K230 System Control API Reference#
The products, services, or features you purchase are subject to the commercial contracts and terms of Beijing Canaan Creative Information Technology Co., Ltd. (“the Company”, hereinafter referred to as such) and its affiliates. Some or all of the products, services, or features described in this document may not be within the scope of your purchase or use. Unless otherwise agreed in the contract, the Company does not provide any express or implied statements or warranties regarding the accuracy, reliability, completeness, merchantability, fitness for a particular purpose, or non-infringement of any representations, information, or content in this document. Unless otherwise agreed, this document is for reference and guidance purposes only.
Trademark Statement#
Copyright © 2023 Beijing Canaan Creative Information Technology Co., Ltd. All rights reserved. Without the Company’s written permission, no unit or individual is allowed to excerpt, copy any part or all of the contents of this document, or spread it in any form.
Table of Contents#
This document mainly introduces the functions and usage of the system control module in the media subsystem. The functions and usage of other modules will be discussed in separate documents.
Audience#
Technical Support Engineers
Abbreviation Definitions#
Abbreviation |
mpp |
Media Process Platform |
vb |
Video Buffer |
Document Version |
Author |
Date |
Initial Version |
Haibo Hao |
2023/3/4 |
System control, based on the characteristics of the K230 chip, completes the reset and basic initialization of various hardware components. It is also responsible for initializing and de-initializing modules such as MPP (Media Process Platform) system memory management, log management, and binding management.
Function Description#
Video Buffer Pool#
The video buffer pool is a group of buffers (not just one), mainly provided for use by multimedia hardware devices and circulated between these devices. The buffer pool is divided into public and private buffer pools. The public buffer pool is mainly for VI, and the size of the buffer blocks must be determined according to the image parameters of VI before using it, and then a certain number of buffer blocks are applied for to form a buffer pool. Generally, for the original image input by VI, the size of one frame corresponds to the size of one buffer block, and multiple buffer blocks provide a multi-frame buffering mechanism for VI. These public buffer blocks can also be used by VO or VENC. Private buffer pools often represent data stored in memory that is closely related to the multimedia device itself. For example, the encoded bitstream data is quite different from the actual image pixel composition of the video stream. These bitstreams are only available to the codec, and VB provides dedicated buffer pools for these devices. The following diagram shows the process of virtual VI and virtual VO using VB to circulate buffer blocks.
System Binding#
System binding establishes an association between the data receiver and the data source (only allowing the data receiver to bind the data source). After binding, the data generated by the data source will be automatically sent to the receiver. The major voice and video processing of K230 is divided into several major modules as follows:
Voice: Audio Input (AI), Audio Encoder (AENC), Audio Recognize (AREC), Audio Decoder (ADEC), Audio Output (AO)
Image: Video Input (VI), Video Encoder (VENC), Image Rotation (handled by GSDMA), Depth Process Unit (DPU), Video Decoder (VDEC), Video Output (VO), Virtual Video Input (VVI), Virtual Video Output (VVO)
The binding relationships supported by K230 are as follows:
Table 11
Data Source |
Data Receiver |
VI (Video Input) |
GSDMA |
VI data can be sent to GSDMA for rotation processing |
VO |
VI data can be directly sent to VO for display |
DPU |
VI data can be directly sent to DPU for processing |
VENC |
VI data can be directly sent to VENC for processing |
GSDMA (Image Rotation) |
VO |
GSDMA processed data can be directly sent to VO for display |
DPU |
GSDMA processed data can be directly sent to DPU for processing |
VENC |
VPROC processed data can be directly sent to VENC for encoding |
VDEC (Video Decoder) |
GSDMA |
VDEC data will eventually be played locally, may need rotation before playback |
VO |
VDEC data will eventually be played locally |
DPU (Depth Processing Unit) |
None |
DPU is the endpoint of video data, does not support binding relationships |
VENC (Video Encoder) |
None |
Does not support binding relationships |
VO (Video Output) |
None |
VO is the endpoint of video data, does not support binding relationships |
AI (Audio Input) |
AREC |
AI processed data can be directly sent to the audio recognition module for recognition |
AENC |
AI processed data can be directly sent to the audio encoding module for encoding |
AO |
AI processed data can be directly played |
ADEC (Audio Decoder) |
AO |
ADEC processed data can be directly played |
AENC (Audio Encoder) |
None |
AO (Audio Output) |
None |
AO is the endpoint of audio data, does not support binding relationships |
API Reference#
Multimedia Memory Management#
kd_mpi_sys_mmz_alloc#
Description:
Allocate MMZ memory in user space.
Syntax:
Parameters:
Parameter Name |
Input/Output |
phy_addr |
Pointer to the physical address. |
Output |
virt_addr |
Pointer to the virtual address pointer. |
Output |
mmb |
String pointer to the MMB name. |
Input |
zone |
String pointer to the MMZ zone name. |
Input |
len |
Size of the memory block. |
Input |
Return Values:
Return Value |
Success |
Non-0 |
Failure, see Error Codes for details |
Chip Differences:
None.
Requirements:
Header file: mpi_sys_api.h
Library file: libsys.a
Notes:
MMZ consists of multiple zones, each zone has multiple MMBs. You can call this MPI to allocate a memory block of size len in the *zone of MMZ. In this case, pointers to the physical address and user-mode virtual address are returned. If there is an anonymous zone in MMZ, set *zone to null. If *mmb is set to null, the created MMB is named null.
None.
Related Topics:
None.
kd_mpi_sys_mmz_alloc_cached#
Description:
Allocate cached MMZ memory in user space.
Syntax:
Parameters:
Parameter Name |
Input/Output |
phy_addr |
Output |
virt_addr |
Output |
mmb |
Input |
zone |
Input |
len |
Input |
Return Values:
Return Value |
Success |
Non-0 |
Chip Differences:
None.
Requirements:
Notes:
The difference between kd_mpi_sys_mmz_alloc_cached and kd_mpi_sys_mmz_alloc: Memory allocated by calling kd_mpi_sys_mmz_alloc_cached supports caching. If the memory to be allocated will be frequently used, it is recommended to use kd_mpi_sys_mmz_alloc_cached. This can improve CPU read/write efficiency and system performance.
When the CPU accesses the memory allocated by this interface, the data in the memory will be placed in the cache. Hardware devices can only access physical memory, not the cache. In this case, kd_mpi_sys_mmz_flush_cache needs to be called to synchronize the data.
None.
Related Topics:
None.
kd_mpi_sys_mmap#
Description: Description:
Memory mapping interface.
