MP4 Module API Manual#
This document provides a detailed introduction to the K230_CanMV MP4 module API’s functionality and usage. The MP4 module is primarily used for generating MP4 files. Developers do not need to focus on the underlying implementation details; they can simply call the provided APIs to generate MP4 files with different encoding formats and video resolutions. This document will introduce both the MP4Container API and the kd_mp4* API, helping developers quickly get started and flexibly use these interfaces.
MP4Container API Introduction#
The MP4Container class provides a convenient way to record camera footage and capture audio to generate MP4 files. This module simplifies the MP4 file processing workflow, making it suitable for application scenarios where there is no need to focus on the underlying implementation details.
MP4Container.Create#
Creates an instance of MP4Container.
Syntax
MP4Container.Create(mp4Cfg)
Parameter Name |
Input/Output |
mp4Cfg |
Configuration for MP4Container |
Input |
Return Values
Return Value |
None |
MP4Container.Start#
Starts the MP4Container to begin processing data.
Syntax
MP4Container.Start()
Return Values
Return Value |
None |
MP4Container.Process#
Writes a frame of audio/video data to the MP4 file.
Syntax
MP4Container.Process()
Return Values
Return Value |
None |
MP4Container.Stop#
Stops the MP4Container from processing data.
Syntax
MP4Container.Stop()
Return Values
Return Value |
None |
MP4Container.Destroy#
Destroys the created MP4Container instance.
Syntax
MP4Container.Destroy()
Return Values
Return Value |
None |
kd_mp4* API Introduction#
This section provides a detailed description of the low-level function interfaces related to the MP4 module, which are used for more flexible control over the creation, writing, and reading of MP4 files. These interfaces are suitable for developers who need higher flexibility and control, allowing them to finely manage various aspects of MP4 files, including container creation, track management, data writing, and reading, and integrate with other modules to create a comprehensive solution.
kd_mp4_create#
Description Creates an MP4 container instance and initializes the configuration.
Syntax
handle = k_u64_ptr()
ret = kd_mp4_create(handle, mp4_cfg)
Parameter Name |
Input/Output |
handle |
Output parameter, return the pointer of the MP4 instance handle |
Output |
config |
Pointer to MP4 container configuration structure |
Input |
Return Values
Return Value |
Success |
Non-0 |
Failure, see specific implementation for error codes |
kd_mp4_create_track#
Description Creates an audio/video track in the MP4 container.
Syntax
track_handle = k_u64_ptr()
ret = kd_mp4_create_track(handle, track_handle, track_info)
Parameter Name |
Input/Output |
handle |
Input |
track_handle |
Output parameter, the handle pointer of the audio and video track instance |
Output |
track_info |
Pointer to track information structure |
Input |
Return Values
Return Value |
Success |
Non-0 |
Failure |
kd_mp4_destroy_tracks#
Description Destroys all created tracks in the MP4 container.
Syntax
ret = kd_mp4_destroy_tracks(handle)
Parameter Name |
Input/Output |
handle |
Input |
Return Values
Return Value |
Success |
Non-0 |
Failure |
kd_mp4_write_frame#
Description Writes a frame of audio/video data to the MP4 file.
Syntax
ret = kd_mp4_write_frame(handle, track_id, frame_data)
Parameter Name |
Input/Output |
handle |
Input |
track_id |
ID of the target track |
Input |
frame_data |
Pointer to frame data structure |
Input |
Return Values
Return Value |
Success |
Non-0 |
Failure |
kd_mp4_get_file_info#
Description Gets global information of the MP4 file (e.g., total duration, number of tracks).
Syntax
file_info = k_mp4_file_info_s()
ret = kd_mp4_get_file_info(handle, file_info)
Parameter Name |
Input/Output |
handle |
Input |
file_info |
Pointer to file information structure |
Output |
Return Values
Return Value |
Success |
Non-0 |
Failure |
kd_mp4_get_track_by_index#
Description Gets detailed information of a specified track by index.
Syntax
track_info = k_mp4_track_info_s()
ret = kd_mp4_get_track_by_index(handle, track_index, track_info)
Parameter Name |
Input/Output |
handle |
Input |
track_index |
Track index (starting from 0) |
Input |
track_info |
Output |
Return Values
Return Value |
Success |
Non-0 |
Failure |
kd_mp4_get_frame#
Description Reads a frame of audio/video data from the MP4 file.
Syntax
ret = kd_mp4_get_frame(handle, frame_data)
Parameter Name |
Input/Output |
handle |
Input |
frame_data |
Output |
Return Values
Return Value |
Success |
Non-0 |
Failure |
Data Structure Description#
Mp4CfgStr#
The configuration properties of MP4Container.
