YOLO Battle#
YOLOv5 Fruit Classification#
Building YOLOv5 Source Code and Training Environment#
For building the YOLOv5 training environment, please refer to ultralytics/yolov5: YOLOv5 🚀 in PyTorch > ONNX > CoreML > TFLite (github.com).
cd yolov5
If you have already set up the environment, you can skip this step.
Preparing Training Data#
Please download the provided sample dataset. The sample dataset contains classification, detection and segmentation datasets provided for the scenes using three types of fruits (apple, banana, orange). Unzip the dataset to yolov5 in the directory, please use fruits_cls as a data set for fruit classification tasks. The sample dataset also contains a desktop signature scene dataset for rotation object detection yolo_pen_obb, the task is in k230 YOLOv5 not supported in the module.
If you want to use your own dataset for training, you can download X-AnyLabeling after completing the annotation, the classification task data does not require tool annotation, and only the directory can be divided according to the format. Convert the annotated data to yolov5 the officially supported training data format is carried out for subsequent training.
cd yolov5
wget https://kendryte-download.canaan-creative.com/developer/k230/yolo_files/datasets.zip
unzip datasets.zip
If you have already downloaded the data, you can skip this step.
Training a Fruit Classification Model with YOLOv5#
Execute the command in the yolov5 directory to train a three - class fruit classification model using yolov5:
python classify/train.py --model yolov5n-cls.pt --data datasets/fruits_cls --epochs 100 --batch-size 8 --imgsz 224 --device '0'
Converting the Fruit Classification kmodel#
For model conversion, the following libraries need to be installed in the training environment:
# Linux platform: nncase and nncase - kpu can be installed online, and dotnet - 7 needs to be installed for nncase - 2.x
pip install --upgrade pip
pip install nncase==2.9.0
pip install nncase-kpu==2.9.0
# Windows platform: Please install dotnet - 7 and add it to the environment variables. nncase can be installed online using pip, but the nncase - kpu library needs to be installed offline. Download nncase_kpu-2.*-py2.py3-none-win_amd64.whl from https://github.com/kendryte/nncase/releases.
# Enter the corresponding Python environment and use pip to install in the download directory of nncase_kpu-2.*-py2.py3-none-win_amd64.whl
# In addition to nncase and nncase - kpu, the following libraries are also used in the script:
pip install onnx
pip install onnxruntime
pip install onnxsim
Download the script tool, unzip the model conversion script tool test_yolov5.zip to the yolov5 directory;
unzip test_yolov5.zip
According to the following commands, first export the pt model under runs/train-cls/exp/weights to an onnx model, and then convert it to a kmodel model:
# Export onnx, please select the path of the pt model by yourself
cd test_yolov5/classify
# Convert kmodel, please select the path of the onnx model by yourself. The generated kmodel is in the same directory as the onnx model
python to_kmodel.py --target k230 --model ../../runs/train-cls/exp/weights/best.onnx --dataset../test --input_width 224 --input_height 224 --ptq_option 0
cd ../../
💡 Parameter description of model conversion script (to_kmodel.py):
Parameter name |
describe |
illustrate |
type |
target |
Target platform |
The optional option is k230/CPU, corresponding to k230 chip; |
str |
model |
Model path |
The path of the ONNX model to be converted; |
str |
dataset |
Calibration picture collection |
Image data used during model conversion, used in the quantization stage |
str |
input_width |
Input width |
Width of model input |
int |
input_height |
Enter height |
The height of the model input |
int |
ptq_option |
Quantitative method |
The quantification method of data and weights is 0 as [uint8,uint8], 1 as [uint8,int16], and 2 as [int16,uint8] |
0/1/2 |
Deploying the Model on K230 Using MicroPython#
Burning the Image and Installing CanMV IDE#
💡 Firmware introduction: Please github download the latest ones according to your development board type PreRelease firmware to ensure Latest features being supported! Or use the latest code to compile the firmware yourself. See the tutorial:Firmware Compilation.
Download and install CanMV IDE (Download link:CanMV IDE download), write code in the IDE and run it.
Copying Model Files#
Connect the IDE and copy the converted model and test images to the CanMV/data directory. This path can be customized, and you only need to modify the corresponding path when writing the code.
YOLOv5 Module#
The YOLOv5 class integrates three tasks of YOLOv5, including classification, detection, and segmentation; it supports two inference modes, including image and video stream; this class encapsulates the kmodel inference process of YOLOv5.
Import Method
from libs.YOLO import YOLOv5
Parameter Description
Parameter Name |
Instructions |
Type |
task_type |
Task type |
Supports three types of tasks, optional values are ‘classify’ / ‘detect’ /’segment’; |
str |
mode |
Inference mode |
Supports two inference modes, optional values are ‘image’ / ‘video’, ‘image’ means inferring images, and ‘video’ means inferring real - time video streams captured by the camera; |
str |
kmodel_path |
kmodel path |
The path of the kmodel copied to the development board; |
str |
labels |
List of class labels |
Label names of different classes; |
list[str] |
rgb888p_size |
Inference frame resolution |
Resolution of the current inference frame, such as [1920,1080], [1280,720], [640,640]; |
list[int] |
model_input_size |
Model input resolution |
Input resolution of the YOLOv5 model during training, such as [224,224], [320,320], [640,640]; |
list[int] |
display_size |
Display resolution |
Set when the inference mode is ‘video’, supports hdmi([1920,1080]) and lcd([800,480]); |
list[int] |
conf_thresh |
Confidence threshold |
Class confidence threshold for classification tasks, and object confidence threshold for detection and segmentation tasks, such as 0.5; |
float【0~1】 |
nms_thresh |
NMS threshold |
Non - maximum suppression threshold, required for detection and segmentation tasks; |
float【0~1】 |
mask_thresh |
Mask threshold |
Binarization threshold for segmenting objects in the detection box in segmentation tasks; |
float【0~1】 |
max_boxes_num |
Maximum number of detection boxes |
The maximum number of detection boxes allowed to be returned in one frame of image; |
int |
debug_mode |
Debug mode |
Whether the timing function is effective, optional values are 0/1, 0 means no timing, 1 means timing; |
int【0/1】 |
Deploying the Model to Implement Image Inference#
For image inference, please refer to the following code. Modify the defined parameter variables in __main__ according to the actual situation;
from libs.Utils import *
import os, sys, gc
import ulab.numpy as np
import image
# The following are examples only. Please modify them according to your own test images, model path, label names, and model input size.
img_path = "/data/test_apple.jpg"
kmodel_path = "/data/best.kmodel"
labels = ["apple", "banana", "orange"]
model_input_size = [224, 224]
confidence_threshold = 0.5
img, img_ori = read_image(img_path)
rgb888p_size = [img.shape[2], img.shape[1]]
# Initialize YOLOv5 instance
yolo = YOLOv5(task_type="classify", mode="image", kmodel_path=kmodel_path, labels=labels, rgb888p_size=rgb888p_size, model_input_size=model_input_size, conf_thresh=confidence_threshold, debug_mode=0)
yolo.config_preprocess()
res = yolo.run(img)
yolo.draw_result(res, img_ori)
yolo.deinit()
gc.collect()
Deploying the Model to Implement Video Inference#
For video inference, please refer to the following code. Modify the defined variables in __main__ according to the actual situation;
import os, sys, gc
import image
# The following are examples only. Please modify them according to your own model path, label names, and model input size.
