VENC Module API Manual#
This manual provides a detailed introduction to the API of the K230_CanMV VENC module. Developers can use these APIs to perform video encoding, generating streams of different resolutions and encoding formats. The VENC module needs to be used in conjunction with the camera module to achieve encoding functionality.
API Introduction#
The VENC module provides the Encoder class, which includes the following methods:
Encoder.__init__#
Constructor to initialize the encoder instance.
Syntax
encoder = Encoder()
Parameter Name |
Input/Output |
None |
Return Value |
Encoder Object |
Encoder Object |
Encoder.SetOutBufs#
Configures the output buffer of the encoder.
Syntax
Parameter Name |
Input/Output |
chn |
Encoding channel number |
Input |
buf_num |
Number of output buffers |
Input |
Width of the encoded image |
Input |
Height of the encoded image |
Input |
Return Value |
None |
Notes
Must be called before MediaManager.init()
Encoder.Create#
Creates an encoder instance.
Syntax
Encoder.Create(chn, chnAttr)
Parameter Name |
Input/Output |
chn |
Input |
chnAttr |
Encoding channel attribute structure |
Input |
Return Value |
None |
Notes
VENC supports up to 4 encoding channels, with channel numbers ranging from [0, 3]. The 4th channel is fixed for IDE image transmission. Unless calling compress_for_ide, it is recommended to use only [0, 2].
Encoder.Start#
Starts the encoding process.
Syntax
Encoder.Start(chn)
Parameter Name |
Input/Output |
chn |
Input |
Return Value |
None |
Encoder.SendFrame#
Sends image data to the encoder for encoding.
Syntax
Parameter Name |
Input/Output |
chn |
Input |
frame_info |
Raw image information structure |
Input |
Return Value |
Success |
Non-zero |
Failure |
Notes
Can encode a full frame of data or a variable-length data stream.
Encoder.GetStream#
Gets a frame of encoded stream data.
Syntax
Encoder.GetStream(chn, streamData,timeout=-1)
Parameter Name |
Input/Output |
chn |
Input |
streamData |
Encoded stream structure |
Output |
timeout |
Obtain the bitstream timeout. Value range: [-1, +∞ ) -1:Blocking. 0: Non-blocking.Greater than 0: Timeout period. |
Input |
Return Value |
Success |
Non-zero |
Failure |
Encoder.ReleaseStream#
Releases a frame of stream buffer.
Syntax
Parameter Name |
Input/Output |
chn |
Input |
streamData |
Input |
Return Value |
None |
Encoder.Stop#
Stops the encoding process.
Syntax
Encoder.Stop(chn)
Parameter Name |
Input/Output |
chn |
Input |
Return Value |
None |
Encoder.Destroy#
Destroys the encoder instance.
Syntax
Encoder.Destroy(chn)
Parameter Name |
Input/Output |
chn |
Input |
Return Value |
None |
Data Structure Description#
ChnAttrStr#
Encoding channel attribute structure.
Definition
class ChnAttrStr:
def __init__(self, payloadType, profile, picWidth, picHeight,bit_rate = 4000,gopLen = 30,src_frame_rate = 30,dst_frame_rate = 30,mjpeg_quality_factor = 45):
self.profile = profile
self.pic_width = picWidth
self.pic_height = picHeight
self.gop_len = gopLen
self.bit_rate = bit_rate
self.src_frame_rate = src_frame_rate
self.dst_frame_rate = dst_frame_rate
self.mjpeg_quality_factor = mjpeg_quality_factor
Members
Member Name |
payload_type |
Encoding format (h264/h265) |
profile |
Encoding Profile |
pic_width |
Image width |
pic_height |
Image height |
gop_len |
Encoding GOP length |
bit_rate |
Bitrate |
src_frame_rate |
Input frame rate |
dst_frame_rate |
Output frame rate |
mjpeg_quality_factor |
MJPEG encoding quality factor (image quality compression ratio parameter) |
StreamData#
Stream structure.