Definition
class Mp4CfgStr:
def __init__(self, type):
self.type = type
self.muxerCfg = MuxerCfgStr()
def SetMuxerCfg(self, fileName, videoPayloadType, picWidth, picHeight, audioPayloadType, fmp4Flag=0):
self.muxerCfg.file_name = fileName
self.muxerCfg.video_payload_type = videoPayloadType
self.muxerCfg.pic_width = picWidth
self.muxerCfg.pic_height = picHeight
self.muxerCfg.audio_payload_type = audioPayloadType
self.muxerCfg.fmp4_flag = fmp4Flag
Members
Member Name |
type |
Muxer type |
muxerCfg |
Demuxer type, currently unsupported |
Relevant data types and interfaces#
MP4Container.Create
MuxerCfgStr#
Configuration properties of the MP4Container muxer type.
Definition
class MuxerCfgStr:
def __init__(self):
self.file_name = 0
self.video_payload_type = 0
self.pic_width = 0
self.pic_height = 0
self.audio_payload_type = 0
self.video_start_timestamp = 0
self.fmp4_flag = 0
Members
Member Name |
file_name |
The file name of the generated MP4 |
video_payload_type |
Video coding format |
pic_width |
Video frame width |
pic_height |
Video frame height |
audio_payload_type |
Audio coding format |
video_start_timestamp |
The timestamp of the video’s start |
fmp4_flag |
The flag bit of fMP4 format |
MP4Container.Create
MP4Container Type#
Enumeration of MP4Container types.
Members
Member Name |
MP4_CONFIG_TYPE_MUXER |
MP4Container type: muxer/demuxer,only muxer is supported |
MP4_CONFIG_TYPE_DEMUXER |
video_payload_type#
Video encoding types.
Members
Member Name |
MP4_CODEC_ID_H264 |
H.264 video encoding type |
MP4_CODEC_ID_H265 |
H.265 video encoding type |
audio_payload_type#
Audio encoding types.
Members
Member Name |
MP4_CODEC_ID_G711U |
G.711U audio encoding type |
MP4_CODEC_ID_G711A |
G.711A audio encoding type |
k_mp4_config_s#
Global configuration structure for MP4 container.
Members
Member Name |
config_type |
Container type (e.g., |
muxer_config |
Muxer configuration (file name, encoding format, etc.) |
demuxer_config |
Demuxer configuration (currently unsupported) |
k_mp4_track_info_s#
Track information structure for creating audio/video tracks.
Members
Member Name |
track_type |
Track type (e.g., |
time_scale |
Time scale (unit: Hz) |
video_info |
Video parameters (resolution, encoding format, etc.) |
audio_info |
Audio parameters (sampling rate, number of channels, etc.) |
k_mp4_frame_data_s#
Frame data structure for reading/writing audio/video frames.
Members
Member Name |
codec_id |
Encoding type (e.g., |
time_stamp |
Timestamp (unit: milliseconds) |
data |
Data pointer |
data_length |
Data length (bytes) |
eof |
End-of-file flag (1 indicates the last frame) |
Example Programs#
Example 1#
This example is used to demonstrate how to call the ‘Mp4Container’ class to generate an MP4 file. Through this routine, developers can record camera footage and capture sound to generate MP4 files. This example demonstrates how to create an ‘Mp4Container’ instance, configure MP4 file parameters, and start and stop the MP4 recording process. Suitable for developers who need to quickly get started with generating MP4 files.
from media.mp4format import *
def canmv_mp4_muxer_test():
print("mp4_muxer_test start")
width = 1280
height = 720
# Please set the width and height of the BPI development board to 640*360
# width=640
# height=360
# Instantiate MP4 Container
mp4_muxer = Mp4Container()
mp4_cfg = Mp4CfgStr(mp4_muxer.MP4_CONFIG_TYPE_MUXER)
if mp4_cfg.type == mp4_muxer.MP4_CONFIG_TYPE_MUXER:
file_name = "/sdcard/examples/test.mp4"
mp4_cfg.SetMuxerCfg(file_name, mp4_muxer.MP4_CODEC_ID_H265, width, height, mp4_muxer.MP4_CODEC_ID_G711U)
# creat MP4 muxer
mp4_muxer.Create(mp4_cfg)
# start MP4 muxer
mp4_muxer.Start()
frame_count = 0
# Process audio and video data and write it into files in MP4 format
mp4_muxer.Process()
frame_count += 1
print("frame_count = ", frame_count)
if frame_count >= 200:
print(e)
# stop MP4 muxer
mp4_muxer.Stop()
# destory MP4 muxer
mp4_muxer.Destroy()
print("mp4_muxer_test stop")
Example 2#
This example is used to demonstrate how to call the kd_mp4* API to directly operate the MP4 module. Through this routine, developers can learn how to create MP4 containers, create audio and video tracks, write audio and video frame data, and destroy MP4 containers. This routine demonstrates a more low-level operation method and is suitable for developers who need to precisely control the MP4 file generation process.