# Add display mode, default is hdmi, options are hdmi/lcd/lt9611/st7701/hx8399.
# hdmi defaults to lt9611 with resolution 1920*1080; lcd defaults to st7701 with resolution 800*480.
display_mode = "lcd"
rgb888p_size = [640, 360]
pl = PipeLine(rgb888p_size=rgb888p_size, display_mode=display_mode)
pl.create()
yolo = YOLOv5(task_type="classify", mode="video", kmodel_path=kmodel_path, labels=labels, rgb888p_size=rgb888p_size, model_input_size=model_input_size, display_size=display_size, conf_thresh=confidence_threshold, debug_mode=0)
img = pl.get_frame()
res = yolo.run(img)
yolo.draw_result(res, pl.osd_img)
pl.show_image()
gc.collect()
yolo.deinit()
pl.destroy()
YOLOv5 Fruit Detection#
cd yolov5
Please download the provided sample dataset. The sample dataset contains classification, detection and segmentation datasets provided for the scenes using three types of fruits (apple, banana, orange). Unzip the dataset to yolov5 in the directory, please use fruits_yolo as a data set for fruit detection tasks. The sample dataset also contains a desktop signature scene dataset for rotation object detection yolo_pen_obb, the task is in k230 YOLOv5 not supported in the module.
If you want to use your own dataset for training, you can download X-AnyLabeling complete the annotation. Convert the marked data to yolov5 the officially supported training data format is carried out for subsequent training.
cd yolov5
unzip datasets.zip
Training a Fruit Detection Model with YOLOv5#
Execute the command in the yolov5 directory to train a three - class fruit detection model using yolov5:
python train.py --weight yolov5n.pt --cfg models/yolov5n.yaml --data datasets/fruits_yolo.yaml --epochs 300 --batch-size 8 --imgsz 320 --device '0'
Converting the Fruit Detection kmodel#
pip install onnx
pip install onnxsim
Download the script tool, and unzip the model conversion script tool test_yolov5.zip to the yolov5 directory;
According to the following commands, first export the pt model under runs/train/exp/weights to an onnx model, and then convert it to a kmodel model:
python export.py --weight runs/train/exp/weights/best.pt --imgsz 320 --batch 1 --include onnx
cd test_yolov5/detect
# Convert kmodel, please customize the path of the onnx model. The generated kmodel is in the same directory as the onnx model
python to_kmodel.py --target k230 --model ../../runs/train/exp/weights/best.onnx --dataset../test --input_width 320 --input_height 320 --ptq_option 0
cd ../../
Parameter name |
describe |
illustrate |
type |
target |
Target platform |
str |
model |
Model path |
str |
dataset |
str |
input_width |
Input width |
int |
input_height |
Enter height |
int |
ptq_option |
0/1/2 |
YOLOv5 Module#
Import Method
Parameter Name |
Instructions |
Type |
task_type |
Task type |
str |
mode |
Inference mode |
str |
kmodel_path |
kmodel path |
str |
labels |
list[str] |
rgb888p_size |
list[int] |
model_input_size |
list[int] |
display_size |
list[int] |
conf_thresh |
float [0 - 1] |
nms_thresh |
NMS threshold |
float [0 - 1] |
mask_thresh |
Mask threshold |
float [0 - 1] |
max_boxes_num |
int |
debug_mode |
Debug mode |
int [0/1] |
import os, sys, gc
import image
# The following are examples only. Please modify them according to your own test image, model path, label names, and model input size.
img_path = "/data/test.jpg"
model_input_size = [320, 320]
nms_threshold = 0.45
yolo = YOLOv5(task_type="detect", mode="image", kmodel_path=kmodel_path, labels=labels, rgb888p_size=rgb888p_size, model_input_size=model_input_size, conf_thresh=confidence_threshold, nms_thresh=nms_threshold, max_boxes_num=50, debug_mode=0)
res = yolo.run(img)
yolo.deinit()
gc.collect()
import os, sys, gc
import image
confidence_threshold = 0.8
pl.create()
yolo = YOLOv5(task_type="detect", mode="video", kmodel_path=kmodel_path, labels=labels, rgb888p_size=rgb888p_size, model_input_size=model_input_size, display_size=display_size, conf_thresh=confidence_threshold, nms_thresh=nms_threshold, max_boxes_num=50, debug_mode=0)
res = yolo.run(img)
pl.show_image()
gc.collect()
yolo.deinit()
pl.destroy()
YOLOv5 Fruit Segmentation#
Setting up the YOLOv5 Source Code and Training Environment#
For setting up the YOLOv5 training environment, please refer to ultralytics/yolov5: YOLOv5 🚀 in PyTorch > ONNX > CoreML > TFLite (github.com).
cd yolov5
Preparing the Training Data#
Please download the provided sample dataset. The sample dataset contains classification, detection and segmentation datasets provided for the scenes using three types of fruits (apple, banana, orange). Unzip the dataset to yolov5 in the directory, please use fruits_seg as a dataset for the fruit segmentation task. The sample dataset also contains a desktop signature scene dataset for rotation object detection yolo_pen_obb, the task is in k230 YOLOv5 not supported in the module.
cd yolov5
unzip datasets.zip
Training a Fruit Segmentation Model with YOLOv5#
Execute the command in the yolov5 directory to train a three - class fruit segmentation model using yolov5:
python segment/train.py --weight yolov5n-seg.pt --cfg models/segment/yolov5n-seg.yaml --data datasets/fruits_seg.yaml --epochs 100 --batch-size 8 --imgsz 320 --device '0'
Converting the Fruit Segmentation kmodel#
# Besides nncase and nncase - kpu, the other libraries used in the script include:
pip install onnx
pip install onnxsim
Download the script tool and unzip the model conversion script tool test_yolov5.zip into the yolov5 directory.
Follow the following commands to first export the model under runs/train-seg/exp/weights to an onnx model, and then convert it to a kmodel model:
python export.py --weight runs/train-seg/exp/weights/best.pt --imgsz 320 --batch 1 --include onnx
cd test_yolov5/segment
# Convert kmodel. Please customize the path of the onnx model. The generated kmodel is in the same directory as the onnx model.
python to_kmodel.py --target k230 --model ../../runs/train-seg/exp/weights/best.onnx --dataset../test --input_width 320 --input_height 320 --ptq_option 0
cd ../../
Parameter name |
describe |
illustrate |
type |
target |
Target platform |
str |
model |
Model path |
str |
dataset |
str |
input_width |
Input width |
int |
input_height |
Enter height |
int |
ptq_option |
0/1/2 |
Copying the Model Files#
The YOLOv5 Module#
The YOLOv5 class integrates three tasks of YOLOv5, including classification (classify), detection (detect), and segmentation (segment); it supports two inference modes, including image (image) and video stream (video); this class encapsulates the kmodel inference process of YOLOv5.
