NONAI2D CSC API Manual#
The K230 chip has 24 built-in hardware Color Space Conversion (CSC) channels, which can efficiently perform image color space conversions. This module supports various image format conversions including common formats such as RGB/YUV, making it suitable for video processing, image display, and similar applications.
API Reference#
Constructor#
Function
Initialize a CSC conversion channel
Syntax
from nonai2d import CSC
csc = CSC(chn, fmt, max_width=1920, max_height=1080, buf_num=2)
Parameter Description
Parameter |
Type |
Default |
chn |
int |
CSC channel number, range: 0–23 |
Required |
fmt |
int |
Target image format (see constant definitions) |
Required |
max_width |
int |
Maximum image width supported (in pixels) |
1920 |
max_height |
int |
Maximum image height supported (in pixels) |
1080 |
buf_num |
int |
Number of VB buffers allocated, affects processing performance |
2 |
Returns a CSC object on success, raises an exception on failure.
Important Notes
The CSC object must be initialized before calling
MediaManager.init()Channel numbers 0–23 must not be reused
It’s recommended to set
max_width/max_heightaccording to actual image size to save memory
convert Method#
Function
Perform image color space conversion
Syntax
result = csc.convert(frame, timeout_ms=1000, cvt=True)
Parameter |
Type |
Default |
frame |
py_video_frame_info |
Input image frame (from |
Required |
timeout_ms |
int |
Conversion timeout in milliseconds |
1000 |
cvt |
bool |
True |
Returns a converted Image object or py_video_frame_info, depending on the cvt parameter.
destroy Method#
Function
Release CSC channel resources
Syntax
csc.destroy()
After calling this method, all resources used by the CSC channel will be released, and the object can no longer be used.
Constant Definitions#
Image Format Constants#
Constant Name |
Typical Use Case |
PIXEL_FORMAT_GRAYSCALE |
Grayscale image format |
Black-and-white image processing |
PIXEL_FORMAT_RGB_565 |
RGB565 format (big-endian) |
LCD display |
PIXEL_FORMAT_RGB_565_LE |
RGB565 format (little-endian) |
Special display devices |
PIXEL_FORMAT_BGR_565 |
BGR565 format (big-endian) |
OpenCV compatibility |
PIXEL_FORMAT_BGR_565_LE |
BGR565 format (little-endian) |
PIXEL_FORMAT_RGB_888 |
RGB888 format |
High-quality image processing |
PIXEL_FORMAT_BGR_888 |
BGR888 format |
PIXEL_FORMAT_ARGB_8888 |
ARGB8888 format (with transparency) |
GUI composition |
PIXEL_FORMAT_YVU_PLANAR_420 |
YVU420 planar format |
Video decoding output |
PIXEL_FORMAT_YUV_SEMIPLANAR_420 |
YUV420 semi-planar format |
Video encoding input |
Best Practice Example#
import time, os, urandom, sys
from media.display import *
from media.uvc import *
DISPLAY_HEIGHT = 480
# hardware Color Space Converter
# use lcd as display output
# init media manager
plugin, dev = UVC.probe()
if plugin:
time.sleep_ms(100)
UVC.start(cvt = True)
clock = time.clock()
clock.tick()
img = UVC.snapshot()
if img is not None:
img = csc.convert(img)
Display.show_image(img)
print(clock.fps())
# deinit display
csc.destroy()
UVC.stop()
time.sleep_ms(100)
# release media buffer