# Save MP4 file example
# Note: You will need an SD card to run this example.
# You can capture audio and video and save them as MP4.The current version only supports MP4 format, video supports 264/265, and audio supports g711a/g711u.
from mpp.mp4_format import *
from mpp.mp4_format_struct import *
from media.vencoder import *
from media.sensor import *
import uctypes
def mp4_muxer_init(file_name, fmp4_flag):
mp4_cfg = k_mp4_config_s()
mp4_cfg.config_type = K_MP4_CONFIG_MUXER
mp4_cfg.muxer_config.file_name[:] = bytes(file_name, 'utf-8')
mp4_cfg.muxer_config.fmp4_flag = fmp4_flag
if ret:
raise OSError("kd_mp4_create failed.")
return handle.value
def mp4_muxer_create_video_track(mp4_handle, width, height, video_payload_type):
video_track_info = k_mp4_track_info_s()
video_track_info.track_type = K_MP4_STREAM_VIDEO
video_track_info.time_scale = 1000
video_track_info.video_info.width = width
video_track_info.video_info.height = height
video_track_info.video_info.codec_id = video_payload_type
video_track_handle = k_u64_ptr()
ret = kd_mp4_create_track(mp4_handle, video_track_handle, video_track_info)
if ret:
raise OSError("kd_mp4_create_track failed.")
return video_track_handle.value
def mp4_muxer_create_audio_track(mp4_handle,channel,sample_rate, bit_per_sample ,audio_payload_type):
audio_track_info = k_mp4_track_info_s()
audio_track_info.track_type = K_MP4_STREAM_AUDIO
audio_track_info.time_scale = 1000
audio_track_info.audio_info.channels = channel
audio_track_info.audio_info.codec_id = audio_payload_type
audio_track_info.audio_info.sample_rate = sample_rate
audio_track_info.audio_info.bit_per_sample = bit_per_sample
audio_track_handle = k_u64_ptr()
ret = kd_mp4_create_track(mp4_handle, audio_track_handle, audio_track_info)
if ret:
return audio_track_handle.value
def vi_bind_venc_mp4_test(file_name,width=1280, height=720,venc_payload_type = K_PT_H264):
print("venc_test start")
venc_chn = VENC_CHN_ID_0
width = ALIGN_UP(width, 16)
frame_data = k_mp4_frame_data_s()
save_idr = bytearray(width * height * 3 // 4)
idr_index = 0
# mp4 muxer init
mp4_handle = mp4_muxer_init(file_name, True)
# create video track
if venc_payload_type == K_PT_H264:
video_payload_type = K_MP4_CODEC_ID_H264
elif venc_payload_type == K_PT_H265:
video_payload_type = K_MP4_CODEC_ID_H265
mp4_video_track_handle = mp4_muxer_create_video_track(mp4_handle, width, height, video_payload_type)
# sensor init
sensor = Sensor()
sensor.reset()
# Set the camera output buffer
# set chn0 output size
# set chn0 output format
# Instantiate the video encoder
encoder = Encoder()
# Set the video encoder output buffer
# Bind the camera and venc
# init media manager
streamData = StreamData()
# Create an encoder
# Start encoder
encoder.Start(venc_chn)
# camera enable
sensor.run()
frame_count = 0
get_first_I_frame = False
encoder.GetStream(venc_chn, streamData) # Obtain a frame of code stream
stream_type = streamData.stream_type[0]
# Retrieve first IDR frame and write to MP4 file. Note: The first frame must be an IDR frame.
if not get_first_I_frame:
if stream_type == encoder.STREAM_TYPE_I:
get_first_I_frame = True
video_start_timestamp = streamData.pts[0]
save_idr[idr_index:idr_index+streamData.data_size[0]] = uctypes.bytearray_at(streamData.data[0], streamData.data_size[0])
idr_index += streamData.data_size[0]
frame_data.codec_id = video_payload_type
frame_data.data = uctypes.addressof(save_idr)
frame_data.data_length = idr_index
frame_data.time_stamp = streamData.pts[0] - video_start_timestamp
ret = kd_mp4_write_frame(mp4_handle, mp4_video_track_handle, frame_data)
if ret:
raise OSError("kd_mp4_write_frame failed.")