Import Method
Parameter Name |
Instructions |
Type |
task_type |
Task type |
Supports three types of tasks, with optional values ‘classify’ / ‘detect’ /’segment’; |
str |
mode |
Inference mode |
Supports two inference modes, with optional values ‘image’ / ‘video’. ‘image’ means inferring images, and ‘video’ means inferring real - time video streams captured by the camera; |
str |
kmodel_path |
kmodel path |
str |
labels |
list[str] |
rgb888p_size |
list[int] |
model_input_size |
list[int] |
display_size |
Set when the inference mode is ‘video’, supporting hdmi([1920,1080]) and lcd([800,480]); |
list[int] |
conf_thresh |
float [0 - 1] |
nms_thresh |
NMS threshold |
float [0 - 1] |
mask_thresh |
Mask threshold |
float [0 - 1] |
max_boxes_num |
The maximum number of detection boxes allowed to be returned in one frame of an image; |
int |
debug_mode |
Debug mode |
Whether the timing function is effective, with optional values 0/1. 0 means no timing, and 1 means timing; |
int [0 - 1] |
Deploying the Model for Image Inference#
For image inference, please refer to the following code. Modify the defined parameter variables in __main__ according to the actual situation:
import os, sys, gc
import image
mask_threshold = 0.5
yolo = YOLOv5(task_type="segment", mode="image", kmodel_path=kmodel_path, labels=labels, rgb888p_size=rgb888p_size, model_input_size=model_input_size, conf_thresh=confidence_threshold, nms_thresh=nms_threshold, mask_thresh=mask_threshold, max_boxes_num=50, debug_mode=0)
res = yolo.run(img)
yolo.deinit()
gc.collect()
Deploying the Model for Video Inference#
For video inference, please refer to the following code. Modify the defined variables in __main__ according to the actual situation:
import os, sys, gc
import image
rgb888p_size = [320, 320]
pl.create()
yolo = YOLOv5(task_type="segment", mode="video", kmodel_path=kmodel_path, labels=labels, rgb888p_size=rgb888p_size, model_input_size=model_input_size, display_size=display_size, conf_thresh=confidence_threshold, nms_thresh=nms_threshold, mask_thresh=mask_threshold, max_boxes_num=50, debug_mode=0)
res = yolo.run(img)
pl.show_image()
gc.collect()
yolo.deinit()
pl.destroy()
YOLOv8 Fruit Classification#
Setting up YOLOv8 Source Code and Training Environment#
For setting up the YOLOv8 training environment, please refer to ultralytics/ultralytics: Ultralytics YOLO 🚀 (github.com).
pip install ultralytics
You can create a new folder first yolov8, please download the provided sample dataset. The sample dataset contains classification, detection and segmentation datasets provided for the scenes using three types of fruits (apple, banana, orange). Unzip the dataset to yolov8 in the directory, please use fruits_cls as a data set for fruit classification tasks. The sample dataset also contains a desktop signature scene dataset for rotation object detection yolo_pen_obb.
If you want to use your own dataset for training, you can download X-AnyLabeling after completing the annotation, the classification task data does not require tool annotation, and only the directory can be divided according to the format. Convert the annotated data to yolov8 the officially supported training data format is carried out for subsequent training.
cd yolov8
unzip datasets.zip
Training a Fruit Classification Model with YOLOv8#
Execute the command in the yolov8 directory to train a three - class fruit classification model using yolov8:
yolo classify train data=datasets/fruits_cls model=yolov8n-cls.pt epochs=100 imgsz=224
pip install onnx
pip install onnxsim
Download the script tool and unzip the model - conversion script tool test_yolov8.zip into the yolov8 directory.
unzip test_yolov8.zip
Follow the following commands to first export the pt model under runs/classify/train/weights to an onnx model, and then convert it to a kmodel model:
yolo export model=runs/classify/train/weights/best.pt format=onnx imgsz=224
cd test_yolov8/classify
# Convert kmodel, please select the path of the onnx model by yourself. The generated kmodel is in the same directory as the onnx model.
python to_kmodel.py --target k230 --model ../../runs/classify/train/weights/best.onnx --dataset../test --input_width 224 --input_height 224 --ptq_option 0
cd ../../
Parameter name |
describe |
illustrate |
type |
target |
Target platform |
str |
model |
Model path |
str |
dataset |
str |
input_width |
Input width |
int |
input_height |
Enter height |
int |
ptq_option |
0/1/2 |
YOLOv8 Module#
The YOLOv8 class integrates four tasks of YOLOv8, including classification (classify), detection (detect), segmentation (segment) and obb; it supports two inference modes, including image (image) and video stream (video); this class encapsulates the kmodel inference process of YOLOv8.
Import Method
from libs.YOLO import YOLOv8
Parameter Name |
Instructions |
Type |
task_type |
Task type |
Supports four types of tasks, with optional values ‘classify’ / ‘detect’ /’segment’/’obb’; |
str |
mode |
Inference mode |
str |
kmodel_path |
kmodel path |
str |
labels |
list[str] |
rgb888p_size |
list[int] |
model_input_size |
Input resolution of the YOLOv8 model during training, such as [224,224], [320,320], [640,640]; |
list[int] |
display_size |
list[int] |
conf_thresh |
float [0 - 1] |
nms_thresh |
NMS threshold |
float [0 - 1] |
mask_thresh |
Mask threshold |
float [0 - 1] |
max_boxes_num |
int |
debug_mode |
Debug mode |
int [0 - 1] |
import os, sys, gc
import image
# Initialize YOLOv8 instance
yolo = YOLOv8(task_type="classify", mode="image", kmodel_path=kmodel_path, labels=labels, rgb888p_size=rgb888p_size, model_input_size=model_input_size, conf_thresh=confidence_threshold, debug_mode=0)
res = yolo.run(img)
yolo.deinit()
gc.collect()
import os, sys, gc
import image
# Initialize PipeLine
pl.create()
yolo = YOLOv8(task_type="classify", mode="video", kmodel_path=kmodel_path, labels=labels, rgb888p_size=rgb888p_size, model_input_size=model_input_size, display_size=display_size, conf_thresh=confidence_threshold, debug_mode=0)
# Process each frame
res = yolo.run(img)
pl.show_image()
gc.collect()
yolo.deinit()
pl.destroy()
YOLOv8 Fruit Detection#
You can create a new folder first yolov8, please download the provided sample dataset. The sample dataset contains classification, detection and segmentation datasets provided for the scenes using three types of fruits (apple, banana, orange). Unzip the dataset to yolov8 in the directory, please use fruits_yolo as a data set for fruit detection tasks. The sample dataset also contains a desktop signature scene dataset for rotation object detection yolo_pen_obb.