Syntax:
Parameters:
Parameter Name |
Input/Output |
phy_addr |
Starting address of the memory unit to be mapped |
Input |
size |
Number of bytes to map |
Input |
Return Values:
Return Value |
Invalid address |
Non-0 |
Valid address |
Chip Differences:
Requirements:
Notes:
Only the physical addresses obtained through MMZ allocation can be mapped using this API.
If the address range belongs to a VB, the size of the mapping must be smaller than the size of the VB pool.
Related Topics:
kd_mpi_sys_mmap_cached#
Description:
Memory mapping interface with cache.
Syntax:
Parameters:
Parameter Name |
Input/Output |
phy_addr |
Input |
size |
Input |
Return Values:
Return Value |
Invalid address |
Non-0 |
Valid address |
Chip Differences:
Requirements:
Notes:
Related Topics:
kd_mpi_sys_munmap#
Description:
Memory unmapping interface.
Syntax:
Parameters:
Parameter Name |
Input/Output |
virt_addr |
Virtual address returned by mmap |
Input |
size |
Number of bytes to unmap |
Input |
Return Values:
Return Value |
Success |
Non-0 |
Failure |
Chip Differences:
Requirements:
Notes:
Related Topics:
kd_mpi_sys_mmz_flush_cache#
Description:
Flush the contents of the cache to memory and invalidate the cache contents.
Syntax:
Parameters:
Parameter Name |
Input/Output |
phy_addr |
Starting physical address of the data to operate on |
Input |
virt_addr |
Starting virtual address pointer of the data to operate on. Cannot be NULL |
Input |
size |
Size of the data to operate on |
Input |
Return Values:
Return Value |
Success |
Non-0 |
Chip Differences:
Requirements:
Notes:
If the cache contains the latest data, you need to call this MPI to synchronize the data to memory. This ensures that hardware that cannot directly access the cache can obtain the correct data.
You must call kd_mpi_sys_mmz_alloc_cached before using this MPI.
If phy_addr is set to 0, it means to operate on the entire cache area. (Not supported currently)
You need to ensure that the parameters passed are valid.
Ensure that kd_mpi_sys_mmz_free is not called to free the memory being flushed; otherwise, unpredictable exceptions may occur.
Related Topics:
kd_mpi_sys_mmz_free#
Description:
Free MMZ memory in user space.
Syntax:
Parameters:
Parameter Name |
Input/Output |
phy_addr |
Physical address |
Input |
virt_addr |
Virtual address pointer |
Input |
Return Values:
Return Value |
Success |
Non-0 |
Chip Differences:
Requirements:
Notes:
The input address must be a valid physical address, and the virtual address pointer can be set to NULL.
Do not free memory that is undergoing a flush operation, as it may cause unpredictable exceptions.
Related Topics:
kd_mpi_sys_get_virmem_info#
Description:
Get the memory information corresponding to the virtual address, including the physical address and cached attributes.
Syntax:
Parameters:
Parameter Name |
Input/Output |
virt_addr |
Input |
mem_info |
Memory information corresponding to the virtual address, including physical address, cached attributes, etc. |
Output |
Return Values:
Return Value |
Success |
Non-0 |
Chip Differences:
Requirements:
Header file: mpi_sys_api.h k_mmz_comm.h
Notes:
The input must be a user-space virtual address.
Cross-process use is not supported.
Related Topics:
kd_mpi_vb_set_config#
Description:
Set MPP video buffer pool attributes.
Syntax:
k_s32 kd_mpi_vb_set_config(const [k_vb_config](#k_vb_config) *config);
Parameters:
Parameter Name |
Input/Output |
config |
Pointer to the video buffer pool attributes |
Input |
Return Values:
Return Value |
Success |
Non-0 |
Chip Differences:
Requirements:
Header file: mpi_vb_api.h k_vb_comm.h
Library file: libvb.a
Notes:
The buffer pool attributes can only be set when the system is uninitialized; otherwise, the function will return failure.
The size of each buffer block in the common buffer pool should vary according to the current image pixel format and whether the image is compressed. For specific allocation sizes, refer to the description in the k_vb_config structure.
Related Topics:
kd_mpi_vb_get_config#
Description:
Get MPP video buffer pool attributes.
Syntax:
k_s32 kd_mpi_vb_get_config(const [k_vb_config](#k_vb_config) *config);
Parameters:
Parameter Name |
Input/Output |
config |
Output |
Return Values:
Return Value |
Success |
Non-0 |
Chip Differences:
Requirements:
Notes:
You must first call kd_mpi_vb_set_config to set the MPP video buffer pool attributes before getting the attributes.
Related Topics:
kd_mpi_vb_init#
Description:
Initialize the MPP video buffer pool.
Syntax:
k_s32 kd_mpi_vb_init(void);
Parameters:
Return Values:
Return Value |
Success |
Non-0 |
Chip Differences:
Requirements:
Notes:
You must first call kd_mpi_vb_set_config to set the MPP video buffer pool attributes before initializing the buffer pool; otherwise, it will fail.
Initialization can be repeated without returning failure.
Related Topics:
kd_mpi_vb_exit#
Description:
Deinitialize the MPP video buffer pool.
Syntax:
k_s32 kd_mpi_vb_exit(void);
Parameters:
Return Values:
Return Value |
Success |
Non-0 |
Chip Differences:
Requirements:
Notes:
Deinitialization does not clear previous buffer pool configurations.
Deinitialization can be repeated without returning failure.
Before exiting the VB pool, ensure that no VB in the VB pool is occupied; otherwise, it cannot be exited.
Related Topics:
kd_mpi_vb_create_pool#
Description:
Create a video buffer pool.
Syntax:
k_s32 kd_mpi_vb_create_pool([k_vb_pool_config](#k_vb_pool_config) *config);
Parameters:
Parameter Name |
Input/Output |
config |
Pointer to the buffer pool configuration attributes |
Input |
Return Values:
Return Value |
Non VB_INVALID_POOLID |
Valid buffer pool ID |
VB_INVALID_POOLID |
Failed to create buffer pool, possibly due to illegal parameters or insufficient reserved memory |
Chip Differences:
Requirements:
Notes:
Related Topics:
kd_mpi_vb_destory_pool#
Description:
Destroy a video buffer pool.
Syntax:
Parameters:
Parameter Name |
Input/Output |
pool_id |
Buffer pool ID. Value range: [0, VB_MAX_POOLS) |
Input |
Return Values:
Return Value |
Success |
Non-0 |
Chip Differences:
Requirements:
Notes:
Destroying a non-existent buffer pool will return K_ERR_VB_UNEXIST.
Only buffer pools created by kd_mpi_vb_create_pool can be destroyed.
Related Topics:
kd_mpi_vb_get_block#
Description:
Acquire a buffer block in user mode.
