MP4 Module API Manual#
This document provides a detailed introduction to the functions and usage of the K230_CanMV MP4 module API. The MP4 module is mainly used for generating MP4 files. Developers do not need to focus on the underlying implementation details; they only need to call the provided APIs to generate MP4 files in different encoding formats and video resolutions.
API Introduction#
This module provides the MP4Container class, which includes the following methods:
MP4Container.Create#
Used to create an instance of MP4Container.
Syntax
MP4Container.Create(mp4Cfg)
Parameter Name
Input/Output
mp4cfg
MP4Container configuration
Input
Return Values
Success
Non-zero
Failure
MP4Container.Start#
Starts the MP4Container to begin processing data.
Syntax
MP4Container.Start()
Return Values
Success
Non-zero
Failure
MP4Container.Process#
Writes a frame of audio/video data into the MP4 file.
Syntax
MP4Container.Process()
Return Values
Success
Non-zero
Failure
MP4Container.Stop#
Stops the MP4Container from processing data.
Syntax
MP4Container.Stop()
Return Values
Success
Non-zero
Failure
MP4Container.Destroy#
Destroys the created instance of MP4Container.
Syntax
MP4Container.Destroy()
Return Values
Success
Non-zero
Failure
Data Structure Description#
Mp4CfgStr#
Configuration properties for MP4Container.
Definition
class Mp4CfgStr:
    def __init__(self, type):
        self.type = type
        self.muxerCfg = MuxerCfgStr()
    def SetMuxerCfg(self, fileName, videoPayloadType, picWidth, picHeight, audioPayloadType, fmp4Flag=0):
        self.muxerCfg.file_name = fileName
        self.muxerCfg.video_payload_type = videoPayloadType
        self.muxerCfg.pic_width = picWidth
        self.muxerCfg.pic_height = picHeight
        self.muxerCfg.audio_payload_type = audioPayloadType
        self.muxerCfg.fmp4_flag = fmp4Flag
Members
Member Name
MP4Container type: muxer/demuxer, currently only supports muxer
muxerCfg
Muxer configuration
MuxerCfgStr#
Configuration properties for MP4Container of muxer type.
Definition
class MuxerCfgStr:
    def __init__(self):
        self.file_name = 0
        self.video_payload_type = 0
        self.pic_width = 0
        self.pic_height = 0
        self.audio_payload_type = 0
Members
Member Name
file_name
Generated MP4 file name
video_payload_type
Video encoding format
pic_width
Video frame width
pic_height
Video frame height
audio_payload_type
Audio encoding format
Related Data Types and Interfaces#
  • MP4Container.Create
MP4Container Types#
Enumeration of MP4Container types.
Members
Member Name
MP4_CONFIG_TYPE_MUXER
Muxer type
MP4_CONFIG_TYPE_DEMUXER
Demuxer type, currently unsupported
video_payload_type#
Video encoding types.
Members
Member Name
MP4_CODEC_ID_H264
H.264 video encoding type
MP4_CODEC_ID_H265
H.265 video encoding type
audio_payload_type#
Audio encoding types.
Members
Member Name
MP4_CODEC_ID_G711U
G.711U audio encoding type
MP4_CODEC_ID_G711A
G.711A audio encoding type
Example Program#
Example 1#
from media.mp4format import *
def canmv_mp4_muxer_test():
    print("mp4_muxer_test starts")
    width = 1280
    height = 720
    # For BPI development boards, set the width and height to 640*360
    # width=640
    # height=360
    # Instantiate MP4 Container
    mp4_muxer = Mp4Container()
    mp4_cfg = Mp4CfgStr(mp4_muxer.MP4_CONFIG_TYPE_MUXER)
    if mp4_cfg.type == mp4_muxer.MP4_CONFIG_TYPE_MUXER:
        file_name = "/sdcard/examples/test.mp4"
        mp4_cfg.SetMuxerCfg(file_name, mp4_muxer.MP4_CODEC_ID_H265, width, height, mp4_muxer.MP4_CODEC_ID_G711U)
    # Create MP4 muxer
    mp4_muxer.Create(mp4_cfg)
    # Start MP4 muxer
    mp4_muxer.Start()
    frame_count = 0
            # Process audio-video data and write to file in MP4 format
            mp4_muxer.Process()
            frame_count += 1
            print("frame_count = ", frame_count)
            if frame_count >= 200:
        print(e)
    # Stop MP4 muxer
    mp4_muxer.Stop()
    # Destroy MP4 muxer
    mp4_muxer.Destroy()
    print("mp4_muxer_test stops")