If you want to use your own dataset for training, you can download X-AnyLabeling complete the annotation. Convert the marked data to yolov8 the officially supported training data format is carried out for subsequent training.
cd yolov8
unzip datasets.zip
Training a Fruit Detection Model with YOLOv8#
Execute the command in the yolov8 directory to train a three - class fruit detection model using yolov8:
yolo detect train data=datasets/fruits_yolo.yaml model=yolov8n.pt epochs=300 imgsz=320
pip install onnx
pip install onnxsim
Follow the following commands to first export the pt model under runs/detect/exp/weights to an onnx model, and then convert it to a kmodel model:
cd test_yolov8/detect
python to_kmodel.py --target k230 --model ../../runs/detect/train/weights/best.onnx --dataset../test --input_width 320 --input_height 320 --ptq_option 0
cd ../../
Parameter name |
describe |
illustrate |
type |
target |
Target platform |
str |
model |
Model path |
str |
dataset |
str |
input_width |
Input width |
int |
input_height |
Enter height |
int |
ptq_option |
0/1/2 |
YOLOv8 Module#
The YOLOv8 class integrates four tasks of YOLOv8, namely classification (classify), detection (detect), segmentation (segment) and obb. It supports two inference modes, namely image (image) and video stream (video). This class encapsulates the kmodel inference process of YOLOv8.
Import Method
Parameter Name |
Instructions |
Type |
task_type |
Task type |
Supports four types of tasks, with optional values ‘classify’/ ‘detect’/’segment’/’obb’; |
str |
mode |
Inference mode |
Supports two inference modes, with optional values ‘image’ or ‘video’. ‘Image’ means inferring images, and ‘video’ means inferring real - time video streams captured by the camera; |
str |
kmodel_path |
kmodel path |
str |
labels |
list[str] |
rgb888p_size |
Resolution of the current inference frame, such as [1920, 1080], [1280, 720], or [640, 640]; |
list[int] |
model_input_size |
Input resolution of the YOLOv8 model during training, such as [224, 224], [320, 320], or [640, 640]; |
list[int] |
display_size |
Set when the inference mode is ‘video’, supporting hdmi([1920, 1080]) and lcd([800, 480]); |
list[int] |
conf_thresh |
float [0 - 1] |
nms_thresh |
NMS threshold |
float [0 - 1] |
mask_thresh |
Mask threshold |
float [0 - 1] |
max_boxes_num |
int |
debug_mode |
Debug mode |
Whether the timing function is effective, with optional values 0 or 1. 0 means no timing, and 1 means timing; |
int [0 - 1] |
import os, sys, gc
import image
yolo = YOLOv8(task_type="detect", mode="image", kmodel_path=kmodel_path, labels=labels, rgb888p_size=rgb888p_size, model_input_size=model_input_size, conf_thresh=confidence_threshold, nms_thresh=nms_threshold, max_boxes_num=50, debug_mode=0)
res = yolo.run(img)
yolo.deinit()
gc.collect()
import os, sys, gc
import image
pl.create()
yolo = YOLOv8(task_type="detect", mode="video", kmodel_path=kmodel_path, labels=labels, rgb888p_size=rgb888p_size, model_input_size=model_input_size, display_size=display_size, conf_thresh=confidence_threshold, nms_thresh=nms_threshold, max_boxes_num=50, debug_mode=0)
res = yolo.run(img)
pl.show_image()
gc.collect()
yolo.deinit()
pl.destroy()
YOLOv8 Fruit Segmentation#
For setting up the training environment of YOLOv8, please refer to ultralytics/ultralytics: Ultralytics YOLO 🚀 (github.com).
You can create a new folder first yolov8, please download the provided sample dataset. The sample dataset contains classification, detection and segmentation datasets provided for the scenes using three types of fruits (apple, banana, orange). Unzip the dataset to yolov8 in the directory, please use fruits_seg as a dataset for the fruit segmentation task. The sample dataset also contains a desktop signature scene dataset for rotation object detection yolo_pen_obb.
cd yolov8
unzip datasets.zip
Training a Fruit Segmentation Model with YOLOv8#
Execute the command in the yolov8 directory to train a three - class fruit segmentation model using yolov8:
yolo segment train data=datasets/fruits_seg.yaml model=yolov8n-seg.pt epochs=100 imgsz=320
pip install onnx
pip install onnxsim
Follow the following commands to first export the pt model under runs/segment/exp/weights to an onnx model, and then convert it to a kmodel model:
cd test_yolov8/segment
python to_kmodel.py --target k230 --model ../../runs/segment/train/weights/best.onnx --dataset../test --input_width 320 --input_height 320 --ptq_option 0
cd ../../
Parameter name |
describe |
illustrate |
type |
target |
Target platform |
str |
model |
Model path |
str |
dataset |
str |
input_width |
Input width |
int |
input_height |
Enter height |
int |
ptq_option |
0/1/2 |
YOLOv8 Module#
Import Method
Parameter Name |
Instructions |
Type |
task_type |
Task type |
Supports four types of tasks, with optional values ‘classify’, ‘detect’, ‘segment’ or ‘obb’; |
str |
mode |
Inference mode |
str |
kmodel_path |
kmodel path |
str |
labels |
list[str] |
rgb888p_size |
list[int] |
model_input_size |
list[int] |
display_size |
list[int] |
conf_thresh |
float [0 - 1] |
nms_thresh |
NMS threshold |
float [0 - 1] |
mask_thresh |
Mask threshold |
float [0 - 1] |
max_boxes_num |
int |
debug_mode |
Debug mode |
int [0 - 1] |
import os, sys, gc
import image
yolo = YOLOv8(task_type="segment", mode="image", kmodel_path=kmodel_path, labels=labels, rgb888p_size=rgb888p_size, model_input_size=model_input_size, conf_thresh=confidence_threshold, nms_thresh=nms_threshold, mask_thresh=mask_threshold, max_boxes_num=50, debug_mode=0)
res = yolo.run(img)
yolo.deinit()
gc.collect()
import os, sys, gc
import image
pl.create()
yolo = YOLOv8(task_type="segment", mode="video", kmodel_path=kmodel_path, labels=labels, rgb888p_size=rgb888p_size, model_input_size=model_input_size, display_size=display_size, conf_thresh=confidence_threshold, nms_thresh=nms_threshold, mask_thresh=mask_threshold, max_boxes_num=50, debug_mode=0)
res = yolo.run(img)
pl.show_image()
gc.collect()
yolo.deinit()
pl.destroy()
YOLOv8 Rotation Object Detection#
Training data preparation#
You can create a new folder first yolov8, please download the provided sample dataset. The sample dataset contains datasets provided separately for the scenes using a rotation object detection category (pen). Unzip the dataset to yolov8 in the directory, please use yolo_pen_obb as a data set for the rotation object detection task.
cd yolov8
unzip datasets.zip
If you have downloaded the data, please ignore this step.
Training a Obb Model with YOLOv8#
pip install onnx
pip install onnxsim
Follow the following commands to first export the pt model under runs/obb/train/weights to an onnx model, and then convert it to a kmodel model:
cd test_yolov8/obb
cd ../../
Parameter name |
describe |
illustrate |
type |
target |
Target platform |
str |
model |
Model path |
str |
dataset |
str |
input_width |
Input width |
int |
input_height |
Enter height |
int |
ptq_option |
0/1/2 |
Connect to the IDE and copy the converted model and test images to the path CanMV/data in the directory. This path can be customized, you only need to modify the corresponding path when writing the code.