Syntax:
Parameters:
Parameter Name |
Input/Output |
pool_id |
Buffer pool ID. Range: [0, VB_MAX_POOLS) |
Input |
blk_size |
Buffer block size in bytes. Range: full data type range |
Input |
mmz_name |
Name of the DDR where the buffer pool is located |
Input |
Return Values:
Return Value |
Non VB_INVALID_HANDLE |
Valid buffer block handle |
VB_INVALID_HANDLE |
Failed to get buffer block |
Chip Differences:
Requirements:
Notes:
Users can call this interface to get a buffer block from a created buffer pool by setting the first parameter
pool_idto the created buffer pool ID. When getting a buffer block from a specified buffer pool, themmz_nameparameter is invalid.If users need to get a buffer block of a specified size from any common buffer pool, they can set the first parameter
pool_idto an invalid ID (VB_INVALID_POOLID), set the second parameterblk_sizeto the required buffer block size, and specify which DDR’s common buffer pool to get the buffer block from. If there is no common buffer pool on the specified DDR, no buffer block will be obtained. Ifmmz_nameis NULL, it means to get the buffer block from the anonymous DDR’s common buffer pool.
Related Topics:
Description:ase_block](#kd_mpi_vb_release_block)
kd_mpi_vb_release_block#
Description:
Release a buffer block in user mode.
Syntax:
Parameters:
Parameter Name |
Input/Output |
block |
Buffer block handle |
Input |
Return Values:
Return Value |
Success |
Non-0 |
Chip Differences:
Requirements:
Notes:
The acquired buffer block should be released using this interface after use.
Related Topics:
Description:block](#2115-kd_mpi_vb_get_block)
kd_mpi_vb_phyaddr_to_handle#
Description:
Get the handle of a buffer block through its physical address in user mode.
Syntax:
Parameters:
Parameter Name |
Input/Output |
phys_addr |
Physical address |
Input |
Return Values:
Return Value |
VB_INVALID_HANDLE |
Failed to get buffer block handle |
Chip Differences:
Requirements:
Notes:
The physical address should be the address of a valid buffer block obtained from the MPP video buffer pool.
Related Topics:
Description:
kd_mpi_vb_handle_to_phyaddr#
Description:
Get the physical address of a buffer block in user mode.
Syntax:
Parameters:
Parameter Name |
Input/Output |
block |
Input |
Return Values:
Return Value |
Invalid return value, illegal buffer block handle |
Non-0 |
Valid physical address |
Chip Differences:
Requirements:
Notes:
The specified buffer block should be a valid buffer block obtained from the MPP video buffer pool.
Related Topics:
Description:
kd_mpi_vb_handle_to_pool_id#
Description:
Get the ID of the buffer pool where a frame buffer block is located in user mode.
Syntax:
Parameters:
Parameter Name |
Input/Output |
block |
Input |
Return Values:
Return Value |
VB_INVALID_POOLID |
Failed to get buffer pool ID |
Chip Differences:
Requirements:
Notes:
Related Topics:
Description:
kd_mpi_vb_inquire_user_cnt#
Description:
Query the usage count information of a buffer block.
Syntax:
Parameters:
Parameter Name |
Input/Output |
block |
Input |
Return Values:
Return Value |
K_FAILED |
Query failed |
Other values |
Buffer block usage count |
Chip Differences:
Requirements:
Notes:
Related Topics:
Description:
kd_mpi_vb_get_supplement_attr#
Description:
Get the supplementary information of VB Block memory.
Syntax:
Parameters:
Parameter Name |
Input/Output |
block |
Input |
supplement |
Supplementary information of VB block memory, such as ISP information, DCF information, etc. |
Output |
Return Values:
Return Value |
Success |
Non-0 |
Chip Differences:
Requirements:
Notes:
The virtual address information of the DCF and ISP stored in Supplement is the kernel-mode virtual address.
Related Topics:
Description:
kd_mpi_vb_set_supplement_config#
Description:
Set the supplementary information of VB memory.
Syntax:
Parameters:
Parameter Name |
Input/Output |
supplement_config |
VB memory supplementary information control structure for supplementary information memory allocation |
Input |
Return Values:
Return Value |
Success |
Non-0 |
Chip Differences:
Requirements:
Notes:
Currently, two types of VB memory supplementary information are supported:
DCF information, corresponding to the structure k_jpeg_dcf. The corresponding MASK is VB_SUPPLEMENT_JPEG_MASK.
ISP information, corresponding to the structure k_isp_frame_info. The corresponding MASK is VB_SUPPLEMENT_ISPINFO_MASK.
This interface needs to be called before kd_mpi_vb_init for the supplementary information to take effect.
Related Topics:
Description:supplement_config](#2123-kd_mpi_vb_get_supplement_config)
kd_mpi_vb_get_supplement_config#
Description:
Get the supplementary information of VB memory.
Syntax:
k_s32 kd_mpi_vb_get_supplement_config(const k_vb_supplement_config *supplement_config);
Parameters:
Parameter Name |
Input/Output |
supplement_config |
Output |
Return Values:
Return Value |
Success |
Non-0 |
Chip Differences:
Requirements:
Notes:
Related Topics:
Description:supplement_config](#2122-kd_mpi_vb_set_supplement_config)
kd_mpi_vb_set_mod_pool_config#
Description:
Set the attributes of the module’s common video buffer pool.
Syntax:
Parameters:
Parameter Name |
Input/Output |
vb_uid |
Module ID using the common video buffer pool |
Input |
config |
Pointer to video buffer pool attributes |
Input |
Return Values:
Return Value |
Success |
Non-0 |
Chip Differences:
Requirements:
Notes:
The configuration of the module’s common video buffer pool should be based on actual needs, otherwise it may cause memory waste.
If the module VB has already been created, reconfiguration will return the error code KD_ERR_VB_BUSY.
Related Topics:
Description:mod_pool_config](#2125-kd_mpi_vb_get_mod_pool_config)
kd_mpi_vb_get_mod_pool_config#
Description:
Get the attributes of the module’s common video buffer pool.
Syntax:
Parameters:
Parameter Name |
Input/Output |
vb_uid |
Input |
config |
Output |
Return Values:
Return Value |
Success |
Non-0 |
Chip Differences:
Requirements:
Notes:
You must call kd_mpi_vb_set_mod_pool_config to set the attributes of the module’s common video buffer pool before getting the attributes.
Related Topics:
Description:mod_pool_config](#2124-kd_mpi_vb_set_mod_pool_config)
kd_mpi_vb_init_mod_common_pool#
Description:
Initialize the module’s common video buffer pool.
Syntax:
Parameters:
Parameter Name |
Input/Output |
vb_uid |
Input |
Return Values:
Return Value |
Success |
Non-0 |
Chip Differences:
Requirements:
Notes:
You must first call kd_mpi_vb_init to initialize the common video buffer pool.