encoder.ReleaseStream(venc_chn, streamData)
continue
elif stream_type == encoder.STREAM_TYPE_HEADER:
continue
encoder.ReleaseStream(venc_chn, streamData) # Release a frame of code stream
continue
# Write video stream to MP4 file (not first idr frame)
frame_data.data = streamData.data[0]
frame_data.data_length = streamData.data_size[0]
print("video size: ", streamData.data_size[0], "video type: ", streamData.stream_type[0],"video timestamp:",frame_data.time_stamp)
if ret:
frame_count += 1
print("user stop: ", e)
import sys
sys.print_exception(e)
# camera stop
sensor.stop()
# Destroy the binding between camera and venc
del link
# Stop coding
encoder.Stop(venc_chn)
# Destroy the encoder
encoder.Destroy(venc_chn)
# Clean the buffer
# mp4 muxer destroy
kd_mp4_destroy_tracks(mp4_handle)
kd_mp4_destroy(mp4_handle)
print("venc_test stop")
vi_bind_venc_mp4_test("/sdcard/examples/test.mp4", 1280, 720)
Example 3#
# MP4 Demuxer Example
# This script demuxes an MP4 file, extracting video and audio streams.
# Supported video codecs: H.264, H.265
# Supported audio codecs: G.711A, G.711U
from media.pyaudio import *
import media.g711 as g711
from media.display import *
import uctypes
import _thread
def demuxer_mp4(filename):
video_info = k_mp4_video_info_s()
video_track = False
audio_info = k_mp4_audio_info_s()
audio_track = False
mp4_handle = k_u64_ptr()
mp4_cfg.config_type = K_MP4_CONFIG_DEMUXER
mp4_cfg.muxer_config.file_name[:] = bytes(filename, 'utf-8')
mp4_cfg.muxer_config.fmp4_flag = 0
ret = kd_mp4_create(mp4_handle, mp4_cfg)
if ret:
raise OSError("kd_mp4_create failed:",filename)
kd_mp4_get_file_info(mp4_handle.value, file_info)
#print("=====file_info: track_num:",file_info.track_num,"duration:",file_info.duration)
for i in range(file_info.track_num):
ret = kd_mp4_get_track_by_index(mp4_handle.value, i, track_info)
if (ret < 0):
raise ValueError("kd_mp4_get_track_by_index failed")
if (track_info.track_type == K_MP4_STREAM_VIDEO):
if (track_info.video_info.codec_id == K_MP4_CODEC_ID_H264 or track_info.video_info.codec_id == K_MP4_CODEC_ID_H265):
video_track = True
video_info = track_info.video_info
print(" codec_id: ", video_info.codec_id)
print(" track_id: ", video_info.track_id)
print(" width: ", video_info.width)
print(" height: ", video_info.height)
print("video not support codecid:",track_info.video_info.codec_id)
elif (track_info.track_type == K_MP4_STREAM_AUDIO):
if (track_info.audio_info.codec_id == K_MP4_CODEC_ID_G711A or track_info.audio_info.codec_id == K_MP4_CODEC_ID_G711U):
audio_track = True
audio_info = track_info.audio_info
print(" codec_id: ", audio_info.codec_id)
print(" track_id: ", audio_info.track_id)
print(" channels: ", audio_info.channels)
print(" sample_rate: ", audio_info.sample_rate)
print(" bit_per_sample: ", audio_info.bit_per_sample)
#audio_info.channels = 2
print("audio not support codecid:",track_info.audio_info.codec_id)
if (video_track == False):
raise ValueError("video track not found")
# Record the initial system time
start_system_time = time.ticks_ms()
# Record the initial video timestamp
start_video_timestamp = 0
while (True):
ret = kd_mp4_get_frame(mp4_handle.value, frame_data)
if (ret < 0):
raise OSError("get frame data failed")
if (frame_data.eof):
if (frame_data.codec_id == K_MP4_CODEC_ID_H264 or frame_data.codec_id == K_MP4_CODEC_ID_H265):
data = uctypes.bytes_at(frame_data.data,frame_data.data_length)
print("video frame_data.codec_id:",frame_data.codec_id,"data_length:",frame_data.data_length,"timestamp:",frame_data.time_stamp)
# Calculate the duration of the video timestamp
video_timestamp_elapsed = frame_data.time_stamp - start_video_timestamp
# Calculate the duration experienced by the system timestamp
current_system_time = time.ticks_ms()
system_time_elapsed = current_system_time - start_system_time
# If the duration experienced by the system timestamp is less than that experienced by the video timestamp, delay it
if system_time_elapsed < video_timestamp_elapsed:
time.sleep_ms(video_timestamp_elapsed - system_time_elapsed)
elif(frame_data.codec_id == K_MP4_CODEC_ID_G711A or frame_data.codec_id == K_MP4_CODEC_ID_G711U):
print("audio frame_data.codec_id:",frame_data.codec_id,"data_length:",frame_data.data_length,"timestamp:",frame_data.time_stamp)
kd_mp4_destroy(mp4_handle.value)
demuxer_mp4("/sdcard/examples/test.mp4")
