;
clock-names = "core", "bus";
max-frequency = <50000000>;
bus-width = <4>;
//cd-gpios = <>;
no-1-8-v;
cap-sd-highspeed;
sdhci,auto-cmd12;
status = "okay";
3.2 内核配置项#
使能kprobes:
|| [*] Kprobes
将cfg80211编入内核注意需要选中 cfg80211 wireless extensions compatibility
 --- Wireless
  <*> cfg80211 - wireless configuration API
  [ ] nl80211 testmode command
  [ ] enable developer warnings
  [ ] cfg80211 certification onus
  [*] enable powersave by default
  [ ] cfg80211 DebugFS entries
  [*] support CRDA
  [*] cfg80211 wireless extensions compatibility
  [ ] lib80211 debugging messages
  < > Generic IEEE 802.11 Networking Stack (mac80211)
 --- Wireless LAN
  [ ] mac80211-based legacy WDS support
  [ ] ADMtek devices
  [*] Aich devices
  <M> Aich AiW4211LV10 (SDIO) support
  [ ] Atheros/Qualcomm devices
  [ ] Atmel devices
  [ ] Broadcom devices
  [ ] Cisco devices
  [ ] Intel devices
  [*] Intersil devices
  <*> IEEE 802.11 for Host AP (Prism2/2.5/3 and WEP/TKIP/CCMP)
  [ ] Support downloading firmware images with Host AP driver
  [ ] Marvell devices
  [ ] MediaTek devices
  [ ] Microchip devices
3.3 SDIO主控增加扫描接口#
if (mmc == NULL) {
return -EINVAL;
mmc_detect_change(mmc, 0);
if (!IS_ERR(priv->bus_clk))
if (err)
goto err_clk;
4. 模块编译#
5. 模块启动#
5.1 WiFi固件#
5.2 驱动加载#
5.3 网络配置#
6. API参考#
6.1 config接口#
6.1.1 API#
配置WiFi工作参数:
  • 配置目标AP的名称、密码、认证及加密方式
  • 配置WiFi休眠等级,苏醒周期以及可唤醒的gpio
  • 配置tcp keepalive时间参数等
6.1.2 数据结构#
6.1.2.1 wifi_config_t#
unsigned int config_mask;
wifi_sleep_t sleep;
wifi_connect_t conn;
wifi_keepalive_t keepalive;
} wifi_config_t;
表 6-1 wifi_config_t结构体成员
成员
config_mask
配置目标项掩码,使能或屏蔽目标项,例如全部配置则:config_mask = CFG_MASK_SLEEP|CFG_MASK_CONNECT|CFG_MASK_KEEPALIVE; CFG_MASK_SLEEP:配置休眠参数,CFG_MASK_CONNECT:配置AP连接参数,CFG_MASK_KEEPALIVE:配置tcp keepalive参数
sleep
休眠参数
conn
AP连接参数
keepalive
tcp keepalive参数
6.1.2.2 wifi_sleep_t#
unsigned int level;
#define WIFI_SLEEP_LIGHT 1
#define WIFI_SLEEP_DEEP 2
#define WIFI_SLEEP_ULTRA 3
unsigned int period;
union
struct {
unsigned int gpio0_wake:1;
unsigned int gpio1_wake:1;
unsigned int gpio2_wake:1;
unsigned int gpio3_wake:1;
unsigned int gpio4_wake:1;
unsigned int gpio5_wake:1;
unsigned int gpio6_wake:1;
unsigned int gpio7_wake:1;
unsigned int gpio8_wake:1;
unsigned int gpio9_wake:1;
unsigned int gpio10_wake:1;
unsigned int gpio11_wake:1;
unsigned int gpio12_wake:1;
unsigned int gpio13_wake:1;
unsigned int gpio14_wake:1;
unsigned int wake_gpios;
} wifi_sleep_t;
表 6-2 wifi_sleep_t结构体成员
成员
level
period
wake_gpios
6.1.2.3 wifi_connect_t#
ext_wifi_auth_mode auth;
ext_wifi_pairwise pairwise;
} wifi_connect_t;
表 6-3 wifi_connect_t结构体成元
ssid
AP名称
auth
Key
AP密码
bssid
AP bssid,一般为AP mac地址
pairwise
6.1.2.4 wifi_keepalive_t#
unsigned char svrip[16];
unsigned short svrport;
} wifi_keepalive_t;
表 6-4 wifi_keepalive_t结构体成员
svrip
server端ip地址
svrport
server端端口号
tcp_keepalive_time
TCP层keepalive心跳包常规发送周期,秒
tcp_keepalive_intvl
TCP层keepalive心跳包无回应之后新的发送周期,秒
tcp_keepalive_probes
heartbeat_intvl
应用层心跳包发送周期,秒
heartbeat_probes
6.2 sleep接口#
int kd_wifi_sleep(void)
7. 基本性能测试#
7.1 吞吐量测试#
server:iperf -s -i 2
表 7-1 TCP吞吐量粗测数据
WiFi ROLE
Bandwidth(Mbits/sec)
client
12.2
server
20.3
server:iperf -s -i 2 -u
表 7-2 UDP吞吐量粗测数据
WiFi ROLE
Jitter(ms)
Lost/Total Datagrams
client
17.8
1.341
1571/455457 (0.34%)
server
21.0
1.064
1/534990 (0.00019%)
7.2 文件传输测试#