You must first call kd_mpi_vb_set_mod_pool_config to configure the buffer pool attributes before initializing the buffer pool, otherwise it will fail.
It can be initialized repeatedly without returning failure.
Related Topics:
Description:_mod_common_pool](#2127-kd_mpi_vb_exit_mod_common_pool)
kd_mpi_vb_exit_mod_common_pool#
Description:
Exit the module’s common video buffer pool.
Syntax:
Parameters:
Parameter Name |
Input/Output |
vb_uid |
Module ID using the common video buffer pool. |
Input |
Return Values:
Return Value |
Success |
Non-0 |
Chip Differences:
Requirements:
Notes:
You must call this interface before calling kd_mpi_vb_exit, otherwise it will return failure.
Exiting will clear the previous configuration of the module’s common video buffer pool.
It can be exited repeatedly without returning failure.
Ensure that no VB in the VB pool is occupied before exiting the VB pool, otherwise it cannot be exited.
Related Topics:
System Binding#
kd_mpi_sys_unbind Description:et_bind_by_dest](#223-kd_mpi_sys_get_bind_by_dest)
kd_mpi_sys_bind#
Description:
Interface for binding data source to data receiver.
Syntax:
Parameters:
Parameter Name |
Input/Output |
src_chn |
Pointer to source channel. |
Input |
dest_chn |
Pointer to destination channel. |
Input |
Return Values:
Return Value |
Success |
Non-0 |
Chip Differences:
Requirements:
Header file: mpi_sys_api.h k_module.h
Notes:
For the currently supported binding relationships, please refer to Table 1-1.
A single data receiver can only bind to one data source.
Binding refers to establishing an association between the data source and the data receiver. After binding, the data generated by the data source will be automatically sent to the receiver.
Related Topics:
Description:ind](#222-kd_mpi_sys_unbind)
kd_mpi_sys_unbind#
Description:
Interface for unbinding data source from data receiver.
Syntax:
Parameters:
Parameter Name |
Input/Output |
src_chn |
Input |
dest_chn |
Input |
Return Values:
Return Value |
Success |
Non-0 |
Chip Differences:
Requirements:
Notes:
If the destination channel cannot find the bound source channel, it will return success directly. If it finds the bound source channel but it does not match the provided source channel, it will return failure.
Related Topics:
Description:d](#221-kd_mpi_sys_bind)
kd_mpi_sys_get_bind_by_dest#
Description:
Get information about the source channel bound to this destination channel.
Syntax:
Parameters:
Parameter Name |
Input/Output |
src_chn |
Output |
dest_chn |
Input |
Return Values:
Return Value |
Success |
Non-0 |
Chip Differences:
Requirements:
Notes:
Related Topics:
Log Management#
kd_mpi_log_set_console Description:et_console](#237-kd_mpi_log_get_console)
kd_mpi_log_set_level_conf#
Description:
Set the log level.
Syntax:
Parameters:
Parameter Name |
Input/Output |
conf |
Log level information structure. |
Input |
Return Values:
Return Value |
Success |
Non-0 |
Chip Differences:
Requirements:
Header file: mpi_sys_api.h k_module.h k_log_comm.h
Notes:
When the mod_name member in conf is set to the string “all”, it will set the log level for all modules. Otherwise, it will only set the log level for the module specified by mod_id.
Related Topics:
Description:_level_conf](#232-kd_mpi_log_get_level_conf)
kd_mpi_log_get_level_conf#
Description:
Get the log level.
Syntax:
Parameters:
Parameter Name |
Input/Output |
conf->mod_id |
Module ID for which to get the log level. |
Input |
conf->level |
Retrieved log level |
Output |
conf->mod_name |
Module name |
Output |
Return Values:
Return Value |
Success |
Non-0 |
Chip Differences:
Requirements:
Notes:
Related Topics:
Description:_level_conf](#231-kd_mpi_log_set_level_conf)
kd_mpi_log_set_wait_flag#
Description:
Set the wait flag when reading logs.
Syntax:
Parameters:
Parameter Name |
Input/Output |
is_wait |
Wait flag when reading logs. |
Input |
Return Values:
Return Value |
Success |
Non-0 |
Chip Differences:
Requirements:
Notes:
Related Topics:
Description:
kd_mpi_log_read#
Description:
Read logs.
Syntax:
Parameters:
Parameter Name |
Input/Output |
buf |
Memory pointer to store the logs. |
Output |
size |
Size of the logs to read. |
Input |
Return Values:
Return Value |
Greater than or equal to 0 |
Size of the successfully read logs. |
Chip Differences:
Requirements:
Notes:
Related Topics:
Description:
kd_mpi_log_close#
Description:
Close the log file.
Syntax:
void kd_mpi_log_close(void);
Parameters:
Return Values:
Chip Differences:
Requirements:
Notes:
Related Topics:
Description:
kd_mpi_log_set_console#
Description:
Configure whether the logs are printed directly through the console.
Syntax:
Parameters:
Parameter Name |
Input/Output |
is_console |
Whether to print through the console |
Input |
Return Values:
Return Value |
Success |
Non-0 |
Chip Differences:
Requirements:
Notes:
Related Topics:
Description:_console](#237-kd_mpi_log_get_console)
kd_mpi_log_get_console#
Description:
Get whether the logs are printed directly through the console.
Syntax:
k_s32 kd_mpi_log_get_console(k_bool is_console);
Parameters:
Parameter Name |
Input/Output |
is_console |
Output |
Return Values:
Return Value |
Success |
Non-0 |
Chip Differences:
Requirements:
Notes:
Related Topics:
Data Types#
Common Data Types#
k_mod_id Description:312-k_mpp_chn)
k_mod_id#
Description:
Defines the module ID enumeration type. Definition:
K_ID_CMPI = 0, /*< Common module platform interface */
K_ID_LOG = 1, /*< MPI device log */
K_ID_MMZ = 2, /*< Media memory zone */
K_ID_MMZ_USER_DEV = 3, /*< Media memory zone user used */
K_ID_VB = 4, /*< Video buffer device */
K_ID_SYS = 5, /*< System control device */
K_ID_VI = 6, /*< Video input device */
K_ID_VPROC = 7, /*< Video processing device */
K_ID_VREC = 8, /*< Video recognition device */
K_ID_VENC = 9, /*< Video encoding device */
K_ID_VDEC = 10, /*< Video decoding device */
K_ID_VO = 11, /*< Video output device */
K_ID_AI = 12, /*< Audio input device */
K_ID_AREC = 13, /*< Audio recognition device */
K_ID_AENC = 14, /*< Audio encoding device */
K_ID_ADEC = 15, /*< Audio decoding device */
K_ID_AO = 16, /*< Audio output device */
K_ID_DPU = 17, /*< Depth Processing Unit */
K_ID_V_VI, /*< Virtual video input device */
K_ID_V_VO, /*< Virtual video output device */
K_ID_DMA, /*< DMA device */
K_ID_BUTT, /*< Invalid */
} k_mod_id;
Notes:
Description:
k_mpp_chn#
Description:
Definition:
} k_mpp_chn;
Members:
Member Name |
mod_id |
Module ID |
dev_id |
Device ID |
chn_id |
Channel ID |
Notes:
k_vb_remap_mode Description:ent_config](#326-k_vb_supplement_config)
VB_MAX_POOLS#
Description:
Maximum number of video buffer pools.
