3.6 VENC Module API Manual#
1. Overview#
This manual provides a detailed introduction to the API of the K230_CanMV VENC module. Developers can use these APIs to perform video encoding, generating streams of different resolutions and encoding formats. The VENC module needs to be used in conjunction with the camera module to achieve encoding functionality.
2. API Introduction#
The VENC module provides the Encoder class, which includes the following methods:
2.1 Encoder.SetOutBufs#
Configures the output buffer of the encoder.
Syntax
Parameter Name
Input/Output
chn
Encoding channel number
Input
buf_num
Number of output buffers
Input
Width of the encoded image
Input
Height of the encoded image
Input
Success
Non-zero
Failure
Notes
Must be called before MediaManager.init()
2.2 Encoder.Create#
Creates an encoder instance.
Syntax
Encoder.Create(chn, chnAttr)
Parameter Name
Input/Output
chn
Input
chnAttr
Encoding channel attribute structure
Input
Success
Non-zero
Failure
Notes
VENC supports up to 4 encoding channels, with channel numbers ranging from [0, 3]. The 4th channel is fixed for IDE image transmission. Unless calling compress_for_ide, it is recommended to use only [0, 2].
2.3 Encoder.Start#
Starts the encoding process.
Syntax
Encoder.Start(chn)
Parameter Name
Input/Output
chn
Input
Success
Non-zero
Failure
2.4 Encoder.SendFrame#
Sends image data to the encoder for encoding.
Syntax
Parameter Name
Input/Output
chn
Input
frame_info
Raw image information structure
Input
Success
Non-zero
Failure
Notes
Can encode a full frame of data or a variable-length data stream.
2.5 Encoder.GetStream#
Gets a frame of encoded stream data.
Syntax
Parameter Name
Input/Output
chn
Input
streamData
Encoded stream structure
Output
Success
Non-zero
Failure
2.6 Encoder.ReleaseStream#
Releases a frame of stream buffer.
Syntax
Parameter Name
Input/Output
chn
Input
streamData
Input
Success
Non-zero
Failure
2.7 Encoder.Stop#
Stops the encoding process.
Syntax
Encoder.Stop(chn)
Parameter Name
Input/Output
chn
Input
2.8 Encoder.Destroy#
Destroys the encoder instance.
Syntax
Encoder.Destroy(chn)
Parameter Name
Input/Output
chn
Input
3. Data Structure Description#
3.1 ChnAttrStr#
Encoding channel attribute structure.
Definition
class ChnAttrStr:
    def __init__(self, payloadType, profile, picWidth, picHeight, gopLen=30):
        self.profile = profile
        self.pic_width = picWidth
        self.pic_height = picHeight
        self.gop_len = gopLen
Members
Member Name
payload_type
Encoding format (h264/h265)
profile
Encoding Profile
pic_width
Image width
pic_height
Image height
gop_len
Encoding GOP length
3.2 StreamData#
Stream structure.
Definition
class StreamData:
    def __init__(self):
        self.pack_cnt = 0
Members
Member Name
Stream data address
data_size
Stream data size
stream_type
Frame type
pack_cnt
Number of packs in the stream
Notes
VENC_PACK_CNT_MAX indicates the maximum number of packs in the stream structure, currently set to 12.
3.3 payload_type#
Encoding format type.
Members
Member Name
PAYLOAD_TYPE_H264
H.264 encoding format
PAYLOAD_TYPE_H265
H.265 encoding format
3.4 profile#
Encoding Profile.
Members
Member Name
H264_PROFILE_BASELINE
H.264 Baseline Profile
H264_PROFILE_MAIN
H.264 Main Profile
H264_PROFILE_HIGH
H.264 High Profile
H265_PROFILE_MAIN
H.265 Main Profile
3.5 stream_type#
Stream frame type.
Members
Member Name
STREAM_TYPE_HEADER
Stream Header
STREAM_TYPE_I
I Frame
STREAM_TYPE_P
P Frame
4. Example Programs#
4.1 Example 1#
Bind VENC to VICAP and save the obtained encoded data to a file.
from media.vencoder import *
from media.sensor import *
import time, os
    print("VENC test starts")
    venc_chn = VENC_CHN_ID_0
    width = ALIGN_UP(width, 16)
    venc_payload_type = K_PT_H264
    # Determine file extension
    if suffix == '264':
    elif suffix == '265':
        venc_payload_type = K_PT_H265
        return
    # Initialize sensor
    sensor = Sensor()
    sensor.reset()
    # Instantiate video encoder
    encoder = Encoder()
    # Bind camera and venc
    # Initialize media manager
    streamData = StreamData()
    # Create encoder
    # Start encoding
    encoder.Start(venc_chn)
    # Start camera
    sensor.run()
    frame_count = 0
    print("Save stream to file: ", file_name)
                encoder.GetStream(venc_chn, streamData)  # Get a frame of stream
                    fo.write(stream_data)  # Write stream to file
                    print("Stream size: ", streamData.data_size[pack_idx], "Stream type: ", streamData.stream_type[pack_idx])
                encoder.ReleaseStream(venc_chn, streamData)  # Release a frame of stream
                frame_count += 1
                if frame_count >= 200:
            print("User stop: ", e)
            import sys
            sys.print_exception(e)
    # Stop camera
    sensor.stop()
    # Destroy the binding of camera and venc
    del link
    # Stop encoding
    encoder.Stop(venc_chn)
    # Destroy encoder
    encoder.Destroy(venc_chn)
    # Clean buffer
    print("VENC test stops")
    vi_bind_venc_test("/sdcard/examples/test.264", 800, 480)  # Example of binding vi to venc
4.2 Example 2#
Encode VENC data stream and save it as a file. Here’s the translated text to English:
import time, os
def stream_venc_test(file_name, width=1280, height=720):
    print("venc_test start")
    # Determine file type
    if suffix == '264':
        return
    # Initialize sensor
    sensor = Sensor()
    sensor.reset()
    # Set camera output buffer
    # Set chn0 output size
    # Set chn0 output format
    encoder = Encoder()
    # Set video encoder output buffer
    # Create encoder
    # Start encoding
    # Start camera
    sensor.run()
    frame_count = 0
    yuv420sp_img = None
                if (yuv420sp_img == -1):
                    continue
                # frame_info.v_frame.phys_addr[1] = yuv420sp_img.phyaddr(1)
                    frame_info.v_frame.phys_addr[1] = frame_info.v_frame.phys_addr[0] + frame_info.v_frame.width * frame_info.v_frame.height + 1024
                    frame_info.v_frame.phys_addr[1] = frame_info.v_frame.phys_addr[0] + frame_info.v_frame.width * frame_info.v_frame.height + 3072
                encoder.SendFrame(venc_chn, frame_info)
                frame_count += 1
            print("user stop: ", e)
            import sys
    # Stop camera
    sensor.stop()
    # Stop encoding
    # Destroy encoder
    # Clean buffer
    print("venc_test stop")
    stream_venc_test("/sdcard/examples/test.264", 800, 480)  # VENC encoding data stream example