YOLOv8 module#
Import Method
Parameter Name |
Instructions |
Type |
task_type |
Task type |
str |
mode |
Inference mode |
str |
kmodel_path |
kmodel path |
str |
labels |
list[str] |
rgb888p_size |
list[int] |
model_input_size |
list[int] |
display_size |
list[int] |
conf_thresh |
float [0 - 1] |
nms_thresh |
NMS threshold |
float [0 - 1] |
mask_thresh |
Mask threshold |
float [0 - 1] |
max_boxes_num |
int |
debug_mode |
Debug mode |
int [0 - 1] |
For picture reasoning, please refer to the following code.Modify according to actual situation__main__Definition parameter variables in;
import os, sys, gc
import image
img_path = "/data/test_obb.jpg"
labels = ['pen']
confidence_threshold = 0.1
nms_threshold = 0.6
yolo = YOLOv8(task_type="obb", mode="image", kmodel_path=kmodel_path, labels=labels, rgb888p_size=rgb888p_size, model_input_size=model_input_size, conf_thresh=confidence_threshold, nms_thresh=nms_threshold, max_boxes_num=100, debug_mode=0)
res = yolo.run(img)
yolo.deinit()
gc.collect()
For video inference, please refer to the following code.Modify according to actual situation__main__Definition variables in;
import os,sys,gc
import image
kmodel_path = "/data/best_yolov8n.kmodel"
labels = ['pen']
nms_threshold = 0.6
pl.create()
yolo = YOLOv8(task_type="obb", mode="video", kmodel_path=kmodel_path, labels=labels, rgb888p_size=rgb888p_size, model_input_size=model_input_size, display_size=display_size, conf_thresh=confidence_threshold, nms_thresh=nms_threshold, max_boxes_num=50, debug_mode=0)
res = yolo.run(img)
pl.show_image()
gc.collect()
yolo.deinit()
pl.destroy()
YOLO11 Fruit Classification#
Setting up YOLO11 Source Code and Training Environment#
For setting up the training environment of YOLO11, please refer to ultralytics/ultralytics: Ultralytics YOLO 🚀 (github.com).
You can create a new folder first yolo11, please download the provided sample dataset. The sample dataset contains classification, detection and segmentation datasets provided for the scenes using three types of fruits (apple, banana, orange). Unzip the dataset to yolo11 in the directory, please use fruits_cls as a data set for fruit classification tasks. The sample dataset also contains a desktop signature scene dataset for rotation object detection yolo_pen_obb.
If you want to use your own dataset for training, you can download X-AnyLabeling after completing the annotation, the classification task data does not require tool annotation, and only the directory can be divided according to the format. Convert the annotated data to yolo11 the officially supported training data format is carried out for subsequent training.
cd yolo11
unzip datasets.zip
Training a Fruit Classification Model with YOLO11#
Execute the command in the yolo11 directory to train a three - class fruit classification model using yolo11:
yolo classify train data=datasets/fruits_cls model=yolo11n-cls.pt epochs=100 imgsz=224
pip install onnx
pip install onnxsim
Download the script tool and unzip the model - conversion script tool test_yolo11.zip into the yolo11 directory.
unzip test_yolo11.zip
Follow the following commands to first export the pt model under runs/classify/exp/weights to an onnx model, and then convert it to a kmodel model:
cd test_yolo11/classify
cd ../../
Parameter name |
describe |
illustrate |
type |
target |
Target platform |
str |
model |
Model path |
str |
dataset |
str |
input_width |
Input width |
int |
input_height |
Enter height |
int |
ptq_option |
0/1/2 |
YOLO11 Module#
The YOLO11 class integrates four tasks of YOLO11, namely classification (classify), detection (detect), segmentation (segment), obb. It supports two inference modes, namely image (image) and video stream (video). This class encapsulates the kmodel inference process of YOLO11.
Import Method
from libs.YOLO import YOLO11
Parameter Name |
Instructions |
Type |
task_type |
Task type |
str |
mode |
Inference mode |
str |
kmodel_path |
kmodel path |
str |
labels |
list[str] |
rgb888p_size |
list[int] |
model_input_size |
Input resolution of the YOLO11 model during training, such as [224, 224], [320, 320], or [640, 640]; |
list[int] |
display_size |
list[int] |
conf_thresh |
float [0 - 1] |
nms_thresh |
NMS threshold |
float [0 - 1] |
mask_thresh |
Mask threshold |
float [0 - 1] |
max_boxes_num |
int |
debug_mode |
Debug mode |
int [0 - 1] |
import os, sys, gc
import image
# Initialize YOLO11 instance
yolo = YOLO11(task_type="classify", mode="image", kmodel_path=kmodel_path, labels=labels, rgb888p_size=rgb888p_size, model_input_size=model_input_size, conf_thresh=confidence_threshold, debug_mode=0)
res = yolo.run(img)
yolo.deinit()
gc.collect()
import os, sys, gc
import image
pl.create()
yolo = YOLO11(task_type="classify", mode="video", kmodel_path=kmodel_path, labels=labels, rgb888p_size=rgb888p_size, model_input_size=model_input_size, display_size=display_size, conf_thresh=confidence_threshold, debug_mode=0)
res = yolo.run(img)
pl.show_image()
gc.collect()
yolo.deinit()
pl.destroy()
YOLO11 Fruit Detection#
You can create a new folder first yolo11, please download the provided sample dataset. The sample dataset contains classification, detection and segmentation datasets provided for the scenes using three types of fruits (apple, banana, orange). Unzip the dataset to yolo11 in the directory, please use fruits_yolo as a data set for fruit detection tasks. The sample dataset also contains a desktop signature scene dataset for rotation object detection yolo_pen_obb.
If you want to use your own dataset for training, you can download X-AnyLabeling complete the annotation. Convert the marked data to yolo11 the officially supported training data format is carried out for subsequent training.
cd yolo11
unzip datasets.zip
Training a Fruit Detection Model with YOLO11#
Execute the command in the yolo11 directory to train a three - class fruit detection model using yolo11:
yolo detect train data=datasets/fruits_yolo.yaml model=yolo11n.pt epochs=300 imgsz=320
# On the Linux platform: nncase and nncase-kpu can be installed online. For nncase-2.x, dotnet-7 needs to be installed.
# On the Windows platform: Please install dotnet-7 and add it to the environment variables. nncase can be installed online using pip, but the nncase-kpu library needs to be installed offline. Download nncase_kpu-2.*-py2.py3-none-win_amd64.whl from https://github.com/kendryte/nncase/releases.
# Enter the corresponding Python environment and use pip to install it in the download directory of nncase_kpu-2.*-py2.py3-none-win_amd64.whl.