Definition:
Notes:
Description:
k_vb_uid#
Description:
Definition:
VB_UID_VI = 0,
VB_UID_VPROC = 1,
VB_UID_VREC = 2,
VB_UID_VENC = 3,
VB_UID_VDEC = 4,
VB_UID_VO = 5,
VB_UID_USER = 6,
VB_UID_AI = 7,
VB_UID_AREC = 8,
VB_UID_AENC = 9,
VB_UID_ADEC = 10,
VB_UID_AO = 11,
VB_UID_V_VI = 12,
VB_UID_V_VO = 13,
VB_UID_DMA = 14,
VB_UID_BUTT = 15,
} k_vb_uid;
Notes:
Description:
k_vb_config#
Description:
Defines the video buffer pool attribute structure.
Definition:
k_u32 max_pool_cnt;
} k_vb_config;
Members:
Member Name |
max_pool_cnt |
Number of buffer pools that can be accommodated in the system. |
comm_pool |
Public buffer pool attribute structure. |
Notes:
If
blk_sizeis 0 orblk_cntis 0, the corresponding buffer pool will not be created.It is recommended to memset the entire structure to 0 before assigning values as needed.
Description:_config
k_vb_pool_config#
Description:
Definition:
} k_vb_pool_config;
Members:
Member Name |
blk_size |
Size of each buffer block in bytes. |
blk_cnt |
Number of buffer blocks in each buffer pool. |
mode |
Kernel mode virtual address mapping mode of the VB |
mmz_name |
Name of the MMZ from which the current buffer pool allocates memory. |
Notes:
blk_sizeshould be calculated based on the current image width, pixel format, data bit width, whether it is compressed, etc.The buffer pool is allocated from the free MMZ memory, and a buffer pool contains several buffer blocks of the same size. If the size of the buffer pool exceeds the free space in the reserved memory, the creation of the buffer pool will fail.
The user must ensure that the input DDR name already exists. If the input DDR name does not exist, memory allocation will fail. If the
mmz_namearray is memset to 0, it means that the buffer pool is created in unnamed DDR.
kd_mpi_vb_set_config Description:eate_pool](#2113-kd_mpi_vb_create_pool)
k_vb_remap_mode#
Description:
Defines the VB kernel mode virtual address mapping mode.
Definition:
VB_REMAP_MODE_NONE = 0, /*< No remap */
VB_REMAP_MODE_NOCACHE = 1, /*< No cache remap */
VB_REMAP_MODE_CACHED = 2, /*< Cache remap, if you use this mode, you should flush cache by yourself */
VB_REMAP_MODE_BUTT
} k_vb_remap_mode;
Members:
Member Name |
VB_REMAP_MODE_NONE |
No remap. |
VB_REMAP_MODE_NOCACHE |
No cache remap. |
VB_REMAP_MODE_CACHED |
Cache remap. |
Notes:
Description:
k_vb_supplement_config#
Description:
Defines the VB supplementary information structure.
Definition:
k_u32 supplement_config; /*< Control of the auxiliary information*/
} k_vb_supplement_config;
Members:
Member Name |
supplement_config |
Auxiliary information control |
Notes:
Currently supports two types of supplementary information. For details, please refer to the description of the interface kd_mpi_vb_set_supplement_config.
Common Video Data Types#
Description:at](#3314-k_pixel_format)
k_video_frame_info#
Description:
Defines the video frame information structure.
Definition:
} k_video_frame_info;
Members:
Member Name |
v_frame |
Video picture frame. |
pool_id |
Video buffer pool ID. |
mod_id |
Logical unit that generated the current frame data. |
Notes:
Description:(#332-k_video_frame)
k_video_frame#
Description:
Definition:
k_video_field field; /*< Video frame field*/
k_video_format video_format;
k_color_gamut color_gamut;
k_u32 header_stride[3];
k_u32 stride[3];
k_u64 header_phys_addr[3];
k_u64 header_virt_addr[3];
k_u64 phys_addr[3];
k_u64 virt_addr[3];
k_s16 offset_top; /* Top offset of show area */
k_s16 offset_bottom; /* Bottom offset of show area */
k_s16 offset_left; /* Left offset of show area */
k_s16 offset_right; /* Right offset of show area */
k_u32 time_ref;
k_u64 pts;
k_u64 priv_data;
} k_video_frame;
Members:
Member Name |
Picture width |
Picture height |
field |
Frame field mode |
pixel_format |
Pixel format of the video picture |
video_format |
Video format of the picture |
dynamic_range |
Dynamic range |
compress_mode |
Video compression mode |
color_gamut |
Color gamut range |
header_stride |
Stride of the compressed header |
stride |
Stride of the image data |
header_phys_addr |
Physical address of the compressed header |
header_virt_addr |
Virtual address of the compressed header (kernel mode virtual address) |
phys_addr |
Physical address of the image data |
virt_addr |
Virtual address of the image data (kernel mode virtual address) |
offset_top |
Top cropping width of the image |
offset_bottom |
Bottom cropping width of the image |
offset_left |
Left cropping width of the image |
offset_right |
Right cropping width of the image |
time_ref |
Frame sequence number |
pts |
Image timestamp |
priv_data |
Private data |
supplement |
Supplementary information about the image |
Notes:
Description:
k_video_supplement#
Description:
Defines the supplementary information for video frames.
