K230_Opencv调用UVC指南#
本文将讲解如何在k230开发板Linux侧驱动USB摄像头,并通过opencv调用uvc。
linux下UVC使用说明#
以k230-canmv为例
配置修改#
修改K230_SDK/src/little/linux/arch/riscv/configs/k230_canmv_defconfig配置文件,增加以下配置
CONFIG_MEDIA_USB_SUPPORT=y
CONFIG_USB_VIDEO_CLASS=y
修改K230_SDK/src/little/buildroot-ext/configs/k230_evb_defconfig配置文件,增加以下配置
BR2_PACKAGE_LIBV4L=y
BR2_PACKAGE_LIBV4L_UTILS=y
BR2_PACKAGE_OPENCV3=y
BR2_PACKAGE_OPENCV3_LIB_HIGHGUI=y
BR2_PACKAGE_OPENCV3_WITH_V4L=y
BR2_PACKAGE_OPENCV3_WITH_JPEG=y
BR2_PACKAGE_OPENCV3_WITH_PNG=y
修改完成后执行make,生成镜像并烧录
上板测试#
连接设备#
系统启动后,连接USB摄像头,系统会检测到USB设备插入,同时/dev目录下会生成/dev/video0 dev/video1两个设备文件
[root@canaan ~ ]#lsusb
Bus 001 Device 001: ID 1d6b:0002
Bus 002 Device 001: ID 1d6b:0002
[root@canaan ~ ]#[ 45.053193] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
[ 46.049135] usb 1-1: new full-speed USB device number 3 using dwc2
[ 46.261329] usb 1-1: not running at top speed; connect to a high speed hub
[ 46.269490] usb 1-1: config 1 interface 1 altsetting 1 endpoint 0x84 has invalid maxpacket 1024, setting to 1023
[ 46.279757] usb 1-1: config 1 interface 4 altsetting 0 endpoint 0x3 has invalid maxpacket 512, setting to 64
[ 46.290402] usb 1-1: New USB device found, idVendor=0380, idProduct=2006, bcdDevice= 0.20
[ 46.298651] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 46.305838] usb 1-1: Product: FHD Camera
[ 46.309790] usb 1-1: Manufacturer: ANYKA
[ 46.313728] usb 1-1: SerialNumber: 12345
[ 46.320244] uvcvideo: Unknown video format 35363248-0000-0010-8000-00aa00389b71
[ 46.327669] uvcvideo: Found UVC 1.00 device FHD Camera (0380:2006)
[ 46.342750] usbhid 1-1:1.4: couldn't find an input interrupt endpoint
Bus 001 Device 003: ID 0380:2006
[root@canaan ~ ]#ls /dev/video*
/dev/video0 /dev/video1
检查设备状态#
使用v4l2-ctl -d /dev/video0 --all命令查看摄像头信息
[root@canaan ~ ]#v4l2-ctl -d /dev/video0 --all
Driver Info:
Driver name : uvcvideo
Card type : FHD Camera: FHD Camera
Bus info : usb-91500000.usb-otg-1
Driver version : 5.10.4
Capabilities : 0x84a00001
Video Capture
Metadata Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Media Driver Info:
Model : FHD Camera: FHD Camera
Serial : 12345
Media version : 5.10.4
Hardware revision: 0x00000020 (32)
Interface Info:
Type : V4L Video
Entity Info:
Name : FHD Camera: FHD Camera
Function : V4L2 I/O
Flags : default
Pad 0x01000007 : 0: Sink
Link 0x0200000d: from remote pad 0x100000a of entity 'Processing 2': Data, Enabled, Immutable
Priority: 2
Video input : 0 (Camera 1: ok)
Format Video Capture:
Width/Height : 1920/1080
Pixel Format : 'MJPG' (Motion-JPEG)
Field : None
Bytes per Line : 0
Size Image : 4147200
Colorspace : Default
Transfer Function : Default (maps to Rec. 709)
YCbCr/HSV Encoding: Default (maps to ITU-R 601)
Quantization : Default (maps to Full Range)
Flags :
Crop Capability Video Capture:
Bounds : Left 0, Top 0, Width 1920, Height 1080
Default : Left 0, Top 0, Width 1920, Height 1080
Pixel Aspect: 1/1
Selection Video Capture: crop_default, Left 0, Top 0, Width 1920, Height 1080, Flags:
Selection Video Capture: crop_bounds, Left 0, Top 0, Width 1920, Height 1080, Flags:
Streaming Parameters Video Capture:
Capabilities : timeperframe
Frames per second: 30.000 (30/1)
Read buffers : 0
使用v4l获取图像#
使用v4l2-ctl --device /dev/video0 --stream-mmap --stream-to=video0-output.jpg --stream-count=1命令采集一张jpg图片
[root@canaan ~ ]#v4l2-ctl --device /dev/video0 --stream-mmap --stream-to=video0-
[root@canaan ~ ]#ls -lh
total 222K
-rw-r--r-- 1 root root 221.7K Jan 1 00:11 video0-output.jpg
使用opencv获取图像#
拷贝video_cap测试应用到文件系统中并执行,会生成一个test.jpg文件
[root@canaan ~ ]#./video_cap
[root@canaan ~ ]#ls
nfs test.jpg video_cap
video_cap可通过命令/opt/toolchain/Xuantie-900-gcc-linux-5.10.4-glibc-x86_64-V2.6.0/bin/riscv64-unknown-linux-gnu-g++ --sysroot=$HOME/k230/k230_sdk/output/k230_evb_defconfig/little/buildroot-ext/host/riscv64-buildroot-linux-gnu/sysroot video_cap.cpp -lopencv_videoio -lopencv_core -lopencv_imgcodecs -o video_cap来编译生成,video_cap.cpp源码如下:
#include "opencv2/opencv.hpp"
using namespace cv;
int main()
VideoCapture capture(0);
Mat frame;
capture>>frame;
imwrite("test.jpg", frame);
用户应用#
通过v4l接口去采集图像,具体请参考
v4l用户编程API或v4l-utils源码通过opencv接口去采集图像,具体请参考
opencv编程