# In addition to nncase and nncase-kpu, other libraries used in the script include:
pip install onnx
pip install onnxsim
Download the script tool and unzip the model conversion script tool test_yolo11.zip into the yolo11 directory:
Follow the following commands to first export the pt model under runs/detect/train/weights to an onnx model, and then convert it to a kmodel model:
# Export to onnx. Please select the path of the pt model by yourself.
cd test_yolo11/detect
# Convert to kmodel. Please select the path of the onnx model by yourself. The generated kmodel will be in the same directory as the onnx model.
python to_kmodel.py --target k230 --model ../../runs/detect/train/weights/best.onnx --dataset ../test --input_width 320 --input_height 320 --ptq_option 0
cd ../../
Parameter name |
describe |
illustrate |
type |
target |
Target platform |
str |
model |
Model path |
str |
dataset |
str |
input_width |
Input width |
int |
input_height |
Enter height |
int |
ptq_option |
0/1/2 |
Connect to the IDE and copy the converted model and test images to the CanMV/data directory. This path can be customized; you just need to modify the corresponding path when writing the code.
The YOLO11 Module#
The YOLO11 class integrates four tasks of YOLO11, namely classification (classify), detection (detect), segmentation (segment), and obb. It supports two inference modes, namely image (image) and video stream (video). This class encapsulates the kmodel inference process of YOLO11.
Import Method
Parameter Name |
Explanation |
Type |
task_type |
Task type |
Supports four types of tasks. The available options are |
str |
mode |
Inference mode |
Supports two inference modes. The available options are |
str |
kmodel_path |
Path of the kmodel |
The path of the kmodel copied to the development board. |
str |
labels |
The label names of different classes. |
list[str] |
rgb888p_size |
Resolution of the inference frame |
The resolution of the current frame for inference, such as |
list[int] |
model_input_size |
Input resolution of the model |
The input resolution of the YOLO11 model during training, such as |
list[int] |
display_size |
Set when the inference mode is |
list[int] |
conf_thresh |
The class confidence threshold for classification tasks and the object confidence threshold for detection and segmentation tasks, e.g., 0.5. |
float [0~1] |
nms_thresh |
NMS threshold |
The non-maximum suppression threshold, which is required for detection and segmentation tasks. |
float [0~1] |
mask_thresh |
Mask threshold |
The binarization threshold for segmenting the objects within the detection boxes in segmentation tasks. |
float [0~1] |
max_boxes_num |
The maximum number of detection boxes allowed to be returned in one frame of the image. |
int |
debug_mode |
Debug mode |
Whether the timing function is enabled. The available options are 0 and 1. 0 means no timing, and 1 means timing is enabled. |
int [0/1] |
import os, sys, gc
import image
yolo = YOLO11(task_type="detect", mode="image", kmodel_path=kmodel_path, labels=labels, rgb888p_size=rgb888p_size, model_input_size=model_input_size, conf_thresh=confidence_threshold, nms_thresh=nms_threshold, max_boxes_num=50, debug_mode=0)
res = yolo.run(img)
yolo.deinit()
gc.collect()
For video inference, please refer to the following code. Modify the defined parameter variables in __main__ according to the actual situation:
import os, sys, gc
import image
pl.create()
yolo = YOLO11(task_type="detect", mode="video", kmodel_path=kmodel_path, labels=labels, rgb888p_size=rgb888p_size, model_input_size=model_input_size, display_size=display_size, conf_thresh=confidence_threshold, nms_thresh=nms_threshold, max_boxes_num=50, debug_mode=0)
res = yolo.run(img)
pl.show_image()
gc.collect()
yolo.deinit()
pl.destroy()
YOLO11 Fruit Segmentation#
Setting up the YOLO11 Source Code and Training Environment#
To set up the YOLO11 training environment, please refer to ultralytics/ultralytics: Ultralytics YOLO 🚀 (github.com).
# Use pip to install the ultralytics package along with all its requirements in a Python environment where Python >= 3.8 and PyTorch >= 1.8.
You can create a new folder first yolo11, please download the provided sample dataset. The sample dataset contains classification, detection and segmentation datasets provided for the scenes using three types of fruits (apple, banana, orange). Unzip the dataset to yolo11 in the directory, please use fruits_seg as a dataset for the fruit segmentation task. The sample dataset also contains a desktop signature scene dataset for rotation object detection yolo_pen_obb.
cd yolo11
unzip datasets.zip
Training a Fruit Segmentation Model with YOLO11#
Execute the following command in the yolo11 directory to train a three-class fruit segmentation model using YOLO11:
yolo segment train data=datasets/fruits_seg.yaml model=yolo11n-seg.pt epochs=100 imgsz=320
The following libraries need to be installed in the training environment for model conversion:
pip install onnx
pip install onnxsim
Follow the commands below to first export the pt model under runs/segment/train/weights to an onnx model and then convert it to a kmodel model:
cd test_yolo11/segment
python to_kmodel.py --target k230 --model ../../runs/segment/train/weights/best.onnx --dataset ../test --input_width 320 --input_height 320 --ptq_option 0
cd ../../
Parameter name |
describe |
illustrate |
type |
target |
Target platform |
str |
model |
Model path |
str |
dataset |
str |
input_width |
Input width |
int |
input_height |
Enter height |
int |
ptq_option |
0/1/2 |
YOLO11 Module#
Import Method
Parameter Name |
Explanation |
Type |
task_type |
Task type |
Supports four types of tasks. The available options are ‘classify’, ‘detect’, ‘segment’, and ‘obb’. |
str |
mode |
Inference mode |
Supports two inference modes. The available options are ‘image’ and ‘video’. ‘Image’ means inferring from images, and ‘video’ means inferring from the real-time video stream captured by the camera. |
str |
kmodel_path |
kmodel path |
str |
labels |
list[str] |
rgb888p_size |
The resolution of the current inference frame, such as [1920, 1080], [1280, 720], or [640, 640]. |
list[int] |
model_input_size |
The input resolution of the YOLO11 model during training, such as [224, 224], [320, 320], or [640, 640]. |
list[int] |
display_size |
Set when the inference mode is ‘video’. It supports HDMI ([1920, 1080]) and LCD ([800, 480]). |
list[int] |
conf_thresh |
The class confidence threshold for classification tasks and the object confidence threshold for detection and segmentation tasks, such as 0.5. |
float [0 - 1] |
nms_thresh |
NMS threshold |
float [0 - 1] |
mask_thresh |
Mask threshold |
The binarization threshold for segmenting the objects in the detection box in segmentation tasks. |
float [0 - 1] |
max_boxes_num |
int |
debug_mode |
Debug mode |
int [0/1] |
import os, sys, gc
import image
yolo = YOLO11(task_type="segment", mode="image", kmodel_path=kmodel_path, labels=labels, rgb888p_size=rgb888p_size, model_input_size=model_input_size, conf_thresh=confidence_threshold, nms_thresh=nms_threshold, mask_thresh=mask_threshold, max_boxes_num=50, debug_mode=0)
res = yolo.run(img)
yolo.deinit()
gc.collect()
import os, sys, gc
import image
pl.create()
yolo = YOLO11(task_type="segment", mode="video", kmodel_path=kmodel_path, labels=labels, rgb888p_size=rgb888p_size, model_input_size=model_input_size, display_size=display_size, conf_thresh=confidence_threshold, nms_thresh=nms_threshold, mask_thresh=mask_threshold, max_boxes_num=50, debug_mode=0)
res = yolo.run(img)
pl.show_image()
gc.collect()
yolo.deinit()
pl.destroy()
YOLO11 Rotation Object Detection#
You can create a new folder first yolo11, please download the provided sample dataset. The sample dataset contains a rotating object detection dataset provided by single-class rotating pen detection (pen) for the scenes. Unzip the dataset to yolo11 in the directory, please use yolo_pen_obb as a data set for the rotation object detection task.