Definition:
k_u64 jpeg_dcf_phy_addr;
k_u64 isp_info_phy_addr;
void jpeg_dcf_kvirt_addr; /*< jpeg_dcf, used in JPEG DCF */
} k_video_supplement;
Members:
Member Name |
jpeg_dcf_phy_addr |
Physical address of JPEG DCF information. |
isp_info_phy_addr |
Physical address of ISP auxiliary information. |
jpeg_dcf_kvirt_addr |
Virtual address of JPEG DCF information (kernel mode virtual address) |
isp_info_kvirt_addr |
Virtual address of ISP auxiliary information (kernel mode virtual address) |
Notes:
k_isp_frame_info#
Description:
Real-time information of the ISP. Definition:
k_u32 exposure_time; /*< exposure time (reciprocal of shutter speed), unit is us */
k_u32 isp_dgain;
k_u32 again;
k_u32 dgain;
k_u32 ratio[3];
k_u32 isp_nr_strength;
k_u32 sensor_mode;
k_u32 hmax_times; /*< sensor hmax_times, unit is ns */
k_u32 vmax; /*< sensor vmax, unit is line */
k_u32 vc_num; /*< when dumping WDR frame, which is long or short exposure frame. */
} k_isp_frame_info;
Members:
Member Name |
iso |
Current sensor analog gain * sensor digital gain * ISP digital gain * 100. |
exposure_time |
Exposure time, unit is microseconds (us). |
isp_dgain |
ISP digital gain. |
again |
Sensor analog gain. |
dgain |
Sensor digital gain. |
ratio |
Default exposure ratio of adjacent frames in multi-frame WDR synthesis. |
isp_nr_strength |
ISP NR strength. Currently not supported, default value is 0. |
f_number |
F-number of the current lens used. |
sensor_id |
Sensor ID currently in use. |
sensor_mode |
Sequence mode of the current sensor. |
hmax_times |
Time to read out one line from the current sensor, unit is nanoseconds (ns). |
vmax |
Number of lines per frame. |
vc_num |
Sequence number of the current frame. |
Notes:
Description:
k_jpeg_dcf#
Description:
DCF information used in JPEG images.
Definition:
k_u8 capture_time[DCF_CAPTURE_TIME_LENGTH]; /*< the date and time when the picture data was generated */
k_u32 flash; /*< whether the picture is captured when a flash lamp is on */
k_u32 digital_zoom_ratio; /*< indicates the digital zoom ratio when the image was shot. If the numerator of the recorded value is 0, this indicates that digital zoom was not used. */
k_isp_dcf_info isp_dcf_info;
} k_jpeg_dcf;
Members:
Member Name |
capture_time |
Time the JPEG image was captured. |
flash |
Whether a flash was used when capturing the JPEG image. |
digital_zoom_ratio |
Digital zoom ratio when capturing the JPEG image. |
isp_dcf_info |
Other DCF information. |
Notes:
k_isp_dcf_info#
Detailed information for this data type is not updated in the current version.
k_isp_dcf_update_info#
k_isp_dcf_const_info#
Description:ation for this data type is not updated in the current version.
k_compress_mode#
Description:
Defines the structure for video compression data format.
Definition:
COMPRESS_MODE_SEG, /* compress unit is 256x1 bytes as a segment. */
COMPRESS_MODE_TILE, /* compress unit is a tile. */
COMPRESS_MODE_FRAME, /* compress unit is the whole frame. YUV for VI, RGB for VO (read) */
COMPRESS_MODE_BUTT
} k_compress_mode;
Members:
Member Name |
COMPRESS_MODE_NONE |
Uncompressed video format. |
COMPRESS_MODE_SEG |
Segment compressed video format. |
COMPRESS_MODE_TILE |
Tile compressed video format, compressed by tile segments. |
COMPRESS_MODE_LINE |
Line compressed video format, compressed by lines. |
COMPRESS_MODE_FRAME |
Frame compressed video format, compressed by frames. |
Notes:
Description:
k_color_gamut#
Description:
Defines the color gamut range enumeration.
Definition:
COLOR_GAMUT_BT601 = 0,
COLOR_GAMUT_BT709,
COLOR_GAMUT_BT2020,
COLOR_GAMUT_USER,
COLOR_GAMUT_BUTT
} k_color_gamut;
Members:
Member Name |
COLOR_GAMUT_BT601 |
BT601 color gamut range. |
COLOR_GAMUT_BT709 |
BT709 color gamut range. |
COLOR_GAMUT_BT2020 |
BT2020 color gamut range. |
COLOR_GAMUT_USER |
User-defined color gamut, non-standard. |
Notes:
The coordinates of the blue, green, red, and white points for each color gamut range are as follows:
Color Gamut |
Primary |
Green |
Blue |
Red |
White |
BT601 |
(0.29, 0.60) |
(0.15, 0.06) |
(0.64, 0.33) |
(0.3127, 0.3290) |
BT709 |
(0.300, 0.600) |
(0.150, 0.060) |
(0.640, 0.330) |
(0.3127, 0.3290) |
BT2020 |
(0.170, 0.797) |
(0.131, 0.046) |
(0.708, 0.292) |
(0.3127, 0.3290) |
Description:
k_dynamic_range#
Description:
Defines the dynamic range enumeration.
Definition:
DYNAMIC_RANGE_SDR8 = 0,
DYNAMIC_RANGE_SDR10,
DYNAMIC_RANGE_HDR10,
DYNAMIC_RANGE_HLG,
DYNAMIC_RANGE_SLF,
DYNAMIC_RANGE_XDR,
DYNAMIC_RANGE_BUTT
} k_dynamic_range;
Members:
Member Name |
DYNAMIC_RANGE_SDR8 |
Standard dynamic range for 8-bit data. |
DYNAMIC_RANGE_SDR10 |
Standard dynamic range for 10-bit data. |
DYNAMIC_RANGE_HDR10 |
High dynamic range for 10-bit data. |
DYNAMIC_RANGE_HLG |
DYNAMIC_RANGE_SLF |
Invalid |
DYNAMIC_RANGE_XDR |
Invalid |
Notes:
The transfer characteristics for each dynamic range are as follows:
Dynamic Range |
Transfer Characteristic |
SDR8/ SDR10 |
V = α * Lc^0.45 - (α - 1) for 1 >= Lc >= β V = 4.500 * Lc for β > Lc >= 0 |
HDR10 |
V = ((c1 + c2 * Lc^n) ÷ (1 + c3 * Lc^n))^m for all values of Lc c1 = c3 - c2 + 1 = 3424 ÷ 4096 = 0.8359375 c2 = 32 * 2413 ÷ 4096 = 18.8515625 c3 = 32 * 2392 ÷ 4096 = 18.6875 m = 128 * 2523 ÷ 4096 = 78.84375 n = 0.25 * 2610 ÷ 4096 = 0.1593017578125 for which Lc equal to 1 for peak white is ordinarily intended to correspond to a reference output luminance level of 10000 candelas per square metre |
HLG |
V = a * Ln(12 * Lc - b) + c for 1 >= Lc > 1 ÷ 12 V = Sqrt(3) * Lc^0.5 for 1 ÷ 12 >= Lc >= 0 a = 0.17883277, b = 0.28466892, c = 0.55991073 |
Description:
k_video_format#
Description:
Defines the video format structure.
