NONAI2D CSC API Manual#
The K230 chip has 24 built-in hardware Color Space Conversion (CSC) channels, which can efficiently perform image color space conversions. This module supports various image format conversions including common formats such as RGB/YUV, making it suitable for video processing, image display, and similar applications.
API Reference#
Constructor#
Function Initialize a CSC conversion channel
Syntax
from nonai2d import CSC
csc = CSC(chn, fmt, max_width=1920, max_height=1080, buf_num=2)
Parameter Description
Parameter
Type
Default
chn
int
CSC channel number, range: 0–23
Required
fmt
int
Target image format (see constant definitions)
Required
max_width
int
Maximum image width supported (in pixels)
1920
max_height
int
Maximum image height supported (in pixels)
1080
buf_num
int
Number of VB buffers allocated, affects processing performance
Return Value Returns a CSC object on success, raises an exception on failure.
Important Notes
  1. The CSC object must be initialized before calling MediaManager.init()
  2. Channel numbers 0–23 must not be reused
  3. It’s recommended to set max_width/max_height according to actual image size to save memory
convert Method#
Function Perform image color space conversion
Syntax
result = csc.convert(frame, timeout_ms=1000, cvt=True)
Parameter
Type
Default
frame
py_video_frame_info
Input image frame (from Sensor.snapshot)
Required
timeout_ms
int
Conversion timeout in milliseconds
1000
cvt
bool
True returns an Image object, False returns py_video_frame_info
True
Return Value Returns a converted Image object or py_video_frame_info, depending on the cvt parameter.
destroy Method#
Function Release CSC channel resources
Syntax
csc.destroy()
Description After calling this method, all resources used by the CSC channel will be released, and the object can no longer be used.
Constant Definitions#
Image Format Constants#
Constant Name
Typical Use Case
PIXEL_FORMAT_GRAYSCALE
Grayscale image format
Black-and-white image processing
PIXEL_FORMAT_RGB_565
RGB565 format (big-endian)
LCD display
PIXEL_FORMAT_RGB_565_LE
RGB565 format (little-endian)
Special display devices
PIXEL_FORMAT_BGR_565
BGR565 format (big-endian)
OpenCV compatibility
PIXEL_FORMAT_BGR_565_LE
BGR565 format (little-endian)
PIXEL_FORMAT_RGB_888
RGB888 format
High-quality image processing
PIXEL_FORMAT_BGR_888
BGR888 format
PIXEL_FORMAT_ARGB_8888
ARGB8888 format (with transparency)
GUI composition
PIXEL_FORMAT_YVU_PLANAR_420
YVU420 planar format
Video decoding output
YUV420 semi-planar format
Video encoding input
Best Practice Example#
import time, os, urandom, sys
from media.display import *
from media.uvc import *
DISPLAY_HEIGHT = 480
# hardware Color Space Converter
# use lcd as display output
# init media manager
    plugin, dev = UVC.probe()
    if plugin:
    time.sleep_ms(100)
UVC.start(cvt = True)
clock = time.clock()
    clock.tick()
    img = UVC.snapshot()
    if img is not None:
        img = csc.convert(img)
        Display.show_image(img)
    print(clock.fps())
# deinit display
csc.destroy()
UVC.stop()
time.sleep_ms(100)
# release media buffer