cd yolo11
unzip datasets.zip
Training a Obb Model with YOLO11#
pip install onnx
pip install onnxsim
Follow the commands below to first export the pt model under runs/obb/train/weights to an onnx model and then convert it to a kmodel model:
cd test_yolo11/obb
cd ../../
Parameter name |
describe |
illustrate |
type |
target |
Target platform |
str |
model |
Model path |
str |
dataset |
str |
input_width |
Input width |
int |
input_height |
Enter height |
int |
ptq_option |
0/1/2 |
YOLO11 module#
Import Method
Parameter Name |
Explanation |
Type |
task_type |
Task type |
str |
mode |
Inference mode |
str |
kmodel_path |
kmodel path |
str |
labels |
list[str] |
rgb888p_size |
list[int] |
model_input_size |
list[int] |
display_size |
list[int] |
conf_thresh |
float [0 - 1] |
nms_thresh |
NMS threshold |
float [0 - 1] |
mask_thresh |
Mask threshold |
float [0 - 1] |
max_boxes_num |
int |
debug_mode |
Debug mode |
int [0/1] |
import os, sys, gc
import image
labels = ['pen']
nms_threshold = 0.6
yolo = YOLO11(task_type="obb", mode="image", kmodel_path=kmodel_path, labels=labels, rgb888p_size=rgb888p_size, model_input_size=model_input_size, conf_thresh=confidence_threshold, nms_thresh=nms_threshold, max_boxes_num=100, debug_mode=0)
res = yolo.run(img)
yolo.deinit()
gc.collect()
import os, sys, gc
import image
labels = ['pen']
nms_threshold = 0.6
pl.create()
yolo = YOLO11(task_type="obb", mode="video", kmodel_path=kmodel_path, labels=labels, rgb888p_size=rgb888p_size, model_input_size=model_input_size, display_size=display_size, conf_thresh=confidence_threshold, nms_thresh=nms_threshold, max_boxes_num=50, debug_mode=0)
res = yolo.run(img)
pl.show_image()
gc.collect()
yolo.deinit()
pl.destroy()
Verification of kmodel Conversion#
The model conversion script toolkits (test_yolov5/test_yolov8/test_yolo11) downloaded for different models contain scripts for kmodel verification.
Note: You need to add environment variables to execute the verification scripts.
Linux:
# The path in the following command is the path of the Python environment where nncase is installed. Please modify it according to your environment. export NNCASE_PLUGIN_PATH=$NNCASE_PLUGIN_PATH:/usr/local/lib/python3.9/5site-packages/ export PATH=$PATH:/usr/local/lib/python3.9/site-packages/ source /etc/profileWindows:
Add the
Lib/site-packagespath under thePythonenvironment wherenncaseis installed to the system variablePathof the environment variables.
Comparing the Outputs of the onnx and kmodel#
Generating the Input bin Files#
Enter the classify/detect/segment directory and execute the following command:
python save_bin.py --image ../test_images/test.jpg --input_width 224 --input_height 224
After executing the script, the bin files onnx_input_float32.bin and kmodel_input_uint8.bin will be generated in the current directory, which will serve as the input files for the onnx model and the kmodel.
Comparing the Outputs#
Copy the converted models best.onnx and best.kmodel to the classify/detect/segment directory, and then execute the verification script with the following command:
python simulate.py --model best.onnx --model_input onnx_input_float32.bin --kmodel best.kmodel --kmodel_input kmodel_input_uint8.bin --input_width 224 --input_height 224
You will get the following output:
output 0 cosine similarity : 0.9985673427581787
The script will compare the cosine similarity of the outputs one by one. If the similarity is above 0.99, the model is generally considered usable. Otherwise, you need to conduct actual inference tests or change the quantization parameters and re-export the kmodel. If the model has multiple outputs, there will be multiple lines of similarity comparison information. For example, for the segmentation task, which has two outputs, the similarity comparison information is as follows:
output 0 cosine similarity : 0.9999530911445618
output 1 cosine similarity : 0.9983288645744324
Inference on Images Using the onnx Model#
Enter the classify/detect/segment directory, open test_cls_onnx.py, modify the parameters in main() to adapt to your model, and then execute the command:
python test_cls_onnx.py
After the command is successfully executed, the result will be saved as onnx_cls_results.jpg.
The detection and segmentation tasks are similar. Execute
test_det_onnx.pyandtest_seg_onnx.pyrespectively.
Inference on Images Using the kmodel#
Enter the classify/detect/segment directory, open test_cls_kmodel.py, modify the parameters in main() to adapt to your model, and then execute the command:
python test_cls_kmodel.py
After the command is successfully executed, the result will be saved as kmodel_cls_results.jpg.
test_det_kmodel.pyandtest_seg_kmodel.pyrespectively.
Tuning Guide#
When the performance of the model on the K230 is not satisfactory, you can generally consider tuning from aspects such as threshold settings, model size, input resolution, quantization methods, and the quality of training data.
Adjusting Thresholds#
Adjust the confidence threshold, nms threshold, and mask threshold to optimize the deployment effect without changing the model. In the detection task, increasing the confidence threshold and lowering the nms threshold will lead to a decrease in the number of detection boxes, and conversely, reducing the confidence threshold and increasing the nms threshold will lead to an increase in the number of detection boxes. In the segmentation task, the mask threshold will affect the partitioning of the segmentation area. You can first adjust according to the actual scenario to find the threshold value under the better effect.
Changing the Model#
Select models of different sizes to balance speed, memory footprint, and accuracy. The n/s/m/l model can be selected for training and transformation according to actual needs.