Definition:
VIDEO_FORMAT_LINEAR = 0, /* natural video line */
VIDEO_FORMAT_BUTT
} k_video_format;
Members:
Member Name |
VIDEO_FORMAT_LINEAR |
Linear storage video format. |
VIDEO_FORMAT_TILE_64x16 |
Tile format video storage, where the tile block size is 64 pixels wide and 16 lines high. |
VIDEO_FORMAT_TILE_16x8 |
Tile format video storage, where the tile block size is 16 pixels wide and 8 lines high, also known as small tile format. |
VIDEO_FORMAT_LINEAR_DISCRETE |
Linear discrete natural line storage data format, data bit width aligned in bytes, low bits valid, high bits invalid. |
Notes:
Description:
k_video_field#
Description:
Defines the video image frame field type.
Definition:
VIDEO_FIELD_BUTT
} k_video_field;
Members:
Member Name |
VIDEO_FIELD_TOP |
Top field type |
VIDEO_FIELD_BOTTOM |
Bottom field type |
VIDEO_FIELD_INTERLACED |
Interlaced field type |
VIDEO_FIELD_FRAME |
Frame type |
Notes:
k_pixel_format#
Description:
Defines the pixel format types.
Definition:
PIXEL_FORMAT_RGB_444 = 0,
PIXEL_FORMAT_RGB_555,
PIXEL_FORMAT_RGB_565,
PIXEL_FORMAT_RGB_888,
PIXEL_FORMAT_BGR_444,
PIXEL_FORMAT_BGR_555,
PIXEL_FORMAT_BGR_565,
PIXEL_FORMAT_BGR_888,
PIXEL_FORMAT_ARGB_1555,
PIXEL_FORMAT_ARGB_4444,
PIXEL_FORMAT_ARGB_8565,
PIXEL_FORMAT_ARGB_8888,
PIXEL_FORMAT_ARGB_2BPP,
PIXEL_FORMAT_ABGR_1555,
PIXEL_FORMAT_ABGR_4444,
PIXEL_FORMAT_ABGR_8565,
PIXEL_FORMAT_ABGR_8888,
PIXEL_FORMAT_RGB_BAYER_8BPP,
PIXEL_FORMAT_RGB_BAYER_10BPP,
PIXEL_FORMAT_RGB_BAYER_12BPP,
PIXEL_FORMAT_RGB_BAYER_14BPP,
PIXEL_FORMAT_RGB_BAYER_16BPP,
PIXEL_FORMAT_YVU_PLANAR_422,
PIXEL_FORMAT_YVU_PLANAR_420,
PIXEL_FORMAT_YVU_PLANAR_444,
PIXEL_FORMAT_YUV_400,
PIXEL_FORMAT_UV_420,
/* SVP data format */
PIXEL_FORMAT_BGR_888_PLANAR,
PIXEL_FORMAT_HSV_888_PACKAGE,
PIXEL_FORMAT_HSV_888_PLANAR,
PIXEL_FORMAT_LAB_888_PACKAGE,
PIXEL_FORMAT_LAB_888_PLANAR,
PIXEL_FORMAT_S8C1,
PIXEL_FORMAT_S8C2_PACKAGE,
PIXEL_FORMAT_S8C2_PLANAR,
PIXEL_FORMAT_S8C3_PLANAR,
PIXEL_FORMAT_S16C1,
PIXEL_FORMAT_U8C1,
PIXEL_FORMAT_U16C1,
PIXEL_FORMAT_S32C1,
PIXEL_FORMAT_U32C1,
PIXEL_FORMAT_U64C1,
PIXEL_FORMAT_S64C1,
PIXEL_FORMAT_BUTT
} k_pixel_format;
Members:
Notes:
Omitted
Multimedia Log Management#
This module has the following data structures:
Description:conf](#341-k_log_level_conf)
k_log_level_conf#
Description:
Defines the log level information structure. Definition:
k_mod_id mod_id;
k_s32 level;
k_char mod_name[16];
} k_log_level_conf;
Members:
Member Name |
mod_id |
ID of the module |
level |
Log level |
mod_name |
Name of the module |
Notes:
Error Codes#
Multimedia Memory Management Error Codes#
Video Buffer Pool Error Codes#
Table 41
Error Code |
Macro Definition |
0xa0048006 |
K_ERR_VB_NULL_PTR |
Null pointer error |
0xa004800c |
K_ERR_VB_NOMEM |
Memory allocation failure |
0xa004800d |
K_ERR_VB_NOBUF |
Buffer allocation failure |
0xa0048005 |
K_ERR_VB_UNEXIST |
Video buffer does not exist |
0xa0048003 |
K_ERR_VB_ILLEGAL_PARAM |
Invalid parameter setting |
0xa0048010 |
K_ERR_VB_NOTREADY |
Buffer pool not ready |
0xa0048012 |
K_ERR_VB_BUSY |
System busy |
0xa0048009 |
K_ERR_VB_NOT_PERM |
Operation not permitted |
0xa0048040 |
K_ERR_VB_2MPOOLS |
Too many buffer pools created |
Multimedia Memory Zone Error Codes#
Table 42
Error Code |
Macro Definition |
0xa0038003 |
K_ERR_MMZ_USERDEV_ILLEGAL_PARAM |
Minor parameter setting |
0xa0038006 |
K_ERR_MMZ_USERDEV_NULL_PTR |
0xa0038008 |
K_ERR_MMZ_USERDEV_NOT_SUPPORT |
Unsupported operation |
0xa0038009 |
K_ERR_MMZ_USERDEV_NOT_PERM |
0xa003800c |
K_ERR_MMZ_USERDEV_NOMEM |
0xa0038010 |
K_ERR_MMZ_USERDEV_NOTREADY |
System not ready |
0xa0038011 |
K_ERR_MMZ_USERDEV_BADADDR |
Invalid address |
0xa0038012 |
K_ERR_MMZ_USERDEV_BUSY |
System busy |
System Binding Error Codes#
Table 43
Error Code |
Macro Definition |
0xa0058003 |
K_ERR_SYS_ILLEGAL_PARAM |
Invalid parameter |
0xa0058006 |
K_ERR_SYS_NULL_PTR |
0xa0058008 |
K_ERR_SYS_NOT_SUPPORT |
Unsupported feature |
0xa0058009 |
K_ERR_SYS_NOT_PERM |
0xa0058010 |
K_ERR_SYS_NOTREADY |
System control attributes not configured |
0xa0058011 |
K_ERR_SYS_BADADDR |
System bad address |
0xa005800c |
K_ERR_SYS_NOMEM |
Memory allocation failure, e.g., insufficient system memory |
Log Management Error Codes#
Table 44
Error Code |
Macro Definition |
0xa0018003 |
K_ERR_LOG_ILLEGAL_PARAM |
Invalid parameter |
0xa0018006 |
K_ERR_LOG_NULL_PTR |
0xa0018009 |
K_ERR_LOG_NOT_PERM |
0xa0018010 |
K_ERR_LOG_NOTREADY |
Log device not ready |
0xa001800c |
K_ERR_LOG_NOMEM |
Debug Information#
The debug information uses the proc file system, reflecting the current system running status in real-time. The recorded information can be used for problem location and analysis.