Definition
class StreamData:
def __init__(self):
self.phy_addr = [0 for i in range(0, VENC_PACK_CNT_MAX)]
self.pts = [0 for i in range(0, VENC_PACK_CNT_MAX)]
self.pack_cnt = 0
Members
Member Name |
data |
Stream data address |
phy_addr |
Physical address of the code stream |
data_size |
Stream data size |
stream_type |
Frame type |
pts |
Display the timestamp |
pack_cnt |
Number of packs in the stream |
Notes
VENC_PACK_CNT_MAX indicates the maximum number of packs in the stream structure, currently set to 12.
payload_type#
Encoding format type.
Members
Member Name |
PAYLOAD_TYPE_H264 |
H.264 encoding format |
PAYLOAD_TYPE_H265 |
H.265 encoding format |
profile#
Encoding Profile.
Members
Member Name |
H264_PROFILE_BASELINE |
H.264 Baseline Profile |
H264_PROFILE_MAIN |
H.264 Main Profile |
H264_PROFILE_HIGH |
H.264 High Profile |
H265_PROFILE_MAIN |
H.265 Main Profile |
stream_type#
Stream frame type.
Members
Member Name |
STREAM_TYPE_HEADER |
Stream Header |
STREAM_TYPE_I |
I Frame |
STREAM_TYPE_P |
P Frame |
Example Programs#
Example 1#
Bind VENC to VICAP and save the obtained encoded data to a file.
from media.vencoder import *
from media.sensor import *
import time, os
print("VENC test starts")
venc_chn = VENC_CHN_ID_0
width = ALIGN_UP(width, 16)
venc_payload_type = K_PT_H264
# Determine file extension
if suffix == '264':
elif suffix == '265':
venc_payload_type = K_PT_H265
return
# Initialize sensor
sensor = Sensor()
sensor.reset()
# Instantiate video encoder
encoder = Encoder()
# Bind camera and venc
# Initialize media manager
streamData = StreamData()
# Create encoder
# Start encoding
encoder.Start(venc_chn)
# Start camera
sensor.run()
frame_count = 0
print("Save stream to file: ", file_name)
encoder.GetStream(venc_chn, streamData) # Get a frame of stream
fo.write(stream_data) # Write stream to file
print("Stream size: ", streamData.data_size[pack_idx], "Stream type: ", streamData.stream_type[pack_idx])
encoder.ReleaseStream(venc_chn, streamData) # Release a frame of stream
frame_count += 1
if frame_count >= 200:
print("User stop: ", e)
import sys
sys.print_exception(e)
# Stop camera
sensor.stop()
# Destroy the binding of camera and venc
del link
# Stop encoding
encoder.Stop(venc_chn)
# Destroy encoder
encoder.Destroy(venc_chn)
# Clean buffer
print("VENC test stops")
vi_bind_venc_test("/sdcard/examples/test.264", 800, 480) # Example of binding vi to venc
Example 2#
Encode VENC data stream and save it as a file. Here’s the translated text to English:
import time, os
def stream_venc_test(file_name, width=1280, height=720):
print("venc_test start")
# Determine file type
if suffix == '264':
return
# Initialize sensor
sensor = Sensor()
sensor.reset()
# Set camera output buffer
# Set chn0 output size
# Set chn0 output format
encoder = Encoder()
# Set video encoder output buffer
# Create encoder
# Start encoding
# Start camera
sensor.run()
frame_count = 0
yuv420sp_img = None
if (yuv420sp_img == -1):
continue
# frame_info.v_frame.phys_addr[1] = yuv420sp_img.phyaddr(1)
frame_info.v_frame.phys_addr[1] = frame_info.v_frame.phys_addr[0] + frame_info.v_frame.width * frame_info.v_frame.height + 1024
frame_info.v_frame.phys_addr[1] = frame_info.v_frame.phys_addr[0] + frame_info.v_frame.width * frame_info.v_frame.height + 3072
encoder.SendFrame(venc_chn, frame_info)
frame_count += 1
print("user stop: ", e)
import sys
# Stop camera
sensor.stop()
# Stop encoding
# Destroy encoder
# Clean buffer
print("venc_test stop")
stream_venc_test("/sdcard/examples/test.264", 800, 480) # VENC encoding data stream example