The following data takes the kmdel obtained by training in the example data set provided by this document as an example, and the operating performance of kmdel is measured on K230. During actual deployment, the post-processing time will be affected Number of results increased impact while memory management gc.collect() the time-consuming process will also increase with the complexity of post-processing, so the following data is only referenced for data comparison, you can Business needs according to different scenarios choose a different model:
Model |
Input resolution |
Task |
kpu inference frame rate |
Full frame inference frame rate |
yolov5n |
224×224 |
cls |
350fps |
57fps |
yolov5s |
224×224 |
cls |
186fps |
56fps |
yolov5m |
224×224 |
cls |
88fps |
47ps |
yolov5l |
224×224 |
cls |
48fps |
31fps |
yolov8n |
224×224 |
cls |
198fps |
57fps |
yolov8s |
224×224 |
cls |
95fps |
48fps |
yolov8m |
224×224 |
cls |
42fps |
28fps |
yolov8l |
224×224 |
cls |
21fps |
16fps |
yolo11n |
224×224 |
cls |
158fps |
56fps |
yolo11s |
224×224 |
cls |
83fps |
43fps |
yolo11m |
224 × 224 |
cls |
50fps |
31fps |
yolo11l |
224 × 224 |
cls |
39fps |
26fps |
yolov5n |
320 × 320 |
det |
54fps |
31fps |
yolov5s |
320 × 320 |
det |
38fps |
24fps |
yolov5m |
320 × 320 |
det |
25fps |
18fps |
yolov5l |
320 × 320 |
det |
16FPS |
12fps |
yolov8n |
320 × 320 |
det |
44fps |
27fps |
yolov8s |
320 × 320 |
det |
25fps |
18fps |
yolov8m |
320 × 320 |
det |
14FPS |
11fps |
yolov8l |
320 × 320 |
det |
8fps |
7fps |
yolo11n |
320 × 320 |
det |
41fps |
26fps |
yolo11s |
320 × 320 |
det |
24fps |
17fps |
yolo11m |
320 × 320 |
det |
14FPS |
11fps |
yolo11l |
320 × 320 |
det |
12fps |
9fps |
yolov5n |
320 × 320 |
seg |
18fps |
11fps |
yolov5s |
320 × 320 |
seg |
15fps |
10fps |
yolov5m |
320 × 320 |
seg |
12fps |
8fps |
yolov5l |
320 × 320 |
seg |
9fps |
7fps |
yolov8n |
320 × 320 |
seg |
39fps |
18fps |
yolov8s |
320 × 320 |
seg |
22FPS |
11fps |
yolov8m |
320 × 320 |
seg |
12fps |
8fps |
yolov8l |
320 × 320 |
seg |
7fps |
5fps |
yolo11n |
320 × 320 |
seg |
37fps |
17fps |
yolo11s |
320 × 320 |
seg |
21FPS |
11fps |
yolo11m |
320 × 320 |
seg |
12fps |
7fps |
yolo11l |
320×320 |
seg |
10fps |
7fps |
yolov8n |
320×320 |
obb |
44fps |
27fps |
yolov8s |
320×320 |
obb |
25fps |
18fps |
yolov8m |
320×320 |
obb |
13fps |
10fps |
yolov8l |
320×320 |
obb |
8fps |
7fps |
yolo11n |
320×320 |
obb |
40fps |
25fps |
yolo11s |
320×320 |
obb |
24fps |
16fps |
yolo11m |
320×320 |
obb |
14fps |
11fps |
yolo11l |
320×320 |
obb |
12fps |
9fps |
Changing the Input Resolution#
Change the input resolution of the model to suit your scene. Larger resolutions may improve deployment results, but will take more inference time.
The following data takes the kmdel obtained by training in the example data set provided by this document as an example, and the operating performance of kmdel is measured on K230. During actual deployment, the post-processing time will be affected Number of results increased impact while memory management gc.collect() the time-consuming process will also increase with the complexity of post-processing, so the following data is only referenced for data comparison, you can Business needs according to different scenarios choose Different input resolutions:
Model |
Input resolution |
Task |
yolov5n |
224×224 |
cls |
350fps |
57fps |
yolov5n |
320×320 |
cls |
220fps |
56fps |
yolov5n |
640 × 640 |
cls |
53fps |
32FPS |
yolov5n |
320 × 320 |
det |
54fps |
31fps |
yolov5n |
640 × 640 |
det |
16FPS |
11fps |
yolov5n |
320 × 320 |
seg |
18fps |
11fps |
yolov5n |
640 × 640 |
seg |
4FPS |
3FPS |
yolov8n |
224 × 224 |
cls |
198fps |
57fps |
yolov8n |
320 × 320 |
cls |
121fps |
55fps |
yolov8n |
640 × 640 |
cls |
38fps |
24fps |
yolov8n |
320 × 320 |
det |
44fps |
27fps |
yolov8n |
640 × 640 |
det |
14FPS |
10fps |
yolov8n |
320 × 320 |
seg |
39fps |
18fps |
yolov8n |
640 × 640 |
seg |
12fps |
7fps |
yolov8n |
320 × 320 |
obb |
44fps |
27fps |
yolov8n |
640 × 640 |
obb |
13fps |
10fps |
yolo11n |
224 × 224 |
cls |
158fps |
56fps |
yolo11n |
320 × 320 |
cls |
102FPS |
49fps |
yolo11n |
640×640 |
cls |
320fps |
25fps |
yolo11n |
320×320 |
det |
41fps |
26fps |
yolo11n |
640×640 |
det |
12fps |
9fps |
yolo11n |
320×320 |
seg |
37fps |
17fps |
yolo11n |
640×640 |
seg |
11fps |
7fps |
yolo11n |
320×320 |
obb |
40fps |
25fps |
yolo11n |
640×640 |
obb |
12fps |
9fps |
Modifying the Quantization Method#
The model conversion script provides 3 quantization parameters,data and weights conduct uint8 quantitative or int16 quantification.
In the convert kmdel script, select different ptq_option values specify different quantization methods.
ptq_option |
data |
Weights |
uint8 |
uint8 |
1 |
uint8 |
int16 |
2 |
int16 |
uint8 |
The following data takes the kmdel obtained by the detection example data set provided by this document as an example to measure the operating performance of kmdel on K230. During actual deployment, the post-processing time will be affected Number of results increased impact while memory management gc.collect() the time-consuming process will also increase with the complexity of post-processing, so the following data is only referenced for data comparison, you can Business needs according to different scenarios choose Different quantification methods:
Model |
Input resolution |
Task |
Quantitative parameters [data, weights] |
yolov5n |
320×320 |
det |
[uint8,uint8] |
54fps |
32fps |
Yolov5n |
320 × 320 |
det |
[Uint8, Int16] |
49fps |
30fps |
Yolov5n |
320 × 320 |
det |
[int16, uint8] |
39fps |
25fps |
Yolov8n |
320 × 320 |
det |
[Uint8, Uint8] |
44fps |
27fps |
Yolov8n |
320 × 320 |
det |
[Uint8, Int16] |
40fps |
25fps |
Yolov8n |
320 × 320 |
det |
[int16, uint8] |
34fps |
23fps |
yolo11n |
320×320 |
det |
[uint8,uint8] |
41fps |
26fps |
yolo11n |
320×320 |
det |
[uint8,int16] |
38fps |
24fps |
yolo11n |
320×320 |
det |
[int16,uint8] |
32fps |
22fps |
Improving Data Quality#
If the training results are poor, improve the quality of the dataset by optimizing aspects such as the data volume, reasonable data distribution, annotation quality, and training parameter settings.
Tuning Tips#
The quantization parameters have a greater impact on the performance of YOLOv8 and YOLO11 than on YOLOv5, as can be seen by comparing different quantized models.
The input resolution has a greater impact on the inference speed than the model size.
The difference in data distribution between the training data and the data captured by the K230 camera may affect the deployment effect. You can collect some data using the K230 and annotate and train it yourself.