File Directory:
/proc/
File List:
File Name |
umap/sysbind |
Records the current system binding status |
umap/vb |
Records the current buffer usage of the VB module |
mem-media |
Records the current multimedia memory usage |
Video Buffer Pool Debug Information#
Debug Information:
MaxPoolCnt
Config Size VbCnt
1 204 21
PoolConfId BlkSize Count RemapMode
0 8294400 5 CACHED
1 8192 3 NONE
2 4096 5 NOCACHE
0 4096 5 CACHED
1 8192 3 NONE
PoolId PhysAddr VirtAddr IsComm Owner BlkSz BlkCnt Free MinFree
0 0x18001000 0xc00d1000 1 -1 8294400 5 2 2
BLK VI VENC VDEC VO USER AI AREC AENC ADEC AO V_VI V_VO DMA DPU
0 0 0 0 0 1 0 0 0 0 0 0 0 0 0
1 0 0 0 0 1 0 0 0 0 0 0 0 0 0
2 0 0 0 0 1 0 0 0 0 0 0 0 0 0
Sum 0 0 0 0 3 0 0 0 0 0 0 0 0 0
1 0x1a78f000 0x0 1 -1 8192 3 3 3
2 0x1a796000 0xc2860000 1 -1 4096 5 5 5
3 0x1a79c000 0xc2866000 1 2 4096 5 5 5
4 0x1a7a2000 0x0 1 2 8192 3 3 3
Debug Information Analysis:
Records the current block usage of the VB module.
Parameter Description:
Parameter |
VB PUB CONFIG |
MaxPoolCnt |
Maximum number of buffer pools. |
VB SUPPLEMENT ATTR |
Config |
Configuration of supplementary information for video frames. |
Size |
Memory space occupied by supplementary information for video frames. |
VbCnt |
Total number of VB blocks in all VB pools (common, private). |
COMMON POOL CONFIG |
PoolId |
Handle of the common buffer pool. |
Size |
Size of blocks in the buffer pool. |
Count |
Number of blocks in the buffer pool. |
MODULE COMMON POOL CONFIG of VB_UID (Common VB allocated by module) |
PoolId |
Size |
Count |
NULL (empty table, i.e., anonymous DDR) |
PoolId |
Handle of the common/private buffer pool. |
PhysAddr |
Starting physical address of the common/private buffer pool. |
VirtAddr |
Starting virtual address of the common/private buffer pool. |
IsComm |
Whether it is a common buffer pool. Values: {0, 1}. |
Owner |
Owner of the buffer pool. -2: Private pool. -1: Common pool. ≥0: Module VB. |
BlkSz |
BlkCnt |
Free |
Number of free blocks in the buffer pool. |
MinFree |
Minimum number of free blocks remaining since the program started. If this count is 0, it may indicate frame drops due to insufficient blocks. |
BLK |
Handle of the blocks in the buffer pool. |
VI/VPROC/VREC/VENC/VDEC/VO/USER/AI/AREC/AENC/ADEC/AO/V_VI/V_VO/DMA/DPU |
Module name. The number below indicates how many places in the current module occupy the block in the buffer pool. 0: Not occupied. Non-0: Number of times occupied. |
Multimedia Memory Zone Debug Information#
Debug Information:
msh /bin>cat /proc/media-mem
+---ZONE: PHYS(0x18000000, 0x1FEFFFFF), GFP=0, nBYTES=130048KB, NAME="anonymous"
|-MMB: phys(0x18000000, 0x18000FFF), kvirt=0xC00D0000, flags=0x00000001, length=4KB, name="sup_nc"
|-MMB: phys(0x18001000, 0x1A78DFFF), kvirt=0xC00D1000, flags=0x00000003, length=40500KB, name="vb_pool"
|-MMB: phys(0x1A78E000, 0x1A78EFFF), kvirt=0xC285E000, flags=0x00000001, length=4KB, name="sup_nc"
|-MMB: phys(0x1A78F000, 0x1A794FFF), kvirt=0x00000000, flags=0x00000000, length=24KB, name="vb_pool"
|-MMB: phys(0x1A795000, 0x1A795FFF), kvirt=0xC285F000, flags=0x00000001, length=4KB, name="sup_nc"
|-MMB: phys(0x1A796000, 0x1A79AFFF), kvirt=0xC2860000, flags=0x00000001, length=20KB, name="vb_pool"
|-MMB: phys(0x1A79B000, 0x1A79BFFF), kvirt=0xC2865000, flags=0x00000001, length=4KB, name="sup_nc"
|-MMB: phys(0x1A79C000, 0x1A7A0FFF), kvirt=0xC2866000, flags=0x00000003, length=20KB, name="vb_mod_pool"
|-MMB: phys(0x1A7A1000, 0x1A7A1FFF), kvirt=0xC286B000, flags=0x00000001, length=4KB, name="sup_nc"
|-MMB: phys(0x1A7A2000, 0x1A7A7FFF), kvirt=0x00000000, flags=0x00000000, length=24KB, name="vb_mod_pool"
---MMZ_USE_INFO:
Records the current usage of multimedia memory.
System Binding#
System Binding Debug Information#
Debug Information:
msh /bin>cat /proc/umap/sysbind
FirMod FirDev FirChn SecMod SecDev SecChn ThrMod ThrDev ThrChn SendCnt rstCnt
vvi 0 0 vvo 0 0 null 0 0 42 0
vvi 0 0 vvo 1 1 null 0 0 42 0
Records the current system binding status.
Parameter |
FirMod |
Module number of the data source |
FirDev |
Device number of the data source |
FirChn |
Channel number of the data source |
SecMod |
Module number of the second module (bound to the data source) |
SecDev |
Device number of the second module (bound to the data source) |
SecChn |
Channel number of the second module (bound to the data source) |
ThrMod |
Module number of the third module (bound to the second module) |
ThrDev |
Device number of the third module (bound to the second module) |
ThrChn |
Channel number of the third module (bound to the second module) |
SendCnt |
Number of times data is sent |
RstCnt |
Number of resets |
