TCP Server Example Explanation#
Environment Preparation#
To ensure a smooth demonstration of TCP communication, we need to confirm that the following environment is correctly configured:
Hardware Connection#
  • Ensure that your CanMV development board and computer are connected to the same router or switch via Ethernet cable, forming a local area network (LAN).
  • Ensure that the router or switch is functioning properly to guarantee network connection stability.
Disable Firewall#
  • To avoid the firewall blocking TCP communication, it is recommended to temporarily disable the firewall on your computer.
Tool Preparation#
Obtain IP Address#
  • Open the Command Prompt (CMD), enter ipconfig, and query and record the IP address of the computer’s network card for subsequent configuration and testing.
Server Example Analysis#
Import Necessary Libraries#
import socket
import network
  • socket: Provides the functionality to create sockets, which is the foundation of network communication.
  • network: Used to configure network interfaces (such as LAN and WLAN).
  • time: Can be used for handling delay operations or network timeout control.
Define Service Content#
CONTENT = b"""
  • Defines the content that the server will send to the client. %d is used to insert the current connection count.
Create and Configure the Server#
def server():
    ip = network_use_wlan(True)  # Obtain the IP of the network interface
    # Create a socket and bind it to the specified address and port
    s.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)  # Allow address reuse
    ai = socket.getaddrinfo(ip, 8080)  # Get address information
    addr = ai[0][-1]  # Extract address and port number
    s.bind(addr)  # Bind the socket to the address and port
    s.listen(5)  # Start listening, allowing up to 5 clients to wait for connection
    print("tcp server %s port:%d\n" % (ip, 8080))
  • This part of the code creates a TCP server and binds it to the development board’s IP address and port 8080. listen(5) indicates that up to 5 clients are allowed to wait for connection.
Handle Client Connections#
counter = 1
    # Accept client connection
    res = s.accept()
    client_sock, client_addr = res  # Get client socket and address
    client_sock.setblocking(False)  # Set non-blocking mode
    # Send message to client
    client_sock.write(CONTENT % counter)
            h = client_sock.read()  # Try to read client data
            if h:
                print(h)
                client_sock.write(b"recv: " + h)  # Reply to client
            if b"end" in h:  # If "end" is received, close the connection
                client_sock.close()
            print("Error:", e)
            time.sleep(0.1)  # Wait a bit after encountering an error
    counter += 1
    if counter > 10:
        print("server exit!")
        s.close()  # Close the server
  • This code segment handles each client connection and loops to listen for data while communicating with the client. When the “end” character is received, the server closes the connection with that client.
  • To handle exceptions in non-blocking mode, try-except is used to manage potential errors during data reading.
Complete Code#
import socket
import network
import time, os
CONTENT = b"""
    if is_wlan:
        sta = network.WLAN(0)
        print(sta.status())
        print(sta.ifconfig())
        ip = sta.ifconfig()[0]
        return ip
        a = network.LAN()
        if not a.active():
        a.ifconfig("dhcp")
        print(a.ifconfig())
        ip = a.ifconfig()[0]
        return ip
def server():
    counter = 1
    addr = ai[0][-1]
    s.bind(addr)
    s.listen(5)
        res = s.accept()
        client_sock = res[0]
        client_addr = res[1]
        client_stream = client_sock
            h = client_stream.read()
            if h:
                print(h)
                client_stream.write(b"recv: " + h)
            if b"end" in h:
                client_stream.close()
        counter += 1
        if counter > 10:
            s.close()
server()
Operation Phenomenon and Instructions#
  1. Run the above server code and observe that the serial terminal will print the server’s IP address and port number.
../../_images/image-20240722162100719.png
  1. Open NetAssist Network Debugging Assistant, configure it as a TCP client, and enter the IP address and port number displayed by the server terminal, then click “Connect”:
../../_images/image-20240722162513633.png
  1. After a successful connection, the client will receive a message from the server.
