Advanced - Custom Firmware#
This chapter introduces how to develop on the K230 CanMV. If you have no custom requirements, you can skip this chapter.
The K230 CanMV is developed based on the K230 SDK and runs applications using Micropython and OpenMV. Users can flexibly develop by invoking hardware resources through the Python language.
Setting Up the Development Environment#
Host Environment |
Ubuntu 20.04.4 LTS (x86_64) |
The K230 CanMV compilation environment is suitable for Ubuntu 20.04 and above. |
Currently, K230 CanMV has only been verified to compile in a Linux environment. Other Linux versions have not been tested, so compatibility with other systems cannot be guaranteed.
Local Build Environment#
Update APT sources (optional)
Install necessary dependencies
apt-get clean all && \
apt-get update && \
Update PIP sources (optional)
Install Python dependencies
Install the repo tool
mkdir -p ~/.bin
chmod a+rx ~/.bin/repo
source ~/.bashrc
Compilation Process#
Source Code Download#
The source code of CanMV-K230 is hosted on Github. Users can download the source code using the repo tool.
# It's recommended to create a directory in the user's home directory before downloading the code
# Download the RT-Smart + CanMV project
repo init -u https://github.com/canmv-k230/manifest -b master --repo-url=https://github.com/canmv-k230/git-repo.git --repo-branch stable
# Download the pure RT-Smart project
repo init -u https://github.com/canmv-k230/manifest -b master -m rtsmart.xml --repo-url=https://github.com/canmv-k230/git-repo.git --repo-branch stable
# Synchronize the code
repo sync
Code Preparation#
When compiling for the first time, you need to download the toolchain. The following command only needs to be executed once.
# Download the toolchain when running for the first time
make dl_toolchain
Compilation#
Select the corresponding board configuration file according to actual needs, and then start compiling.
# List available configuration options
make list_def
# Select the corresponding board configuration file
make xxxx_defconfig
# Start compilation
time make log
After compilation, the image files will be generated in the ~/canmv_k230/output/xxxx/xxx.img directory.
If you don’t want to compile CanMV, you need to modify the configuration to disable only that module.
make menuconfig
# Disable the CanMV module
Code Directory Description#
canmv_k230
├── boards
├── configs
├── include
├── output
├── src
│ ├── applications
│ ├── canmv
│ ├── opensbi
│ ├── rtsmart
│ └── uboot
└── tools
Directory structure description:
boards: Board-related filesconfigs: List of configuration filesinclude: Automatically generated header filesoutput: Compiled files, including images and temporary filessrc/applications: User applicationssrc/canmv: CanMV-related filessrc/opensbi: OpenSBI-related filessrc/rtsmart: RT-Smart and MPP-related filessrc/uboot: U-Boot-related filesscripts: Compilation system-related scripts
